how to limit the slots in docker?
FAH provides a V7 client installer for Debian / Mint / Ubuntu / RedHat / CentOS / Fedora. Installation on other distros may or may not be easy but if you can offer help to others, they would appreciate it.
Etherion
Post by Etherion »
I am running FAHClient in a docker image Nvidia/OpenCL but I have a few problems.
1. How do I prevent it from using the CPU? have tried FAHClient --cpus=-1 but that does not stop it. nore does --cpus=0
2. The docker passes 1 of 6 GPUs through but FAHClient still opens 6 slots with only one compute units assigned.
I have tried --gpu=false --opencl-index=1 --gpu-index=1 --cuda-index=1 --gpu=false
pr0ti3n
Re: how to limit the slots in docker?
Post by pr0ti3n »
Try:
cpu-usage 0
1. You need to remove the entire CPU slot section.
2. I don't understand ... you many GPUs do you have ? How many GPU slot are created ?
