I have tried multiple paths to get the gpu to detect, including adding a gpu slot in the configuration window, initially and after trying three separate drivers, but it will not detect it. My current driver is Nvidia 440.64 from PPA graphics drivers.
System Info follows;
https://imgur.com/a/TqArsbq
06:34:39:Removing old file 'configs/config-20200327-061036.xml'
06:34:39:Saving configuration to /etc/fahclient/config.xml
06:34:39:<config>
06:34:39: <!-- Client Control -->
06:34:39: <fold-anon v='true'/>
06:34:39:
06:34:39: <!-- Folding Slot Configuration -->
06:34:39: <gpu v='false'/>
06:34:39:
06:34:39: <!-- Network -->
06:34:39: <proxy v=':8080'/>
06:34:39:
06:34:39: <!-- Slot Control -->
06:34:39: <power v='light'/>
06:34:39:
06:34:39: <!-- User Information -->
06:34:39: <team v='223518'/>
06:34:39: <user v='TheLadySilver'/>
06:34:39:
06:34:39: <!-- Folding Slots -->
06:34:39: <slot id='0' type='CPU'>
06:34:39: <paused v='true'/>
06:34:39: </slot>
06:34:39:</config>
06:34:45:FS00:Unpaused
06:34:45:WU01:FS00:Starting
06:34:45:WU01:FS00:Running FahCore: /usr/bin/FAHCoreWrapper /var/lib/fahclient/cores/cores.foldingathome.org/v7/lin/64bit/avx/Core_a7.fah/FahCore_a7 -dir 01 -suffix 01 -version 705 -lifeline 1317 -checkpoint 15 -np 3
06:34:45:WU01:FS00:Started FahCore on PID 5307
06:34:45:WU01:FS00:Core PID:5311
06:34:45:WU01:FS00:FahCore 0xa7 started
06:34:46:WU01:FS00:0xa7:*********************** Log Started 2020-04-02T06:34:45Z ***********************
06:34:46:WU01:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
06:34:46:WU01:FS00:0xa7: Type: 0xa7
06:34:46:WU01:FS00:0xa7: Core: Gromacs
06:34:46:WU01:FS00:0xa7: Args: -dir 01 -suffix 01 -version 705 -lifeline 5307 -checkpoint 15 -np 3
06:34:46:WU01:FS00:0xa7:************************************ CBang *************************************
06:34:46:WU01:FS00:0xa7: Date: Nov 5 2019
06:34:46:WU01:FS00:0xa7: Time: 06:06:57
06:34:46:WU01:FS00:0xa7: Revision: 46c96f1aa8419571d83f3e63f9c99a0d602f6da9
06:34:46:WU01:FS00:0xa7: Branch: master
06:34:46:WU01:FS00:0xa7: Compiler: GNU 8.3.0
06:34:46:WU01:FS00:0xa7: Options: -std=c++11 -O3 -funroll-loops -fno-pie -fPIC
06:34:46:WU01:FS00:0xa7: Platform: linux2 4.19.0-5-amd64
06:34:46:WU01:FS00:0xa7: Bits: 64
06:34:46:WU01:FS00:0xa7: Mode: Release
06:34:46:WU01:FS00:0xa7:************************************ System ************************************
06:34:46:WU01:FS00:0xa7: CPU: AMD FX(tm)-8320 Eight-Core Processor
06:34:46:WU01:FS00:0xa7: CPU ID: AuthenticAMD Family 21 Model 2 Stepping 0
06:34:46:WU01:FS00:0xa7: CPUs: 8
06:34:46:WU01:FS00:0xa7: Memory: 15.54GiB
06:34:46:WU01:FS00:0xa7:Free Memory: 12.34GiB
06:34:46:WU01:FS00:0xa7: Threads: POSIX_THREADS
06:34:46:WU01:FS00:0xa7: OS Version: 5.3
06:34:46:WU01:FS00:0xa7:Has Battery: false
06:34:46:WU01:FS00:0xa7: On Battery: false
06:34:46:WU01:FS00:0xa7: UTC Offset: -6
06:34:46:WU01:FS00:0xa7: PID: 5311
06:34:46:WU01:FS00:0xa7: CWD: /var/lib/fahclient/work
06:34:46:WU01:FS00:0xa7:******************************** Build - libFAH ********************************
06:34:46:WU01:FS00:0xa7: Version: 0.0.18
06:34:46:WU01:FS00:0xa7: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
06:34:46:WU01:FS00:0xa7: Copyright: 2019 foldingathome.org
06:34:46:WU01:FS00:0xa7: Homepage: https://foldingathome.org/
06:34:46:WU01:FS00:0xa7: Time: 06:13:26
06:34:46:WU01:FS00:0xa7: Revision: 490c9aa2957b725af319379424d5c5cb36efb656
06:34:46:WU01:FS00:0xa7:************************************ Build *************************************
06:34:46:WU01:FS00:0xa7: SIMD: avx_256
06:34:46:WU01:FS00:0xa7:********************************************************************************
06:34:46:WU01:FS00:0xa7:Project: 14601 (Run 86, Clone 8, Gen 3)
06:34:46:WU01:FS00:0xa7:Unit: 0x000000049bf7a4d65e83a3393cf709ef
06:34:46:WU01:FS00:0xa7:Digital signatures verified
06:34:46:WU01:FS00:0xa7:Calling: mdrun -s frame3.tpr -o frame3.trr -cpi state.cpt -cpt 15 -nt 3
06:34:46:WU01:FS00:0xa7:Steps: first=0 total=250000
06:34:47:WU01:FS00:0xa7:Completed 71187 out of 250000 steps (28%)
06:34:59:Removing old file 'configs/config-20200327-062753.xml'
06:34:59:Saving configuration to /etc/fahclient/config.xml
06:34:59:<config>
06:34:59: <!-- Client Control -->
06:34:59: <fold-anon v='true'/>
06:34:59:
06:34:59: <!-- Folding Slot Configuration -->
06:34:59: <gpu v='false'/>
06:34:59:
06:34:59: <!-- Network -->
06:34:59: <proxy v=':8080'/>
06:34:59:
06:34:59: <!-- Slot Control -->
06:34:59: <power v='light'/>
06:34:59:
06:34:59: <!-- User Information -->
06:34:59: <team v='223518'/>
06:34:59: <user v='TheLadySilver'/>
06:34:59:
06:34:59: <!-- Folding Slots -->
06:34:59: <slot id='0' type='CPU'/>
06:34:59:</config>
06:37:28:WU01:FS00:0xa7:Completed 72500 out of 250000 steps (29%)
06:42:33:WU01:FS00:0xa7:Completed 75000 out of 250000 steps (30%)
