On client "local" 127.0.1
Option 'gpu-index' has no default and is not set.
iter should be a GtkTreeIter
No net connections have been changed, and net is working fine.
How do I get this thing back to work?
In "Configure", I have no longer have a "slots" tab, only "Connection".MrFrizzy wrote:So when you go into "Configure" and click on the slots tab, what happens when you click "Add" and try to select the GPU?
Usually a full uninstall and reinstall does the trick, but you have already done that. What graphics card did you have before and what do you have now?
05:25:58:Saving configuration to config.xml
05:25:58:<config>
05:25:58: <!-- Network -->
05:25:58: <proxy v=':8080'/>
05:25:58https://foldingforum.org/mcp.php?i=134&f=61&t=33828&p=321517:
05:25:58: <!-- User Information -->
05:25:58: <passkey v='********************************'/>
05:25:58: <team v='227867'/>
05:25:58: <user v='Frodo3636'/>
05:25:58:
05:25:58: <!-- Folding Slots -->
05:25:58: <slot id='1' type='GPU'/>
05:25:58:</config>
05:25:58:WU00:FS00:Slot ID 0 no longer exists and not yet downloaded, dumping
05:25:58:WU00:FS00:Cleaning up
05:26:05:WU01:FS01:Connecting to 65.254.110.245:8080
05:26:05:WARNING:WU01:FS01:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
05:26:05:WU01:FS01:Connecting to 18.218.241.186:80
05:26:07:WU01:FS01:Assigned to work server 40.114.52.201
05:26:07:WU01:FS01:Requesting new work unit for slot 01: READY gpu:0:TU116 [GeForce GTX 1660 Ti] from 40.114.52.201
05:26:07:WU01:FS01:Connecting to 40.114.52.201:8080
05:26:24:Saving configuration to config.xml
05:26:24:<config>
05:26:24: <!-- Network -->
05:26:24: <proxy v=':8080'/>
05:26:24:
05:26:24: <!-- Slot Control -->
05:26:24: <power v='full'/>
05:26:24:
05:26:24: <!-- User Information -->
05:26:24: <passkey v='********************************'/>
05:26:24: <team v='227867'/>
05:26:24: <user v='Frodo3636'/>
05:26:24:
05:26:24: <!-- Folding Slots -->
05:26:24: <slot id='1' type='GPU'/>
05:26:24:</config>
05:26:28:WARNING:WU01:FS01:WorkServer connection failed on port 8080 trying 80
05:26:28:WU01:FS01:Connecting to 40.114.52.201:80
05:26:49:ERROR:WU01:FS01:Exception: Failed to connect to 40.114.52.201:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
05:27:42:WU01:FS01:Connecting to 65.254.110.245:8080
05:27:42:WU01:FS01:Assigned to work server 13.82.98.119
05:27:42:WU01:FS01:Requesting new work unit for slot 01: READY gpu:0:TU116 [GeForce GTX 1660 Ti] from 13.82.98.119
05:27:42:WU01:FS01:Connecting to 13.82.98.119:8080
05:27:43:ERROR:WU01:FS01:Exception: Server did not assign work unit
05:30:20:WU01:FS01:Connecting to 65.254.110.245:8080
05:30:20:WARNING:WU01:FS01:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
05:30:20:WU01:FS01:Connecting to 18.218.241.186:80
05:30:20:WARNING:WU01:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
05:30:20:ERROR:WU01:FS01:Exception: Could not get an assignment
05:34:34:WU01:FS01:Connecting to 65.254.110.245:8080
05:34:34:WARNING:WU01:FS01:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
05:34:34:WU01:FS01:Connecting to 18.218.241.186:80
05:34:34:WARNING:WU01:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
05:34:34:ERROR:WU01:FS01:Exception: Could not get an assignment
05:41:25:WU01:FS01:Connecting to 65.254.110.245:8080
05:41:25:WARNING:WU01:FS01:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
05:41:25:WU01:FS01:Connecting to 18.218.241.186:80
05:41:26:WARNING:WU01:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
05:41:26:ERROR:WU01:FS01:Exception: Could not get an assignment
05:52:31:WU01:FS01:Connecting to 65.254.110.245:8080
05:52:31:WARNING:WU01:FS01:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
05:52:31:WU01:FS01:Connecting to 18.218.241.186:80
05:52:31:WARNING:WU01:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
05:52:31:ERROR:WU01:FS01:Exception: Could not get an assignment
