Old Sony VAIO VPCZ2290X not getting GPU WU
RMCholewa
Hardware configuration: Lenovo Y540 Notebook with an Intel Core i7-9750H, nvidia RTX2060 Mobile amd 32GB RAM
Post by RMCholewa »
Hi there!
I have an old Sony VAIO VPCZ 2290X, a notebook that payed itself tenfold since I bought it in 2011. It is a core i7-2640M with 8GB of RAM running windows 10. It still feels pretty fast with a dual SSD @ RAID0.
Buuuuut... It has an external ATI Radeon detected by Folding @ Home as a Whistler XT (Radeon HD 6770M Series).
My father uses this notebook on a daily basis as his PC (without the external GPU - was not being used since 2014 and I kept it in a drawer). When I started folding, I thought it might give some extra processing power (in fact< I was amazed it still works), but this GPU never gets anything. I started thinking that it might be too old for the task.
Logs are bellow.
My question: will it eventually get WUs or is it a waste of time (and energy) keeping it connected to the notebook?
Thanks in advance!
*********************** Log Started 2020-03-31T22:50:58Z ***********************
22:50:58:************************* Folding@home Client *************************
22:50:58:        Website: https://foldingathome.org/
22:50:58:      Copyright: (c) 2009-2018 foldingathome.org
22:50:58:         Author: Joseph Coffland <joseph@cauldrondevelopment.com>
22:50:58:           Args: --open-web-control
22:50:58:         Config: C:\Users\StealthNet\AppData\Roaming\FAHClient\config.xml
22:50:58:******************************** Build ********************************
22:50:58:        Version: 7.5.1
22:50:58:           Date: May 11 2018
22:50:58:           Time: 13:06:32
22:50:58:     Repository: Git
22:50:58:       Revision: 4705bf53c635f88b8fe85af7675557e15d491ff0
22:50:58:         Branch: master
22:50:58:       Compiler: Visual C++ 2008
22:50:58:        Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
22:50:58:       Platform: win32 10
22:50:58:           Bits: 32
22:50:58:           Mode: Release
22:50:58:******************************* System ********************************
22:50:58:            CPU: Intel(R) Core(TM) i7-2640M CPU @ 2.80GHz
22:50:58:         CPU ID: GenuineIntel Family 6 Model 42 Stepping 7
22:50:58:           CPUs: 4
22:50:58:         Memory: 7.92GiB
22:50:58:    Free Memory: 3.13GiB
22:50:58:        Threads: WINDOWS_THREADS
22:50:58:     OS Version: 6.2
22:50:58:    Has Battery: true
22:50:58:     On Battery: false
22:50:58:     UTC Offset: -3
22:50:58:            PID: 22488
22:50:58:            CWD: C:\Users\StealthNet\AppData\Roaming\FAHClient
22:50:58:             OS: Windows 10 Enterprise
22:50:58:        OS Arch: AMD64
22:50:58:           GPUs: 1
22:50:58:          GPU 0: Bus:22 Slot:0 Func:0 AMD:4 Whistler XT [Radeon HD 6770M Series]
22:50:58:           CUDA: Not detected: Failed to open dynamic library 'nvcuda.dll': Não
22:50:58:                 foi possível encontrar o módulo especificado.
22:50:58:
22:50:58:OpenCL Device 0: Platform:0 Device:0 Bus:22 Slot:0 Compute:1.2 Driver:1800.8
22:50:58:  Win32 Service: false
22:50:58:***********************************************************************
22:52:04:WU01:FS01:Connecting to 65.254.110.245:8080
22:52:05:WU01:FS01:Assigned to work server 192.0.2.1
22:52:05:WU01:FS01:Requesting new work unit for slot 01: READY gpu:0:Whistler XT [Radeon HD 6770M Series] from 192.0.2.1
22:52:05:WU01:FS01:Connecting to 192.0.2.1:8080
22:52:06:ERROR:WU01:FS01:Exception: 10002: Received short response, expected 512 bytes, got 0
22:53:41:WU01:FS01:Connecting to 65.254.110.245:8080
22:53:42:WU01:FS01:Assigned to work server 192.0.2.1
22:53:42:WU01:FS01:Requesting new work unit for slot 01: READY gpu:0:Whistler XT [Radeon HD 6770M Series] from 192.0.2.1
22:53:42:WU01:FS01:Connecting to 192.0.2.1:8080
22:53:43:ERROR:WU01:FS01:Exception: 10002: Received short response, expected 512 bytes, got 0
22:56:18:WU01:FS01:Connecting to 65.254.110.245:8080
22:56:20:WU01:FS01:Assigned to work server 192.0.2.1
22:56:20:WU01:FS01:Requesting new work unit for slot 01: READY gpu:0:Whistler XT [Radeon HD 6770M Series] from 192.0.2.1
22:56:20:WU01:FS01:Connecting to 192.0.2.1:8080
22:56:20:ERROR:WU01:FS01:Exception: 10002: Received short response, expected 512 bytes, got 0
22:57:08:WU00:FS00:0xa7:Completed 5000 out of 500000 steps (1%)
23:00:32:WU01:FS01:Connecting to 65.254.110.245:8080
23:00:34:WU01:FS01:Assigned to work server 192.0.2.1
23:00:34:WU01:FS01:Requesting new work unit for slot 01: READY gpu:0:Whistler XT [Radeon HD 6770M Series] from 192.0.2.1
23:00:34:WU01:FS01:Connecting to 192.0.2.1:8080
23:00:35:ERROR:WU01:FS01:Exception: 10002: Received short response, expected 512 bytes, got 0
23:02:31:WU00:FS00:0xa7:Completed 10000 out of 500000 steps (2%)
23:07:24:WU01:FS01:Connecting to 65.254.110.245:8080
23:07:25:WU01:FS01:Assigned to work server 192.0.2.1
23:07:25:WU01:FS01:Requesting new work unit for slot 01: READY gpu:0:Whistler XT [Radeon HD 6770M Series] from 192.0.2.1
23:07:25:WU01:FS01:Connecting to 192.0.2.1:8080
23:07:26:ERROR:WU01:FS01:Exception: 10002: Received short response, expected 512 bytes, got 0
23:08:15:WU00:FS00:0xa7:Completed 15000 out of 500000 steps (3%)
23:13:40:WU00:FS00:0xa7:Completed 20000 out of 500000 steps (4%)
23:18:29:WU01:FS01:Connecting to 65.254.110.245:8080
23:18:31:WU01:FS01:Assigned to work server 192.0.2.1
23:18:31:WU01:FS01:Requesting new work unit for slot 01: READY gpu:0:Whistler XT [Radeon HD 6770M Series] from 192.0.2.1
23:18:31:WU01:FS01:Connecting to 192.0.2.1:8080
23:18:32:ERROR:WU01:FS01:Exception: 10002: Received short response, expected 512 bytes, got 0
jo___l
Re: Old Sony VAIO VPCZ2290X not getting GPU WU
Post by jo___l »
That GPU is not supported by FAH.
RMCholewa
Post by RMCholewa »
jo___l wrote:That GPU is not supported by FAH.
Thank you for the quick response! Will remove the module.
jo___l
Post by jo___l »
It does not support DP (double precision) which is required by some, not all, GPU jobs. If you know what to look for this (that it is not supported) is shown in the log.
This is a private ip and "not available on the internet" and is how the assigning servers says "Nopes, GPU not supported. Bye.".
RMCholewa
Post by RMCholewa »
True... didn't notice that! Thank you!
