Issues with AMD RX 560 in Kubuntu 18.04
jah-on
Post by jah-on »
Hello,
Thanks to any one who responds! I have been trying to get my GPU to fold but keep running into issues. I installed the AMD drivers with OpenCL, and confirmed that it was successfully installed by testing it with a Blender render using only the GPU. I have put the F@Hcontrol logging output below. It can receive WUs, but then errors out with "No WUs available for this configuration".
Thanks again for any help!
Jah-On
*********************** Log Started 2020-04-01T14:46:03Z ***********************
******************************* Date: 2020-04-02 *******************************
04:12:25:WU01:FS01:0x22:*********************** Log Started 2020-04-02T04:12:25Z ***********************
04:12:25:WU01:FS01:0x22:*************************** Core22 Folding@home Core ***************************
04:12:25:WU01:FS01:0x22:       Type: 0x22
04:12:25:WU01:FS01:0x22:       Core: Core22
04:12:25:WU01:FS01:0x22:    Website: https://foldingathome.org/
04:12:25:WU01:FS01:0x22:  Copyright: (c) 2009-2018 foldingathome.org
04:12:25:WU01:FS01:0x22:     Author: John Chodera <john.chodera@choderalab.org> and Rafal Wiewiora
04:12:25:WU01:FS01:0x22:             <rafal.wiewiora@choderalab.org>
04:12:25:WU01:FS01:0x22:       Args: -dir 01 -suffix 01 -version 705 -lifeline 16353 -checkpoint 3
04:12:25:WU01:FS01:0x22:             -gpu-vendor amd -opencl-device 0 -gpu 0
04:12:25:WU01:FS01:0x22:     Config: <none>
04:12:25:WU01:FS01:0x22:************************************ Build *************************************
04:12:25:WU01:FS01:0x22:    Version: 0.0.2
04:12:25:WU01:FS01:0x22:       Date: Dec 6 2019
04:12:25:WU01:FS01:0x22:       Time: 21:20:17
04:12:25:WU01:FS01:0x22: Repository: Git
04:12:25:WU01:FS01:0x22:   Revision: f87d92b58abdf7e6bf2e173cfbc4dc3e837c7042
04:12:25:WU01:FS01:0x22:     Branch: core22
04:12:25:WU01:FS01:0x22:   Compiler: GNU 4.8.2 20140120 (Red Hat 4.8.2-15)
04:12:25:WU01:FS01:0x22:    Options: -std=gnu++98 -O3 -funroll-loops
04:12:25:WU01:FS01:0x22:   Platform: linux2 4.9.87-linuxkit-aufs
04:12:25:WU01:FS01:0x22:       Bits: 64
04:12:25:WU01:FS01:0x22:       Mode: Release
04:12:25:WU01:FS01:0x22:************************************ System ************************************
04:12:25:WU01:FS01:0x22:        CPU: Intel(R) Core(TM) i7-3770 CPU @ 3.40GHz
04:12:25:WU01:FS01:0x22:     CPU ID: GenuineIntel Family 6 Model 58 Stepping 9
04:12:25:WU01:FS01:0x22:       CPUs: 8
04:12:25:WU01:FS01:0x22:     Memory: 19.54GiB
04:12:25:WU01:FS01:0x22:Free Memory: 9.81GiB
04:12:25:WU01:FS01:0x22:    Threads: POSIX_THREADS
04:12:25:WU01:FS01:0x22: OS Version: 5.3
04:12:25:WU01:FS01:0x22:Has Battery: false
04:12:25:WU01:FS01:0x22: On Battery: false
04:12:25:WU01:FS01:0x22: UTC Offset: -5
04:12:25:WU01:FS01:0x22:        PID: 16357
04:12:25:WU01:FS01:0x22:        CWD: /var/lib/fahclient/work
04:12:25:WU01:FS01:0x22:         OS: Linux 5.3.0-45-generic x86_64
04:12:25:WU01:FS01:0x22:    OS Arch: AMD64
04:12:25:WU01:FS01:0x22:********************************************************************************
04:12:25:WU01:FS01:0x22:Project: 11776 (Run 0, Clone 1289, Gen 9)
04:12:25:WU01:FS01:0x22:Unit: 0x00000019287234c95e73c47fc3307a0c
04:12:25:WU01:FS01:0x22:Reading tar file core.xml
04:12:25:WU01:FS01:0x22:Reading tar file integrator.xml
04:12:25:WU01:FS01:0x22:Reading tar file state.xml
04:12:25:WU01:FS01:0x22:Reading tar file system.xml
04:12:26:WU01:FS01:0x22:Digital signatures verified
04:12:26:WU01:FS01:0x22:Folding@home GPU Core22 Folding@home Core
04:12:26:WU01:FS01:0x22:Version 0.0.2
04:12:35:WU01:FS01:0x22:ERROR:exception: Error initializing context: clGetDeviceIDs (-1)
04:12:35:WU01:FS01:0x22:Saving result file ../logfile_01.txt
04:12:35:WU01:FS01:0x22:Saving result file science.log
04:12:35:WU01:FS01:0x22:Folding@home Core Shutdown: BAD_WORK_UNIT
04:12:35:WARNING:WU01:FS01:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
04:12:35:WU01:FS01:Sending unit results: id:01 state:SEND error:FAULTY project:11776 run:0 clone:1289 gen:9 core:0x22 unit:0x00000019287234c95e73c47fc3307a0c
04:12:35:WU01:FS01:Uploading 7.50KiB to 40.114.52.201
04:12:35:WU01:FS01:Connecting to 40.114.52.201:8080
04:12:35:WU02:FS01:Connecting to 65.254.110.245:8080
04:12:35:WARNING:WU02:FS01:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
04:12:35:WU02:FS01:Connecting to 18.218.241.186:80
04:12:36:WU02:FS01:Assigned to work server 140.163.4.231
04:12:36:WU02:FS01:Requesting new work unit for slot 01: READY gpu:0:Baffin XT [Radeon RX 460] from 140.163.4.231
04:12:36:WU02:FS01:Connecting to 140.163.4.231:8080
04:12:54:WU01:FS01:Upload complete
04:12:54:WU01:FS01:Server responded WORK_ACK (400)
04:12:54:WU01:FS01:Cleaning up
04:13:05:WU02:FS01:Downloading 7.85MiB
04:13:15:WU02:FS01:Download 24.68%
04:13:21:WU02:FS01:Download 36.62%
04:13:28:WU02:FS01:Download 71.65%
04:13:34:WU02:FS01:Download 76.43%
04:13:41:WU02:FS01:Download 83.59%
04:13:44:WU02:FS01:Download complete
04:13:44:WU02:FS01:Received Unit: id:02 state:DOWNLOAD error:NO_ERROR project:11750 run:0 clone:801 gen:14 core:0x22 unit:0x000000218ca304e75e6a801dbf5efa41
04:13:44:WU02:FS01:Starting
04:13:44:WU02:FS01:Running FahCore: /usr/bin/FAHCoreWrapper /var/lib/fahclient/cores/cores.foldingathome.org/v7/lin/64bit/Core_22.fah/FahCore_22 -dir 02 -suffix 01 -version 705 -lifeline 1371 -checkpoint 3 -gpu-vendor amd -opencl-device 0 -gpu 0
04:13:44:WU02:FS01:Started FahCore on PID 16368
04:13:44:WU02:FS01:Core PID:16372
04:13:44:WU02:FS01:FahCore 0x22 started
04:13:45:WU02:FS01:0x22:*********************** Log Started 2020-04-02T04:13:44Z ***********************
04:13:45:WU02:FS01:0x22:*************************** Core22 Folding@home Core ***************************
04:13:45:WU02:FS01:0x22:       Type: 0x22
04:13:45:WU02:FS01:0x22:       Core: Core22
04:13:45:WU02:FS01:0x22:    Website: https://foldingathome.org/
04:13:45:WU02:FS01:0x22:  Copyright: (c) 2009-2018 foldingathome.org
04:13:45:WU02:FS01:0x22:     Author: John Chodera <john.chodera@choderalab.org> and Rafal Wiewiora
04:13:45:WU02:FS01:0x22:             <rafal.wiewiora@choderalab.org>
04:13:45:WU02:FS01:0x22:       Args: -dir 02 -suffix 01 -version 705 -lifeline 16368 -checkpoint 3
04:13:45:WU02:FS01:0x22:             -gpu-vendor amd -opencl-device 0 -gpu 0
04:13:45:WU02:FS01:0x22:     Config: <none>
04:13:45:WU02:FS01:0x22:************************************ Build *************************************
04:13:45:WU02:FS01:0x22:    Version: 0.0.2
04:13:45:WU02:FS01:0x22:       Date: Dec 6 2019
04:13:45:WU02:FS01:0x22:       Time: 21:20:17
04:13:45:WU02:FS01:0x22: Repository: Git
04:13:45:WU02:FS01:0x22:   Revision: f87d92b58abdf7e6bf2e173cfbc4dc3e837c7042
04:13:45:WU02:FS01:0x22:     Branch: core22
04:13:45:WU02:FS01:0x22:   Compiler: GNU 4.8.2 20140120 (Red Hat 4.8.2-15)
04:13:45:WU02:FS01:0x22:    Options: -std=gnu++98 -O3 -funroll-loops
04:13:45:WU02:FS01:0x22:   Platform: linux2 4.9.87-linuxkit-aufs
04:13:45:WU02:FS01:0x22:       Bits: 64
04:13:45:WU02:FS01:0x22:       Mode: Release
04:13:45:WU02:FS01:0x22:************************************ System ************************************
04:13:45:WU02:FS01:0x22:        CPU: Intel(R) Core(TM) i7-3770 CPU @ 3.40GHz
04:13:45:WU02:FS01:0x22:     CPU ID: GenuineIntel Family 6 Model 58 Stepping 9
04:13:45:WU02:FS01:0x22:       CPUs: 8
04:13:45:WU02:FS01:0x22:     Memory: 19.54GiB
04:13:45:WU02:FS01:0x22:Free Memory: 9.88GiB
04:13:45:WU02:FS01:0x22:    Threads: POSIX_THREADS
04:13:45:WU02:FS01:0x22: OS Version: 5.3
04:13:45:WU02:FS01:0x22:Has Battery: false
04:13:45:WU02:FS01:0x22: On Battery: false
04:13:45:WU02:FS01:0x22: UTC Offset: -5
04:13:45:WU02:FS01:0x22:        PID: 16372
04:13:45:WU02:FS01:0x22:        CWD: /var/lib/fahclient/work
04:13:45:WU02:FS01:0x22:         OS: Linux 5.3.0-45-generic x86_64
04:13:45:WU02:FS01:0x22:    OS Arch: AMD64
04:13:45:WU02:FS01:0x22:********************************************************************************
04:13:45:WU02:FS01:0x22:Project: 11750 (Run 0, Clone 801, Gen 14)
04:13:45:WU02:FS01:0x22:Unit: 0x000000218ca304e75e6a801dbf5efa41
04:13:45:WU02:FS01:0x22:Reading tar file core.xml
04:13:45:WU02:FS01:0x22:Reading tar file integrator.xml
04:13:45:WU02:FS01:0x22:Reading tar file state.xml
04:13:46:WU02:FS01:0x22:Reading tar file system.xml
04:13:46:WU02:FS01:0x22:Digital signatures verified
04:13:46:WU02:FS01:0x22:Folding@home GPU Core22 Folding@home Core
04:13:46:WU02:FS01:0x22:Version 0.0.2
04:13:52:WU02:FS01:0x22:ERROR:exception: Error initializing context: clGetDeviceIDs (-1)
04:13:52:WU02:FS01:0x22:Saving result file ../logfile_01.txt
04:13:52:WU02:FS01:0x22:Saving result file science.log
04:13:52:WU02:FS01:0x22:Folding@home Core Shutdown: BAD_WORK_UNIT
04:13:52:WARNING:WU02:FS01:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
04:13:52:WU02:FS01:Sending unit results: id:02 state:SEND error:FAULTY project:11750 run:0 clone:801 gen:14 core:0x22 unit:0x000000218ca304e75e6a801dbf5efa41
04:13:52:WU02:FS01:Uploading 2.51KiB to 140.163.4.231
04:13:52:WU02:FS01:Connecting to 140.163.4.231:8080
04:13:53:WU01:FS01:Connecting to 65.254.110.245:8080
04:13:53:WARNING:WU01:FS01:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
04:13:53:WU01:FS01:Connecting to 18.218.241.186:80
04:13:53:WU02:FS01:Upload complete
04:13:53:WU02:FS01:Server responded WORK_ACK (400)
04:13:53:WU02:FS01:Cleaning up
04:13:53:WARNING:WU01:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
04:13:53:ERROR:WU01:FS01:Exception: Could not get an assignment
04:13:54:WARNING:WU01:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
04:13:54:ERROR:WU01:FS01:Exception: Could not get an assignment
04:14:53:WU01:FS01:Connecting to 65.254.110.245:8080
04:14:53:WARNING:WU01:FS01:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
04:14:53:WU01:FS01:Connecting to 18.218.241.186:80
04:14:55:WU01:FS01:Assigned to work server 40.114.52.201
04:14:55:WU01:FS01:Requesting new work unit for slot 01: READY gpu:0:Baffin XT [Radeon RX 460] from 40.114.52.201
04:14:55:WU01:FS01:Connecting to 40.114.52.201:8080
04:17:05:WARNING:WU01:FS01:WorkServer connection failed on port 8080 trying 80
04:17:05:WU01:FS01:Connecting to 40.114.52.201:80
04:17:32:WU01:FS01:Downloading 29.59MiB
04:17:38:WU01:FS01:Download 10.14%
04:17:44:WU01:FS01:Download 31.90%
04:17:50:WU01:FS01:Download 59.78%
04:18:20:WU01:FS01:Download 67.81%
04:18:26:WU01:FS01:Download 92.31%
04:18:27:WU01:FS01:Download complete
04:18:27:WU01:FS01:Received Unit: id:01 state:DOWNLOAD error:NO_ERROR project:11778 run:0 clone:27082 gen:5 core:0x22 unit:0x0000000b287234c95e77487a8983960d
04:18:27:WU01:FS01:Starting
04:18:27:WU01:FS01:Running FahCore: /usr/bin/FAHCoreWrapper /var/lib/fahclient/cores/cores.foldingathome.org/v7/lin/64bit/Core_22.fah/FahCore_22 -dir 01 -suffix 01 -version 705 -lifeline 1371 -checkpoint 3 -gpu-vendor amd -opencl-device 0 -gpu 0
04:18:27:WU01:FS01:Started FahCore on PID 16388
04:18:27:WU01:FS01:Core PID:16392
04:18:27:WU01:FS01:FahCore 0x22 started
04:18:27:WU01:FS01:0x22:*********************** Log Started 2020-04-02T04:18:27Z ***********************
04:18:27:WU01:FS01:0x22:*************************** Core22 Folding@home Core ***************************
04:18:27:WU01:FS01:0x22:       Type: 0x22
04:18:27:WU01:FS01:0x22:       Core: Core22
04:18:27:WU01:FS01:0x22:    Website: https://foldingathome.org/
04:18:27:WU01:FS01:0x22:  Copyright: (c) 2009-2018 foldingathome.org
04:18:27:WU01:FS01:0x22:     Author: John Chodera <john.chodera@choderalab.org> and Rafal Wiewiora
04:18:27:WU01:FS01:0x22:             <rafal.wiewiora@choderalab.org>
04:18:27:WU01:FS01:0x22:       Args: -dir 01 -suffix 01 -version 705 -lifeline 16388 -checkpoint 3
04:18:27:WU01:FS01:0x22:             -gpu-vendor amd -opencl-device 0 -gpu 0
04:18:27:WU01:FS01:0x22:     Config: <none>
04:18:27:WU01:FS01:0x22:************************************ Build *************************************
04:18:27:WU01:FS01:0x22:    Version: 0.0.2
04:18:27:WU01:FS01:0x22:       Date: Dec 6 2019
04:18:27:WU01:FS01:0x22:       Time: 21:20:17
04:18:27:WU01:FS01:0x22: Repository: Git
04:18:27:WU01:FS01:0x22:   Revision: f87d92b58abdf7e6bf2e173cfbc4dc3e837c7042
04:18:27:WU01:FS01:0x22:     Branch: core22
04:18:27:WU01:FS01:0x22:   Compiler: GNU 4.8.2 20140120 (Red Hat 4.8.2-15)
04:18:27:WU01:FS01:0x22:    Options: -std=gnu++98 -O3 -funroll-loops
04:18:27:WU01:FS01:0x22:   Platform: linux2 4.9.87-linuxkit-aufs
04:18:27:WU01:FS01:0x22:       Bits: 64
04:18:27:WU01:FS01:0x22:       Mode: Release
04:18:27:WU01:FS01:0x22:************************************ System ************************************
04:18:27:WU01:FS01:0x22:        CPU: Intel(R) Core(TM) i7-3770 CPU @ 3.40GHz
04:18:27:WU01:FS01:0x22:     CPU ID: GenuineIntel Family 6 Model 58 Stepping 9
04:18:27:WU01:FS01:0x22:       CPUs: 8
04:18:27:WU01:FS01:0x22:     Memory: 19.54GiB
04:18:27:WU01:FS01:0x22:Free Memory: 9.85GiB
04:18:27:WU01:FS01:0x22:    Threads: POSIX_THREADS
04:18:27:WU01:FS01:0x22: OS Version: 5.3
04:18:27:WU01:FS01:0x22:Has Battery: false
04:18:27:WU01:FS01:0x22: On Battery: false
04:18:27:WU01:FS01:0x22: UTC Offset: -5
04:18:27:WU01:FS01:0x22:        PID: 16392
04:18:27:WU01:FS01:0x22:        CWD: /var/lib/fahclient/work
04:18:27:WU01:FS01:0x22:         OS: Linux 5.3.0-45-generic x86_64
04:18:27:WU01:FS01:0x22:    OS Arch: AMD64
04:18:27:WU01:FS01:0x22:********************************************************************************
04:18:27:WU01:FS01:0x22:Project: 11778 (Run 0, Clone 27082, Gen 5)
04:18:27:WU01:FS01:0x22:Unit: 0x0000000b287234c95e77487a8983960d
04:18:27:WU01:FS01:0x22:Reading tar file core.xml
04:18:27:WU01:FS01:0x22:Reading tar file integrator.xml
04:18:27:WU01:FS01:0x22:Reading tar file state.xml
04:18:27:WU01:FS01:0x22:Reading tar file system.xml
04:18:27:WU01:FS01:0x22:Digital signatures verified
04:18:27:WU01:FS01:0x22:Folding@home GPU Core22 Folding@home Core
04:18:27:WU01:FS01:0x22:Version 0.0.2
04:18:31:WU01:FS01:0x22:ERROR:exception: Error initializing context: clGetDeviceIDs (-1)
04:18:31:WU01:FS01:0x22:Saving result file ../logfile_01.txt
04:18:31:WU01:FS01:0x22:Saving result file science.log
04:18:31:WU01:FS01:0x22:Folding@home Core Shutdown: BAD_WORK_UNIT
04:18:31:WARNING:WU01:FS01:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
04:18:31:WU01:FS01:Sending unit results: id:01 state:SEND error:FAULTY project:11778 run:0 clone:27082 gen:5 core:0x22 unit:0x0000000b287234c95e77487a8983960d
04:18:31:WU01:FS01:Uploading 7.50KiB to 40.114.52.201
04:18:31:WU01:FS01:Connecting to 40.114.52.201:8080
04:18:31:WU02:FS01:Connecting to 65.254.110.245:8080
04:18:31:WARNING:WU02:FS01:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
04:18:31:WU02:FS01:Connecting to 18.218.241.186:80
04:18:31:WARNING:WU02:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
04:18:31:ERROR:WU02:FS01:Exception: Could not get an assignment
04:18:32:WU02:FS01:Connecting to 65.254.110.245:8080
04:18:32:WARNING:WU02:FS01:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
04:18:32:WU02:FS01:Connecting to 18.218.241.186:80
04:18:32:WARNING:WU02:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
04:18:32:ERROR:WU02:FS01:Exception: Could not get an assignment
04:18:44:WU01:FS01:Upload complete
04:18:44:WU01:FS01:Server responded WORK_ACK (400)
04:18:44:WU01:FS01:Cleaning up
04:19:32:WU02:FS01:Connecting to 65.254.110.245:8080
04:19:32:WARNING:WU02:FS01:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
04:19:32:WU02:FS01:Connecting to 18.218.241.186:80
04:19:32:WARNING:WU02:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
04:19:32:ERROR:WU02:FS01:Exception: Could not get an assignment
04:21:09:WU02:FS01:Connecting to 65.254.110.245:8080
04:21:09:WARNING:WU02:FS01:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
04:21:09:WU02:FS01:Connecting to 18.218.241.186:80
04:21:09:WARNING:WU02:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
04:21:09:ERROR:WU02:FS01:Exception: Could not get an assignment
04:23:46:WU02:FS01:Connecting to 65.254.110.245:8080
04:23:46:WARNING:WU02:FS01:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
04:23:46:WU02:FS01:Connecting to 18.218.241.186:80
04:23:46:WARNING:WU02:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
04:23:46:ERROR:WU02:FS01:Exception: Could not get an assignment
04:28:01:WU02:FS01:Connecting to 65.254.110.245:8080
04:28:01:WARNING:WU02:FS01:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
04:28:01:WU02:FS01:Connecting to 18.218.241.186:80
04:28:01:WARNING:WU02:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
04:28:01:ERROR:WU02:FS01:Exception: Could not get an assignment
04:34:52:WU02:FS01:Connecting to 65.254.110.245:8080
04:34:52:WARNING:WU02:FS01:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
04:34:52:WU02:FS01:Connecting to 18.218.241.186:80
04:34:52:WARNING:WU02:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
04:34:52:ERROR:WU02:FS01:Exception: Could not get an assignment
04:45:57:WU02:FS01:Connecting to 65.254.110.245:8080
04:45:58:WU02:FS01:Assigned to work server 40.114.52.201
04:45:58:WU02:FS01:Requesting new work unit for slot 01: READY gpu:0:Baffin XT [Radeon RX 460] from 40.114.52.201
04:45:58:WU02:FS01:Connecting to 40.114.52.201:8080
04:46:31:WU02:FS01:Downloading 29.59MiB
04:46:37:WU02:FS01:Download 14.57%
04:46:43:WU02:FS01:Download 37.81%
04:46:49:WU02:FS01:Download 52.59%
04:46:55:WU02:FS01:Download 68.86%
04:47:01:WU02:FS01:Download 89.14%
04:47:03:WU02:FS01:Download complete
04:47:03:WU02:FS01:Received Unit: id:02 state:DOWNLOAD error:NO_ERROR project:11778 run:0 clone:15355 gen:7 core:0x22 unit:0x00000011287234c95e774972a9fb8a9a
04:47:03:WU02:FS01:Starting
04:47:03:WU02:FS01:Running FahCore: /usr/bin/FAHCoreWrapper /var/lib/fahclient/cores/cores.foldingathome.org/v7/lin/64bit/Core_22.fah/FahCore_22 -dir 02 -suffix 01 -version 705 -lifeline 1371 -checkpoint 3 -gpu-vendor amd -opencl-device 0 -gpu 0
04:47:03:WU02:FS01:Started FahCore on PID 16461
04:47:03:WU02:FS01:Core PID:16465
04:47:03:WU02:FS01:FahCore 0x22 started
04:47:03:WU02:FS01:0x22:*********************** Log Started 2020-04-02T04:47:03Z ***********************
04:47:03:WU02:FS01:0x22:*************************** Core22 Folding@home Core ***************************
04:47:03:WU02:FS01:0x22:       Type: 0x22
04:47:03:WU02:FS01:0x22:       Core: Core22
04:47:03:WU02:FS01:0x22:    Website: https://foldingathome.org/
04:47:03:WU02:FS01:0x22:  Copyright: (c) 2009-2018 foldingathome.org
04:47:03:WU02:FS01:0x22:     Author: John Chodera <john.chodera@choderalab.org> and Rafal Wiewiora
04:47:03:WU02:FS01:0x22:             <rafal.wiewiora@choderalab.org>
04:47:03:WU02:FS01:0x22:       Args: -dir 02 -suffix 01 -version 705 -lifeline 16461 -checkpoint 3
04:47:03:WU02:FS01:0x22:             -gpu-vendor amd -opencl-device 0 -gpu 0
04:47:03:WU02:FS01:0x22:     Config: <none>
04:47:03:WU02:FS01:0x22:************************************ Build *************************************
04:47:03:WU02:FS01:0x22:    Version: 0.0.2
04:47:03:WU02:FS01:0x22:       Date: Dec 6 2019
04:47:03:WU02:FS01:0x22:       Time: 21:20:17
04:47:03:WU02:FS01:0x22: Repository: Git
04:47:03:WU02:FS01:0x22:   Revision: f87d92b58abdf7e6bf2e173cfbc4dc3e837c7042
04:47:03:WU02:FS01:0x22:     Branch: core22
04:47:03:WU02:FS01:0x22:   Compiler: GNU 4.8.2 20140120 (Red Hat 4.8.2-15)
04:47:03:WU02:FS01:0x22:    Options: -std=gnu++98 -O3 -funroll-loops
04:47:03:WU02:FS01:0x22:   Platform: linux2 4.9.87-linuxkit-aufs
04:47:03:WU02:FS01:0x22:       Bits: 64
04:47:03:WU02:FS01:0x22:       Mode: Release
04:47:03:WU02:FS01:0x22:************************************ System ************************************
04:47:03:WU02:FS01:0x22:        CPU: Intel(R) Core(TM) i7-3770 CPU @ 3.40GHz
04:47:03:WU02:FS01:0x22:     CPU ID: GenuineIntel Family 6 Model 58 Stepping 9
04:47:03:WU02:FS01:0x22:       CPUs: 8
04:47:03:WU02:FS01:0x22:     Memory: 19.54GiB
04:47:03:WU02:FS01:0x22:Free Memory: 9.70GiB
04:47:03:WU02:FS01:0x22:    Threads: POSIX_THREADS
04:47:03:WU02:FS01:0x22: OS Version: 5.3
04:47:03:WU02:FS01:0x22:Has Battery: false
04:47:03:WU02:FS01:0x22: On Battery: false
04:47:03:WU02:FS01:0x22: UTC Offset: -5
04:47:03:WU02:FS01:0x22:        PID: 16465
04:47:03:WU02:FS01:0x22:        CWD: /var/lib/fahclient/work
04:47:03:WU02:FS01:0x22:         OS: Linux 5.3.0-45-generic x86_64
04:47:03:WU02:FS01:0x22:    OS Arch: AMD64
04:47:03:WU02:FS01:0x22:********************************************************************************
04:47:03:WU02:FS01:0x22:Project: 11778 (Run 0, Clone 15355, Gen 7)
04:47:03:WU02:FS01:0x22:Unit: 0x00000011287234c95e774972a9fb8a9a
04:47:03:WU02:FS01:0x22:Reading tar file core.xml
04:47:03:WU02:FS01:0x22:Reading tar file integrator.xml
04:47:03:WU02:FS01:0x22:Reading tar file state.xml
04:47:03:WU02:FS01:0x22:Reading tar file system.xml
04:47:03:WU02:FS01:0x22:Digital signatures verified
04:47:03:WU02:FS01:0x22:Folding@home GPU Core22 Folding@home Core
04:47:03:WU02:FS01:0x22:Version 0.0.2
04:47:07:WU02:FS01:0x22:ERROR:exception: Error initializing context: clGetDeviceIDs (-1)
04:47:07:WU02:FS01:0x22:Saving result file ../logfile_01.txt
04:47:07:WU02:FS01:0x22:Saving result file science.log
04:47:07:WU02:FS01:0x22:Folding@home Core Shutdown: BAD_WORK_UNIT
04:47:07:WARNING:WU02:FS01:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
04:47:07:WU02:FS01:Sending unit results: id:02 state:SEND error:FAULTY project:11778 run:0 clone:15355 gen:7 core:0x22 unit:0x00000011287234c95e774972a9fb8a9a
04:47:07:WU02:FS01:Uploading 7.50KiB to 40.114.52.201
04:47:07:WU02:FS01:Connecting to 40.114.52.201:8080
04:47:07:WU01:FS01:Connecting to 65.254.110.245:8080
04:47:08:WU01:FS01:Assigned to work server 128.252.203.10
04:47:08:WU01:FS01:Requesting new work unit for slot 01: READY gpu:0:Baffin XT [Radeon RX 460] from 128.252.203.10
04:47:08:WU01:FS01:Connecting to 128.252.203.10:8080
04:47:23:WU02:FS01:Upload 100.00%
04:47:44:WU02:FS01:Upload complete
04:47:44:WU02:FS01:Server responded WORK_ACK (400)
04:47:44:WU02:FS01:Cleaning up
04:48:00:WU01:FS01:Downloading 29.59MiB
04:48:06:WU01:FS01:Download 56.61%
04:48:09:WU01:FS01:Download complete
04:48:09:WU01:FS01:Received Unit: id:01 state:DOWNLOAD error:NO_ERROR project:11761 run:0 clone:4231 gen:25 core:0x22 unit:0x0000002880fccb0a5e6d7d6344de8d5b
04:48:09:WU01:FS01:Starting
04:48:09:WU01:FS01:Running FahCore: /usr/bin/FAHCoreWrapper /var/lib/fahclient/cores/cores.foldingathome.org/v7/lin/64bit/Core_22.fah/FahCore_22 -dir 01 -suffix 01 -version 705 -lifeline 1371 -checkpoint 3 -gpu-vendor amd -opencl-device 0 -gpu 0
04:48:09:WU01:FS01:Started FahCore on PID 16476
04:48:09:WU01:FS01:Core PID:16480
04:48:09:WU01:FS01:FahCore 0x22 started
04:48:10:WU01:FS01:0x22:*********************** Log Started 2020-04-02T04:48:09Z ***********************
04:48:10:WU01:FS01:0x22:*************************** Core22 Folding@home Core ***************************
04:48:10:WU01:FS01:0x22:       Type: 0x22
04:48:10:WU01:FS01:0x22:       Core: Core22
04:48:10:WU01:FS01:0x22:    Website: https://foldingathome.org/
04:48:10:WU01:FS01:0x22:  Copyright: (c) 2009-2018 foldingathome.org
04:48:10:WU01:FS01:0x22:     Author: John Chodera <john.chodera@choderalab.org> and Rafal Wiewiora
04:48:10:WU01:FS01:0x22:             <rafal.wiewiora@choderalab.org>
04:48:10:WU01:FS01:0x22:       Args: -dir 01 -suffix 01 -version 705 -lifeline 16476 -checkpoint 3
04:48:10:WU01:FS01:0x22:             -gpu-vendor amd -opencl-device 0 -gpu 0
04:48:10:WU01:FS01:0x22:     Config: <none>
04:48:10:WU01:FS01:0x22:************************************ Build *************************************
04:48:10:WU01:FS01:0x22:    Version: 0.0.2
04:48:10:WU01:FS01:0x22:       Date: Dec 6 2019
04:48:10:WU01:FS01:0x22:       Time: 21:20:17
04:48:10:WU01:FS01:0x22: Repository: Git
04:48:10:WU01:FS01:0x22:   Revision: f87d92b58abdf7e6bf2e173cfbc4dc3e837c7042
04:48:10:WU01:FS01:0x22:     Branch: core22
04:48:10:WU01:FS01:0x22:   Compiler: GNU 4.8.2 20140120 (Red Hat 4.8.2-15)
04:48:10:WU01:FS01:0x22:    Options: -std=gnu++98 -O3 -funroll-loops
04:48:10:WU01:FS01:0x22:   Platform: linux2 4.9.87-linuxkit-aufs
04:48:10:WU01:FS01:0x22:       Bits: 64
04:48:10:WU01:FS01:0x22:       Mode: Release
04:48:10:WU01:FS01:0x22:************************************ System ************************************
04:48:10:WU01:FS01:0x22:        CPU: Intel(R) Core(TM) i7-3770 CPU @ 3.40GHz
04:48:10:WU01:FS01:0x22:     CPU ID: GenuineIntel Family 6 Model 58 Stepping 9
04:48:10:WU01:FS01:0x22:       CPUs: 8
04:48:10:WU01:FS01:0x22:     Memory: 19.54GiB
04:48:10:WU01:FS01:0x22:Free Memory: 9.70GiB
04:48:10:WU01:FS01:0x22:    Threads: POSIX_THREADS
04:48:10:WU01:FS01:0x22: OS Version: 5.3
04:48:10:WU01:FS01:0x22:Has Battery: false
04:48:10:WU01:FS01:0x22: On Battery: false
04:48:10:WU01:FS01:0x22: UTC Offset: -5
04:48:10:WU01:FS01:0x22:        PID: 16480
04:48:10:WU01:FS01:0x22:        CWD: /var/lib/fahclient/work
04:48:10:WU01:FS01:0x22:         OS: Linux 5.3.0-45-generic x86_64
04:48:10:WU01:FS01:0x22:    OS Arch: AMD64
04:48:10:WU01:FS01:0x22:********************************************************************************
04:48:10:WU01:FS01:0x22:Project: 11761 (Run 0, Clone 4231, Gen 25)
04:48:10:WU01:FS01:0x22:Unit: 0x0000002880fccb0a5e6d7d6344de8d5b
04:48:10:WU01:FS01:0x22:Reading tar file core.xml
04:48:10:WU01:FS01:0x22:Reading tar file integrator.xml
04:48:10:WU01:FS01:0x22:Reading tar file state.xml
04:48:10:WU01:FS01:0x22:Reading tar file system.xml
04:48:10:WU01:FS01:0x22:Digital signatures verified
04:48:10:WU01:FS01:0x22:Folding@home GPU Core22 Folding@home Core
04:48:10:WU01:FS01:0x22:Version 0.0.2
04:48:13:WU01:FS01:0x22:ERROR:exception: Error initializing context: clGetDeviceIDs (-1)
04:48:13:WU01:FS01:0x22:Saving result file ../logfile_01.txt
04:48:13:WU01:FS01:0x22:Saving result file science.log
04:48:13:WU01:FS01:0x22:Folding@home Core Shutdown: BAD_WORK_UNIT
04:48:13:WARNING:WU01:FS01:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
04:48:13:WU01:FS01:Sending unit results: id:01 state:SEND error:FAULTY project:11761 run:0 clone:4231 gen:25 core:0x22 unit:0x0000002880fccb0a5e6d7d6344de8d5b
04:48:13:WU01:FS01:Uploading 7.50KiB to 128.252.203.10
04:48:13:WU01:FS01:Connecting to 128.252.203.10:8080
04:48:13:WU02:FS01:Connecting to 65.254.110.245:8080
04:48:14:WARNING:WU02:FS01:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
04:48:14:WU02:FS01:Connecting to 18.218.241.186:80
04:48:14:WU02:FS01:Assigned to work server 13.90.152.57
04:48:14:WU02:FS01:Requesting new work unit for slot 01: READY gpu:0:Baffin XT [Radeon RX 460] from 13.90.152.57
04:48:14:WU02:FS01:Connecting to 13.90.152.57:8080
04:48:20:WU01:FS01:Upload 100.00%
04:49:13:WU02:FS01:Downloading 50.73MiB
04:49:19:WU02:FS01:Download 21.80%
04:49:25:WU02:FS01:Download 53.83%
04:49:31:WU02:FS01:Download 82.66%
04:49:36:WU02:FS01:Download complete
04:49:36:WU02:FS01:Received Unit: id:02 state:DOWNLOAD error:NO_ERROR project:11779 run:0 clone:3671 gen:26 core:0x22 unit:0x000000250d5a98395e73c5a99a64da70
04:49:36:WU02:FS01:Starting
04:49:36:WU02:FS01:Running FahCore: /usr/bin/FAHCoreWrapper /var/lib/fahclient/cores/cores.foldingathome.org/v7/lin/64bit/Core_22.fah/FahCore_22 -dir 02 -suffix 01 -version 705 -lifeline 1371 -checkpoint 3 -gpu-vendor amd -opencl-device 0 -gpu 0
04:49:36:WU02:FS01:Started FahCore on PID 16502
04:49:36:WU02:FS01:Core PID:16506
04:49:36:WU02:FS01:FahCore 0x22 started
04:49:36:WU02:FS01:0x22:*********************** Log Started 2020-04-02T04:49:36Z ***********************
04:49:36:WU02:FS01:0x22:*************************** Core22 Folding@home Core ***************************
04:49:36:WU02:FS01:0x22:       Type: 0x22
04:49:36:WU02:FS01:0x22:       Core: Core22
04:49:36:WU02:FS01:0x22:    Website: https://foldingathome.org/
04:49:36:WU02:FS01:0x22:  Copyright: (c) 2009-2018 foldingathome.org
04:49:36:WU02:FS01:0x22:     Author: John Chodera <john.chodera@choderalab.org> and Rafal Wiewiora
04:49:36:WU02:FS01:0x22:             <rafal.wiewiora@choderalab.org>
04:49:36:WU02:FS01:0x22:       Args: -dir 02 -suffix 01 -version 705 -lifeline 16502 -checkpoint 3
04:49:36:WU02:FS01:0x22:             -gpu-vendor amd -opencl-device 0 -gpu 0
04:49:36:WU02:FS01:0x22:     Config: <none>
04:49:36:WU02:FS01:0x22:************************************ Build *************************************
04:49:36:WU02:FS01:0x22:    Version: 0.0.2
04:49:36:WU02:FS01:0x22:       Date: Dec 6 2019
04:49:36:WU02:FS01:0x22:       Time: 21:20:17
04:49:36:WU02:FS01:0x22: Repository: Git
04:49:36:WU02:FS01:0x22:   Revision: f87d92b58abdf7e6bf2e173cfbc4dc3e837c7042
04:49:36:WU02:FS01:0x22:     Branch: core22
04:49:36:WU02:FS01:0x22:   Compiler: GNU 4.8.2 20140120 (Red Hat 4.8.2-15)
04:49:36:WU02:FS01:0x22:    Options: -std=gnu++98 -O3 -funroll-loops
04:49:36:WU02:FS01:0x22:   Platform: linux2 4.9.87-linuxkit-aufs
04:49:36:WU02:FS01:0x22:       Bits: 64
04:49:36:WU02:FS01:0x22:       Mode: Release
04:49:36:WU02:FS01:0x22:************************************ System ************************************
04:49:36:WU02:FS01:0x22:        CPU: Intel(R) Core(TM) i7-3770 CPU @ 3.40GHz
04:49:36:WU02:FS01:0x22:     CPU ID: GenuineIntel Family 6 Model 58 Stepping 9
04:49:36:WU02:FS01:0x22:       CPUs: 8
04:49:36:WU02:FS01:0x22:     Memory: 19.54GiB
04:49:36:WU02:FS01:0x22:Free Memory: 9.65GiB
04:49:36:WU02:FS01:0x22:    Threads: POSIX_THREADS
04:49:36:WU02:FS01:0x22: OS Version: 5.3
04:49:36:WU02:FS01:0x22:Has Battery: false
04:49:36:WU02:FS01:0x22: On Battery: false
04:49:36:WU02:FS01:0x22: UTC Offset: -5
04:49:36:WU02:FS01:0x22:        PID: 16506
04:49:36:WU02:FS01:0x22:        CWD: /var/lib/fahclient/work
04:49:36:WU02:FS01:0x22:         OS: Linux 5.3.0-45-generic x86_64
04:49:36:WU02:FS01:0x22:    OS Arch: AMD64
04:49:36:WU02:FS01:0x22:********************************************************************************
04:49:36:WU02:FS01:0x22:Project: 11779 (Run 0, Clone 3671, Gen 26)
04:49:36:WU02:FS01:0x22:Unit: 0x000000250d5a98395e73c5a99a64da70
04:49:36:WU02:FS01:0x22:Reading tar file core.xml
04:49:36:WU02:FS01:0x22:Reading tar file integrator.xml
04:49:36:WU02:FS01:0x22:Reading tar file state.xml
04:49:36:WU02:FS01:0x22:Reading tar file system.xml
04:49:36:WU02:FS01:0x22:Digital signatures verified
04:49:36:WU02:FS01:0x22:Folding@home GPU Core22 Folding@home Core
04:49:36:WU02:FS01:0x22:Version 0.0.2
04:49:42:WU02:FS01:0x22:ERROR:exception: Error initializing context: clGetDeviceIDs (-1)
04:49:42:WU02:FS01:0x22:Saving result file ../logfile_01.txt
04:49:42:WU02:FS01:0x22:Saving result file science.log
04:49:42:WU02:FS01:0x22:Folding@home Core Shutdown: BAD_WORK_UNIT
04:49:43:WARNING:WU02:FS01:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
04:49:43:WU02:FS01:Sending unit results: id:02 state:SEND error:FAULTY project:11779 run:0 clone:3671 gen:26 core:0x22 unit:0x000000250d5a98395e73c5a99a64da70
04:49:43:WU02:FS01:Uploading 7.50KiB to 13.90.152.57
04:49:43:WU02:FS01:Connecting to 13.90.152.57:8080
04:49:43:WU03:FS01:Connecting to 65.254.110.245:8080
04:49:43:WARNING:WU03:FS01:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
04:49:43:WU03:FS01:Connecting to 18.218.241.186:80
04:49:44:WARNING:WU03:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
04:49:44:ERROR:WU03:FS01:Exception: Could not get an assignment
04:49:44:WU03:FS01:Connecting to 65.254.110.245:8080
04:49:44:WU03:FS01:Assigned to work server 13.82.98.119
04:49:44:WU03:FS01:Requesting new work unit for slot 01: READY gpu:0:Baffin XT [Radeon RX 460] from 13.82.98.119
04:49:44:WU03:FS01:Connecting to 13.82.98.119:8080
04:49:45:ERROR:WU03:FS01:Exception: Server did not assign work unit
04:49:50:WU02:FS01:Upload 100.00%
04:50:14:WU02:FS01:Upload complete
04:50:14:WU02:FS01:Server responded WORK_ACK (400)
04:50:14:WU02:FS01:Cleaning up
04:50:28:WARNING:WU01:FS01:Exception: Failed to send results to work server: 10002: Received short response, expected 512 bytes, got 0
04:50:28:WU01:FS01:Trying to send results to collection server
04:50:28:WU01:FS01:Uploading 7.50KiB to 52.224.109.74
04:50:28:WU01:FS01:Connecting to 52.224.109.74:8080
04:50:29:WU01:FS01:Upload complete
04:50:29:WU01:FS01:Server responded WORK_ACK (400)
04:50:29:WU01:FS01:Cleaning up
04:50:45:WU03:FS01:Connecting to 65.254.110.245:8080
04:50:45:WU03:FS01:Assigned to work server 40.114.52.201
04:50:45:WU03:FS01:Requesting new work unit for slot 01: READY gpu:0:Baffin XT [Radeon RX 460] from 40.114.52.201
04:50:45:WU03:FS01:Connecting to 40.114.52.201:8080
04:51:11:WU03:FS01:Downloading 79.12MiB
04:51:17:WU03:FS01:Download 5.21%
04:51:24:WU03:FS01:Download 15.09%
04:51:30:WU03:FS01:Download 25.91%
04:51:36:WU03:FS01:Download 35.31%
04:51:42:WU03:FS01:Download 48.11%
04:51:50:WU03:FS01:Download 57.98%
04:51:56:WU03:FS01:Download 68.01%
04:52:02:WU03:FS01:Download 76.54%
04:52:08:WU03:FS01:Download 87.44%
04:52:14:WU03:FS01:Download 98.03%
04:52:19:WU03:FS01:Download complete
04:52:19:WU03:FS01:Received Unit: id:03 state:DOWNLOAD error:NO_ERROR project:11776 run:0 clone:5252 gen:18 core:0x22 unit:0x0000001f287234c95e7433a3d2bc9cc8
04:52:19:WU03:FS01:Starting
04:52:19:WU03:FS01:Running FahCore: /usr/bin/FAHCoreWrapper /var/lib/fahclient/cores/cores.foldingathome.org/v7/lin/64bit/Core_22.fah/FahCore_22 -dir 03 -suffix 01 -version 705 -lifeline 1371 -checkpoint 3 -gpu-vendor amd -opencl-device 0 -gpu 0
04:52:19:WU03:FS01:Started FahCore on PID 16518
04:52:19:WU03:FS01:Core PID:16522
04:52:19:WU03:FS01:FahCore 0x22 started
04:52:20:WU03:FS01:0x22:*********************** Log Started 2020-04-02T04:52:19Z ***********************
04:52:20:WU03:FS01:0x22:*************************** Core22 Folding@home Core ***************************
04:52:20:WU03:FS01:0x22:       Type: 0x22
04:52:20:WU03:FS01:0x22:       Core: Core22
04:52:20:WU03:FS01:0x22:    Website: https://foldingathome.org/
04:52:20:WU03:FS01:0x22:  Copyright: (c) 2009-2018 foldingathome.org
04:52:20:WU03:FS01:0x22:     Author: John Chodera <john.chodera@choderalab.org> and Rafal Wiewiora
04:52:20:WU03:FS01:0x22:             <rafal.wiewiora@choderalab.org>
04:52:20:WU03:FS01:0x22:       Args: -dir 03 -suffix 01 -version 705 -lifeline 16518 -checkpoint 3
04:52:20:WU03:FS01:0x22:             -gpu-vendor amd -opencl-device 0 -gpu 0
04:52:20:WU03:FS01:0x22:     Config: <none>
04:52:20:WU03:FS01:0x22:************************************ Build *************************************
04:52:20:WU03:FS01:0x22:    Version: 0.0.2
04:52:20:WU03:FS01:0x22:       Date: Dec 6 2019
04:52:20:WU03:FS01:0x22:       Time: 21:20:17
04:52:20:WU03:FS01:0x22: Repository: Git
04:52:20:WU03:FS01:0x22:   Revision: f87d92b58abdf7e6bf2e173cfbc4dc3e837c7042
04:52:20:WU03:FS01:0x22:     Branch: core22
04:52:20:WU03:FS01:0x22:   Compiler: GNU 4.8.2 20140120 (Red Hat 4.8.2-15)
04:52:20:WU03:FS01:0x22:    Options: -std=gnu++98 -O3 -funroll-loops
04:52:20:WU03:FS01:0x22:   Platform: linux2 4.9.87-linuxkit-aufs
04:52:20:WU03:FS01:0x22:       Bits: 64
04:52:20:WU03:FS01:0x22:       Mode: Release
04:52:20:WU03:FS01:0x22:************************************ System ************************************
04:52:20:WU03:FS01:0x22:        CPU: Intel(R) Core(TM) i7-3770 CPU @ 3.40GHz
04:52:20:WU03:FS01:0x22:     CPU ID: GenuineIntel Family 6 Model 58 Stepping 9
04:52:20:WU03:FS01:0x22:       CPUs: 8
04:52:20:WU03:FS01:0x22:     Memory: 19.54GiB
04:52:20:WU03:FS01:0x22:Free Memory: 9.65GiB
04:52:20:WU03:FS01:0x22:    Threads: POSIX_THREADS
04:52:20:WU03:FS01:0x22: OS Version: 5.3
04:52:20:WU03:FS01:0x22:Has Battery: false
04:52:20:WU03:FS01:0x22: On Battery: false
04:52:20:WU03:FS01:0x22: UTC Offset: -5
04:52:20:WU03:FS01:0x22:        PID: 16522
04:52:20:WU03:FS01:0x22:        CWD: /var/lib/fahclient/work
04:52:20:WU03:FS01:0x22:         OS: Linux 5.3.0-45-generic x86_64
04:52:20:WU03:FS01:0x22:    OS Arch: AMD64
04:52:20:WU03:FS01:0x22:********************************************************************************
04:52:20:WU03:FS01:0x22:Project: 11776 (Run 0, Clone 5252, Gen 18)
04:52:20:WU03:FS01:0x22:Unit: 0x0000001f287234c95e7433a3d2bc9cc8
04:52:20:WU03:FS01:0x22:Reading tar file core.xml
04:52:20:WU03:FS01:0x22:Reading tar file integrator.xml
04:52:20:WU03:FS01:0x22:Reading tar file state.xml
04:52:20:WU03:FS01:0x22:Reading tar file system.xml
04:52:20:WU03:FS01:0x22:Digital signatures verified
04:52:20:WU03:FS01:0x22:Folding@home GPU Core22 Folding@home Core
04:52:20:WU03:FS01:0x22:Version 0.0.2
04:52:26:WU03:FS01:0x22:ERROR:exception: Error initializing context: clGetDeviceIDs (-1)
04:52:26:WU03:FS01:0x22:Saving result file ../logfile_01.txt
04:52:26:WU03:FS01:0x22:Saving result file science.log
04:52:26:WU03:FS01:0x22:Folding@home Core Shutdown: BAD_WORK_UNIT
04:52:26:WARNING:WU03:FS01:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
04:52:26:WU03:FS01:Sending unit results: id:03 state:SEND error:FAULTY project:11776 run:0 clone:5252 gen:18 core:0x22 unit:0x0000001f287234c95e7433a3d2bc9cc8
04:52:26:WU03:FS01:Uploading 7.50KiB to 40.114.52.201
04:52:26:WU03:FS01:Connecting to 40.114.52.201:8080
04:52:27:WU01:FS01:Connecting to 65.254.110.245:8080
04:52:27:WARNING:WU01:FS01:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
04:52:27:WU01:FS01:Connecting to 18.218.241.186:80
04:52:27:WU01:FS01:Assigned to work server 128.252.203.10
04:52:27:WU01:FS01:Requesting new work unit for slot 01: READY gpu:0:Baffin XT [Radeon RX 460] from 128.252.203.10
04:52:27:WU01:FS01:Connecting to 128.252.203.10:8080
04:52:34:ERROR:WU01:FS01:Exception: 10002: Received short response, expected 512 bytes, got 0
04:52:34:WU01:FS01:Connecting to 65.254.110.245:8080
04:52:35:WU01:FS01:Assigned to work server 140.163.4.241
04:52:35:WU01:FS01:Requesting new work unit for slot 01: READY gpu:0:Baffin XT [Radeon RX 460] from 140.163.4.241
04:52:35:WU01:FS01:Connecting to 140.163.4.241:8080
04:52:58:WU03:FS01:Upload 100.00%
04:53:20:WU01:FS01:Downloading 11.98MiB
04:53:25:WU03:FS01:Upload complete
04:53:25:WU03:FS01:Server responded WORK_ACK (400)
04:53:25:WU03:FS01:Cleaning up
04:53:27:WU01:FS01:Download 66.25%
04:53:30:WU01:FS01:Download complete
04:53:30:WU01:FS01:Received Unit: id:01 state:DOWNLOAD error:NO_ERROR project:11741 run:0 clone:1821 gen:22 core:0x22 unit:0x0000002e8ca304f15e67d858b18d7fef
04:53:30:WU01:FS01:Starting
04:53:30:WU01:FS01:Running FahCore: /usr/bin/FAHCoreWrapper /var/lib/fahclient/cores/cores.foldingathome.org/v7/lin/64bit/Core_22.fah/FahCore_22 -dir 01 -suffix 01 -version 705 -lifeline 1371 -checkpoint 3 -gpu-vendor amd -opencl-device 0 -gpu 0
04:53:30:WU01:FS01:Started FahCore on PID 16543
04:53:30:WU01:FS01:Core PID:16547
04:53:30:WU01:FS01:FahCore 0x22 started
04:53:30:WU01:FS01:0x22:*********************** Log Started 2020-04-02T04:53:30Z ***********************
04:53:30:WU01:FS01:0x22:*************************** Core22 Folding@home Core ***************************
04:53:30:WU01:FS01:0x22:       Type: 0x22
04:53:30:WU01:FS01:0x22:       Core: Core22
04:53:30:WU01:FS01:0x22:    Website: https://foldingathome.org/
04:53:30:WU01:FS01:0x22:  Copyright: (c) 2009-2018 foldingathome.org
04:53:30:WU01:FS01:0x22:     Author: John Chodera <john.chodera@choderalab.org> and Rafal Wiewiora
04:53:30:WU01:FS01:0x22:             <rafal.wiewiora@choderalab.org>
04:53:30:WU01:FS01:0x22:       Args: -dir 01 -suffix 01 -version 705 -lifeline 16543 -checkpoint 3
04:53:30:WU01:FS01:0x22:             -gpu-vendor amd -opencl-device 0 -gpu 0
04:53:30:WU01:FS01:0x22:     Config: <none>
04:53:30:WU01:FS01:0x22:************************************ Build *************************************
04:53:30:WU01:FS01:0x22:    Version: 0.0.2
04:53:30:WU01:FS01:0x22:       Date: Dec 6 2019
04:53:30:WU01:FS01:0x22:       Time: 21:20:17
04:53:30:WU01:FS01:0x22: Repository: Git
04:53:30:WU01:FS01:0x22:   Revision: f87d92b58abdf7e6bf2e173cfbc4dc3e837c7042
04:53:30:WU01:FS01:0x22:     Branch: core22
04:53:30:WU01:FS01:0x22:   Compiler: GNU 4.8.2 20140120 (Red Hat 4.8.2-15)
04:53:30:WU01:FS01:0x22:    Options: -std=gnu++98 -O3 -funroll-loops
04:53:30:WU01:FS01:0x22:   Platform: linux2 4.9.87-linuxkit-aufs
04:53:30:WU01:FS01:0x22:       Bits: 64
04:53:30:WU01:FS01:0x22:       Mode: Release
04:53:30:WU01:FS01:0x22:************************************ System ************************************
04:53:30:WU01:FS01:0x22:        CPU: Intel(R) Core(TM) i7-3770 CPU @ 3.40GHz
04:53:30:WU01:FS01:0x22:     CPU ID: GenuineIntel Family 6 Model 58 Stepping 9
04:53:30:WU01:FS01:0x22:       CPUs: 8
04:53:30:WU01:FS01:0x22:     Memory: 19.54GiB
04:53:30:WU01:FS01:0x22:Free Memory: 9.72GiB
04:53:30:WU01:FS01:0x22:    Threads: POSIX_THREADS
04:53:30:WU01:FS01:0x22: OS Version: 5.3
04:53:30:WU01:FS01:0x22:Has Battery: false
04:53:30:WU01:FS01:0x22: On Battery: false
04:53:30:WU01:FS01:0x22: UTC Offset: -5
04:53:30:WU01:FS01:0x22:        PID: 16547
04:53:30:WU01:FS01:0x22:        CWD: /var/lib/fahclient/work
04:53:30:WU01:FS01:0x22:         OS: Linux 5.3.0-45-generic x86_64
04:53:30:WU01:FS01:0x22:    OS Arch: AMD64
04:53:30:WU01:FS01:0x22:********************************************************************************
04:53:30:WU01:FS01:0x22:Project: 11741 (Run 0, Clone 1821, Gen 22)
04:53:30:WU01:FS01:0x22:Unit: 0x0000002e8ca304f15e67d858b18d7fef
04:53:30:WU01:FS01:0x22:Reading tar file core.xml
04:53:30:WU01:FS01:0x22:Reading tar file integrator.xml
04:53:30:WU01:FS01:0x22:Reading tar file state.xml
04:53:33:WU01:FS01:0x22:Reading tar file system.xml
04:53:34:WU01:FS01:0x22:Digital signatures verified
04:53:34:WU01:FS01:0x22:Folding@home GPU Core22 Folding@home Core
04:53:34:WU01:FS01:0x22:Version 0.0.2
04:53:43:WU01:FS01:0x22:ERROR:exception: Error initializing context: clGetDeviceIDs (-1)
04:53:43:WU01:FS01:0x22:Saving result file ../logfile_01.txt
04:53:43:WU01:FS01:0x22:Saving result file science.log
04:53:43:WU01:FS01:0x22:Folding@home Core Shutdown: BAD_WORK_UNIT
04:53:43:WARNING:WU01:FS01:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
04:53:43:WU01:FS01:Sending unit results: id:01 state:SEND error:FAULTY project:11741 run:0 clone:1821 gen:22 core:0x22 unit:0x0000002e8ca304f15e67d858b18d7fef
04:53:43:WU01:FS01:Uploading 2.51KiB to 140.163.4.241
04:53:43:WU01:FS01:Connecting to 140.163.4.241:8080
04:53:48:WU01:FS01:Upload complete
04:53:48:WU01:FS01:Server responded WORK_ACK (400)
04:53:48:WU01:FS01:Cleaning up
15:38:18:FS01:Paused
15:38:21:FS01:Unpaused
15:38:21:WU00:FS01:Connecting to 65.254.110.245:8080
15:38:21:WU00:FS01:Assigned to work server 128.252.203.10
15:38:21:WU00:FS01:Requesting new work unit for slot 01: READY gpu:0:Baffin XT [Radeon RX 460] from 128.252.203.10
15:38:21:WU00:FS01:Connecting to 128.252.203.10:8080
15:40:33:WARNING:WU00:FS01:WorkServer connection failed on port 8080 trying 80
15:40:33:WU00:FS01:Connecting to 128.252.203.10:80
15:41:06:WU00:FS01:Downloading 51.19MiB
15:41:12:WU00:FS01:Download 20.39%
15:41:18:WU00:FS01:Download 49.32%
15:41:24:WU00:FS01:Download 74.23%
15:41:28:WU00:FS01:Download complete
15:41:28:WU00:FS01:Received Unit: id:00 state:DOWNLOAD error:NO_ERROR project:11763 run:0 clone:9279 gen:34 core:0x22 unit:0x0000002a80fccb0a5e711351da3a934e
15:41:28:WU00:FS01:Starting
15:41:28:WU00:FS01:Running FahCore: /usr/bin/FAHCoreWrapper /var/lib/fahclient/cores/cores.foldingathome.org/v7/lin/64bit/Core_22.fah/FahCore_22 -dir 00 -suffix 01 -version 705 -lifeline 1371 -checkpoint 3 -gpu-vendor amd -opencl-device 0 -gpu 0
15:41:28:WU00:FS01:Started FahCore on PID 21787
15:41:28:WU00:FS01:Core PID:21791
15:41:28:WU00:FS01:FahCore 0x22 started
15:41:29:WU00:FS01:0x22:*********************** Log Started 2020-04-02T15:41:28Z ***********************
15:41:29:WU00:FS01:0x22:*************************** Core22 Folding@home Core ***************************
15:41:29:WU00:FS01:0x22:       Type: 0x22
15:41:29:WU00:FS01:0x22:       Core: Core22
15:41:29:WU00:FS01:0x22:    Website: https://foldingathome.org/
15:41:29:WU00:FS01:0x22:  Copyright: (c) 2009-2018 foldingathome.org
15:41:29:WU00:FS01:0x22:     Author: John Chodera <john.chodera@choderalab.org> and Rafal Wiewiora
15:41:29:WU00:FS01:0x22:             <rafal.wiewiora@choderalab.org>
15:41:29:WU00:FS01:0x22:       Args: -dir 00 -suffix 01 -version 705 -lifeline 21787 -checkpoint 3
15:41:29:WU00:FS01:0x22:             -gpu-vendor amd -opencl-device 0 -gpu 0
15:41:29:WU00:FS01:0x22:     Config: <none>
15:41:29:WU00:FS01:0x22:************************************ Build *************************************
15:41:29:WU00:FS01:0x22:    Version: 0.0.2
15:41:29:WU00:FS01:0x22:       Date: Dec 6 2019
15:41:29:WU00:FS01:0x22:       Time: 21:20:17
15:41:29:WU00:FS01:0x22: Repository: Git
15:41:29:WU00:FS01:0x22:   Revision: f87d92b58abdf7e6bf2e173cfbc4dc3e837c7042
15:41:29:WU00:FS01:0x22:     Branch: core22
15:41:29:WU00:FS01:0x22:   Compiler: GNU 4.8.2 20140120 (Red Hat 4.8.2-15)
15:41:29:WU00:FS01:0x22:    Options: -std=gnu++98 -O3 -funroll-loops
15:41:29:WU00:FS01:0x22:   Platform: linux2 4.9.87-linuxkit-aufs
15:41:29:WU00:FS01:0x22:       Bits: 64
15:41:29:WU00:FS01:0x22:       Mode: Release
15:41:29:WU00:FS01:0x22:************************************ System ************************************
15:41:29:WU00:FS01:0x22:        CPU: Intel(R) Core(TM) i7-3770 CPU @ 3.40GHz
15:41:29:WU00:FS01:0x22:     CPU ID: GenuineIntel Family 6 Model 58 Stepping 9
15:41:29:WU00:FS01:0x22:       CPUs: 8
15:41:29:WU00:FS01:0x22:     Memory: 19.54GiB
15:41:29:WU00:FS01:0x22:Free Memory: 8.17GiB
15:41:29:WU00:FS01:0x22:    Threads: POSIX_THREADS
15:41:29:WU00:FS01:0x22: OS Version: 5.3
15:41:29:WU00:FS01:0x22:Has Battery: false
15:41:29:WU00:FS01:0x22: On Battery: false
15:41:29:WU00:FS01:0x22: UTC Offset: -5
15:41:29:WU00:FS01:0x22:        PID: 21791
15:41:29:WU00:FS01:0x22:        CWD: /var/lib/fahclient/work
15:41:29:WU00:FS01:0x22:         OS: Linux 5.3.0-45-generic x86_64
15:41:29:WU00:FS01:0x22:    OS Arch: AMD64
15:41:29:WU00:FS01:0x22:********************************************************************************
15:41:29:WU00:FS01:0x22:Project: 11763 (Run 0, Clone 9279, Gen 34)
15:41:29:WU00:FS01:0x22:Unit: 0x0000002a80fccb0a5e711351da3a934e
15:41:29:WU00:FS01:0x22:Reading tar file core.xml
15:41:29:WU00:FS01:0x22:Reading tar file integrator.xml
15:41:29:WU00:FS01:0x22:Reading tar file state.xml
15:41:29:WU00:FS01:0x22:Reading tar file system.xml
15:41:29:WU00:FS01:0x22:Digital signatures verified
15:41:29:WU00:FS01:0x22:Folding@home GPU Core22 Folding@home Core
15:41:29:WU00:FS01:0x22:Version 0.0.2
15:41:35:WU00:FS01:0x22:ERROR:exception: Error initializing context: clGetDeviceIDs (-1)
15:41:35:WU00:FS01:0x22:Saving result file ../logfile_01.txt
15:41:35:WU00:FS01:0x22:Saving result file science.log
15:41:35:WU00:FS01:0x22:Folding@home Core Shutdown: BAD_WORK_UNIT
15:41:35:WARNING:WU00:FS01:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
15:41:35:WU00:FS01:Sending unit results: id:00 state:SEND error:FAULTY project:11763 run:0 clone:9279 gen:34 core:0x22 unit:0x0000002a80fccb0a5e711351da3a934e
15:41:35:WU00:FS01:Uploading 7.50KiB to 128.252.203.10
15:41:35:WU00:FS01:Connecting to 128.252.203.10:8080
15:41:36:WU00:FS01:Upload complete
15:41:36:WU00:FS01:Server responded WORK_ACK (400)
15:41:36:WU00:FS01:Cleaning up
15:41:36:WU02:FS01:Connecting to 65.254.110.245:8080
15:41:36:WARNING:WU02:FS01:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
15:41:36:WU02:FS01:Connecting to 18.218.241.186:80
15:41:36:WARNING:WU02:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
15:41:36:ERROR:WU02:FS01:Exception: Could not get an assignment
15:41:37:WARNING:WU02:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
15:41:37:ERROR:WU02:FS01:Exception: Could not get an assignment
15:42:36:WU02:FS01:Connecting to 65.254.110.245:8080
15:42:37:WARNING:WU02:FS01:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
15:42:37:WU02:FS01:Connecting to 18.218.241.186:80
15:42:37:WU02:FS01:Assigned to work server 128.252.203.10
15:42:37:WU02:FS01:Requesting new work unit for slot 01: READY gpu:0:Baffin XT [Radeon RX 460] from 128.252.203.10
15:42:37:WU02:FS01:Connecting to 128.252.203.10:8080
15:43:52:WU02:FS01:Downloading 50.74MiB
15:43:58:WU02:FS01:Download 16.63%
15:44:04:WU02:FS01:Download 36.83%
15:44:10:WU02:FS01:Download 78.10%
15:44:12:WU02:FS01:Download complete
15:44:12:WU02:FS01:Received Unit: id:02 state:DOWNLOAD error:NO_ERROR project:11762 run:0 clone:7867 gen:18 core:0x22 unit:0x0000001e80fccb0a5e7113d1a32346d6
15:44:12:WU02:FS01:Starting
15:44:12:WU02:FS01:Running FahCore: /usr/bin/FAHCoreWrapper /var/lib/fahclient/cores/cores.foldingathome.org/v7/lin/64bit/Core_22.fah/FahCore_22 -dir 02 -suffix 01 -version 705 -lifeline 1371 -checkpoint 3 -gpu-vendor amd -opencl-device 0 -gpu 0
15:44:12:WU02:FS01:Started FahCore on PID 21848
15:44:12:WU02:FS01:Core PID:21852
15:44:12:WU02:FS01:FahCore 0x22 started
15:44:13:WU02:FS01:0x22:*********************** Log Started 2020-04-02T15:44:12Z ***********************
15:44:13:WU02:FS01:0x22:*************************** Core22 Folding@home Core ***************************
15:44:13:WU02:FS01:0x22:       Type: 0x22
15:44:13:WU02:FS01:0x22:       Core: Core22
15:44:13:WU02:FS01:0x22:    Website: https://foldingathome.org/
15:44:13:WU02:FS01:0x22:  Copyright: (c) 2009-2018 foldingathome.org
15:44:13:WU02:FS01:0x22:     Author: John Chodera <john.chodera@choderalab.org> and Rafal Wiewiora
15:44:13:WU02:FS01:0x22:             <rafal.wiewiora@choderalab.org>
15:44:13:WU02:FS01:0x22:       Args: -dir 02 -suffix 01 -version 705 -lifeline 21848 -checkpoint 3
15:44:13:WU02:FS01:0x22:             -gpu-vendor amd -opencl-device 0 -gpu 0
15:44:13:WU02:FS01:0x22:     Config: <none>
15:44:13:WU02:FS01:0x22:************************************ Build *************************************
15:44:13:WU02:FS01:0x22:    Version: 0.0.2
15:44:13:WU02:FS01:0x22:       Date: Dec 6 2019
15:44:13:WU02:FS01:0x22:       Time: 21:20:17
15:44:13:WU02:FS01:0x22: Repository: Git
15:44:13:WU02:FS01:0x22:   Revision: f87d92b58abdf7e6bf2e173cfbc4dc3e837c7042
15:44:13:WU02:FS01:0x22:     Branch: core22
15:44:13:WU02:FS01:0x22:   Compiler: GNU 4.8.2 20140120 (Red Hat 4.8.2-15)
15:44:13:WU02:FS01:0x22:    Options: -std=gnu++98 -O3 -funroll-loops
15:44:13:WU02:FS01:0x22:   Platform: linux2 4.9.87-linuxkit-aufs
15:44:13:WU02:FS01:0x22:       Bits: 64
15:44:13:WU02:FS01:0x22:       Mode: Release
15:44:13:WU02:FS01:0x22:************************************ System ************************************
15:44:13:WU02:FS01:0x22:        CPU: Intel(R) Core(TM) i7-3770 CPU @ 3.40GHz
15:44:13:WU02:FS01:0x22:     CPU ID: GenuineIntel Family 6 Model 58 Stepping 9
15:44:13:WU02:FS01:0x22:       CPUs: 8
15:44:13:WU02:FS01:0x22:     Memory: 19.54GiB
15:44:13:WU02:FS01:0x22:Free Memory: 7.90GiB
15:44:13:WU02:FS01:0x22:    Threads: POSIX_THREADS
15:44:13:WU02:FS01:0x22: OS Version: 5.3
15:44:13:WU02:FS01:0x22:Has Battery: false
15:44:13:WU02:FS01:0x22: On Battery: false
15:44:13:WU02:FS01:0x22: UTC Offset: -5
15:44:13:WU02:FS01:0x22:        PID: 21852
15:44:13:WU02:FS01:0x22:        CWD: /var/lib/fahclient/work
15:44:13:WU02:FS01:0x22:         OS: Linux 5.3.0-45-generic x86_64
15:44:13:WU02:FS01:0x22:    OS Arch: AMD64
15:44:13:WU02:FS01:0x22:********************************************************************************
15:44:13:WU02:FS01:0x22:Project: 11762 (Run 0, Clone 7867, Gen 18)
15:44:13:WU02:FS01:0x22:Unit: 0x0000001e80fccb0a5e7113d1a32346d6
15:44:13:WU02:FS01:0x22:Reading tar file core.xml
15:44:13:WU02:FS01:0x22:Reading tar file integrator.xml
15:44:13:WU02:FS01:0x22:Reading tar file state.xml
15:44:13:WU02:FS01:0x22:Reading tar file system.xml
15:44:13:WU02:FS01:0x22:Digital signatures verified
15:44:13:WU02:FS01:0x22:Folding@home GPU Core22 Folding@home Core
15:44:13:WU02:FS01:0x22:Version 0.0.2
15:44:19:WU02:FS01:0x22:ERROR:exception: Error initializing context: clGetDeviceIDs (-1)
15:44:19:WU02:FS01:0x22:Saving result file ../logfile_01.txt
15:44:19:WU02:FS01:0x22:Saving result file science.log
15:44:19:WU02:FS01:0x22:Folding@home Core Shutdown: BAD_WORK_UNIT
15:44:20:WARNING:WU02:FS01:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
15:44:20:WU02:FS01:Sending unit results: id:02 state:SEND error:FAULTY project:11762 run:0 clone:7867 gen:18 core:0x22 unit:0x0000001e80fccb0a5e7113d1a32346d6
15:44:20:WU02:FS01:Uploading 7.50KiB to 128.252.203.10
15:44:20:WU02:FS01:Connecting to 128.252.203.10:8080
15:44:20:WU00:FS01:Connecting to 65.254.110.245:8080
15:44:20:WU00:FS01:Assigned to work server 40.114.52.201
15:44:20:WU00:FS01:Requesting new work unit for slot 01: READY gpu:0:Baffin XT [Radeon RX 460] from 40.114.52.201
15:44:20:WU00:FS01:Connecting to 40.114.52.201:8080
15:44:41:WU00:FS01:Downloading 29.70MiB
15:44:47:WU00:FS01:Download 31.36%
15:44:54:WU00:FS01:Download 40.20%
15:45:01:WU00:FS01:Download 57.88%
15:45:07:WU00:FS01:Download 85.24%
15:45:13:WU00:FS01:Download 99.13%
15:45:13:WU00:FS01:Download complete
15:45:13:WU00:FS01:Received Unit: id:00 state:DOWNLOAD error:NO_ERROR project:11777 run:0 clone:9119 gen:16 core:0x22 unit:0x00000019287234c95e7432d99af885cb
15:45:13:WU00:FS01:Starting
15:45:13:WU00:FS01:Running FahCore: /usr/bin/FAHCoreWrapper /var/lib/fahclient/cores/cores.foldingathome.org/v7/lin/64bit/Core_22.fah/FahCore_22 -dir 00 -suffix 01 -version 705 -lifeline 1371 -checkpoint 3 -gpu-vendor amd -opencl-device 0 -gpu 0
15:45:13:WU00:FS01:Started FahCore on PID 21878
15:45:13:WU00:FS01:Core PID:21882
15:45:13:WU00:FS01:FahCore 0x22 started
15:45:14:WU00:FS01:0x22:*********************** Log Started 2020-04-02T15:45:13Z ***********************
15:45:14:WU00:FS01:0x22:*************************** Core22 Folding@home Core ***************************
15:45:14:WU00:FS01:0x22:       Type: 0x22
15:45:14:WU00:FS01:0x22:       Core: Core22
15:45:14:WU00:FS01:0x22:    Website: https://foldingathome.org/
15:45:14:WU00:FS01:0x22:  Copyright: (c) 2009-2018 foldingathome.org
15:45:14:WU00:FS01:0x22:     Author: John Chodera <john.chodera@choderalab.org> and Rafal Wiewiora
15:45:14:WU00:FS01:0x22:             <rafal.wiewiora@choderalab.org>
15:45:14:WU00:FS01:0x22:       Args: -dir 00 -suffix 01 -version 705 -lifeline 21878 -checkpoint 3
15:45:14:WU00:FS01:0x22:             -gpu-vendor amd -opencl-device 0 -gpu 0
15:45:14:WU00:FS01:0x22:     Config: <none>
15:45:14:WU00:FS01:0x22:************************************ Build *************************************
15:45:14:WU00:FS01:0x22:    Version: 0.0.2
15:45:14:WU00:FS01:0x22:       Date: Dec 6 2019
15:45:14:WU00:FS01:0x22:       Time: 21:20:17
15:45:14:WU00:FS01:0x22: Repository: Git
15:45:14:WU00:FS01:0x22:   Revision: f87d92b58abdf7e6bf2e173cfbc4dc3e837c7042
15:45:14:WU00:FS01:0x22:     Branch: core22
15:45:14:WU00:FS01:0x22:   Compiler: GNU 4.8.2 20140120 (Red Hat 4.8.2-15)
15:45:14:WU00:FS01:0x22:    Options: -std=gnu++98 -O3 -funroll-loops
15:45:14:WU00:FS01:0x22:   Platform: linux2 4.9.87-linuxkit-aufs
15:45:14:WU00:FS01:0x22:       Bits: 64
15:45:14:WU00:FS01:0x22:       Mode: Release
15:45:14:WU00:FS01:0x22:************************************ System ************************************
15:45:14:WU00:FS01:0x22:        CPU: Intel(R) Core(TM) i7-3770 CPU @ 3.40GHz
15:45:14:WU00:FS01:0x22:     CPU ID: GenuineIntel Family 6 Model 58 Stepping 9
15:45:14:WU00:FS01:0x22:       CPUs: 8
15:45:14:WU00:FS01:0x22:     Memory: 19.54GiB
15:45:14:WU00:FS01:0x22:Free Memory: 7.90GiB
15:45:14:WU00:FS01:0x22:    Threads: POSIX_THREADS
15:45:14:WU00:FS01:0x22: OS Version: 5.3
15:45:14:WU00:FS01:0x22:Has Battery: false
15:45:14:WU00:FS01:0x22: On Battery: false
15:45:14:WU00:FS01:0x22: UTC Offset: -5
15:45:14:WU00:FS01:0x22:        PID: 21882
15:45:14:WU00:FS01:0x22:        CWD: /var/lib/fahclient/work
15:45:14:WU00:FS01:0x22:         OS: Linux 5.3.0-45-generic x86_64
15:45:14:WU00:FS01:0x22:    OS Arch: AMD64
15:45:14:WU00:FS01:0x22:********************************************************************************
15:45:14:WU00:FS01:0x22:Project: 11777 (Run 0, Clone 9119, Gen 16)
15:45:14:WU00:FS01:0x22:Unit: 0x00000019287234c95e7432d99af885cb
15:45:14:WU00:FS01:0x22:Reading tar file core.xml
15:45:14:WU00:FS01:0x22:Reading tar file integrator.xml
15:45:14:WU00:FS01:0x22:Reading tar file state.xml
15:45:14:WU00:FS01:0x22:Reading tar file system.xml
15:45:14:WU00:FS01:0x22:Digital signatures verified
15:45:14:WU00:FS01:0x22:Folding@home GPU Core22 Folding@home Core
15:45:14:WU00:FS01:0x22:Version 0.0.2
15:45:15:WU02:FS01:Upload complete
15:45:15:WU02:FS01:Server responded WORK_ACK (400)
15:45:15:WU02:FS01:Cleaning up
15:45:17:WU00:FS01:0x22:ERROR:exception: Error initializing context: clGetDeviceIDs (-1)
15:45:17:WU00:FS01:0x22:Saving result file ../logfile_01.txt
15:45:17:WU00:FS01:0x22:Saving result file science.log
15:45:17:WU00:FS01:0x22:Folding@home Core Shutdown: BAD_WORK_UNIT
15:45:17:WARNING:WU00:FS01:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
15:45:17:WU00:FS01:Sending unit results: id:00 state:SEND error:FAULTY project:11777 run:0 clone:9119 gen:16 core:0x22 unit:0x00000019287234c95e7432d99af885cb
15:45:17:WU00:FS01:Uploading 7.50KiB to 40.114.52.201
15:45:17:WU00:FS01:Connecting to 40.114.52.201:8080
15:45:18:WU02:FS01:Connecting to 65.254.110.245:8080
15:45:18:WARNING:WU02:FS01:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
15:45:18:WU02:FS01:Connecting to 18.218.241.186:80
15:45:18:WARNING:WU02:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
15:45:18:ERROR:WU02:FS01:Exception: Could not get an assignment
15:45:19:WARNING:WU02:FS01:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
15:45:19:WU02:FS01:Connecting to 18.218.241.186:80
15:45:19:WARNING:WU02:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
15:45:19:ERROR:WU02:FS01:Exception: Could not get an assignment
15:45:33:FS01:Paused
Mod Edit: Moved Thread To Correct Forum - PantherX
jah-on
Re: Issues with AMD RX 560 in Kubuntu 18.04
Post by jah-on »
Sorry, I put this in a bad field.
We will need the log showing the client startup ... something doesn't seem correctly installed.
jah-on
Post by jah-on »
OK, here is a link to it since it exceeds the max character limit. It seems to not detect OpenCL for some reason.
https://drive.google.com/file/d/1FrqdyL ... sp=sharing
Thanks!
ipkh
Post by ipkh »
In that case, which drivers are installed? You might need the AMD proprietary driver.
jah-on
Post by jah-on »
ipkh wrote:In that case, which drivers are installed? You might need the AMD proprietary driver.
Yup, that's what I have installed. I tried installing these dependencies http://hansekbrand.se/code/OpenCLAgain.html as well.
At the present time, the AMD drivers for your GPU have a serious bug that causes them to crash on the COVID projects. We have no estimate when they'll be able to fix this bug. Only the Navi GPUs work with the current drivers.
Bottom line: You'll have to work on other projects until the new drivers are available.
jah-on
Post by jah-on »
bruce wrote:At the present time, the AMD drivers for your GPU have a serious bug that causes them to crash on the COVID projects. We have no estimate when they'll be able to fix this bug. Only the Navi GPUs work with the current drivers.
OK, thank you so much for letting me know!
kwthom
Post by kwthom »
Don't know if this info about AMD GPU's and COVID projects having issues has been posted, but similar issue here with a totally different configuration, OS, and everything else.
Just an AMD GPU.
Is there a recommended course of action from the users side?
Welcome to the F@H Forum kwthom,
Can you please post your F@H log and include the section at the top which has your system configuration :)
kwthom
Post by kwthom »
EDIT: Y'know, I probably should post this in a new thread...
