02:24:40:WU00:FS01:Sending unit results: id:00 state:SEND error:NO_ERROR project:11751 run:0 clone:8222 gen:0 core:0x22 unit:0x000000018ca304e75e6bbc9556e064d7
02:24:40:WU00:FS01:Uploading 14.66MiB to 140.163.4.231
02:24:40:WU00:FS01:Connecting to 140.163.4.231:8080
02:24:42:WU01:FS01:0x22:Completed 290000 out of 1000000 steps (29%)
02:24:46:WU00:FS01:Upload 35.39%
02:24:52:WU00:FS01:Upload 77.59%
02:24:55:WU00:FS01:Upload complete
02:24:55:WU00:FS01:Server responded PLEASE_WAIT (464)
02:24:55:WARNING:WU00:FS01:Failed to send results, will try again later
For some reason, this keeps failing to send. Other projects are being done, but it will never get rid of this WU. It's beginning to bug me =P
Sending failed with WU/Project 11751
Re: Sending failed with WU/Project 11751
Yes, I have the same issue with Project 11749. Upload of other packages are not an issue.
This should be investigated as it must cause massive, unnecessary server load.
I have seen the software trying to upload this package over and over for days now. In the last 90 Minutes it was uploaded fully (12.6 MB) at 10 times to different servers, thus causing a lot of unnessecary load.
The team are aware of this problem, I have no visibility of work in progress to fix it, but it is quite important because it is probably causing a lot of unnecessary upload traffic. I will enquire whether this is a case for dumping the WU.
Could you post the date and time of the first time you got the PLEASE_WAIT message? What name and team are you folding as?
