Completed WU 11741 (0, 6359, 14) fails to upload
CoxTH
Post by CoxTH »
My client has completed the aforementioned WU and has been attempting to upload it for hours. I have restarted my client, but this doesn't seem to have fixed the issue. Here are the corresponding logs:
*********************** Log Started 2020-03-31T18:00:41Z ***********************
18:00:41:************************* Folding@home Client *************************
18:00:41:        Website: https://foldingathome.org/
18:00:41:      Copyright: (c) 2009-2018 foldingathome.org
18:00:41:         Author: Joseph Coffland <joseph@cauldrondevelopment.com>
18:00:41:           Args: --open-web-control
18:00:41:         Config: C:\Users\Christian\AppData\Roaming\FAHClient\config.xml
18:00:41:******************************** Build ********************************
18:00:41:        Version: 7.5.1
18:00:41:           Date: May 11 2018
18:00:41:           Time: 13:06:32
18:00:41:     Repository: Git
18:00:41:       Revision: 4705bf53c635f88b8fe85af7675557e15d491ff0
18:00:41:         Branch: master
18:00:41:       Compiler: Visual C++ 2008
18:00:41:        Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
18:00:41:       Platform: win32 10
18:00:41:           Bits: 32
18:00:41:           Mode: Release
18:00:41:******************************* System ********************************
18:00:41:            CPU: Intel(R) Core(TM) i5-9600K CPU @ 3.70GHz
18:00:41:         CPU ID: GenuineIntel Family 6 Model 158 Stepping 12
18:00:41:           CPUs: 6
18:00:41:         Memory: 15.94GiB
18:00:41:    Free Memory: 1.88GiB
18:00:41:        Threads: WINDOWS_THREADS
18:00:41:     OS Version: 6.2
18:00:41:    Has Battery: false
18:00:41:     On Battery: false
18:00:41:     UTC Offset: 2
18:00:41:            PID: 9700
18:00:41:            CWD: C:\Users\Christian\AppData\Roaming\FAHClient
18:00:41:             OS: Windows 10 Home
18:00:41:        OS Arch: AMD64
18:00:41:           GPUs: 1
18:00:41:          GPU 0: Bus:1 Slot:0 Func:0 NVIDIA:8 GP102 [GeForce GTX 1080 Ti] 11380
18:00:41:  CUDA Device 0: Platform:0 Device:0 Bus:1 Slot:0 Compute:6.1 Driver:10.1
18:00:41:OpenCL Device 0: Platform:0 Device:0 Bus:1 Slot:0 Compute:1.2 Driver:436.15
18:00:41:  Win32 Service: false
18:00:41:***********************************************************************
18:00:41:<config>
18:00:41:  <!-- Network -->
18:00:41:  <proxy v=':8080'/>
18:00:41:
18:00:41:  <!-- User Information -->
18:00:41:  <passkey v='********************************'/>
18:00:41:  <team v='50959'/>
18:00:41:  <user v='CoxTH'/>
18:00:41:
18:00:41:  <!-- Folding Slots -->
18:00:41:  <slot id='0' type='CPU'/>
18:00:41:  <slot id='1' type='GPU'/>
18:00:41:</config>
18:00:41:Trying to access database...
18:00:41:Successfully acquired database lock
18:00:41:Enabled folding slot 00: READY cpu:4
18:00:41:Enabled folding slot 01: READY gpu:0:GP102 [GeForce GTX 1080 Ti] 11380
18:00:41:ERROR:Exception: Failed to register systray icon: Unbekannter Fehler
18:00:41:WU01:FS01:Sending unit results: id:01 state:SEND error:NO_ERROR project:11741 run:0 clone:6359 gen:14 core:0x22 unit:0x0000001f8ca304f15e6bc58d6737854c
18:00:41:WU01:FS01:Uploading 21.92MiB to 140.163.4.241
18:00:41:WU01:FS01:Connecting to 140.163.4.241:8080
18:00:42:WU00:FS00:Connecting to 65.254.110.245:8080
18:00:42:WU02:FS01:Connecting to 65.254.110.245:8080
18:00:42:WARNING:WU00:FS00:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
18:00:42:WU00:FS00:Connecting to 18.218.241.186:80
18:00:42:WARNING:WU02:FS01:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
18:00:42:WU02:FS01:Connecting to 18.218.241.186:80
18:00:42:WARNING:WU00:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
18:00:42:ERROR:WU00:FS00:Exception: Could not get an assignment
18:00:42:WARNING:WU02:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
18:00:42:ERROR:WU02:FS01:Exception: Could not get an assignment
18:00:43:WU02:FS01:Connecting to 65.254.110.245:8080
18:00:43:WARNING:WU00:FS00:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
18:00:43:WU00:FS00:Connecting to 18.218.241.186:80
18:00:43:WARNING:WU02:FS01:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
18:00:43:WU02:FS01:Connecting to 18.218.241.186:80
18:00:43:WARNING:WU00:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
18:00:43:ERROR:WU00:FS00:Exception: Could not get an assignment
18:00:43:WARNING:WU02:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
18:00:43:ERROR:WU02:FS01:Exception: Could not get an assignment
18:00:47:WU01:FS01:Upload 10.55%
18:00:53:WU01:FS01:Upload 25.66%
18:00:59:WU01:FS01:Upload 32.21%
18:01:05:WU01:FS01:Upload 43.90%
18:01:11:WU01:FS01:Upload 59.01%
18:01:17:WU01:FS01:Upload 72.69%
18:01:23:WU01:FS01:Upload 87.52%
18:01:28:WU01:FS01:Upload complete
18:01:28:WU01:FS01:Server responded PLEASE_WAIT (464)
18:01:28:WARNING:WU01:FS01:Failed to send results, will try again later
18:01:28:WU01:FS01:Sending unit results: id:01 state:SEND error:NO_ERROR project:11741 run:0 clone:6359 gen:14 core:0x22 unit:0x0000001f8ca304f15e6bc58d6737854c
18:01:28:WU01:FS01:Uploading 21.92MiB to 140.163.4.241
18:01:28:WU01:FS01:Connecting to 140.163.4.241:8080
18:01:34:WU01:FS01:Upload 13.97%
18:01:40:WU01:FS01:Upload 25.37%
18:01:42:WU00:FS00:Connecting to 65.254.110.245:8080
18:01:43:WU02:FS01:Connecting to 65.254.110.245:8080
18:01:43:WARNING:WU00:FS00:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
18:01:43:WU00:FS00:Connecting to 18.218.241.186:80
18:01:43:WARNING:WU02:FS01:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
18:01:43:WU02:FS01:Connecting to 18.218.241.186:80
18:01:43:WARNING:WU00:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
18:01:43:ERROR:WU00:FS00:Exception: Could not get an assignment
18:01:43:WARNING:WU02:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
18:01:43:ERROR:WU02:FS01:Exception: Could not get an assignment
18:01:46:WU01:FS01:Upload 40.48%
18:01:52:WU01:FS01:Upload 55.30%
18:01:58:WU01:FS01:Upload 70.41%
18:02:04:WU01:FS01:Upload 85.24%
18:02:10:WU01:FS01:Upload complete
18:02:10:WU01:FS01:Server responded PLEASE_WAIT (464)
18:02:10:WARNING:WU01:FS01:Failed to send results, will try again later
18:02:28:WU01:FS01:Sending unit results: id:01 state:SEND error:NO_ERROR project:11741 run:0 clone:6359 gen:14 core:0x22 unit:0x0000001f8ca304f15e6bc58d6737854c
18:02:28:WU01:FS01:Uploading 21.92MiB to 140.163.4.241
18:02:28:WU01:FS01:Connecting to 140.163.4.241:8080
18:02:34:WU01:FS01:Upload 13.40%
18:02:40:WU01:FS01:Upload 27.65%
18:02:46:WU01:FS01:Upload 42.19%
18:02:52:WU01:FS01:Upload 56.73%
18:02:58:WU01:FS01:Upload 71.55%
18:03:04:WU01:FS01:Upload 86.09%
18:03:09:WU01:FS01:Upload complete
18:03:09:WU01:FS01:Server responded PLEASE_WAIT (464)
18:03:09:WARNING:WU01:FS01:Failed to send results, will try again later
18:03:20:WU00:FS00:Connecting to 65.254.110.245:8080
18:03:20:WARNING:WU00:FS00:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
18:03:20:WU00:FS00:Connecting to 18.218.241.186:80
18:03:20:WU02:FS01:Connecting to 65.254.110.245:8080
18:03:20:WARNING:WU02:FS01:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
18:03:20:WU02:FS01:Connecting to 18.218.241.186:80
18:03:21:WARNING:WU02:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
18:03:21:ERROR:WU02:FS01:Exception: Could not get an assignment
18:03:21:WARNING:WU00:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
18:03:21:ERROR:WU00:FS00:Exception: Could not get an assignment
18:04:05:WU01:FS01:Sending unit results: id:01 state:SEND error:NO_ERROR project:11741 run:0 clone:6359 gen:14 core:0x22 unit:0x0000001f8ca304f15e6bc58d6737854c
18:04:05:WU01:FS01:Uploading 21.92MiB to 140.163.4.241
18:04:05:WU01:FS01:Connecting to 140.163.4.241:8080
18:04:11:WU01:FS01:Upload 13.11%
18:04:17:WU01:FS01:Upload 27.65%
18:04:23:WU01:FS01:Upload 40.48%
18:04:26:676:127.0.0.1:New Web connection
18:04:29:WU01:FS01:Upload 50.46%
18:04:35:WU01:FS01:Upload 60.72%
18:04:41:WU01:FS01:Upload 71.84%
18:04:47:WU01:FS01:Upload 85.24%
18:04:53:WU01:FS01:Upload 100.00%
18:04:53:WU01:FS01:Upload complete
18:04:53:WU01:FS01:Server responded PLEASE_WAIT (464)
18:04:53:WARNING:WU01:FS01:Failed to send results, will try again later
18:05:57:WU00:FS00:Connecting to 65.254.110.245:8080
18:05:57:WU02:FS01:Connecting to 65.254.110.245:8080
18:05:57:WARNING:WU00:FS00:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
18:05:57:WU00:FS00:Connecting to 18.218.241.186:80
18:05:57:WARNING:WU02:FS01:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
18:05:57:WU02:FS01:Connecting to 18.218.241.186:80
18:05:57:WARNING:WU00:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
18:05:57:ERROR:WU00:FS00:Exception: Could not get an assignment
18:05:58:WARNING:WU02:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
18:05:58:ERROR:WU02:FS01:Exception: Could not get an assignment
18:06:42:WU01:FS01:Sending unit results: id:01 state:SEND error:NO_ERROR project:11741 run:0 clone:6359 gen:14 core:0x22 unit:0x0000001f8ca304f15e6bc58d6737854c
18:06:42:WU01:FS01:Uploading 21.92MiB to 140.163.4.241
18:06:42:WU01:FS01:Connecting to 140.163.4.241:8080
18:06:48:WU01:FS01:Upload 10.55%
18:06:54:WU01:FS01:Upload 25.37%
18:07:00:WU01:FS01:Upload 40.48%
18:07:06:WU01:FS01:Upload 55.30%
18:07:12:WU01:FS01:Upload 70.13%
18:07:18:WU01:FS01:Upload 84.67%
18:07:24:WU01:FS01:Upload 94.07%
18:07:26:WU01:FS01:Upload complete
18:07:26:WU01:FS01:Server responded PLEASE_WAIT (464)
18:07:26:WARNING:WU01:FS01:Failed to send results, will try again later
davidcoton
Re: Completed WU 11741 (0, 6359, 14) fails to upload
Post by davidcoton »
My guess is that the upload succeeded, but it's not showing in the stats yet.
Wait if you want to be sure of the points.
CoxTH
Post by CoxTH »
I don't think so. The WU is still listed in my client in the "Send" status. If it had been received by the server, it would be gone from my client, wouldn't it?
davidcoton
In theory, that's how it works. Recent upgrade seems to result in this issue, where the WU has uploaded but the server gives PLEASE_WAIT instead of acknowledging. We're still tying down the circumstances and consequences.
Remind me here tomorrow if the situation persists and I'll check again.
I just started seeing this today. I don't understand it ... but I've asked the experts.
We've had a number of uploads fail which did not include the last 3 messages so it seems that there's a little more information now, even if it doesn't tell us anything new. I consider this as progress since a day or two ago.
I did check on project:11741 run:0 clone:6359 gen:14. It has been assigned and has failed several times and reassigned. One of the uploaded results was deemed acceptable, so the science has moved on. That means that scientifically, your results are now non-essential to the research. Traditionally, you'd be awarded points anyway and that may or may not be happening. (We'll have to see.) Since your client could not confirm the upload was successful, it will keep trying until the 8-day final deadline.
The server may or may know all of that information. If it did, it would process the WU as a redundant upload and discard it but give you credit anyway. I'm sure somebody will figure out how to have that happen one of these days because nobody needs the repeated upload attempts.
CoxTH
Post by CoxTH »
Quick update: After booting up my PC today, the WU uploaded without any problem.
