Unable to run CPU wu and GPU wu at the same time
Simplex0
Post by Simplex0 »
I have 2 computer running folding.
Set up 1 is…
CPU AMD FX-8350, GPU 2 X GTX1070, OS Windows 8.
This computer usually get new work units both for the CPU and GPU at the same time and works just fine.
Set up 2 is…
CPU AMD Threadripper 1950X, GPU RTX2080, OS Windows 10 Pro
This computer us get a work units for either the GPU or the CPU but I only manage to get a WU for the CPU after I had closed the Folding program and restart it.
My settings for the CPU slot is 28 threads and for the GPU Index I have -1.
Is there something I can change to get WU for both slots at the same time?
The log looks like this…
*********************** Log Started 2020-03-31T12:40:48Z ***********************
12:40:48:************************* Folding@home Client *************************
12:40:48:        Website: https://foldingathome.org/
12:40:48:      Copyright: (c) 2009-2018 foldingathome.org
12:40:48:         Author: Joseph Coffland <joseph@cauldrondevelopment.com>
12:40:48:           Args: --open-web-control
12:40:48:         Config: D:\Program\Folding\Data\config.xml
12:40:48:******************************** Build ********************************
12:40:48:        Version: 7.5.1
12:40:48:           Date: May 11 2018
12:40:48:           Time: 13:06:32
12:40:48:     Repository: Git
12:40:48:       Revision: 4705bf53c635f88b8fe85af7675557e15d491ff0
12:40:48:         Branch: master
12:40:48:       Compiler: Visual C++ 2008
12:40:48:        Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
12:40:48:       Platform: win32 10
12:40:48:           Bits: 32
12:40:48:           Mode: Release
12:40:48:******************************* System ********************************
12:40:48:            CPU: AMD Ryzen Threadripper 1950X 16-Core Processor
12:40:48:         CPU ID: AuthenticAMD Family 23 Model 1 Stepping 1
12:40:48:           CPUs: 32
12:40:48:         Memory: 31.90GiB
12:40:48:    Free Memory: 26.77GiB
12:40:48:        Threads: WINDOWS_THREADS
12:40:48:     OS Version: 6.2
12:40:48:    Has Battery: false
12:40:48:     On Battery: false
12:40:48:     UTC Offset: 2
12:40:48:            PID: 13412
12:40:48:            CWD: D:\Program\Folding\Data
12:40:48:             OS: Windows 10 Enterprise
12:40:48:        OS Arch: AMD64
12:40:48:           GPUs: 1
12:40:48:          GPU 0: Bus:65 Slot:0 Func:0 NVIDIA:8 TU104 [GeForce RTX 2080]
12:40:48:  CUDA Device 0: Platform:0 Device:0 Bus:65 Slot:0 Compute:7.5 Driver:10.2
12:40:48:OpenCL Device 0: Platform:0 Device:0 Bus:65 Slot:0 Compute:1.2 Driver:430.64
12:40:48:  Win32 Service: false
12:40:48:***********************************************************************
12:40:48:<config>
12:40:48:  <!-- Folding Core -->
12:40:48:  <core-priority v='low'/>
12:40:48:
12:40:48:  <!-- Network -->
12:40:48:  <proxy v=':8080'/>
12:40:48:
12:40:48:  <!-- Slot Control -->
12:40:48:  <pause-on-battery v='false'/>
12:40:48:  <power v='full'/>
12:40:48:
12:40:48:  <!-- User Information -->
12:40:48:  <passkey v='********************************'/>
12:40:48:  <team v='50711'/>
12:40:48:  <user v='Simplex0'/>
12:40:48:
12:40:48:  <!-- Folding Slots -->
12:40:48:  <slot id='0' type='CPU'>
12:40:48:    <cpus v='28'/>
12:40:48:  </slot>
12:40:48:  <slot id='1' type='GPU'/>
12:40:48:</config>
12:40:48:Trying to access database...
12:40:48:Successfully acquired database lock
12:40:48:Enabled folding slot 00: READY cpu:28
12:40:48:Enabled folding slot 01: READY gpu:0:TU104 [GeForce RTX 2080]
12:40:48:WU00:FS00:Connecting to 65.254.110.245:8080
12:40:48:WU01:FS01:Connecting to 65.254.110.245:8080
12:40:49:WARNING:WU00:FS00:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
12:40:49:WU00:FS00:Connecting to 18.218.241.186:80
12:40:49:WU01:FS01:Assigned to work server 128.252.203.2
12:40:49:WU01:FS01:Requesting new work unit for slot 01: READY gpu:0:TU104 [GeForce RTX 2080] from 128.252.203.2
12:40:49:WU01:FS01:Connecting to 128.252.203.2:8080
12:40:49:WARNING:WU00:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
12:40:50:ERROR:WU00:FS00:Exception: Could not get an assignment
12:40:50:WU00:FS00:Connecting to 65.254.110.245:8080
12:40:50:WU00:FS00:Assigned to work server 40.114.52.201
12:40:50:WU00:FS00:Requesting new work unit for slot 00: READY cpu:28 from 40.114.52.201
12:40:50:WU00:FS00:Connecting to 40.114.52.201:8080
12:40:54:12:127.0.0.1:New Web connection
12:41:10:WARNING:WU01:FS01:WorkServer connection failed on port 8080 trying 80
12:41:10:WU01:FS01:Connecting to 128.252.203.2:80
12:41:11:WARNING:WU00:FS00:WorkServer connection failed on port 8080 trying 80
12:41:11:WU00:FS00:Connecting to 40.114.52.201:80
12:41:31:ERROR:WU01:FS01:Exception: Failed to connect to 128.252.203.2:80: Anslutningsförsöket misslyckades eftersom den anslutna datorn inte svarade inom en viss tid eller på grund av att den etablerade anslutningen till värddatorn inte längre fungerar.
12:41:31:WU01:FS01:Connecting to 65.254.110.245:8080
12:41:32:WARNING:WU01:FS01:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
12:41:32:WU01:FS01:Connecting to 18.218.241.186:80
12:41:32:WARNING:WU01:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
12:41:32:ERROR:WU01:FS01:Exception: Could not get an assignment
12:41:48:WU00:FS00:Downloading 2.14MiB
12:41:54:WU00:FS00:Download 78.81%
12:41:55:WU00:FS00:Download complete
12:41:55:WU00:FS00:Received Unit: id:00 state:DOWNLOAD error:NO_ERROR project:13850 run:0 clone:1480 gen:20 core:0xa7 unit:0x0000001b287234c95e72594f94c6e5f4
12:41:55:WU00:FS00:Starting
12:41:55:WU00:FS00:Running FahCore: D:\Program\Folding\FAHClient/FAHCoreWrapper.exe D:\Program\Folding\Data\cores/cores.foldingathome.org/v7/win/64bit/avx/Core_a7.fah/FahCore_a7.exe -dir 00 -suffix 01 -version 705 -lifeline 13412 -checkpoint 15 -np 28
12:41:55:WU00:FS00:Started FahCore on PID 3064
12:41:56:WU00:FS00:Core PID:13788
12:41:56:WU00:FS00:FahCore 0xa7 started
12:41:56:WU00:FS00:0xa7:*********************** Log Started 2020-03-31T12:41:56Z ***********************
12:41:56:WU00:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
12:41:56:WU00:FS00:0xa7:       Type: 0xa7
12:41:56:WU00:FS00:0xa7:       Core: Gromacs
12:41:56:WU00:FS00:0xa7:       Args: -dir 00 -suffix 01 -version 705 -lifeline 3064 -checkpoint 15 -np
12:41:56:WU00:FS00:0xa7:             28
12:41:56:WU00:FS00:0xa7:************************************ CBang *************************************
12:41:56:WU00:FS00:0xa7:       Date: Oct 26 2019
12:41:56:WU00:FS00:0xa7:       Time: 01:38:25
12:41:56:WU00:FS00:0xa7:   Revision: c46a1a011a24143739ac7218c5a435f66777f62f
12:41:56:WU00:FS00:0xa7:     Branch: master
12:41:56:WU00:FS00:0xa7:   Compiler: Visual C++ 2008
12:41:56:WU00:FS00:0xa7:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
12:41:56:WU00:FS00:0xa7:   Platform: win32 10
12:41:56:WU00:FS00:0xa7:       Bits: 64
12:41:56:WU00:FS00:0xa7:       Mode: Release
12:41:56:WU00:FS00:0xa7:************************************ System ************************************
12:41:56:WU00:FS00:0xa7:        CPU: AMD Ryzen Threadripper 1950X 16-Core Processor
12:41:56:WU00:FS00:0xa7:     CPU ID: AuthenticAMD Family 23 Model 1 Stepping 1
12:41:56:WU00:FS00:0xa7:       CPUs: 32
12:41:56:WU00:FS00:0xa7:     Memory: 31.90GiB
12:41:56:WU00:FS00:0xa7:Free Memory: 26.81GiB
12:41:56:WU00:FS00:0xa7:    Threads: WINDOWS_THREADS
12:41:56:WU00:FS00:0xa7: OS Version: 6.2
12:41:56:WU00:FS00:0xa7:Has Battery: false
12:41:56:WU00:FS00:0xa7: On Battery: false
12:41:56:WU00:FS00:0xa7: UTC Offset: 2
12:41:56:WU00:FS00:0xa7:        PID: 13788
12:41:56:WU00:FS00:0xa7:        CWD: D:\Program\Folding\Data\work
12:41:56:WU00:FS00:0xa7:******************************** Build - libFAH ********************************
12:41:56:WU00:FS00:0xa7:    Version: 0.0.18
12:41:56:WU00:FS00:0xa7:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
12:41:56:WU00:FS00:0xa7:  Copyright: 2019 foldingathome.org
12:41:56:WU00:FS00:0xa7:   Homepage: https://foldingathome.org/
12:41:56:WU00:FS00:0xa7:       Time: 01:52:30
12:41:56:WU00:FS00:0xa7:   Revision: c1e3513b1bc0c16013668f2173ee969e5995b38e
12:41:56:WU00:FS00:0xa7:************************************ Build *************************************
12:41:56:WU00:FS00:0xa7:       SIMD: avx_256
12:41:56:WU00:FS00:0xa7:********************************************************************************
12:41:56:WU00:FS00:0xa7:Project: 13850 (Run 0, Clone 1480, Gen 20)
12:41:56:WU00:FS00:0xa7:Unit: 0x0000001b287234c95e72594f94c6e5f4
12:41:56:WU00:FS00:0xa7:Reading tar file core.xml
12:41:56:WU00:FS00:0xa7:Reading tar file frame20.tpr
12:41:56:WU00:FS00:0xa7:Digital signatures verified
12:41:56:WU00:FS00:0xa7:Calling: mdrun -s frame20.tpr -o frame20.trr -x frame20.xtc -e frame20.edr -cpt 15 -nt 28
12:41:56:WU00:FS00:0xa7:Steps: first=10000000 total=500000
12:41:57:WU00:FS00:0xa7:Completed 1 out of 500000 steps (0%)
12:42:31:WU01:FS01:Connecting to 65.254.110.245:8080
12:42:32:WARNING:WU01:FS01:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
12:42:32:WU01:FS01:Connecting to 18.218.241.186:80
12:42:32:WARNING:WU01:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
12:42:32:ERROR:WU01:FS01:Exception: Could not get an assignment
12:42:41:WU00:FS00:0xa7:Completed 5000 out of 500000 steps (1%)
12:43:24:WU00:FS00:0xa7:Completed 10000 out of 500000 steps (2%)
12:44:08:WU01:FS01:Connecting to 65.254.110.245:8080
12:44:08:WU00:FS00:0xa7:Completed 15000 out of 500000 steps (3%)
12:44:09:WARNING:WU01:FS01:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
12:44:09:WU01:FS01:Connecting to 18.218.241.186:80
12:44:09:WARNING:WU01:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
12:44:09:ERROR:WU01:FS01:Exception: Could not get an assignment
12:44:52:WU00:FS00:0xa7:Completed 20000 out of 500000 steps (4%)
12:45:35:WU00:FS00:0xa7:Completed 25000 out of 500000 steps (5%)
12:46:18:WU00:FS00:0xa7:Completed 30000 out of 500000 steps (6%)
12:46:45:WU01:FS01:Connecting to 65.254.110.245:8080
12:46:46:WARNING:WU01:FS01:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
12:46:46:WU01:FS01:Connecting to 18.218.241.186:80
12:46:46:WARNING:WU01:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
12:46:46:ERROR:WU01:FS01:Exception: Could not get an assignment
12:47:02:WU00:FS00:0xa7:Completed 35000 out of 500000 steps (7%)
12:47:46:WU00:FS00:0xa7:Completed 40000 out of 500000 steps (8%)
12:48:29:WU00:FS00:0xa7:Completed 45000 out of 500000 steps (9%)
12:49:13:WU00:FS00:0xa7:Completed 50000 out of 500000 steps (10%)
12:49:57:WU00:FS00:0xa7:Completed 55000 out of 500000 steps (11%)
12:50:40:WU00:FS00:0xa7:Completed 60000 out of 500000 steps (12%)
12:51:00:WU01:FS01:Connecting to 65.254.110.245:8080
12:51:00:WARNING:WU01:FS01:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
12:51:00:WU01:FS01:Connecting to 18.218.241.186:80
12:51:01:WARNING:WU01:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
12:51:01:ERROR:WU01:FS01:Exception: Could not get an assignment
12:51:24:WU00:FS00:0xa7:Completed 65000 out of 500000 steps (13%)
12:52:08:WU00:FS00:0xa7:Completed 70000 out of 500000 steps (14%)
12:52:51:WU00:FS00:0xa7:Completed 75000 out of 500000 steps (15%)
12:53:35:WU00:FS00:0xa7:Completed 80000 out of 500000 steps (16%)
12:54:19:WU00:FS00:0xa7:Completed 85000 out of 500000 steps (17%)
12:55:03:WU00:FS00:0xa7:Completed 90000 out of 500000 steps (18%)
12:55:46:WU00:FS00:0xa7:Completed 95000 out of 500000 steps (19%)
12:56:30:WU00:FS00:0xa7:Completed 100000 out of 500000 steps (20%)
12:57:14:WU00:FS00:0xa7:Completed 105000 out of 500000 steps (21%)
12:57:51:WU01:FS01:Connecting to 65.254.110.245:8080
12:57:52:WARNING:WU01:FS01:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
12:57:52:WU01:FS01:Connecting to 18.218.241.186:80
12:57:52:WARNING:WU01:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
12:57:52:ERROR:WU01:FS01:Exception: Could not get an assignment
12:57:57:WU00:FS00:0xa7:Completed 110000 out of 500000 steps (22%)
12:58:41:WU00:FS00:0xa7:Completed 115000 out of 500000 steps (23%)
12:59:24:WU00:FS00:0xa7:Completed 120000 out of 500000 steps (24%)
13:00:08:WU00:FS00:0xa7:Completed 125000 out of 500000 steps (25%)
13:00:51:WU00:FS00:0xa7:Completed 130000 out of 500000 steps (26%)
13:01:35:WU00:FS00:0xa7:Completed 135000 out of 500000 steps (27%)
13:02:18:WU00:FS00:0xa7:Completed 140000 out of 500000 steps (28%)
13:03:02:WU00:FS00:0xa7:Completed 145000 out of 500000 steps (29%)
13:03:45:WU00:FS00:0xa7:Completed 150000 out of 500000 steps (30%)
13:04:29:WU00:FS00:0xa7:Completed 155000 out of 500000 steps (31%)
13:05:12:WU00:FS00:0xa7:Completed 160000 out of 500000 steps (32%)
13:05:56:WU00:FS00:0xa7:Completed 165000 out of 500000 steps (33%)
13:06:39:WU00:FS00:0xa7:Completed 170000 out of 500000 steps (34%)
13:07:23:WU00:FS00:0xa7:Completed 175000 out of 500000 steps (35%)
13:08:06:WU00:FS00:0xa7:Completed 180000 out of 500000 steps (36%)
13:08:50:WU00:FS00:0xa7:Completed 185000 out of 500000 steps (37%)
13:08:56:WU01:FS01:Connecting to 65.254.110.245:8080
13:08:57:WARNING:WU01:FS01:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
13:08:57:WU01:FS01:Connecting to 18.218.241.186:80
13:08:58:WARNING:WU01:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
13:08:58:ERROR:WU01:FS01:Exception: Could not get an assignment
13:09:33:WU00:FS00:0xa7:Completed 190000 out of 500000 steps (38%)
13:10:17:WU00:FS00:0xa7:Completed 195000 out of 500000 steps (39%)
13:11:00:WU00:FS00:0xa7:Completed 200000 out of 500000 steps (40%)
13:11:44:WU00:FS00:0xa7:Completed 205000 out of 500000 steps (41%)
13:12:28:WU00:FS00:0xa7:Completed 210000 out of 500000 steps (42%)
13:13:11:WU00:FS00:0xa7:Completed 215000 out of 500000 steps (43%)
13:13:54:WU00:FS00:0xa7:Completed 220000 out of 500000 steps (44%)
13:14:38:WU00:FS00:0xa7:Completed 225000 out of 500000 steps (45%)
13:15:21:WU00:FS00:0xa7:Completed 230000 out of 500000 steps (46%)
13:16:04:WU00:FS00:0xa7:Completed 235000 out of 500000 steps (47%)
13:16:47:WU00:FS00:0xa7:Completed 240000 out of 500000 steps (48%)
13:17:30:WU00:FS00:0xa7:Completed 245000 out of 500000 steps (49%)
13:18:14:WU00:FS00:0xa7:Completed 250000 out of 500000 steps (50%)
13:18:57:WU00:FS00:0xa7:Completed 255000 out of 500000 steps (51%)
13:19:41:WU00:FS00:0xa7:Completed 260000 out of 500000 steps (52%)
13:20:24:WU00:FS00:0xa7:Completed 265000 out of 500000 steps (53%)
13:21:08:WU00:FS00:0xa7:Completed 270000 out of 500000 steps (54%)
13:21:52:WU00:FS00:0xa7:Completed 275000 out of 500000 steps (55%)
13:22:35:WU00:FS00:0xa7:Completed 280000 out of 500000 steps (56%)
13:23:19:WU00:FS00:0xa7:Completed 285000 out of 500000 steps (57%)
13:24:02:WU00:FS00:0xa7:Completed 290000 out of 500000 steps (58%)
13:24:46:WU00:FS00:0xa7:Completed 295000 out of 500000 steps (59%)
13:25:29:WU00:FS00:0xa7:Completed 300000 out of 500000 steps (60%)
13:26:13:WU00:FS00:0xa7:Completed 305000 out of 500000 steps (61%)
13:26:53:WU01:FS01:Connecting to 65.254.110.245:8080
13:26:54:WARNING:WU01:FS01:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
13:26:54:WU01:FS01:Connecting to 18.218.241.186:80
13:26:54:WARNING:WU01:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
13:26:54:ERROR:WU01:FS01:Exception: Could not get an assignment
13:26:57:WU00:FS00:0xa7:Completed 310000 out of 500000 steps (62%)
13:27:40:WU00:FS00:0xa7:Completed 315000 out of 500000 steps (63%)
13:28:24:WU00:FS00:0xa7:Completed 320000 out of 500000 steps (64%)
13:29:07:WU00:FS00:0xa7:Completed 325000 out of 500000 steps (65%)
13:29:51:WU00:FS00:0xa7:Completed 330000 out of 500000 steps (66%)
13:30:34:WU00:FS00:0xa7:Completed 335000 out of 500000 steps (67%)
13:31:18:WU00:FS00:0xa7:Completed 340000 out of 500000 steps (68%)
13:32:01:WU00:FS00:0xa7:Completed 345000 out of 500000 steps (69%)
13:32:45:WU00:FS00:0xa7:Completed 350000 out of 500000 steps (70%)
13:33:29:WU00:FS00:0xa7:Completed 355000 out of 500000 steps (71%)
13:34:12:WU00:FS00:0xa7:Completed 360000 out of 500000 steps (72%)
13:34:25:ERROR:Receive error: 10053: En etablerad anslutning avbröts av programvaran i värddatorn.
13:34:56:WU00:FS00:0xa7:Completed 365000 out of 500000 steps (73%)
13:35:39:WU00:FS00:0xa7:Completed 370000 out of 500000 steps (74%)
13:36:23:WU00:FS00:0xa7:Completed 375000 out of 500000 steps (75%)
13:37:06:WU00:FS00:0xa7:Completed 380000 out of 500000 steps (76%)
13:37:49:WU00:FS00:0xa7:Completed 385000 out of 500000 steps (77%)
13:38:32:WU00:FS00:0xa7:Completed 390000 out of 500000 steps (78%)
13:39:16:WU00:FS00:0xa7:Completed 395000 out of 500000 steps (79%)
13:39:59:WU00:FS00:0xa7:Completed 400000 out of 500000 steps (80%)
13:40:42:WU00:FS00:0xa7:Completed 405000 out of 500000 steps (81%)
13:41:25:WU00:FS00:0xa7:Completed 410000 out of 500000 steps (82%)
13:42:09:WU00:FS00:0xa7:Completed 415000 out of 500000 steps (83%)
13:42:52:WU00:FS00:0xa7:Completed 420000 out of 500000 steps (84%)
13:43:35:WU00:FS00:0xa7:Completed 425000 out of 500000 steps (85%)
13:44:18:WU00:FS00:0xa7:Completed 430000 out of 500000 steps (86%)
13:45:02:WU00:FS00:0xa7:Completed 435000 out of 500000 steps (87%)
13:45:45:WU00:FS00:0xa7:Completed 440000 out of 500000 steps (88%)
13:46:30:WU00:FS00:0xa7:Completed 445000 out of 500000 steps (89%)
13:47:14:WU00:FS00:0xa7:Completed 450000 out of 500000 steps (90%)
13:47:57:WU00:FS00:0xa7:Completed 455000 out of 500000 steps (91%)
13:48:40:WU00:FS00:0xa7:Completed 460000 out of 500000 steps (92%)
13:49:24:WU00:FS00:0xa7:Completed 465000 out of 500000 steps (93%)
13:50:07:WU00:FS00:0xa7:Completed 470000 out of 500000 steps (94%)
13:50:50:WU00:FS00:0xa7:Completed 475000 out of 500000 steps (95%)
13:51:33:WU00:FS00:0xa7:Completed 480000 out of 500000 steps (96%)
13:52:17:WU00:FS00:0xa7:Completed 485000 out of 500000 steps (97%)
13:53:00:WU00:FS00:0xa7:Completed 490000 out of 500000 steps (98%)
13:53:43:WU00:FS00:0xa7:Completed 495000 out of 500000 steps (99%)
13:53:44:WU02:FS00:Connecting to 65.254.110.245:8080
13:53:44:WARNING:WU02:FS00:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
13:53:44:WU02:FS00:Connecting to 18.218.241.186:80
13:53:45:WARNING:WU02:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
13:53:45:ERROR:WU02:FS00:Exception: Could not get an assignment
13:53:45:WU02:FS00:Connecting to 65.254.110.245:8080
13:53:46:WARNING:WU02:FS00:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
13:53:46:WU02:FS00:Connecting to 18.218.241.186:80
13:53:46:WARNING:WU02:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
13:53:46:ERROR:WU02:FS00:Exception: Could not get an assignment
13:54:27:WU00:FS00:0xa7:Completed 500000 out of 500000 steps (100%)
13:54:28:WU00:FS00:0xa7:Saving result file ..\logfile_01.txt
13:54:28:WU00:FS00:0xa7:Saving result file frame20.edr
13:54:28:WU00:FS00:0xa7:Saving result file frame20.trr
13:54:28:WU00:FS00:0xa7:Saving result file frame20.xtc
13:54:28:WU00:FS00:0xa7:Saving result file md.log
13:54:28:WU00:FS00:0xa7:Saving result file science.log
13:54:28:WU00:FS00:0xa7:Folding@home Core Shutdown: FINISHED_UNIT
13:54:29:WU00:FS00:FahCore returned: FINISHED_UNIT (100 = 0x64)
13:54:29:WU00:FS00:Sending unit results: id:00 state:SEND error:NO_ERROR project:13850 run:0 clone:1480 gen:20 core:0xa7 unit:0x0000001b287234c95e72594f94c6e5f4
13:54:29:WU00:FS00:Uploading 2.47MiB to 40.114.52.201
13:54:29:WU00:FS00:Connecting to 40.114.52.201:8080
13:54:42:WU00:FS00:Upload 7.60%
13:54:45:WU02:FS00:Connecting to 65.254.110.245:8080
13:54:46:WARNING:WU02:FS00:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
13:54:46:WU02:FS00:Connecting to 18.218.241.186:80
13:54:46:WARNING:WU02:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
13:54:46:ERROR:WU02:FS00:Exception: Could not get an assignment
13:54:52:WU00:FS00:Upload 30.41%
13:54:59:WU00:FS00:Upload 50.68%
13:55:05:WU00:FS00:Upload 65.89%
13:55:12:WU00:FS00:Upload 81.09%
13:55:18:WU00:FS00:Upload 91.23%
13:55:27:WU00:FS00:Upload complete
13:55:27:WU00:FS00:Server responded WORK_ACK (400)
13:55:27:WU00:FS00:Final credit estimate, 10066.00 points
13:55:27:WU00:FS00:Cleaning up
13:55:56:WU01:FS01:Connecting to 65.254.110.245:8080
13:55:56:WARNING:WU01:FS01:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
13:55:56:WU01:FS01:Connecting to 18.218.241.186:80
13:55:57:WU01:FS01:Assigned to work server 140.163.4.241
13:55:57:WU01:FS01:Requesting new work unit for slot 01: READY gpu:0:TU104 [GeForce RTX 2080] from 140.163.4.241
13:55:57:WU01:FS01:Connecting to 140.163.4.241:8080
13:56:04:WU01:FS01:Downloading 4.52MiB
13:56:10:WU01:FS01:Download 76.11%
13:56:11:WU01:FS01:Download complete
13:56:11:WU01:FS01:Received Unit: id:01 state:DOWNLOAD error:NO_ERROR project:11743 run:0 clone:6995 gen:16 core:0x22 unit:0x0000001b8ca304f15e6bc498a669fa6a
13:56:11:WU01:FS01:Starting
13:56:11:WU01:FS01:Running FahCore: D:\Program\Folding\FAHClient/FAHCoreWrapper.exe D:\Program\Folding\Data\cores/cores.foldingathome.org/v7/win/64bit/Core_22.fah/FahCore_22.exe -dir 01 -suffix 01 -version 705 -lifeline 13412 -checkpoint 15 -gpu-vendor nvidia -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu 0
13:56:11:WU01:FS01:Started FahCore on PID 12684
13:56:11:WU01:FS01:Core PID:10268
13:56:11:WU01:FS01:FahCore 0x22 started
13:56:11:WU01:FS01:0x22:*********************** Log Started 2020-03-31T13:56:11Z ***********************
13:56:11:WU01:FS01:0x22:*************************** Core22 Folding@home Core ***************************
13:56:11:WU01:FS01:0x22:       Type: 0x22
13:56:11:WU01:FS01:0x22:       Core: Core22
13:56:11:WU01:FS01:0x22:    Website: https://foldingathome.org/
13:56:11:WU01:FS01:0x22:  Copyright: (c) 2009-2018 foldingathome.org
13:56:11:WU01:FS01:0x22:     Author: John Chodera <john.chodera@choderalab.org> and Rafal Wiewiora
13:56:11:WU01:FS01:0x22:             <rafal.wiewiora@choderalab.org>
13:56:11:WU01:FS01:0x22:       Args: -dir 01 -suffix 01 -version 705 -lifeline 12684 -checkpoint 15
13:56:11:WU01:FS01:0x22:             -gpu-vendor nvidia -opencl-platform 0 -opencl-device 0 -cuda-device
13:56:11:WU01:FS01:0x22:             0 -gpu 0
13:56:11:WU01:FS01:0x22:     Config: <none>
13:56:11:WU01:FS01:0x22:************************************ Build *************************************
13:56:11:WU01:FS01:0x22:    Version: 0.0.2
13:56:11:WU01:FS01:0x22:       Date: Dec 6 2019
13:56:11:WU01:FS01:0x22:       Time: 21:30:31
13:56:11:WU01:FS01:0x22: Repository: Git
13:56:11:WU01:FS01:0x22:   Revision: abeb39247cc72df5af0f63723edafadb23d5dfbe
13:56:11:WU01:FS01:0x22:     Branch: HEAD
13:56:11:WU01:FS01:0x22:   Compiler: Visual C++ 2008
13:56:11:WU01:FS01:0x22:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
13:56:11:WU01:FS01:0x22:   Platform: win32 10
13:56:11:WU01:FS01:0x22:       Bits: 64
13:56:11:WU01:FS01:0x22:       Mode: Release
13:56:11:WU01:FS01:0x22:************************************ System ************************************
13:56:11:WU01:FS01:0x22:        CPU: AMD Ryzen Threadripper 1950X 16-Core Processor
13:56:11:WU01:FS01:0x22:     CPU ID: AuthenticAMD Family 23 Model 1 Stepping 1
13:56:11:WU01:FS01:0x22:       CPUs: 32
13:56:11:WU01:FS01:0x22:     Memory: 31.90GiB
13:56:11:WU01:FS01:0x22:Free Memory: 25.35GiB
13:56:11:WU01:FS01:0x22:    Threads: WINDOWS_THREADS
13:56:11:WU01:FS01:0x22: OS Version: 6.2
13:56:11:WU01:FS01:0x22:Has Battery: false
13:56:11:WU01:FS01:0x22: On Battery: false
13:56:11:WU01:FS01:0x22: UTC Offset: 2
13:56:11:WU01:FS01:0x22:        PID: 10268
13:56:11:WU01:FS01:0x22:        CWD: D:\Program\Folding\Data\work
13:56:11:WU01:FS01:0x22:         OS: Windows 10 Pro
13:56:11:WU01:FS01:0x22:    OS Arch: AMD64
13:56:11:WU01:FS01:0x22:********************************************************************************
13:56:11:WU01:FS01:0x22:Project: 11743 (Run 0, Clone 6995, Gen 16)
13:56:11:WU01:FS01:0x22:Unit: 0x0000001b8ca304f15e6bc498a669fa6a
13:56:11:WU01:FS01:0x22:Reading tar file core.xml
13:56:11:WU01:FS01:0x22:Reading tar file integrator.xml
13:56:11:WU01:FS01:0x22:Reading tar file state.xml
13:56:12:WU01:FS01:0x22:Reading tar file system.xml
13:56:12:WU01:FS01:0x22:Digital signatures verified
13:56:12:WU01:FS01:0x22:Folding@home GPU Core22 Folding@home Core
13:56:12:WU01:FS01:0x22:Version 0.0.2
13:56:18:WU01:FS01:0x22:Completed 0 out of 2000000 steps (0%)
13:56:18:WU01:FS01:0x22:Temperature control disabled. Requirements: single Nvidia GPU, tmax must be < 110 and twait >= 900
13:56:22:WU02:FS00:Connecting to 65.254.110.245:8080
13:56:23:WARNING:WU02:FS00:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
13:56:23:WU02:FS00:Connecting to 18.218.241.186:80
13:56:24:WARNING:WU02:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
13:56:24:ERROR:WU02:FS00:Exception: Could not get an assignment
13:57:04:WU01:FS01:0x22:Completed 20000 out of 2000000 steps (1%)
13:57:49:WU01:FS01:0x22:Completed 40000 out of 2000000 steps (2%)
13:58:36:WU01:FS01:0x22:Completed 60000 out of 2000000 steps (3%)
13:59:00:WU02:FS00:Connecting to 65.254.110.245:8080
13:59:00:WARNING:WU02:FS00:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
13:59:00:WU02:FS00:Connecting to 18.218.241.186:80
13:59:01:WARNING:WU02:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
13:59:01:ERROR:WU02:FS00:Exception: Could not get an assignment
13:59:22:WU01:FS01:0x22:Completed 80000 out of 2000000 steps (4%)
14:00:07:WU01:FS01:0x22:Completed 100000 out of 2000000 steps (5%)
14:00:54:WU01:FS01:0x22:Completed 120000 out of 2000000 steps (6%)
14:01:39:WU01:FS01:0x22:Completed 140000 out of 2000000 steps (7%)
14:02:27:WU01:FS01:0x22:Completed 160000 out of 2000000 steps (8%)
14:03:11:WU01:FS01:0x22:Completed 180000 out of 2000000 steps (9%)
14:03:14:WU02:FS00:Connecting to 65.254.110.245:8080
14:03:14:WARNING:WU02:FS00:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
14:03:14:WU02:FS00:Connecting to 18.218.241.186:80
14:03:15:WARNING:WU02:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
14:03:15:ERROR:WU02:FS00:Exception: Could not get an assignment
14:03:57:WU01:FS01:0x22:Completed 200000 out of 2000000 steps (10%)
14:04:44:WU01:FS01:0x22:Completed 220000 out of 2000000 steps (11%)
14:05:30:WU01:FS01:0x22:Completed 240000 out of 2000000 steps (12%)
14:06:17:WU01:FS01:0x22:Completed 260000 out of 2000000 steps (13%)
14:07:03:WU01:FS01:0x22:Completed 280000 out of 2000000 steps (14%)
14:07:48:WU01:FS01:0x22:Completed 300000 out of 2000000 steps (15%)
14:08:35:WU01:FS01:0x22:Completed 320000 out of 2000000 steps (16%)
14:09:20:WU01:FS01:0x22:Completed 340000 out of 2000000 steps (17%)
14:10:05:WU02:FS00:Connecting to 65.254.110.245:8080
14:10:06:WARNING:WU02:FS00:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
14:10:06:WU02:FS00:Connecting to 18.218.241.186:80
14:10:06:WARNING:WU02:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
14:10:06:ERROR:WU02:FS00:Exception: Could not get an assignment
14:10:08:WU01:FS01:0x22:Completed 360000 out of 2000000 steps (18%)
14:10:53:WU01:FS01:0x22:Completed 380000 out of 2000000 steps (19%)
14:11:38:WU01:FS01:0x22:Completed 400000 out of 2000000 steps (20%)
14:12:25:WU01:FS01:0x22:Completed 420000 out of 2000000 steps (21%)
14:13:11:WU01:FS01:0x22:Completed 440000 out of 2000000 steps (22%)
14:13:58:WU01:FS01:0x22:Completed 460000 out of 2000000 steps (23%)
14:14:43:WU01:FS01:0x22:Completed 480000 out of 2000000 steps (24%)
14:15:29:WU01:FS01:0x22:Completed 500000 out of 2000000 steps (25%)
14:16:16:WU01:FS01:0x22:Completed 520000 out of 2000000 steps (26%)
14:17:01:WU01:FS01:0x22:Completed 540000 out of 2000000 steps (27%)
14:17:49:WU01:FS01:0x22:Completed 560000 out of 2000000 steps (28%)
14:18:34:WU01:FS01:0x22:Completed 580000 out of 2000000 steps (29%)
14:19:19:WU01:FS01:0x22:Completed 600000 out of 2000000 steps (30%)
14:20:07:WU01:FS01:0x22:Completed 620000 out of 2000000 steps (31%)
14:20:52:WU01:FS01:0x22:Completed 640000 out of 2000000 steps (32%)
14:21:11:WU02:FS00:Connecting to 65.254.110.245:8080
14:21:11:WARNING:WU02:FS00:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
14:21:11:WU02:FS00:Connecting to 18.218.241.186:80
14:21:12:WARNING:WU02:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
14:21:12:ERROR:WU02:FS00:Exception: Could not get an assignment
14:21:39:WU01:FS01:0x22:Completed 660000 out of 2000000 steps (33%)
14:22:24:WU01:FS01:0x22:Completed 680000 out of 2000000 steps (34%)
14:23:10:WU01:FS01:0x22:Completed 700000 out of 2000000 steps (35%)
14:23:57:WU01:FS01:0x22:Completed 720000 out of 2000000 steps (36%)
14:24:42:WU01:FS01:0x22:Completed 740000 out of 2000000 steps (37%)
14:25:29:WU01:FS01:0x22:Completed 760000 out of 2000000 steps (38%)
14:26:15:WU01:FS01:0x22:Completed 780000 out of 2000000 steps (39%)
14:27:00:WU01:FS01:0x22:Completed 800000 out of 2000000 steps (40%)
14:27:47:WU01:FS01:0x22:Completed 820000 out of 2000000 steps (41%)
14:28:32:WU01:FS01:0x22:Completed 840000 out of 2000000 steps (42%)
14:29:20:WU01:FS01:0x22:Completed 860000 out of 2000000 steps (43%)
Re: Unable to run CPU wu and GPU wu at the same time
Folding@Home is just really busy now.
I am getting about 1/3 the PPD I used to, we just need F@H to get more servers, that takes time and money.
Simplex0
Post by Simplex0 »
Thank you JimboPalmer. You seams to be right, now I only have GPU wu's running on both my computers, no CPU work units.
Post by Neil-B »
Just a thought - and this may not be relevant to the availability of work issue - but your CPU slot configured at 28cores is a multiple of 7 - I have seen a number of threads discussing "large prime numbers" and issues this can cause large seems to mainly be 7 or greater but 5 is also advised against ... iirc dropping the cores on that slot to 24 would be the advisable course of action ... I and sure one of the more technical will be able to confirm if this is the case.
Simplex0
Post by Simplex0 »
Thank you Neil-B.
I will try 24 and 27 tomorrow and try to dig in to this a little deeper.
Post by Neil-B »
Apologies … Mind storm on my part - I totally forgot 27 was fine !!
Simplex0
Post by Simplex0 »
Looks like I found a fix.
In my firewall settings I have 2 rows with the application "fahclien", one row had only the 'Private' check box marked and the other row had only the 'Public' check box marked.
I changed this and marked all the check boxes and restarted folding and so fare so good, now it download work units and run on the CPU and GPU at the same time.
The installation of folding under Windows 10 is a complete mess.
When I first try to install the new version of folding it would not complete the installation so I try to uninstall the folding application which did not work either.
Then I manually removed the application and dig in to the Register and removed everything I could find connected to folding and finally after a very long installation process I finally got the new folding application installed.
I guess the firewall settings got mixed upp during this process.
Thankfully everything works ok now.
Simplex0
Post by Simplex0 »
Nopp! I spoke too soon.
I guess the main problem is that it is not wu's enough.
