Macbook: WU00:FS00:FahCore returned: FAILED_3 (255 = 0xff)
krazik
Post by krazik »
02:27:24:WU00:FS00:Started FahCore on PID 25829
02:27:24:WU00:FS00:FahCore 0xa7 started
02:27:25:WARNING:WU00:FS00:FahCore returned: FAILED_3 (255 = 0xff)
02:28:24:WU00:FS00:Starting
02:28:24:WU00:FS00:Running FahCore: /usr/local/bin/FAHCoreWrapper "/Library/Application Support/FAHClient/cores/cores.foldingathome.org/v7/osx/64bit/avx/Core_a7.fah/FahCore_a7" -dir 00 -suffix 01 -version 705 -lifeline 24280 -checkpoint 15 -np 7
02:28:24:WU00:FS00:Started FahCore on PID 25872
02:28:24:WU00:FS00:FahCore 0xa7 started
02:28:25:WARNING:WU00:FS00:FahCore returned: FAILED_3 (255 = 0xff)
02:28:25:WARNING:WU00:FS00:Too many errors, failing
Just one of my macbooks is giving this, any idea? My 2017 model seems fine
Hardware Overview:
Model Name: MacBook Pro
Model Identifier: MacBookPro15,1
Processor Name: Intel Core i9
Processor Speed: 2.3 GHz
Number of Processors: 1
Total Number of Cores: 8
L2 Cache (per Core): 256 KB
L3 Cache: 16 MB
Hyper-Threading Technology: Enabled
Memory: 16 GB
Intel UHD Graphics 630:
Chipset Model: Intel UHD Graphics 630
Type: GPU
Bus: Built-In
VRAM (Dynamic, Max): 1536 MB
Vendor: Intel
Device ID: 0x3e9b
Revision ID: 0x0002
Automatic Graphics Switching: Supported
gMux Version: 5.0.0
Metal: Supported, feature set macOS GPUFamily2 v1
Radeon Pro 560X:
Chipset Model: Radeon Pro 560X
Type: GPU
Bus: PCIe
PCIe Lane Width: x8
VRAM (Total): 4 GB
Vendor: AMD (0x1002)
Device ID: 0x67ef
Revision ID: 0x00c2
ROM Revision: 113-C980AL-075
VBIOS Version: 113-C97501U-005
EFI Driver Version: 01.A1.075
gMux Version: 5.0.0
Re: Macbook: WU00:FS00:FahCore returned: FAILED_3 (255 = 0xf
What version of the folding client is running on that MacBook? Could you post the first 200 lines of the log file, that would show the system hardware and software setup for the client and also dhow the configuration of the folding software.
krazik
Post by krazik »
*********************** Log Started 2020-04-02T14:40:00Z ***********************
14:40:00:************************* Folding@home Client *************************
14:40:00:    Website: https://foldingathome.org/
14:40:00:  Copyright: (c) 2009-2018 foldingathome.org
14:40:00:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
14:40:00:       Args:
14:40:00:     Config: /Library/Application Support/FAHClient/config.xml
14:40:00:******************************** Build ********************************
14:40:00:    Version: 7.5.1
14:40:00:       Date: May 11 2018
14:40:00:       Time: 12:57:01
14:40:00: Repository: Git
14:40:00:   Revision: 4705bf53c635f88b8fe85af7675557e15d491ff0
14:40:00:     Branch: master
14:40:00:   Compiler: GNU 4.2.1 Compatible Apple LLVM 7.3.0 (clang-703.0.31)
14:40:00:    Options: -std=gnu++98 -O3 -funroll-loops -mmacosx-version-min=10.6
14:40:00:             -Wno-unused-local-typedefs
14:40:00:   Platform: darwin 15.6.0
14:40:00:       Bits: 64
14:40:00:       Mode: Release
14:40:00:******************************* System ********************************
14:40:00:        CPU: Intel(R) Core(TM) i9-9880H CPU @ 2.30GHz
14:40:00:     CPU ID: GenuineIntel Family 6 Model 158 Stepping 13
14:40:00:       CPUs: 16
14:40:00:     Memory: 16.00GiB
14:40:00:Free Memory: 31.98MiB
14:40:00:    Threads: POSIX_THREADS
14:40:00: OS Version: 10.14
14:40:00:Has Battery: true
14:40:00: On Battery: true
14:40:00: UTC Offset: -7
14:40:00:        PID: 45842
14:40:00:        CWD: /Library/Application Support/FAHClient
14:40:00:         OS: Darwin 18.7.0 x86_64
14:40:00:    OS Arch: AMD64
14:40:00:       GPUs: 0
14:40:00:       CUDA: Not detected: Failed to open dynamic library 'libcuda.dylib':
14:40:00:             dlopen(libcuda.dylib, 1): image not found
14:40:00:     OpenCL: Not detected: Failed to open dynamic library 'libOpenCL.dylib':
14:40:00:             dlopen(libOpenCL.dylib, 1): image not found
14:40:00:***********************************************************************
14:40:00:<config>
14:40:00:  <!-- Network -->
14:40:00:  <proxy v=':8080'/>
14:40:00:
14:40:00:  <!-- User Information -->
14:40:00:  <team v='240492'/>
14:40:00:  <user v='krazik'/>
14:40:00:
14:40:00:  <!-- Folding Slots -->
14:40:00:  <slot id='0' type='CPU'>
14:40:00:    <paused v='true'/>
14:40:00:  </slot>
14:40:00:</config>
14:40:00:Trying to access database...
14:40:00:Successfully acquired database lock
14:40:00:Enabled folding slot 00: PAUSED cpu:7 (by user)
14:40:07:4:127.0.0.1:New Web connection
I am not seeing anything obvious, you may just have run ito a bad WU if you only got that error on one WU. If it is continuing that failed message instead of dumping the WU and requesting another, something may have stuck on retrying. If that is the case we can give directions on how to manually remove the WU.
If you get this error on every WU, different Project, Run, Clone and Generation numbers, it is possible something got corrupted. Are you running any antivirus or anti malware scans?
By default, after the install the client is requesting to run WUs on 7 CPU threads. It should automatically reducing the thread count to 6 at the time a WU starts. You can set 6 to be the request number in FAHControl if you want, or a different number.
krazik
Post by krazik »
happened on multiple wu's. and yeah machine has av software on it. I'll see about disabling.
7 is when the slider was on low, 16 on "high" all settings giver WU errors.
You may just need to exclude the work/data directory from scanning. The files located in /Library/Application Support/FAHClient/ are the ones used by the folding client.
