new gpu needed
qualche_tipo
new gpu needed
Post by qualche_tipo »
lspci | grep -i vga
00:02.0 VGA compatible controller: Intel Corporation 3rd Gen Core processor Graphics Controller (rev 09)
01:00.0 VGA compatible controller: NVIDIA Corporation GK107GLM [Quadro K2000M] (rev a1)
FAHClient --lspci
0x8086:0x0154:0:0:0:Intel Corporation:
0x8086:0x0151:0:1:0:Intel Corporation:
0x8086:0x0166:0:2:0:Intel Corporation:
0x8086:0x1e31:0:20:0:Intel Corporation:
0x8086:0x1e3a:0:22:0:Intel Corporation:
0x8086:0x1502:0:25:0:Intel Corporation:
0x8086:0x1e2d:0:26:0:Intel Corporation:
0x8086:0x1e20:0:27:0:Intel Corporation:
0x8086:0x1e10:0:28:0:Intel Corporation:
0x8086:0x1e12:0:28:1:Intel Corporation:
0x8086:0x1e14:0:28:2:Intel Corporation:
0x8086:0x1e26:0:29:0:Intel Corporation:
0x8086:0x1e55:0:31:0:Intel Corporation:
0x8086:0x1e03:0:31:2:Intel Corporation:
0x8086:0x1e22:0:31:3:Intel Corporation:
0x10de:0x0ffb:1:0:0:NVIDIA Corporation:
0x10de:0x0e1b:1:0:1:NVIDIA Corporation:
0x1180:0xe822:2:0:0:Ricoh Co Ltd:
0x1180:0xe832:2:0:3:Ricoh Co Ltd:
0x8086:0x0085:3:0:0:Intel Corporation:
Re: new gpu needed
Welcome to Folding@Home!
https://www.techpowerup.com/gpu-specs/q ... 000m.c1424
As a hardware device, this seems to be adequate to fold, It supports OpenCL 1.2 and Double Precision floating point math.
many Nvidia laptops use a technology called Optimus, where they use an Intel GPU until there is heavy load and then switch to the Nvidia GPU. No Intel GPUs are supported and they will crash F@H
(Some folks use the the Nvidia co\ntrol panel, under 3D setting to disable the Intal GPU)
https://www.geforce.com/hardware/techno ... technology
If you get it to work, it will be very slow.
Re: new gpu needed
This GPU is already white listed.
qualche_tipo
Re: new gpu needed
JimboPalmer, So, I shouldn't enable it for folding@home?
toTow
Oh, I see it. I had grep'd for K2000M....
