GPU won't start folding
dkro
Post by dkro »
Hi all, Two days ago I joined Folding@home. I'm sorry if I miss something here.
I have problem that my CPU is folding fine but my GPU won't start folding at all.
My colleague who joined today has no problems and his CPU and GPU is folding both fine.
Could you help me find where is problem that my GPU is not folding?
11:13:00:WU01:FS00:0xa7:*********************** Log Started 2020-03-31T11:13:00Z ***********************
11:13:00:WU01:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
11:13:00:WU01:FS00:0xa7:       Type: 0xa7
11:13:00:WU01:FS00:0xa7:       Core: Gromacs
11:13:00:WU01:FS00:0xa7:       Args: -dir 01 -suffix 01 -version 705 -lifeline 21008 -checkpoint 15 -np
11:13:00:WU01:FS00:0xa7:             1
11:13:00:WU01:FS00:0xa7:************************************ CBang *************************************
11:13:00:WU01:FS00:0xa7:       Date: Nov 5 2019
11:13:00:WU01:FS00:0xa7:       Time: 06:06:57
11:13:00:WU01:FS00:0xa7:   Revision: 46c96f1aa8419571d83f3e63f9c99a0d602f6da9
11:13:00:WU01:FS00:0xa7:     Branch: master
11:13:00:WU01:FS00:0xa7:   Compiler: GNU 8.3.0
11:13:00:WU01:FS00:0xa7:    Options: -std=c++11 -O3 -funroll-loops -fno-pie -fPIC
11:13:00:WU01:FS00:0xa7:   Platform: linux2 4.19.0-5-amd64
11:13:00:WU01:FS00:0xa7:       Bits: 64
11:13:00:WU01:FS00:0xa7:       Mode: Release
11:13:00:WU01:FS00:0xa7:************************************ System ************************************
11:13:00:WU01:FS00:0xa7:        CPU: Intel(R) Core(TM) i5-4570 CPU @ 3.20GHz
11:13:00:WU01:FS00:0xa7:     CPU ID: GenuineIntel Family 6 Model 60 Stepping 3
11:13:00:WU01:FS00:0xa7:       CPUs: 4
11:13:00:WU01:FS00:0xa7:     Memory: 15.60GiB
11:13:00:WU01:FS00:0xa7:Free Memory: 687.03MiB
11:13:00:WU01:FS00:0xa7:    Threads: POSIX_THREADS
11:13:00:WU01:FS00:0xa7: OS Version: 4.15
11:13:00:WU01:FS00:0xa7:Has Battery: false
11:13:00:WU01:FS00:0xa7: On Battery: false
11:13:00:WU01:FS00:0xa7: UTC Offset: 2
11:13:00:WU01:FS00:0xa7:        PID: 21015
11:13:00:WU01:FS00:0xa7:        CWD: /root/snap/folding-at-home-fcole90/11/work
11:13:00:WU01:FS00:0xa7:******************************** Build - libFAH ********************************
11:13:00:WU01:FS00:0xa7:    Version: 0.0.18
11:13:00:WU01:FS00:0xa7:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
11:13:00:WU01:FS00:0xa7:  Copyright: 2019 foldingathome.org
11:13:00:WU01:FS00:0xa7:   Homepage: https://foldingathome.org/
11:13:00:WU01:FS00:0xa7:       Time: 06:13:26
11:13:00:WU01:FS00:0xa7:   Revision: 490c9aa2957b725af319379424d5c5cb36efb656
11:13:00:WU01:FS00:0xa7:************************************ Build *************************************
11:13:00:WU01:FS00:0xa7:       SIMD: avx_256
11:13:00:WU01:FS00:0xa7:********************************************************************************
11:13:00:WU01:FS00:0xa7:Project: 14406 (Run 0, Clone 650, Gen 23)
11:13:00:WU01:FS00:0xa7:Unit: 0x0000001b80fccb095e6e434fc325e758
11:13:00:WU01:FS00:0xa7:Digital signatures verified
11:13:00:WU01:FS00:0xa7:Calling: mdrun -s frame23.tpr -o frame23.trr -x frame23.xtc -cpi state.cpt -cpt 15 -nt 1
11:13:00:WU01:FS00:0xa7:Steps: first=2875000 total=125000
11:13:02:WU01:FS00:0xa7:Completed 10002 out of 125000 steps (8%)
11:13:04:Removing old file 'configs/config-20200330-194805.xml'
11:13:04:Saving configuration to config.xml
11:13:04:<config>
11:13:04:  <!-- Network -->
11:13:04:  <proxy v=':8080'/>
11:13:04:
11:13:04:  <!-- Slot Control -->
11:13:04:  <pause-on-battery v='false'/>
11:13:04:
11:13:04:  <!-- User Information -->
11:13:04:  <team v='255832'/>
11:13:04:  <user v='dkro'/>
11:13:04:
11:13:04:  <!-- Folding Slots -->
11:13:04:  <slot id='0' type='CPU'/>
11:13:04:  <slot id='1' type='GPU'/>
11:13:04:</config>
11:14:37:WU00:FS01:Connecting to 65.254.110.245:8080
11:14:38:WU00:FS01:Assigned to work server 192.0.2.1
11:14:38:WU00:FS01:Requesting new work unit for slot 01: READY gpu:0:Barts LE [Radeon HD 6700 Series] from 192.0.2.1
11:14:38:WU00:FS01:Connecting to 192.0.2.1:8080
11:14:51:FS00:Shutting core down
11:14:51:WU01:FS00:0xa7:Caught signal SIGINT(2) on PID 21015
11:14:51:WU01:FS00:0xa7:Exiting, please wait. . .
11:14:54:WU01:FS00:0xa7:Folding@home Core Shutdown: INTERRUPTED
11:14:54:WU01:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
11:14:54:WU01:FS00:Starting
11:14:54:WARNING:WU01:FS00:Changed SMP threads from 2 to 1 this can cause some work units to fail
11:14:54:WU01:FS00:Running FahCore: /snap/folding-at-home-fcole90/11/usr/bin/FAHCoreWrapper /root/snap/folding-at-home-fcole90/11/cores/cores.foldingathome.org/v7/lin/64bit/avx/Core_a7.fah/FahCore_a7 -dir 01 -suffix 01 -version 705 -lifeline 1446 -checkpoint 15 -np 1
11:14:54:WU01:FS00:Started FahCore on PID 25904
11:14:54:WU01:FS00:Core PID:25915
11:14:54:WU01:FS00:FahCore 0xa7 started
11:14:55:WU01:FS00:0xa7:*********************** Log Started 2020-03-31T11:14:54Z ***********************
11:14:55:WU01:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
11:14:55:WU01:FS00:0xa7:       Type: 0xa7
11:14:55:WU01:FS00:0xa7:       Core: Gromacs
11:14:55:WU01:FS00:0xa7:       Args: -dir 01 -suffix 01 -version 705 -lifeline 25904 -checkpoint 15 -np
11:14:55:WU01:FS00:0xa7:             1
11:14:55:WU01:FS00:0xa7:************************************ CBang *************************************
11:14:55:WU01:FS00:0xa7:       Date: Nov 5 2019
11:14:55:WU01:FS00:0xa7:       Time: 06:06:57
11:14:55:WU01:FS00:0xa7:   Revision: 46c96f1aa8419571d83f3e63f9c99a0d602f6da9
11:14:55:WU01:FS00:0xa7:     Branch: master
11:14:55:WU01:FS00:0xa7:   Compiler: GNU 8.3.0
11:14:55:WU01:FS00:0xa7:    Options: -std=c++11 -O3 -funroll-loops -fno-pie -fPIC
11:14:55:WU01:FS00:0xa7:   Platform: linux2 4.19.0-5-amd64
11:14:55:WU01:FS00:0xa7:       Bits: 64
11:14:55:WU01:FS00:0xa7:       Mode: Release
11:14:55:WU01:FS00:0xa7:************************************ System ************************************
11:14:55:WU01:FS00:0xa7:        CPU: Intel(R) Core(TM) i5-4570 CPU @ 3.20GHz
11:14:55:WU01:FS00:0xa7:     CPU ID: GenuineIntel Family 6 Model 60 Stepping 3
11:14:55:WU01:FS00:0xa7:       CPUs: 4
11:14:55:WU01:FS00:0xa7:     Memory: 15.60GiB
11:14:55:WU01:FS00:0xa7:Free Memory: 2.54GiB
11:14:55:WU01:FS00:0xa7:    Threads: POSIX_THREADS
11:14:55:WU01:FS00:0xa7: OS Version: 4.15
11:14:55:WU01:FS00:0xa7:Has Battery: false
11:14:55:WU01:FS00:0xa7: On Battery: false
11:14:55:WU01:FS00:0xa7: UTC Offset: 2
11:14:55:WU01:FS00:0xa7:        PID: 25915
11:14:55:WU01:FS00:0xa7:        CWD: /root/snap/folding-at-home-fcole90/11/work
11:14:55:WU01:FS00:0xa7:******************************** Build - libFAH ********************************
11:14:55:WU01:FS00:0xa7:    Version: 0.0.18
11:14:55:WU01:FS00:0xa7:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
11:14:55:WU01:FS00:0xa7:  Copyright: 2019 foldingathome.org
11:14:55:WU01:FS00:0xa7:   Homepage: https://foldingathome.org/
11:14:55:WU01:FS00:0xa7:       Time: 06:13:26
11:14:55:WU01:FS00:0xa7:   Revision: 490c9aa2957b725af319379424d5c5cb36efb656
11:14:55:WU01:FS00:0xa7:************************************ Build *************************************
11:14:55:WU01:FS00:0xa7:       SIMD: avx_256
11:14:55:WU01:FS00:0xa7:********************************************************************************
11:14:55:WU01:FS00:0xa7:Project: 14406 (Run 0, Clone 650, Gen 23)
11:14:55:WU01:FS00:0xa7:Unit: 0x0000001b80fccb095e6e434fc325e758
11:14:55:WU01:FS00:0xa7:Digital signatures verified
11:14:55:WU01:FS00:0xa7:Calling: mdrun -s frame23.tpr -o frame23.trr -x frame23.xtc -cpi state.cpt -cpt 15 -nt 1
11:14:55:WU01:FS00:0xa7:Steps: first=2875000 total=125000
11:14:56:WU01:FS00:0xa7:Completed 10362 out of 125000 steps (8%)
11:15:06:Removing old file 'configs/config-20200330-214338.xml'
11:15:06:Saving configuration to config.xml
11:15:06:<config>
11:15:06:  <!-- Network -->
11:15:06:  <proxy v=':8080'/>
11:15:06:
11:15:06:  <!-- Slot Control -->
11:15:06:  <pause-on-battery v='false'/>
11:15:06:  <power v='light'/>
11:15:06:
11:15:06:  <!-- User Information -->
11:15:06:  <team v='255832'/>
11:15:06:  <user v='dkro'/>
11:15:06:
11:15:06:  <!-- Folding Slots -->
11:15:06:  <slot id='0' type='CPU'/>
11:15:06:  <slot id='1' type='GPU'/>
11:15:06:</config>
11:15:09:98:127.0.0.1 GET /api/updates?_=1585641204914&sid=5b0a128a2c36f1d491b19fb3a440a0b0
11:16:47:98:127.0.0.1 GET /api/updates?_=1585641204994&sid=5b0a128a2c36f1d491b19fb3a440a0b0
11:16:48:WARNING:WU00:FS01:WorkServer connection failed on port 8080 trying 80
11:16:48:WU00:FS01:Connecting to 192.0.2.1:80
11:16:48:98:127.0.0.1 GET /api/updates?_=1585641204995&sid=5b0a128a2c36f1d491b19fb3a440a0b0
11:17:18:99:127.0.0.1 GET /api/updates?_=1585641205013&sid=5b0a128a2c36f1d491b19fb3a440a0b0
11:18:59:ERROR:WU00:FS01:Exception: Failed to connect to 192.0.2.1:80: Connection timed out
11:19:10:WU01:FS00:0xa7:Completed 11250 out of 125000 steps (9%)
11:25:20:WU01:FS00:0xa7:Completed 12500 out of 125000 steps (10%)
11:31:22:WU01:FS00:0xa7:Completed 13750 out of 125000 steps (11%)
11:37:20:WU01:FS00:0xa7:Completed 15000 out of 125000 steps (12%)
11:44:02:WU01:FS00:0xa7:Completed 16250 out of 125000 steps (13%)
11:49:58:WU01:FS00:0xa7:Completed 17500 out of 125000 steps (14%)
11:51:14:FS00:Shutting core down
11:51:14:WU00:FS01:Connecting to 65.254.110.245:8080
11:51:14:WU01:FS00:0xa7:Caught signal SIGINT(2) on PID 25915
11:51:14:WU01:FS00:0xa7:Exiting, please wait. . .
11:51:14:WU00:FS01:Assigned to work server 192.0.2.1
11:51:14:WU00:FS01:Requesting new work unit for slot 01: READY gpu:0:Barts LE [Radeon HD 6700 Series] from 192.0.2.1
11:51:14:WU00:FS01:Connecting to 192.0.2.1:8080
11:51:18:WU01:FS00:0xa7:Folding@home Core Shutdown: INTERRUPTED
11:51:19:WU01:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
11:51:19:WU01:FS00:Starting
11:51:19:WARNING:WU01:FS00:Changed SMP threads from 1 to 3 this can cause some work units to fail
11:51:19:WARNING:WU01:FS00:AS lowered CPUs from 3 to 1
11:51:19:WU01:FS00:Running FahCore: /snap/folding-at-home-fcole90/11/usr/bin/FAHCoreWrapper /root/snap/folding-at-home-fcole90/11/cores/cores.foldingathome.org/v7/lin/64bit/avx/Core_a7.fah/FahCore_a7 -dir 01 -suffix 01 -version 705 -lifeline 1446 -checkpoint 15 -np 1
11:51:19:WU01:FS00:Started FahCore on PID 16414
11:51:19:WU01:FS00:Core PID:16418
11:51:19:WU01:FS00:FahCore 0xa7 started
11:51:20:WU01:FS00:0xa7:*********************** Log Started 2020-03-31T11:51:19Z ***********************
11:51:20:WU01:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
11:51:20:WU01:FS00:0xa7:       Type: 0xa7
11:51:20:WU01:FS00:0xa7:       Core: Gromacs
11:51:20:WU01:FS00:0xa7:       Args: -dir 01 -suffix 01 -version 705 -lifeline 16414 -checkpoint 15 -np
11:51:20:WU01:FS00:0xa7:             1
11:51:20:WU01:FS00:0xa7:************************************ CBang *************************************
11:51:20:WU01:FS00:0xa7:       Date: Nov 5 2019
11:51:20:WU01:FS00:0xa7:       Time: 06:06:57
11:51:20:WU01:FS00:0xa7:   Revision: 46c96f1aa8419571d83f3e63f9c99a0d602f6da9
11:51:20:WU01:FS00:0xa7:     Branch: master
11:51:20:WU01:FS00:0xa7:   Compiler: GNU 8.3.0
11:51:20:WU01:FS00:0xa7:    Options: -std=c++11 -O3 -funroll-loops -fno-pie -fPIC
11:51:20:WU01:FS00:0xa7:   Platform: linux2 4.19.0-5-amd64
11:51:20:WU01:FS00:0xa7:       Bits: 64
11:51:20:WU01:FS00:0xa7:       Mode: Release
11:51:20:WU01:FS00:0xa7:************************************ System ************************************
11:51:20:WU01:FS00:0xa7:        CPU: Intel(R) Core(TM) i5-4570 CPU @ 3.20GHz
11:51:20:WU01:FS00:0xa7:     CPU ID: GenuineIntel Family 6 Model 60 Stepping 3
11:51:20:WU01:FS00:0xa7:       CPUs: 4
11:51:20:WU01:FS00:0xa7:     Memory: 15.60GiB
11:51:20:WU01:FS00:0xa7:Free Memory: 2.19GiB
11:51:20:WU01:FS00:0xa7:    Threads: POSIX_THREADS
11:51:20:WU01:FS00:0xa7: OS Version: 4.15
11:51:20:WU01:FS00:0xa7:Has Battery: false
11:51:20:WU01:FS00:0xa7: On Battery: false
11:51:20:WU01:FS00:0xa7: UTC Offset: 2
11:51:20:WU01:FS00:0xa7:        PID: 16418
11:51:20:WU01:FS00:0xa7:        CWD: /root/snap/folding-at-home-fcole90/11/work
11:51:20:WU01:FS00:0xa7:******************************** Build - libFAH ********************************
11:51:20:WU01:FS00:0xa7:    Version: 0.0.18
11:51:20:WU01:FS00:0xa7:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
11:51:20:WU01:FS00:0xa7:  Copyright: 2019 foldingathome.org
11:51:20:WU01:FS00:0xa7:   Homepage: https://foldingathome.org/
11:51:20:WU01:FS00:0xa7:       Time: 06:13:26
11:51:20:WU01:FS00:0xa7:   Revision: 490c9aa2957b725af319379424d5c5cb36efb656
11:51:20:WU01:FS00:0xa7:************************************ Build *************************************
11:51:20:WU01:FS00:0xa7:       SIMD: avx_256
11:51:20:WU01:FS00:0xa7:********************************************************************************
11:51:20:WU01:FS00:0xa7:Project: 14406 (Run 0, Clone 650, Gen 23)
11:51:20:WU01:FS00:0xa7:Unit: 0x0000001b80fccb095e6e434fc325e758
11:51:20:WU01:FS00:0xa7:Digital signatures verified
11:51:20:WU01:FS00:0xa7:Calling: mdrun -s frame23.tpr -o frame23.trr -x frame23.xtc -cpi state.cpt -cpt 15 -nt 1
11:51:20:WU01:FS00:0xa7:Steps: first=2875000 total=125000
11:51:21:WU01:FS00:0xa7:Completed 17782 out of 125000 steps (14%)
11:51:42:Removing old file 'configs/config-20200331-045516.xml'
11:51:42:Saving configuration to config.xml
11:51:42:<config>
11:51:42:  <!-- Network -->
11:51:42:  <proxy v=':8080'/>
11:51:42:
11:51:42:  <!-- Slot Control -->
11:51:42:  <pause-on-battery v='false'/>
11:51:42:  <power v='full'/>
11:51:42:
11:51:42:  <!-- User Information -->
11:51:42:  <team v='255832'/>
11:51:42:  <user v='dkro'/>
11:51:42:
11:51:42:  <!-- Folding Slots -->
11:51:42:  <slot id='0' type='CPU'/>
11:51:42:  <slot id='1' type='GPU'/>
11:51:42:</config>
11:53:24:WARNING:WU00:FS01:WorkServer connection failed on port 8080 trying 80
11:53:24:WU00:FS01:Connecting to 192.0.2.1:80
11:55:35:ERROR:WU00:FS01:Exception: Failed to connect to 192.0.2.1:80: Connection timed out
11:55:49:WU01:FS00:0xa7:Completed 18750 out of 125000 steps (15%)
12:01:34:WU01:FS00:0xa7:Completed 20000 out of 125000 steps (16%)
******************************* Date: 2020-03-31 *******************************
12:07:19:WU01:FS00:0xa7:Completed 21250 out of 125000 steps (17%)
12:13:04:WU01:FS00:0xa7:Completed 22500 out of 125000 steps (18%)
12:19:01:WU01:FS00:0xa7:Completed 23750 out of 125000 steps (19%)
12:20:16:WU00:FS01:Connecting to 65.254.110.245:8080
12:20:16:WU00:FS01:Assigned to work server 192.0.2.1
12:20:16:WU00:FS01:Requesting new work unit for slot 01: READY gpu:0:Barts LE [Radeon HD 6700 Series] from 192.0.2.1
12:20:16:WU00:FS01:Connecting to 192.0.2.1:8080
12:22:27:WARNING:WU00:FS01:WorkServer connection failed on port 8080 trying 80
12:22:27:WU00:FS01:Connecting to 192.0.2.1:80
12:24:38:ERROR:WU00:FS01:Exception: Failed to connect to 192.0.2.1:80: Connection timed out
12:24:50:WU01:FS00:0xa7:Completed 25000 out of 125000 steps (20%)
12:30:39:WU01:FS00:0xa7:Completed 26250 out of 125000 steps (21%)
12:34:28:FS00:Shutting core down
12:34:28:WU01:FS00:0xa7:Caught signal SIGINT(2) on PID 16418
12:34:28:WU01:FS00:0xa7:Exiting, please wait. . .
12:34:33:WU01:FS00:0xa7:Folding@home Core Shutdown: INTERRUPTED
12:34:34:WU01:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
12:34:34:WU01:FS00:Starting
12:34:34:WARNING:WU01:FS00:Changed SMP threads from 3 to 2 this can cause some work units to fail
12:34:34:WARNING:WU01:FS00:AS lowered CPUs from 2 to 1
12:34:34:WU01:FS00:Running FahCore: /snap/folding-at-home-fcole90/11/usr/bin/FAHCoreWrapper /root/snap/folding-at-home-fcole90/11/cores/cores.foldingathome.org/v7/lin/64bit/avx/Core_a7.fah/FahCore_a7 -dir 01 -suffix 01 -version 705 -lifeline 1446 -checkpoint 15 -np 1
12:34:34:WU01:FS00:Started FahCore on PID 19583
12:34:34:WU01:FS00:Core PID:19587
12:34:34:WU01:FS00:FahCore 0xa7 started
12:34:35:WU01:FS00:0xa7:*********************** Log Started 2020-03-31T12:34:34Z ***********************
12:34:35:WU01:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
12:34:35:WU01:FS00:0xa7:       Type: 0xa7
12:34:35:WU01:FS00:0xa7:       Core: Gromacs
12:34:35:WU01:FS00:0xa7:       Args: -dir 01 -suffix 01 -version 705 -lifeline 19583 -checkpoint 15 -np
12:34:35:WU01:FS00:0xa7:             1
12:34:35:WU01:FS00:0xa7:************************************ CBang *************************************
12:34:35:WU01:FS00:0xa7:       Date: Nov 5 2019
12:34:35:WU01:FS00:0xa7:       Time: 06:06:57
12:34:35:WU01:FS00:0xa7:   Revision: 46c96f1aa8419571d83f3e63f9c99a0d602f6da9
12:34:35:WU01:FS00:0xa7:     Branch: master
12:34:35:WU01:FS00:0xa7:   Compiler: GNU 8.3.0
12:34:35:WU01:FS00:0xa7:    Options: -std=c++11 -O3 -funroll-loops -fno-pie -fPIC
12:34:35:WU01:FS00:0xa7:   Platform: linux2 4.19.0-5-amd64
12:34:35:WU01:FS00:0xa7:       Bits: 64
12:34:35:WU01:FS00:0xa7:       Mode: Release
12:34:35:WU01:FS00:0xa7:************************************ System ************************************
12:34:35:WU01:FS00:0xa7:        CPU: Intel(R) Core(TM) i5-4570 CPU @ 3.20GHz
12:34:35:WU01:FS00:0xa7:     CPU ID: GenuineIntel Family 6 Model 60 Stepping 3
12:34:35:WU01:FS00:0xa7:       CPUs: 4
12:34:35:WU01:FS00:0xa7:     Memory: 15.60GiB
12:34:35:WU01:FS00:0xa7:Free Memory: 1.99GiB
12:34:35:WU01:FS00:0xa7:    Threads: POSIX_THREADS
12:34:35:WU01:FS00:0xa7: OS Version: 4.15
12:34:35:WU01:FS00:0xa7:Has Battery: false
12:34:35:WU01:FS00:0xa7: On Battery: false
12:34:35:WU01:FS00:0xa7: UTC Offset: 2
12:34:35:WU01:FS00:0xa7:        PID: 19587
12:34:35:WU01:FS00:0xa7:        CWD: /root/snap/folding-at-home-fcole90/11/work
12:34:35:WU01:FS00:0xa7:******************************** Build - libFAH ********************************
12:34:35:WU01:FS00:0xa7:    Version: 0.0.18
12:34:35:WU01:FS00:0xa7:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
12:34:35:WU01:FS00:0xa7:  Copyright: 2019 foldingathome.org
12:34:35:WU01:FS00:0xa7:   Homepage: https://foldingathome.org/
12:34:35:WU01:FS00:0xa7:       Time: 06:13:26
12:34:35:WU01:FS00:0xa7:   Revision: 490c9aa2957b725af319379424d5c5cb36efb656
12:34:35:WU01:FS00:0xa7:************************************ Build *************************************
12:34:35:WU01:FS00:0xa7:       SIMD: avx_256
12:34:35:WU01:FS00:0xa7:********************************************************************************
12:34:35:WU01:FS00:0xa7:Project: 14406 (Run 0, Clone 650, Gen 23)
12:34:35:WU01:FS00:0xa7:Unit: 0x0000001b80fccb095e6e434fc325e758
12:34:35:WU01:FS00:0xa7:Digital signatures verified
12:34:35:WU01:FS00:0xa7:Calling: mdrun -s frame23.tpr -o frame23.trr -x frame23.xtc -cpi state.cpt -cpt 15 -nt 1
12:34:35:WU01:FS00:0xa7:Steps: first=2875000 total=125000
12:34:36:WU01:FS00:0xa7:Completed 27062 out of 125000 steps (21%)
12:35:25:Removing old file 'configs/config-20200331-051435.xml'
12:35:25:Saving configuration to config.xml
12:35:25:<config>
12:35:25:  <!-- Network -->
12:35:25:  <proxy v=':8080'/>
12:35:25:
12:35:25:  <!-- Slot Control -->
12:35:25:  <pause-on-battery v='false'/>
12:35:25:
12:35:25:  <!-- User Information -->
12:35:25:  <team v='255832'/>
12:35:25:  <user v='dkro'/>
12:35:25:
12:35:25:  <!-- Folding Slots -->
12:35:25:  <slot id='0' type='CPU'/>
12:35:25:  <slot id='1' type='GPU'/>
12:35:25:</config>
12:36:46:WU01:FS00:0xa7:Completed 27500 out of 125000 steps (22%)
12:41:05:100:127.0.0.1 GET /api/updates?_=1585641205015&sid=5b0a128a2c36f1d491b19fb3a440a0b0
12:41:06:103:127.0.0.1 GET /?nocache=0.7567738462693135
12:41:06:104:127.0.0.1 GET /api/updates?_=1585641205016&sid=5b0a128a2c36f1d491b19fb3a440a0b0
12:41:06:105:127.0.0.1 GET /css/normalize.css
12:41:06:106:127.0.0.1 GET /css/main.css
12:41:06:107:127.0.0.1 GET /js/jquery-1.10.2.min.js
12:41:06:108:127.0.0.1 GET /js/libs/jquery.selectbox-0.2.js
12:41:06:109:127.0.0.1 GET /js/intercom.min.js
12:41:06:110:127.0.0.1 GET /js/main.js
12:41:06:110:127.0.0.1:New Web connection
12:41:07:111:127.0.0.1 GET /images/mail.png
12:41:07:112:127.0.0.1 GET /images/facebook.png
12:41:07:113:127.0.0.1 GET /images/twitter.png
12:41:07:114:127.0.0.1 GET /images/report-bug.png
12:41:07:115:127.0.0.1 GET /images/template/bg.jpg
12:41:07:116:127.0.0.1 GET /images/template/logo_folding_home.png
12:41:08:117:127.0.0.1 GET /api/updates/set?_=1585658467091&sid=07b503bb17764a36c826eb4231a4731e&update_id=0&update_path=/api/basic&update_rate=1
12:41:08:118:127.0.0.1 GET /api/updates/set?_=1585658467092&sid=07b503bb17764a36c826eb4231a4731e&update_id=1&update_path=/api/slots&update_rate=1
12:41:08:119:127.0.0.1 GET /api/configured?_=1585658467093&sid=07b503bb17764a36c826eb4231a4731e
12:41:08:120:127.0.0.1 GET /images/template/input_radio.png
12:41:08:121:127.0.0.1 GET /images/template/button_bg.png
12:41:08:122:127.0.0.1 GET /images/template/ui-bg-slider.png
12:41:09:123:127.0.0.1 GET /api/updates?_=1585658467094&sid=07b503bb17764a36c826eb4231a4731e
12:41:09:124:127.0.0.1 GET /images/template/select-icons.png
12:41:09:125:127.0.0.1 GET /images/template/ui-icon-slider.png
12:41:09:123:127.0.0.1 GET /api/updates?_=1585658467095&sid=07b503bb17764a36c826eb4231a4731e
12:41:09:126:127.0.0.1 GET /images/template/ui-progress-bg.png
12:41:09:127:127.0.0.1 GET /images/template/anim_arrow.gif
12:41:10:128:127.0.0.1 GET /api/updates?_=1585658467098&sid=07b503bb17764a36c826eb4231a4731e
12:42:48:123:127.0.0.1 GET /api/updates?_=1585658467183&sid=07b503bb17764a36c826eb4231a4731e
12:42:48:WU01:FS00:0xa7:Completed 28750 out of 125000 steps (23%)
12:42:49:129:127.0.0.1 GET /api/updates?_=1585658467184&sid=07b503bb17764a36c826eb4231a4731e
12:43:13:129:127.0.0.1 GET /api/updates?_=1585658467200&sid=07b503bb17764a36c826eb4231a4731e
12:48:42:WU01:FS00:0xa7:Completed 30000 out of 125000 steps (24%)
12:51:22:130:127.0.0.1 GET /api/updates?_=1585658467201&sid=07b503bb17764a36c826eb4231a4731e
12:53:28:131:127.0.0.1 GET /api/updates?_=1585658467296&sid=07b503bb17764a36c826eb4231a4731e
12:54:38:WU01:FS00:0xa7:Completed 31250 out of 125000 steps (25%)
12:55:32:FS00:Shutting core down
12:55:32:WU01:FS00:0xa7:Caught signal SIGINT(2) on PID 19587
12:55:32:WU01:FS00:0xa7:Exiting, please wait. . .
12:55:36:WU01:FS00:0xa7:Folding@home Core Shutdown: INTERRUPTED
12:55:36:WU01:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
12:55:36:WU01:FS00:Starting
12:55:36:WARNING:WU01:FS00:Changed SMP threads from 2 to 1 this can cause some work units to fail
12:55:36:WU01:FS00:Running FahCore: /snap/folding-at-home-fcole90/11/usr/bin/FAHCoreWrapper /root/snap/folding-at-home-fcole90/11/cores/cores.foldingathome.org/v7/lin/64bit/avx/Core_a7.fah/FahCore_a7 -dir 01 -suffix 01 -version 705 -lifeline 1446 -checkpoint 15 -np 1
12:55:36:WU01:FS00:Started FahCore on PID 5038
12:55:36:WU01:FS00:Core PID:5042
12:55:36:WU01:FS00:FahCore 0xa7 started
12:55:37:WU01:FS00:0xa7:*********************** Log Started 2020-03-31T12:55:36Z ***********************
12:55:37:WU01:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
12:55:37:WU01:FS00:0xa7:       Type: 0xa7
12:55:37:WU01:FS00:0xa7:       Core: Gromacs
12:55:37:WU01:FS00:0xa7:       Args: -dir 01 -suffix 01 -version 705 -lifeline 5038 -checkpoint 15 -np 1
12:55:37:WU01:FS00:0xa7:************************************ CBang *************************************
12:55:37:WU01:FS00:0xa7:       Date: Nov 5 2019
12:55:37:WU01:FS00:0xa7:       Time: 06:06:57
12:55:37:WU01:FS00:0xa7:   Revision: 46c96f1aa8419571d83f3e63f9c99a0d602f6da9
12:55:37:WU01:FS00:0xa7:     Branch: master
12:55:37:WU01:FS00:0xa7:   Compiler: GNU 8.3.0
12:55:37:WU01:FS00:0xa7:    Options: -std=c++11 -O3 -funroll-loops -fno-pie -fPIC
12:55:37:WU01:FS00:0xa7:   Platform: linux2 4.19.0-5-amd64
12:55:37:WU01:FS00:0xa7:       Bits: 64
12:55:37:WU01:FS00:0xa7:       Mode: Release
12:55:37:WU01:FS00:0xa7:************************************ System ************************************
12:55:37:WU01:FS00:0xa7:        CPU: Intel(R) Core(TM) i5-4570 CPU @ 3.20GHz
12:55:37:WU01:FS00:0xa7:     CPU ID: GenuineIntel Family 6 Model 60 Stepping 3
12:55:37:WU01:FS00:0xa7:       CPUs: 4
12:55:37:WU01:FS00:0xa7:     Memory: 15.60GiB
12:55:37:WU01:FS00:0xa7:Free Memory: 262.80MiB
12:55:37:WU01:FS00:0xa7:    Threads: POSIX_THREADS
12:55:37:WU01:FS00:0xa7: OS Version: 4.15
12:55:37:WU01:FS00:0xa7:Has Battery: false
12:55:37:WU01:FS00:0xa7: On Battery: false
12:55:37:WU01:FS00:0xa7: UTC Offset: 2
12:55:37:WU01:FS00:0xa7:        PID: 5042
12:55:37:WU01:FS00:0xa7:        CWD: /root/snap/folding-at-home-fcole90/11/work
12:55:37:WU01:FS00:0xa7:******************************** Build - libFAH ********************************
12:55:37:WU01:FS00:0xa7:    Version: 0.0.18
12:55:37:WU01:FS00:0xa7:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
12:55:37:WU01:FS00:0xa7:  Copyright: 2019 foldingathome.org
12:55:37:WU01:FS00:0xa7:   Homepage: https://foldingathome.org/
12:55:37:WU01:FS00:0xa7:       Time: 06:13:26
12:55:37:WU01:FS00:0xa7:   Revision: 490c9aa2957b725af319379424d5c5cb36efb656
12:55:37:WU01:FS00:0xa7:************************************ Build *************************************
12:55:37:WU01:FS00:0xa7:       SIMD: avx_256
12:55:37:WU01:FS00:0xa7:********************************************************************************
12:55:37:WU01:FS00:0xa7:Project: 14406 (Run 0, Clone 650, Gen 23)
12:55:37:WU01:FS00:0xa7:Unit: 0x0000001b80fccb095e6e434fc325e758
12:55:37:WU01:FS00:0xa7:Digital signatures verified
12:55:37:WU01:FS00:0xa7:Calling: mdrun -s frame23.tpr -o frame23.trr -x frame23.xtc -cpi state.cpt -cpt 15 -nt 1
12:55:37:WU01:FS00:0xa7:Steps: first=2875000 total=125000
12:55:38:WU01:FS00:0xa7:Completed 31432 out of 125000 steps (25%)
12:55:45:Removing old file 'configs/config-20200331-054303.xml'
12:55:45:Saving configuration to config.xml
12:55:45:<config>
12:55:45:  <!-- Network -->
12:55:45:  <proxy v=':8080'/>
12:55:45:
12:55:45:  <!-- Slot Control -->
12:55:45:  <pause-on-battery v='false'/>
12:55:45:  <power v='light'/>
12:55:45:
12:55:45:  <!-- User Information -->
12:55:45:  <team v='255832'/>
12:55:45:  <user v='dkro'/>
12:55:45:
12:55:45:  <!-- Folding Slots -->
12:55:45:  <slot id='0' type='CPU'/>
12:55:45:  <slot id='1' type='GPU'/>
12:55:45:</config>
13:00:42:WU01:FS00:0xa7:Completed 32500 out of 125000 steps (26%)
13:06:37:WU01:FS00:0xa7:Completed 33750 out of 125000 steps (27%)
13:09:43:FS00:Paused
13:09:43:FS01:Paused
13:09:44:FS00:Shutting core down
13:09:44:WU01:FS00:0xa7:Caught signal SIGINT(2) on PID 5042
13:09:44:WU01:FS00:0xa7:Exiting, please wait. . .
13:09:46:WU01:FS00:0xa7:Folding@home Core Shutdown: INTERRUPTED
13:09:47:WU01:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
13:09:59:Removing old file 'configs/config-20200331-055616.xml'
13:09:59:Saving configuration to config.xml
13:09:59:<config>
13:09:59:  <!-- Network -->
13:09:59:  <proxy v=':8080'/>
13:09:59:
13:09:59:  <!-- Slot Control -->
13:09:59:  <pause-on-battery v='false'/>
13:09:59:  <power v='light'/>
13:09:59:
13:09:59:  <!-- User Information -->
13:09:59:  <team v='255832'/>
13:09:59:  <user v='dkro'/>
13:09:59:
13:09:59:  <!-- Folding Slots -->
13:09:59:  <slot id='0' type='CPU'>
13:09:59:    <paused v='true'/>
13:09:59:  </slot>
13:09:59:  <slot id='1' type='GPU'>
13:09:59:  </slot>
13:09:59:</config>
13:10:23:132:127.0.0.1 GET /api/updates?_=1585658467298&sid=07b503bb17764a36c826eb4231a4731e
13:12:46:132:127.0.0.1 GET /api/updates?_=1585658467330&sid=07b503bb17764a36c826eb4231a4731e
13:22:09:137:127.0.0.1 GET /ping?_=1585660928852&callback=jQuery19009953564767659773_1585660928851
13:22:10:140:127.0.0.1 GET /?nocache=0.09504637699623664
13:22:11:138:127.0.0.1 GET /css/main.css
13:22:11:139:127.0.0.1 GET /css/normalize.css
13:22:11:141:127.0.0.1 GET /js/jquery-1.10.2.min.js
13:22:11:142:127.0.0.1 GET /js/libs/jquery.selectbox-0.2.js
13:22:11:143:127.0.0.1 GET /js/intercom.min.js
13:22:11:144:127.0.0.1 GET /js/main.js
13:22:11:144:127.0.0.1:New Web connection
13:22:11:145:127.0.0.1 GET /images/template/input_radio.png
13:22:11:146:127.0.0.1 GET /images/template/logo_folding_home.png
13:22:11:147:127.0.0.1 GET /api/configured?_=1585660931190&sid=ab82a8698b6461ca5f8c9753ea8696ce
13:22:11:148:127.0.0.1 GET /api/updates/set?_=1585660931189&sid=ab82a8698b6461ca5f8c9753ea8696ce&update_id=1&update_path=/api/slots&update_rate=1
13:22:11:149:127.0.0.1 GET /api/updates/set?_=1585660931188&sid=ab82a8698b6461ca5f8c9753ea8696ce&update_id=0&update_path=/api/basic&update_rate=1
13:22:11:150:127.0.0.1 GET /images/template/ui-progress-bg.png
13:22:11:151:127.0.0.1 GET /images/template/select-icons.png
13:22:11:152:127.0.0.1 GET /images/template/ui-bg-slider.png
13:22:11:153:127.0.0.1 GET /images/template/ui-icon-slider.png
13:22:12:155:127.0.0.1 GET /?nocache=0.09504637699623664
13:22:12:156:127.0.0.1 GET /api/updates?_=1585660931191&sid=ab82a8698b6461ca5f8c9753ea8696ce
13:22:13:FS00:Unpaused
13:22:13:FS01:Unpaused
13:22:13:WU01:FS00:Starting
13:22:13:WU01:FS00:Running FahCore: /snap/folding-at-home-fcole90/11/usr/bin/FAHCoreWrapper /root/snap/folding-at-home-fcole90/11/cores/cores.foldingathome.org/v7/lin/64bit/avx/Core_a7.fah/FahCore_a7 -dir 01 -suffix 01 -version 705 -lifeline 1446 -checkpoint 15 -np 1
13:22:13:WU01:FS00:Started FahCore on PID 3074
13:22:13:WU01:FS00:Core PID:3078
13:22:13:WU01:FS00:FahCore 0xa7 started
13:22:13:157:127.0.0.1 GET /css/normalize.css
13:22:13:158:127.0.0.1 GET /css/main.css
13:22:13:159:127.0.0.1 GET /js/jquery-1.10.2.min.js
13:22:13:160:127.0.0.1 GET /js/libs/jquery.selectbox-0.2.js
13:22:13:161:127.0.0.1 GET /js/intercom.min.js
13:22:13:162:127.0.0.1 GET /js/main.js
13:22:13:162:127.0.0.1:New Web connection
13:22:13:WU01:FS00:0xa7:*********************** Log Started 2020-03-31T13:22:13Z ***********************
13:22:13:WU01:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
13:22:13:WU01:FS00:0xa7:       Type: 0xa7
13:22:13:WU01:FS00:0xa7:       Core: Gromacs
13:22:13:WU01:FS00:0xa7:       Args: -dir 01 -suffix 01 -version 705 -lifeline 3074 -checkpoint 15 -np 1
13:22:13:WU01:FS00:0xa7:************************************ CBang *************************************
13:22:13:WU01:FS00:0xa7:       Date: Nov 5 2019
13:22:13:WU01:FS00:0xa7:       Time: 06:06:57
13:22:13:WU01:FS00:0xa7:   Revision: 46c96f1aa8419571d83f3e63f9c99a0d602f6da9
13:22:13:WU01:FS00:0xa7:     Branch: master
13:22:13:WU01:FS00:0xa7:   Compiler: GNU 8.3.0
13:22:13:WU01:FS00:0xa7:    Options: -std=c++11 -O3 -funroll-loops -fno-pie -fPIC
13:22:13:WU01:FS00:0xa7:   Platform: linux2 4.19.0-5-amd64
13:22:13:WU01:FS00:0xa7:       Bits: 64
13:22:13:WU01:FS00:0xa7:       Mode: Release
13:22:13:WU01:FS00:0xa7:************************************ System ************************************
13:22:13:WU01:FS00:0xa7:        CPU: Intel(R) Core(TM) i5-4570 CPU @ 3.20GHz
13:22:13:WU01:FS00:0xa7:     CPU ID: GenuineIntel Family 6 Model 60 Stepping 3
13:22:13:WU01:FS00:0xa7:       CPUs: 4
13:22:13:WU01:FS00:0xa7:     Memory: 15.60GiB
13:22:13:WU01:FS00:0xa7:Free Memory: 8.90GiB
13:22:13:WU01:FS00:0xa7:    Threads: POSIX_THREADS
13:22:13:WU01:FS00:0xa7: OS Version: 4.15
13:22:13:WU01:FS00:0xa7:Has Battery: false
13:22:13:WU01:FS00:0xa7: On Battery: false
13:22:13:WU01:FS00:0xa7: UTC Offset: 2
13:22:13:WU01:FS00:0xa7:        PID: 3078
13:22:13:WU01:FS00:0xa7:        CWD: /root/snap/folding-at-home-fcole90/11/work
13:22:13:WU01:FS00:0xa7:******************************** Build - libFAH ********************************
13:22:13:WU01:FS00:0xa7:    Version: 0.0.18
13:22:13:WU01:FS00:0xa7:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
13:22:13:WU01:FS00:0xa7:  Copyright: 2019 foldingathome.org
13:22:13:WU01:FS00:0xa7:   Homepage: https://foldingathome.org/
13:22:13:WU01:FS00:0xa7:       Time: 06:13:26
13:22:13:WU01:FS00:0xa7:   Revision: 490c9aa2957b725af319379424d5c5cb36efb656
13:22:13:WU01:FS00:0xa7:************************************ Build *************************************
13:22:13:WU01:FS00:0xa7:       SIMD: avx_256
13:22:13:WU01:FS00:0xa7:********************************************************************************
13:22:13:WU01:FS00:0xa7:Project: 14406 (Run 0, Clone 650, Gen 23)
13:22:13:WU01:FS00:0xa7:Unit: 0x0000001b80fccb095e6e434fc325e758
13:22:13:WU01:FS00:0xa7:Digital signatures verified
13:22:13:WU01:FS00:0xa7:Calling: mdrun -s frame23.tpr -o frame23.trr -x frame23.xtc -cpi state.cpt -cpt 15 -nt 1
13:22:13:WU01:FS00:0xa7:Steps: first=2875000 total=125000
13:22:14:163:127.0.0.1 GET /images/mail.png
13:22:14:164:127.0.0.1 GET /images/facebook.png
13:22:14:165:127.0.0.1 GET /images/twitter.png
13:22:14:166:127.0.0.1 GET /images/report-bug.png
13:22:14:167:127.0.0.1 GET /images/template/bg.jpg
13:22:14:168:127.0.0.1 GET /images/template/logo_folding_home.png
13:22:15:WU01:FS00:0xa7:Completed 34392 out of 125000 steps (27%)
13:22:15:169:127.0.0.1 GET /api/updates/set?_=1585660933585&sid=98ba4a49d535c4d7785734898eafab33&update_id=0&update_path=/api/basic&update_rate=1
13:22:15:170:127.0.0.1 GET /api/updates/set?_=1585660933586&sid=98ba4a49d535c4d7785734898eafab33&update_id=1&update_path=/api/slots&update_rate=1
13:22:15:171:127.0.0.1 GET /api/configured?_=1585660933587&sid=98ba4a49d535c4d7785734898eafab33
13:22:15:172:127.0.0.1 GET /api/updates?_=1585660933588&sid=98ba4a49d535c4d7785734898eafab33
13:22:15:173:127.0.0.1 GET /images/template/input_radio.png
13:22:15:174:127.0.0.1 GET /images/template/button_bg.png
13:22:15:172:127.0.0.1 GET /images/template/ui-bg-slider.png
13:22:15:175:127.0.0.1 GET /images/template/select-icons.png
13:22:15:176:127.0.0.1 GET /images/template/ui-icon-slider.png
13:22:16:177:127.0.0.1 GET /images/template/ui-progress-bg.png
13:22:16:178:127.0.0.1 GET /images/template/anim_arrow.gif
13:22:16:179:127.0.0.1 GET /api/updates?_=1585660933592&sid=98ba4a49d535c4d7785734898eafab33
13:22:17:180:127.0.0.1 GET /api/updates?_=1585660933593&sid=98ba4a49d535c4d7785734898eafab33
13:22:19:179:127.0.0.1 GET /api/updates?_=1585660933594&sid=98ba4a49d535c4d7785734898eafab33
13:22:22:180:127.0.0.1 GET /api/updates?_=1585660933595&sid=98ba4a49d535c4d7785734898eafab33
13:22:24:179:127.0.0.1 GET /api/updates?_=1585660933596&sid=98ba4a49d535c4d7785734898eafab33
13:22:27:179:127.0.0.1 GET /api/updates?_=1585660933597&sid=98ba4a49d535c4d7785734898eafab33
13:22:28:FS00:Shutting core down
13:22:28:WU01:FS00:0xa7:Caught signal SIGINT(2) on PID 3078
13:22:28:WU01:FS00:0xa7:Exiting, please wait. . .
13:22:28:WU00:FS01:Connecting to 65.254.110.245:8080
13:22:28:WU00:FS01:Assigned to work server 192.0.2.1
13:22:28:WU00:FS01:Requesting new work unit for slot 01: READY gpu:0:Barts LE [Radeon HD 6700 Series] from 192.0.2.1
13:22:28:WU00:FS01:Connecting to 192.0.2.1:8080
13:22:30:180:127.0.0.1 GET /api/updates?_=1585660933599&sid=98ba4a49d535c4d7785734898eafab33
13:22:31:WU01:FS00:0xa7:Folding@home Core Shutdown: INTERRUPTED
13:22:31:WU01:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
13:22:31:180:127.0.0.1 GET /api/updates?_=1585660933600&sid=98ba4a49d535c4d7785734898eafab33
13:23:11:180:127.0.0.1 GET /api/updates?_=1585660933631&sid=98ba4a49d535c4d7785734898eafab33
13:23:12:Removing old file 'configs/config-20200331-060020.xml'
13:23:12:Saving configuration to config.xml
13:23:12:<config>
13:23:12:  <!-- Network -->
13:23:12:  <proxy v=':8080'/>
13:23:12:
13:23:12:  <!-- Slot Control -->
13:23:12:  <pause-on-battery v='false'/>
13:23:12:
13:23:12:  <!-- User Information -->
13:23:12:  <team v='255832'/>
13:23:12:  <user v='dkro'/>
13:23:12:
13:23:12:  <!-- Folding Slots -->
13:23:12:  <slot id='0' type='CPU'/>
13:23:12:  <slot id='1' type='GPU'/>
13:23:12:</config>
13:23:12:180:127.0.0.1 GET /api/updates?_=1585660933632&sid=98ba4a49d535c4d7785734898eafab33
13:23:13:WU01:FS00:Starting
13:23:13:WARNING:WU01:FS00:Changed SMP threads from 1 to 2 this can cause some work units to fail
13:23:13:WARNING:WU01:FS00:AS lowered CPUs from 2 to 1
13:23:13:WU01:FS00:Running FahCore: /snap/folding-at-home-fcole90/11/usr/bin/FAHCoreWrapper /root/snap/folding-at-home-fcole90/11/cores/cores.foldingathome.org/v7/lin/64bit/avx/Core_a7.fah/FahCore_a7 -dir 01 -suffix 01 -version 705 -lifeline 1446 -checkpoint 15 -np 1
13:23:13:WU01:FS00:Started FahCore on PID 4006
13:23:13:WU01:FS00:Core PID:4010
13:23:13:WU01:FS00:FahCore 0xa7 started
13:23:13:180:127.0.0.1 GET /api/updates?_=1585660933633&sid=98ba4a49d535c4d7785734898eafab33
13:23:13:WU01:FS00:0xa7:*********************** Log Started 2020-03-31T13:23:13Z ***********************
13:23:13:WU01:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
13:23:13:WU01:FS00:0xa7:       Type: 0xa7
13:23:13:WU01:FS00:0xa7:       Core: Gromacs
13:23:13:WU01:FS00:0xa7:       Args: -dir 01 -suffix 01 -version 705 -lifeline 4006 -checkpoint 15 -np 1
13:23:13:WU01:FS00:0xa7:************************************ CBang *************************************
13:23:13:WU01:FS00:0xa7:       Date: Nov 5 2019
13:23:13:WU01:FS00:0xa7:       Time: 06:06:57
13:23:13:WU01:FS00:0xa7:   Revision: 46c96f1aa8419571d83f3e63f9c99a0d602f6da9
13:23:13:WU01:FS00:0xa7:     Branch: master
13:23:13:WU01:FS00:0xa7:   Compiler: GNU 8.3.0
13:23:13:WU01:FS00:0xa7:    Options: -std=c++11 -O3 -funroll-loops -fno-pie -fPIC
13:23:13:WU01:FS00:0xa7:   Platform: linux2 4.19.0-5-amd64
13:23:13:WU01:FS00:0xa7:       Bits: 64
13:23:13:WU01:FS00:0xa7:       Mode: Release
13:23:13:WU01:FS00:0xa7:************************************ System ************************************
13:23:13:WU01:FS00:0xa7:        CPU: Intel(R) Core(TM) i5-4570 CPU @ 3.20GHz
13:23:13:WU01:FS00:0xa7:     CPU ID: GenuineIntel Family 6 Model 60 Stepping 3
13:23:13:WU01:FS00:0xa7:       CPUs: 4
13:23:13:WU01:FS00:0xa7:     Memory: 15.60GiB
13:23:13:WU01:FS00:0xa7:Free Memory: 8.16GiB
13:23:13:WU01:FS00:0xa7:    Threads: POSIX_THREADS
13:23:13:WU01:FS00:0xa7: OS Version: 4.15
13:23:13:WU01:FS00:0xa7:Has Battery: false
13:23:13:WU01:FS00:0xa7: On Battery: false
13:23:13:WU01:FS00:0xa7: UTC Offset: 2
13:23:13:WU01:FS00:0xa7:        PID: 4010
13:23:13:WU01:FS00:0xa7:        CWD: /root/snap/folding-at-home-fcole90/11/work
13:23:13:WU01:FS00:0xa7:******************************** Build - libFAH ********************************
13:23:13:WU01:FS00:0xa7:    Version: 0.0.18
13:23:13:WU01:FS00:0xa7:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
13:23:13:WU01:FS00:0xa7:  Copyright: 2019 foldingathome.org
13:23:13:WU01:FS00:0xa7:   Homepage: https://foldingathome.org/
13:23:13:WU01:FS00:0xa7:       Time: 06:13:26
13:23:13:WU01:FS00:0xa7:   Revision: 490c9aa2957b725af319379424d5c5cb36efb656
13:23:13:WU01:FS00:0xa7:************************************ Build *************************************
13:23:13:WU01:FS00:0xa7:       SIMD: avx_256
13:23:13:WU01:FS00:0xa7:********************************************************************************
13:23:13:WU01:FS00:0xa7:Project: 14406 (Run 0, Clone 650, Gen 23)
13:23:13:WU01:FS00:0xa7:Unit: 0x0000001b80fccb095e6e434fc325e758
13:23:13:WU01:FS00:0xa7:Digital signatures verified
13:23:13:WU01:FS00:0xa7:Calling: mdrun -s frame23.tpr -o frame23.trr -x frame23.xtc -cpi state.cpt -cpt 15 -nt 1
13:23:13:WU01:FS00:0xa7:Steps: first=2875000 total=125000
13:23:14:180:127.0.0.1 GET /api/updates?_=1585660933634&sid=98ba4a49d535c4d7785734898eafab33
13:23:15:WU01:FS00:0xa7:Completed 34442 out of 125000 steps (27%)
13:23:15:180:127.0.0.1 GET /api/updates?_=1585660933635&sid=98ba4a49d535c4d7785734898eafab33
13:24:35:179:127.0.0.1 GET /api/updates?_=1585660933674&sid=98ba4a49d535c4d7785734898eafab33
13:24:38:WARNING:WU00:FS01:WorkServer connection failed on port 8080 trying 80
13:24:38:WU00:FS01:Connecting to 192.0.2.1:80
13:24:39:180:127.0.0.1 GET /api/updates?_=1585660933675&sid=98ba4a49d535c4d7785734898eafab33
13:25:05:179:127.0.0.1 GET /api/updates?_=1585660933684&sid=98ba4a49d535c4d7785734898eafab33
13:25:52:WU01:FS00:0xa7:Completed 35000 out of 125000 steps (28%)
13:26:49:ERROR:WU00:FS01:Exception: Failed to connect to 192.0.2.1:80: Connection timed out
13:26:50:WU00:FS01:Connecting to 65.254.110.245:8080
13:26:50:WU00:FS01:Assigned to work server 192.0.2.1
13:26:50:WU00:FS01:Requesting new work unit for slot 01: READY gpu:0:Barts LE [Radeon HD 6700 Series] from 192.0.2.1
13:26:50:WU00:FS01:Connecting to 192.0.2.1:8080
13:29:00:WARNING:WU00:FS01:WorkServer connection failed on port 8080 trying 80
13:29:00:WU00:FS01:Connecting to 192.0.2.1:80
13:31:11:ERROR:WU00:FS01:Exception: Failed to connect to 192.0.2.1:80: Connection timed out
13:31:12:WU00:FS01:Connecting to 65.254.110.245:8080
13:31:12:WU00:FS01:Assigned to work server 192.0.2.1
13:31:12:WU00:FS01:Requesting new work unit for slot 01: READY gpu:0:Barts LE [Radeon HD 6700 Series] from 192.0.2.1
13:31:12:WU00:FS01:Connecting to 192.0.2.1:8080
13:31:41:WU01:FS00:0xa7:Completed 36250 out of 125000 steps (29%)
13:32:22:181:127.0.0.1 GET /api/updates?_=1585660933685&sid=98ba4a49d535c4d7785734898eafab33
13:32:22:181:127.0.0.1 GET /images/template/ui-icon-slider-hover.png
13:32:23:182:127.0.0.1 GET /api/updates?_=1585660933686&sid=98ba4a49d535c4d7785734898eafab33
13:33:21:183:127.0.0.1 GET /api/updates?_=1585660933721&sid=98ba4a49d535c4d7785734898eafab33
13:33:22:WARNING:WU00:FS01:WorkServer connection failed on port 8080 trying 80
13:33:22:WU00:FS01:Connecting to 192.0.2.1:80
13:33:23:183:127.0.0.1 GET /api/updates?_=1585660933722&sid=98ba4a49d535c4d7785734898eafab33
13:34:48:186:127.0.0.1 GET /api/updates?_=1585660933790&sid=98ba4a49d535c4d7785734898eafab33
13:35:33:ERROR:WU00:FS01:Exception: Failed to connect to 192.0.2.1:80: Connection timed out
13:35:34:WU00:FS01:Connecting to 65.254.110.245:8080
13:35:34:WU00:FS01:Assigned to work server 192.0.2.1
13:35:34:WU00:FS01:Requesting new work unit for slot 01: READY gpu:0:Barts LE [Radeon HD 6700 Series] from 192.0.2.1
13:35:34:WU00:FS01:Connecting to 192.0.2.1:8080
jonault
Re: GPU won't start folding
Post by jonault »
Sorry, but the Radeon HD 6700 GPU doesn't have 64 floating point so it's not going to fold. You should just delete the GPU slot.
Post by Neil-B »
Sorry to say this but I believe the Radeon 6700 doesn't have the capability to fold ... If you use the search tool with "Radeon 6700" there is a thread that explains this better that I can.
dkro
Post by dkro »
Thank for your answers @Nell-B and @jonault
As I understand my card hasn't double precision so therefore can't be used for folding for current projects.
I tried search "Radeon 6700" in search tool however I nothing found that Radeon 6700 doesn't have the capabilities :(
I found file https://apps.foldingathome.org/GPUs.txt where is Radeon HD 6700 but page with explanation how to read this file doesn't work :/ (https://fah.stanford.edu/projects/FAHCl ... tOfGPUsTxt).
Post by Neil-B »
Really sorry … I recalled a thread from earlier - another Radeon with this (or a similar number) and the same DP issue … can't find it now so apologies for having wasted your time searching.
The links to sites on stanford.edu mostly don't work, almost all of the infrastructure has moved away from there since Dr Pande's lab is dormant after his move to the private sector.
To show the difference for AMD cards that can be used and those which can not:
0x1002:0x673e:1:4:Barts LE [Radeon HD 6700 Series]
0x1002:0x671f:1:5:Cayman [Radeon HD 6900 Series]
These are two lines copied from the GPUs.txt file. The first two fields are the manufacturer code and device ID. The next field is whether the card is whether the card is AMD or nVidia, 1 is AMD and 2 is nVidia. The fourth filed is the "species" number, defines what class of hardware capabilities are supported. In this case, for AMD cards 4 or lower indicates no DP support, 5 and above indicate DP is supported. 6 is currently the highest number used, it was used to classify the RDNA based cards such as the 5700 XT. Due to software changes that were needed to support the RDNA based cards, only Core_22 can be run on them, the older Core_21 can not and they are not back porting the changes necessary.
P.S. Even if you were able to get to the page explaining the format, some of the usage of the species designations have changed since that was current.
