Please add RTX 2080 Ti
MEGIDDO
Post by MEGIDDO »
Name:
NVIDIA GeForce RTX 2080 Ti
Device ID:
10DE 1E07 - 1043 866C
GPU Name:
TU102
GPU Variant:
TU102-300A-K1-A1
16:14:26:WU01:FS01:0x22:************************************ System ************************************
16:14:26:WU01:FS01:0x22:        CPU: Intel(R) Core(TM) i5-9600K CPU @ 3.70GHz
16:14:26:WU01:FS01:0x22:     CPU ID: GenuineIntel Family 6 Model 158 Stepping 12
16:14:26:WU01:FS01:0x22:       CPUs: 6
16:14:26:WU01:FS01:0x22:     Memory: 31.92GiB
16:14:26:WU01:FS01:0x22:Free Memory: 20.09GiB
16:14:26:WU01:FS01:0x22:    Threads: WINDOWS_THREADS
16:14:26:WU01:FS01:0x22: OS Version: 6.2
16:14:26:WU01:FS01:0x22:Has Battery: false
16:14:26:WU01:FS01:0x22: On Battery: false
16:14:26:WU01:FS01:0x22: UTC Offset: -7
16:14:26:WU01:FS01:0x22:        PID: 17360
16:14:26:WU01:FS01:0x22:        CWD: C:\Users\My 2080TI\AppData\Roaming\FAHClient\work
16:14:26:WU01:FS01:0x22:         OS: Windows 10 Pro
16:14:26:WU01:FS01:0x22:    OS Arch: AMD64
16:14:26:WU01:FS01:0x22:********************************************************************************
16:14:26:WU01:FS01:0x22:Project: 11779 (Run 0, Clone 6576, Gen 16)
16:14:26:WU01:FS01:0x22:Unit: 0x000000160d5a98395e758986443f40fa
16:14:26:WU01:FS01:0x22:Reading tar file core.xml
16:14:26:WU01:FS01:0x22:Reading tar file integrator.xml
16:14:26:WU01:FS01:0x22:Reading tar file state.xml
16:14:26:WU01:FS01:0x22:Reading tar file system.xml
16:14:26:WU01:FS01:0x22:Digital signatures verified
16:14:26:WU01:FS01:0x22:Folding@home GPU Core22 Folding@home Core
16:14:26:WU01:FS01:0x22:Version 0.0.2
16:14:32:WU00:FS00:Connecting to 65.254.110.245:8080
16:14:32:WARNING:WU00:FS00:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
16:14:32:WU00:FS00:Connecting to 18.218.241.186:80
16:14:32:WU00:FS00:Assigned to work server 128.252.203.9
16:14:32:WU00:FS00:Requesting new work unit for slot 00: READY cpu:5 from 128.252.203.9
16:14:32:WU00:FS00:Connecting to 128.252.203.9:8080
16:14:51:WU01:FS01:0x22:Completed 0 out of 1000000 steps (0%)
16:14:51:WU01:FS01:0x22:Temperature control disabled. Requirements: single Nvidia GPU, tmax must be < 110 and twait >= 900
16:14:53:WARNING:WU00:FS00:WorkServer connection failed on port 8080 trying 80
16:14:53:WU00:FS00:Connecting to 128.252.203.9:80
16:15:23:WU01:FS01:0x22:Completed 10000 out of 1000000 steps (1%)
16:15:28:ERROR:WU00:FS00:Exception: 10002: Received short response, expected 512 bytes, got 0
16:15:54:WU01:FS01:0x22:Completed 20000 out of 1000000 steps (2%)
16:16:09:WU00:FS00:Connecting to 65.254.110.245:8080
16:16:09:WARNING:WU00:FS00:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
16:16:09:WU00:FS00:Connecting to 18.218.241.186:80
16:16:10:WARNING:WU00:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
16:16:10:ERROR:WU00:FS00:Exception: Could not get an assignment
I dont know what all of this means, hopefully it's all that's needed to get this working right.
Thank you...
ipkh
Re: Please add RTX 2080 Ti
Post by ipkh »
The 2080ti is supported. You can't add an unsupported gpu to a folding slot.
Servers are currently under intense load and occasionally make your client wait for work.
Every few hours you can pause and restart the slot to reset the retry timer.
MEGIDDO
Post by MEGIDDO »
Thank you, I was wondering..
Although I didnt see the 2080TI in the GPUdata I figured it had to have been supported.
But yeah, it's been acting funny lately, and it had me curious as to why.
Thank you again.
jonault
Post by jonault »
It's listed in my GPUs.txt. If the file on your PC has not been updated in a while you might delete it so the client will download a new one.
