Returning Folder needs help!
will25u
Post by will25u »
OK, so I have downloaded F@H and have been a contributor before. With the whole COViD stuff, I wanted to help again, but am hitting my head on a wall. Before, I just installed F@H and it worked. But now, on multiple machines on multiple networks I get nothing. Here is my log on my home PC. Maybe it is just lack of work but one line did catch my eye. Anyway, any help is appreciated.
18:31:54:Enabled folding slot 00: PAUSED cpu:1 (not configured)
*********************** Log Started 2020-03-31T18:31:53Z ***********************
18:31:53:************************* Folding@home Client *************************
18:31:53:        Website: https://foldingathome.org/
18:31:53:      Copyright: (c) 2009-2018 foldingathome.org
18:31:53:         Author: Joseph Coffland <joseph@cauldrondevelopment.com>
18:31:53:           Args: --open-web-control
18:31:53:         Config: <none>
18:31:53:******************************** Build ********************************
18:31:53:        Version: 7.5.1
18:31:53:           Date: May 11 2018
18:31:53:           Time: 13:06:32
18:31:53:     Repository: Git
18:31:53:       Revision: 4705bf53c635f88b8fe85af7675557e15d491ff0
18:31:53:         Branch: master
18:31:53:       Compiler: Visual C++ 2008
18:31:53:        Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
18:31:53:       Platform: win32 10
18:31:53:           Bits: 32
18:31:53:           Mode: Release
18:31:53:******************************* System ********************************
18:31:53:            CPU: Intel(R) Core(TM) i5-5200U CPU @ 2.20GHz
18:31:53:         CPU ID: GenuineIntel Family 6 Model 61 Stepping 4
18:31:53:           CPUs: 4
18:31:53:         Memory: 7.41GiB
18:31:53:    Free Memory: 3.49GiB
18:31:53:        Threads: WINDOWS_THREADS
18:31:53:     OS Version: 6.2
18:31:53:    Has Battery: true
18:31:53:     On Battery: false
18:31:53:     UTC Offset: -4
18:31:53:            PID: 3048
18:31:53:            CWD: C:\Users\HTPC Laptop\AppData\Roaming\FAHClient
18:31:53:             OS: Windows 10 Enterprise
18:31:53:        OS Arch: AMD64
18:31:53:           GPUs: 0
18:31:53:           CUDA: Not detected: Failed to open dynamic library 'nvcuda.dll': The
18:31:53:                 specified module could not be found.
18:31:53:
18:31:53:OpenCL Device 0: Platform:0 Device:0 Bus:NA Slot:NA Compute:2.0 Driver:20.19
18:31:53:  Win32 Service: false
18:31:53:***********************************************************************
18:31:53:<config>
18:31:53:  <!-- Folding Slots -->
18:31:53:</config>
18:31:53:Connecting to assign1.foldingathome.org:8080
18:31:53:Updated GPUs.txt
18:31:53:Read GPUs.txt
18:31:53:Trying to access database...
18:31:54:Successfully acquired database lock
18:31:58:10:127.0.0.1:New Web connection
18:32:11:Set client configured
18:32:12:WU00:FS00:Connecting to 65.254.110.245:8080
18:32:55:Saving configuration to config.xml
18:32:55:<config>
18:32:55:  <!-- User Information -->
18:32:55:  <passkey v='********************************'/>
18:32:55:  <user v='will_and_jamie'/>
18:32:55:
18:32:55:  <!-- Folding Slots -->
18:32:55:  <slot id='0' type='CPU'/>
18:32:55:</config>
18:36:56:Saving configuration to config.xml
18:36:56:<config>
18:36:56:  <!-- Network -->
18:36:56:  <proxy v=':8080'/>
18:36:56:
18:36:56:  <!-- User Information -->
18:36:56:  <passkey v='********************************'/>
18:36:56:  <user v='will_and_jamie'/>
18:36:56:
18:36:56:  <!-- Folding Slots -->
18:36:56:  <slot id='0' type='CPU'>
18:36:56:    <cpus v='4'/>
18:36:56:  </slot>
18:36:56:</config>
18:36:59:Saving configuration to config.xml
18:36:59:<config>
18:36:59:  <!-- Network -->
18:36:59:  <proxy v=':8080'/>
18:36:59:
18:36:59:  <!-- User Information -->
18:36:59:  <passkey v='********************************'/>
18:36:59:  <user v='will_and_jamie'/>
18:36:59:
18:36:59:  <!-- Folding Slots -->
18:36:59:  <slot id='0' type='CPU'>
18:36:59:    <cpus v='4'/>
18:36:59:  </slot>
18:36:59:</config>
18:38:15:Saving configuration to config.xml
18:38:15:<config>
18:38:15:  <!-- Folding Core -->
18:38:15:  <checkpoint v='3'/>
18:38:15:  <core-priority v='low'/>
18:38:15:
18:38:15:  <!-- Network -->
18:38:15:  <proxy v=':8080'/>
18:38:15:
18:38:15:  <!-- User Information -->
18:38:15:  <passkey v='********************************'/>
18:38:15:  <user v='will_and_jamie'/>
18:38:15:
18:38:15:  <!-- Folding Slots -->
18:38:15:  <slot id='0' type='CPU'>
18:38:15:    <cpus v='4'/>
18:38:15:  </slot>
18:38:15:</config>
18:39:01:Saving configuration to config.xml
18:39:01:<config>
18:39:01:  <!-- Folding Core -->
18:39:01:  <checkpoint v='3'/>
18:39:01:  <core-priority v='low'/>
18:39:01:
18:39:01:  <!-- Network -->
18:39:01:  <proxy v=':8080'/>
18:39:01:
18:39:01:  <!-- User Information -->
18:39:01:  <passkey v='********************************'/>
18:39:01:  <user v='will_and_jamie'/>
18:39:01:
18:39:01:  <!-- Folding Slots -->
18:39:01:  <slot id='0' type='CPU'>
18:39:01:    <cpus v='4'/>
18:39:01:  </slot>
18:39:01:</config>
18:41:59:Saving configuration to config.xml
18:41:59:<config>
18:41:59:  <!-- Folding Core -->
18:41:59:  <checkpoint v='3'/>
18:41:59:  <core-priority v='low'/>
18:41:59:
18:41:59:  <!-- Network -->
18:41:59:  <proxy v=':8080'/>
18:41:59:
18:41:59:  <!-- Slot Control -->
18:41:59:  <power v='full'/>
18:41:59:
18:41:59:  <!-- User Information -->
18:41:59:  <passkey v='********************************'/>
18:41:59:  <user v='will_and_jamie'/>
18:41:59:
18:41:59:  <!-- Folding Slots -->
18:41:59:  <slot id='0' type='CPU'>
18:41:59:    <cpus v='2'/>
18:41:59:  </slot>
18:41:59:</config>
18:42:04:Saving configuration to config.xml
18:42:04:<config>
18:42:04:  <!-- Folding Core -->
18:42:04:  <checkpoint v='3'/>
18:42:04:  <core-priority v='low'/>
18:42:04:
18:42:04:  <!-- Network -->
18:42:04:  <proxy v=':8080'/>
18:42:04:
18:42:04:  <!-- Slot Control -->
18:42:04:  <power v='full'/>
18:42:04:
18:42:04:  <!-- User Information -->
18:42:04:  <passkey v='********************************'/>
18:42:04:  <user v='will_and_jamie'/>
18:42:04:
18:42:04:  <!-- Folding Slots -->
18:42:04:  <slot id='0' type='CPU'>
18:42:04:    <cpus v='2'/>
18:42:04:  </slot>
18:42:04:</config>
18:42:50:Saving configuration to config.xml
18:42:50:<config>
18:42:50:  <!-- Folding Core -->
18:42:50:  <checkpoint v='3'/>
18:42:50:  <core-priority v='low'/>
18:42:50:
18:42:50:  <!-- Network -->
18:42:50:  <proxy v=':8080'/>
18:42:50:
18:42:50:  <!-- Slot Control -->
18:42:50:  <power v='full'/>
18:42:50:
18:42:50:  <!-- User Information -->
18:42:50:  <passkey v='********************************'/>
18:42:50:  <user v='will_and_jamie'/>
18:42:50:
18:42:50:  <!-- Folding Slots -->
18:42:50:  <slot id='0' type='CPU'/>
18:42:50:</config>
18:43:05:Saving configuration to config.xml
18:43:05:<config>
18:43:05:  <!-- Folding Core -->
18:43:05:  <checkpoint v='3'/>
18:43:05:  <core-priority v='low'/>
18:43:05:
18:43:05:  <!-- Network -->
18:43:05:  <proxy v=':8080'/>
18:43:05:
18:43:05:  <!-- Slot Control -->
18:43:05:  <power v='full'/>
18:43:05:
18:43:05:  <!-- User Information -->
18:43:05:  <passkey v='********************************'/>
18:43:05:  <user v='will_and_jamie'/>
18:43:05:
18:43:05:  <!-- Folding Slots -->
18:43:05:  <slot id='0' type='CPU'/>
18:43:05:</config>
18:51:59:Saving configuration to config.xml
18:51:59:<config>
18:51:59:  <!-- Folding Core -->
18:51:59:  <checkpoint v='3'/>
18:51:59:  <core-priority v='low'/>
18:51:59:
18:51:59:  <!-- Network -->
18:51:59:  <proxy v=':8080'/>
18:51:59:
18:51:59:  <!-- Slot Control -->
18:51:59:  <power v='full'/>
18:51:59:
18:51:59:  <!-- User Information -->
18:51:59:  <passkey v='********************************'/>
18:51:59:  <user v='will_and_jamie'/>
18:51:59:
18:51:59:  <!-- Folding Slots -->
18:51:59:  <slot id='0' type='CPU'/>
18:51:59:</config>
will25u
Re: Returning Folder needs help!
Post by will25u »
I closed out of everything, and reopened, and here is the log. It just gets stuck on...
20:52:49:WU00:FS00:Connecting to 65.254.110.245:8080
*********************** Log Started 2020-03-31T20:52:49Z ***********************
20:52:49:************************* Folding@home Client *************************
20:52:49:        Website: https://foldingathome.org/
20:52:49:      Copyright: (c) 2009-2018 foldingathome.org
20:52:49:         Author: Joseph Coffland <joseph@cauldrondevelopment.com>
20:52:49:           Args: --open-web-control
20:52:49:         Config: C:\Users\HTPC Laptop\AppData\Roaming\FAHClient\config.xml
20:52:49:******************************** Build ********************************
20:52:49:        Version: 7.5.1
20:52:49:           Date: May 11 2018
20:52:49:           Time: 13:06:32
20:52:49:     Repository: Git
20:52:49:       Revision: 4705bf53c635f88b8fe85af7675557e15d491ff0
20:52:49:         Branch: master
20:52:49:       Compiler: Visual C++ 2008
20:52:49:        Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
20:52:49:       Platform: win32 10
20:52:49:           Bits: 32
20:52:49:           Mode: Release
20:52:49:******************************* System ********************************
20:52:49:            CPU: Intel(R) Core(TM) i5-5200U CPU @ 2.20GHz
20:52:49:         CPU ID: GenuineIntel Family 6 Model 61 Stepping 4
20:52:49:           CPUs: 4
20:52:49:         Memory: 7.41GiB
20:52:49:    Free Memory: 2.43GiB
20:52:49:        Threads: WINDOWS_THREADS
20:52:49:     OS Version: 6.2
20:52:49:    Has Battery: true
20:52:49:     On Battery: false
20:52:49:     UTC Offset: -4
20:52:49:            PID: 14248
20:52:49:            CWD: C:\Users\HTPC Laptop\AppData\Roaming\FAHClient
20:52:49:             OS: Windows 10 Enterprise
20:52:49:        OS Arch: AMD64
20:52:49:           GPUs: 0
20:52:49:           CUDA: Not detected: Failed to open dynamic library 'nvcuda.dll': The
20:52:49:                 specified module could not be found.
20:52:49:
20:52:49:OpenCL Device 0: Platform:0 Device:0 Bus:NA Slot:NA Compute:2.0 Driver:20.19
20:52:49:  Win32 Service: false
20:52:49:***********************************************************************
20:52:49:<config>
20:52:49:  <!-- Folding Core -->
20:52:49:  <checkpoint v='3'/>
20:52:49:  <core-priority v='low'/>
20:52:49:
20:52:49:  <!-- Network -->
20:52:49:  <proxy v=':8080'/>
20:52:49:
20:52:49:  <!-- Slot Control -->
20:52:49:  <power v='full'/>
20:52:49:
20:52:49:  <!-- User Information -->
20:52:49:  <passkey v='********************************'/>
20:52:49:  <team v='37726'/>
20:52:49:  <user v='will25u'/>
20:52:49:
20:52:49:  <!-- Folding Slots -->
20:52:49:  <slot id='0' type='CPU'/>
20:52:49:</config>
20:52:49:Trying to access database...
20:52:49:Successfully acquired database lock
20:52:49:Enabled folding slot 00: READY cpu:4
ipkh
Post by ipkh »
Try reinstalling the Nvidia drivers. It looks like it can't find the cuda and OpenCL drivers.
Do you have a firewall or anti-malware software running? The FAHClient process needs the same access for transfers as a web browser, some of these block these uploads and downloads over HTTP if they are not from a "known" browser such as Chrome, Firefox, Opera, and so on.
Upload and download may need an exception added for the FAHclient executable, it is transferring over ports 8080 and 80 using HTTP or HTTPS.
One of the first things the client does after startup is download a copy of the current GPUs.txt file. If your GPU is newer than the list contained in the initial installer, the client will not recognize your card until after it has received a new copy.
For drivers, the video drivers installed through Windows Update leave out the necessary OpenCL support. Download the drivers directly from AMD or nVidia.
