Whilst I can't retrieve the specific details of which WUs they are (closed the client since then) I know that my client (+1 other using the same user info) has completed 2 WUs (and potentially 3) in the last 24 hours, but they don't appear to have registered anywhere.
I just wanted to make sure that the returned completed units aren't going missing somewhere, amidst this surge in folding interest recently.
Username - ~Jinx~ (user 719959)
Team - Custom PC & Bit-Tech (35947)
Any assistance is gratefully received!
*********************** Log Started 2020-03-31T07:07:11Z ***********************
07:07:11:************************* Folding@home Client *************************
07:07:11: Website: https://foldingathome.org/
07:07:11: Copyright: (c) 2009-2018 foldingathome.org
07:07:11: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
07:07:11: Args:
07:07:11: Config: C:\Users\j.chester\AppData\Roaming\FAHClient\config.xml
07:07:11:******************************** Build ********************************
07:07:11: Version: 7.5.1
07:07:11: Date: May 11 2018
07:07:11: Time: 13:06:32
07:07:11: Repository: Git
07:07:11: Revision: 4705bf53c635f88b8fe85af7675557e15d491ff0
07:07:11: Branch: master
07:07:11: Compiler: Visual C++ 2008
07:07:11: Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
07:07:11: Platform: win32 10
07:07:11: Bits: 32
07:07:11: Mode: Release
07:07:11:******************************* System ********************************
07:07:11: CPU: Intel(R) Core(TM) i7-6700 CPU @ 3.40GHz
07:07:11: CPU ID: GenuineIntel Family 6 Model 94 Stepping 3
07:07:11: CPUs: 8
07:07:11: Memory: 15.89GiB
07:07:11: Free Memory: 12.93GiB
07:07:11: Threads: WINDOWS_THREADS
07:07:11: OS Version: 6.2
07:07:11: Has Battery: false
07:07:11: On Battery: false
07:07:11: UTC Offset: 1
07:07:11: PID: 13020
07:07:11: CWD: C:\Users\j.chester\AppData\Roaming\FAHClient
07:07:11: OS: Windows 10 Enterprise
07:07:11: OS Arch: AMD64
07:07:11: GPUs: 1
07:07:11: GPU 0: Bus:1 Slot:0 Func:0 NVIDIA:7 GP107GL [Quadro P1000]
07:07:11: CUDA Device 0: Platform:0 Device:0 Bus:1 Slot:0 Compute:6.1 Driver:10.2
07:07:11:OpenCL Device 0: Platform:0 Device:0 Bus:NA Slot:NA Compute:2.1 Driver:26.20
07:07:11:OpenCL Device 2: Platform:1 Device:0 Bus:1 Slot:0 Compute:1.2 Driver:441.12
07:07:11: Win32 Service: false
07:07:11:***********************************************************************
