Does not want to start automatically
krissn
Post by krissn »
Hi
I have win10 pro.
I use it as standard user and if i want install software i have pop-up when i give Administrator's credentials.
Unfortunately, after restart FAH does not want to start automatically. I have to run fahclient.exe manually - then i have console window opened and sometime no tray icon. Or i can reinstall it and it's fine till next reboot.
would be nice if someone fix that, please.
Thanks
Krissn
Re: Does not want to start automatically
You may find the shortcut to start the FAHClient process showing up on the admin account. Take a copy of that and move it to the user account, and edit the path for data files if it does not point to the APPDATA directory for the user account.
ipkh
Post by ipkh »
You can add a flag to the setip.
In advanced control, configure, expert.
Add the following flag pause-on-start and set it to true. Now it will need to be started manually after each reboot or login.
Stel2112
Hardware configuration: CPU: AMD Ryzen 5 2600, Six Core, 3.4GHz
GPU: XFX Radeon R9 290X
Memory: Corsair Vengeance LPX, 3200MHz, 16GB
Post by Stel2112 »
You might be having this problem:
viewtopic.php?f=106&t=33531
