Could not get assignment id
bronozoj
Post by bronozoj »
Is this a problem with my network configuration on my server or is this an error with f@h servers right now?
*********************** Log Started 2020-04-02T12:33:59Z ***********************
12:33:59:************************* Folding@home Client *************************
12:33:59:    Website: https://foldingathome.org/
12:33:59:  Copyright: (c) 2009-2018 foldingathome.org
12:33:59:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
12:33:59:       Args: --child --lifeline 28684 /etc/fahclient/config.xml --run-as
12:33:59:             fahclient --pid-file=/var/run/fahclient.pid --daemon
12:33:59:     Config: /etc/fahclient/config.xml
12:33:59:******************************** Build ********************************
12:33:59:    Version: 7.5.1
12:33:59:       Date: May 12 2018
12:33:59:       Time: 22:51:07
12:33:59: Repository: Git
12:33:59:   Revision: 4705bf53c635f88b8fe85af7675557e15d491ff0
12:33:59:     Branch: master
12:33:59:   Compiler: GNU 4.4.7 20120313 (Red Hat 4.4.7-18)
12:33:59:    Options: -std=gnu++98 -O3 -funroll-loops
12:33:59:   Platform: linux2 4.14.0-3-amd64
12:33:59:       Bits: 64
12:33:59:       Mode: Release
12:33:59:******************************* System ********************************
12:33:59:        CPU: Intel(R) Xeon(R) CPU E5-4607 v2 @ 2.60GHz
12:33:59:     CPU ID: GenuineIntel Family 6 Model 62 Stepping 4
12:33:59:       CPUs: 48
12:33:59:     Memory: 125.72GiB
12:33:59:Free Memory: 103.46GiB
12:33:59:    Threads: POSIX_THREADS
12:33:59: OS Version: 3.10
12:33:59:Has Battery: false
12:33:59: On Battery: false
12:33:59: UTC Offset: 8
12:33:59:        PID: 28686
12:33:59:        CWD: /var/lib/fahclient
12:33:59:         OS: Linux 3.10.0-957.el7.x86_64 x86_64
12:33:59:    OS Arch: AMD64
12:33:59:       GPUs: 0
12:33:59:       CUDA: Not detected: Failed to open dynamic library 'libcuda.so':
12:33:59:             libcuda.so: cannot open shared object file: No such file or
12:33:59:             directory
12:33:59:     OpenCL: Not detected: Failed to open dynamic library 'libOpenCL.so':
12:33:59:             libOpenCL.so: cannot open shared object file: No such file or
12:33:59:             directory
12:33:59:***********************************************************************
12:33:59:<config>
12:33:59:  <!-- Folding Slot Configuration -->
12:33:59:  <gpu v='false'/>
12:33:59:
12:33:59:  <!-- User Information -->
12:33:59:  <passkey v='********************************'/>
12:33:59:  <user v='Dasher164'/>
12:33:59:
12:33:59:  <!-- Folding Slots -->
12:33:59:</config>
12:33:59:Switching to user fahclient
12:33:59:Trying to access database...
12:34:00:Successfully acquired database lock
12:34:00:FS00:Set client configured
12:34:00:Enabled folding slot 00: READY cpu:47
12:34:00:WU00:FS00:Connecting to 65.254.110.245:8080
12:35:01:Saving configuration to /etc/fahclient/config.xml
12:35:01:<config>
12:35:01:  <!-- Folding Slot Configuration -->
12:35:01:  <gpu v='false'/>
12:35:01:
12:35:01:  <!-- User Information -->
12:35:01:  <passkey v='********************************'/>
12:35:01:  <user v='Dasher164'/>
12:35:01:
12:35:01:  <!-- Folding Slots -->
12:35:01:  <slot id='0' type='CPU'/>
12:35:01:</config>
12:38:04:Saving configuration to /etc/fahclient/config.xml
12:38:04:<config>
12:38:04:  <!-- Folding Slot Configuration -->
12:38:04:  <gpu v='false'/>
12:38:04:
12:38:04:  <!-- Slot Control -->
12:38:04:  <power v='full'/>
12:38:04:
12:38:04:  <!-- User Information -->
12:38:04:  <passkey v='********************************'/>
12:38:04:  <user v='Dasher164'/>
12:38:04:
12:38:04:  <!-- Folding Slots -->
12:38:04:  <slot id='0' type='CPU'/>
12:38:04:</config>
12:51:15:WARNING:WU00:FS00:Failed to get ID from '65.254.110.245:8080': 10002: Received short response, expected 8 bytes, got 0
12:51:15:WU00:FS00:Connecting to 18.218.241.186:80
13:08:18:WARNING:WU00:FS00:Failed to get ID from '18.218.241.186:80': 10002: Received short response, expected 8 bytes, got 0
13:08:18:ERROR:WU00:FS00:Exception: Could not get an assignment ID
13:08:18:WU00:FS00:Connecting to 65.254.110.245:8080
13:23:50:WARNING:WU00:FS00:Failed to get ID from '65.254.110.245:8080': 10002: Received short response, expected 8 bytes, got 0
13:23:50:WU00:FS00:Connecting to 18.218.241.186:80
13:40:55:WARNING:WU00:FS00:Failed to get ID from '18.218.241.186:80': 10002: Received short response, expected 8 bytes, got 0
13:40:55:ERROR:WU00:FS00:Exception: Could not get an assignment ID
13:40:55:WU00:FS00:Connecting to 65.254.110.245:8080
13:56:28:WARNING:WU00:FS00:Failed to get ID from '65.254.110.245:8080': 10002: Received short response, expected 8 bytes, got 0
13:56:28:WU00:FS00:Connecting to 18.218.241.186:80
I do not have fahcontrol installed because i only connect to the server remotely as i cannot go to my office to gain physical access to it. It also doesnt have a dedicated gpu so i didnt bother to install cuda and opencl.
accessing via telnet does bring this up:
PyON 1 units
  {"id": "00", "state": "DOWNLOAD", "error": "NO_ERROR", "project": 0, "run": 0, "clone": 0, "gen": 0, "core": "unknown", "unit": "0x00000000000000000000000000000000", "percentdone": "0.00%", "eta": "0.00 secs", "ppd": "0", "creditestimate": "0", "waitingon": "", "nextattempt": "0.00 secs", "timeremaining": "unknown time", "totalframes": 0, "framesdone": 0, "assigned": "<invalid>", "timeout": "<invalid>", "deadline": "<invalid>", "ws": "0.0.0.0", "cs": "0.0.0.0", "attempts": 0, "slot": "00", "tpf": "0.00 secs", "basecredit": "0"}
im running a local instance of f@h in my home and it doesnt have the same error listed. any ideas?
Re: Could not get assignment id
Welcome to Folding@Home!
Corporate firewall, either Hardware or Software?
(The F@H EULA requires permission of the computer's owner, often a CEO or CIO)
the_giant_sugar_cube
Post by the_giant_sugar_cube »
same here
bronozoj
Post by bronozoj »
I have been given permission by our project manager (current owner) to run distributed computing applications to help with COVID-19 research. I could access assignment servers and ip addresses from inside the server (wget downloads the http index webpage) as well as ping the servers by name and ip address. I am new to CentOS as most servers i have handled either run Ubuntu or Debian. Does folding@home need any firewall exceptions to run?
Possibly. Some firewalls block HTTP(S) data transfers if it is not from a "known" browser such as Chrome, Edge, Firefox and so on. If that is the case, then an exception would need to be added to allow the FAHClient process to transfer using those protocols over ports 8080 and/or 80.
Others block transfers over "raw" IP numbers such as used here:
Again the appropriate exceptions might need to be added.
