Overclock Core2 Duo E7500
I have an old E7500 and now I want to OC it. I set it to (327 x 11 = 3.6 GHz) and (+0.175v) but BSOD appeared. I have overclocked it before but I don't remember the voltage setting. Can anyone help? :'(
Re: Overclock Core2 Duo E7500
I suggest you do not hard overclock for this project, the workunits really push cpu resources and cooling ability of otherwise stable setups. The risk is that you will fail on work frequently which will delay the project and effectively lessen your output in the attempt to speed it up.
