Switched power and my laptop stopped folding
When I switched my power from medium to light due to heating my laptop just stopped with its folding task even though it was folding before when it was on medium.
Jesse_V
CPU: i7-6700k
GPU: GTX 970, GTX 1080 TI
Re: Switched power and my laptop stopped folding
Welcome to the forum!
When you move the power slider bar down to Light, that will mean that less components in your PC are actively engaged in molecular simulations. So when you move down, your GPU and most of your CPU will stop work in order to only use a little bit on that Light setting. So it's by design and expected. Does that explain what you saw?
Das vedanya, comrade.
If you want to reduce heat and still run your GPU on medium setting then use tools like MSI Afterburner to limit power usage.
