Beta Core_22.fah - Failed to access core package
ToeBlister
Post by ToeBlister »
F@H Client is unable to download the beta core.
I can download it from my browser.
Can I manually extract the downloaded .fah into the program folder?
*********************** Log Started 2020-04-01T00:59:52Z ***********************
00:59:52:************************* Folding@home Client *************************
00:59:52:        Website: https://foldingathome.org/
00:59:52:      Copyright: (c) 2009-2018 foldingathome.org
00:59:52:         Author: Joseph Coffland <joseph@cauldrondevelopment.com>
00:59:52:           Args:
00:59:52:         Config: C:\Users\Li Wen Loan Unit\AppData\Roaming\FAHClient\config.xml
00:59:52:******************************** Build ********************************
00:59:52:        Version: 7.5.1
00:59:52:           Date: May 11 2018
00:59:52:           Time: 13:06:32
00:59:52:     Repository: Git
00:59:52:       Revision: 4705bf53c635f88b8fe85af7675557e15d491ff0
00:59:52:         Branch: master
00:59:52:       Compiler: Visual C++ 2008
00:59:52:        Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
00:59:52:       Platform: win32 10
00:59:52:           Bits: 32
00:59:52:           Mode: Release
00:59:52:******************************* System ********************************
00:59:52:            CPU: Intel(R) Core(TM) i7-9750H CPU @ 2.60GHz
00:59:52:         CPU ID: GenuineIntel Family 6 Model 158 Stepping 10
00:59:52:           CPUs: 12
00:59:52:         Memory: 31.86GiB
00:59:52:    Free Memory: 22.45GiB
00:59:52:        Threads: WINDOWS_THREADS
00:59:52:     OS Version: 6.2
00:59:52:    Has Battery: true
00:59:52:     On Battery: false
00:59:52:     UTC Offset: 8
00:59:52:            PID: 18428
00:59:52:            CWD: C:\Users\Li Wen Loan Unit\AppData\Roaming\FAHClient
00:59:52:             OS: Windows 10 Home
00:59:52:        OS Arch: AMD64
00:59:52:           GPUs: 1
00:59:52:          GPU 0: Bus:1 Slot:0 Func:0 NVIDIA:7 TU106M [GeForce RTX 2060 Mobile]
00:59:52:  CUDA Device 0: Platform:0 Device:0 Bus:1 Slot:0 Compute:7.5 Driver:11.0
00:59:52:OpenCL Device 0: Platform:0 Device:0 Bus:1 Slot:0 Compute:1.2 Driver:445.75
00:59:52:OpenCL Device 1: Platform:1 Device:0 Bus:NA Slot:NA Compute:2.1 Driver:26.20
00:59:52:  Win32 Service: false
00:59:52:***********************************************************************
00:59:52:<config>
00:59:52:  <service-description v='Folding@home Client'/>
00:59:52:  <service-restart v='true'/>
00:59:52:  <service-restart-delay v='5000'/>
00:59:52:
00:59:52:  <!-- Client Control -->
00:59:52:  <client-threads v='6'/>
00:59:52:  <cycle-rate v='4'/>
00:59:52:  <cycles v='-1'/>
00:59:52:  <data-directory v='.'/>
00:59:52:  <disable-sleep-when-active v='true'/>
00:59:52:  <exec-directory v='C:\Program Files (x86)\FAHClient'/>
00:59:52:  <exit-when-done v='false'/>
00:59:52:  <fold-anon v='false'/>
00:59:52:  <open-web-control v='false'/>
00:59:52:
00:59:52:  <!-- Configuration -->
00:59:52:  <config-rotate v='true'/>
00:59:52:  <config-rotate-dir v='configs'/>
00:59:52:  <config-rotate-max v='16'/>
00:59:52:
00:59:52:  <!-- Debugging -->
00:59:52:  <assignment-servers>
00:59:52:    assign1.foldingathome.org:8080 assign2.foldingathome.org:80
00:59:52:  </assignment-servers>
00:59:52:  <auth-as v='true'/>
00:59:52:  <capture-directory v='capture'/>
00:59:52:  <capture-on-error v='false'/>
00:59:52:  <capture-packets v='false'/>
00:59:52:  <capture-requests v='false'/>
00:59:52:  <capture-responses v='false'/>
00:59:52:  <capture-sockets v='false'/>
00:59:52:  <core-exec v='FahCore_$type'/>
00:59:52:  <core-wrapper-exec v='FAHCoreWrapper'/>
00:59:52:  <debug-sockets v='false'/>
00:59:52:  <exception-locations v='true'/>
00:59:52:  <stack-traces v='false'/>
00:59:52:
00:59:52:  <!-- Error Handling -->
00:59:52:  <max-slot-errors v='10'/>
00:59:52:  <max-unit-errors v='5'/>
00:59:52:
00:59:52:  <!-- Folding Core -->
00:59:52:  <checkpoint v='15'/>
00:59:52:  <core-dir v='cores'/>
00:59:52:  <core-priority v='low'/>
00:59:52:  <cpu-affinity v='false'/>
00:59:52:  <cpu-usage v='100'/>
00:59:52:  <gpu-usage v='100'/>
00:59:52:  <no-assembly v='false'/>
00:59:52:
00:59:52:  <!-- Folding Slot Configuration -->
00:59:52:  <cause v='ANY'/>
00:59:52:  <client-subtype v='STDCLI'/>
00:59:52:  <client-type v='beta'/>
00:59:52:  <cpu-species v='X86_PENTIUM_II'/>
00:59:52:  <cpu-type v='AMD64'/>
00:59:52:  <cpus v='-1'/>
00:59:52:  <disable-viz v='false'/>
00:59:52:  <gpu v='true'/>
00:59:52:  <max-packet-size v='normal'/>
00:59:52:  <os-species v='WIN_8'/>
00:59:52:  <os-type v='WIN32'/>
00:59:52:  <project-key v='0'/>
00:59:52:  <smp v='true'/>
00:59:52:
00:59:52:  <!-- GUI -->
00:59:52:  <gui-enabled v='true'/>
00:59:52:
00:59:52:  <!-- HTTP Server -->
00:59:52:  <allow v='127.0.0.1'/>
00:59:52:  <connection-timeout v='60'/>
00:59:52:  <deny v='0/0'/>
00:59:52:  <http-addresses v='0:7396'/>
00:59:52:  <https-addresses v=''/>
00:59:52:  <max-connect-time v='900'/>
00:59:52:  <max-connections v='800'/>
00:59:52:  <max-request-length v='52428800'/>
00:59:52:  <min-connect-time v='300'/>
00:59:52:
00:59:52:  <!-- Logging -->
00:59:52:  <log v='log.txt'/>
00:59:52:  <log-color v='false'/>
00:59:52:  <log-crlf v='true'/>
00:59:52:  <log-date v='false'/>
00:59:52:  <log-date-periodically v='21600'/>
00:59:52:  <log-domain v='false'/>
00:59:52:  <log-header v='true'/>
00:59:52:  <log-level v='true'/>
00:59:52:  <log-no-info-header v='true'/>
00:59:52:  <log-redirect v='false'/>
00:59:52:  <log-rotate v='true'/>
00:59:52:  <log-rotate-dir v='logs'/>
00:59:52:  <log-rotate-max v='16'/>
00:59:52:  <log-short-level v='false'/>
00:59:52:  <log-simple-domains v='true'/>
00:59:52:  <log-thread-id v='false'/>
00:59:52:  <log-thread-prefix v='true'/>
00:59:52:  <log-time v='true'/>
00:59:52:  <log-to-screen v='true'/>
00:59:52:  <log-truncate v='false'/>
00:59:52:  <verbosity v='5'/>
00:59:52:
00:59:52:  <!-- Network -->
00:59:52:  <proxy v=':8080'/>
00:59:52:  <proxy-enable v='false'/>
00:59:52:  <proxy-pass v=''/>
00:59:52:  <proxy-user v=''/>
00:59:52:
00:59:52:  <!-- Process Control -->
00:59:52:  <child v='false'/>
00:59:52:  <daemon v='false'/>
00:59:52:  <pid v='false'/>
00:59:52:  <pid-file v='Folding@home Client.pid'/>
00:59:52:  <respawn v='false'/>
00:59:52:  <service v='false'/>
00:59:52:
00:59:52:  <!-- Remote Command Server -->
00:59:52:  <command-address v='0.0.0.0'/>
00:59:52:  <command-allow-no-pass v='127.0.0.1'/>
00:59:52:  <command-deny-no-pass v='0/0'/>
00:59:52:  <command-enable v='true'/>
00:59:52:  <command-port v='36330'/>
00:59:52:
00:59:52:  <!-- Slot Control -->
00:59:52:  <idle v='false'/>
00:59:52:  <max-shutdown-wait v='60'/>
00:59:52:  <pause-on-battery v='true'/>
00:59:52:  <pause-on-start v='false'/>
00:59:52:  <paused v='false'/>
00:59:52:  <power v='FULL'/>
00:59:52:
00:59:52:  <!-- User Information -->
00:59:52:  <machine-id v='0'/>
00:59:52:  <passkey v='********************************'/>
00:59:52:  <team v='197'/>
00:59:52:  <user v='ToeBlister'/>
00:59:52:
00:59:52:  <!-- Web Server -->
00:59:52:  <web-allow v='127.0.0.1'/>
00:59:52:  <web-deny v='0/0'/>
00:59:52:  <web-enable v='true'/>
00:59:52:
00:59:52:  <!-- Web Server Sessions -->
00:59:52:  <session-cookie v='sid'/>
00:59:52:  <session-lifetime v='86400'/>
00:59:52:  <session-timeout v='3600'/>
00:59:52:
00:59:52:  <!-- Work Unit Control -->
00:59:52:  <dump-after-deadline v='true'/>
00:59:52:  <max-queue v='16'/>
00:59:52:  <max-units v='0'/>
00:59:52:  <next-unit-percentage v='97'/>
00:59:52:  <stall-detection-enabled v='false'/>
00:59:52:  <stall-percent v='5'/>
00:59:52:  <stall-timeout v='1800'/>
00:59:52:
00:59:52:  <!-- Folding Slots -->
00:59:52:  <slot id='0' type='GPU'/>
00:59:52:</config>
00:59:52:Trying to access database...
00:59:52:Successfully acquired database lock
00:59:52:Enabled folding slot 00: READY gpu:0:TU106M [GeForce RTX 2060 Mobile]
00:59:52:Started thread 4 on PID 18428
00:59:52:Started thread 7 on PID 18428
00:59:52:Started thread 5 on PID 18428
00:59:52:Started thread 6 on PID 18428
00:59:52:Started thread 8 on PID 18428
00:59:52:Started thread 9 on PID 18428
00:59:52:WU00:FS00:Downloading core from http://cores.foldingathome.org/v7/win/64bit/beta/Core_22.fah
00:59:52:WU00:FS00:Connecting to cores.foldingathome.org:80
00:59:53:ERROR:WU00:FS00:Exception: Failed to access core package.
00:59:54:Started thread 10 on PID 18428
Re: Beta Core_22.fah - Failed to access core package
There is currently no beta testing for a FAHCore.
there is beta testing of new projects, followd by Advanced testing, followed by the release of that project to all of FAH
The released version of that core is automatically downloaded
When a WU is assigned, it will download the current production version.
I can download http://cores.foldingathome.org/v7/win/6 ... ore_22.fah in my browser, but that copy is not usable. Since your FAHClient is unable to download that same file, it's a problem with your firewall blocking the download. Add an exception to your firewall to permit that download.
ToeBlister
bruce wrote:There is currently no beta testing for a FAHCore. When a WU is assigned, it will download the current production version.
Thanks. I just added a flag to accept beta WUs so F@H Client is trying to download the core.
I'll check my firewall setting. It is strange thought.. I can download WUs and that core manually, but client has an issue.
ToeBlister
I wonder if this method still works:
http://web.archive.org/web/201603080700 ... s_manually
ToeBlister
ToeBlister wrote:I wonder if this method still works:
The answer is no.
Your security software contains a list of known browsers and thy're given permission to open html pages on the web. FAHClient must have the same permissions but (depending on your firewall) you may need to do that manually.
Are you a registered beta tester : viewtopic.php?f=16&t=8 ?
If no, don't use that flag, no support is offered for beta outside the beta forum.
ToeBlister
toTOW wrote:Are you a registered beta tester : viewtopic.php?f=16&t=8 ?
I changed to advanced instead.
Didn't realize there was a advanced branch of WUs before writing the initial post.
Error was due to proxy setting when I switched internet connection.
