auto-start web page control in browser, how to disable?
massimo2
Post by massimo2 »
Hi all,
each time i start F&H it automatically open the default browser (W10) showing the web control page.
Is there any way to disable this?
If yes, is possbile to show the advaced control when i start F%H?
thanks
massimo
jonault
Re: auto-start web page control in browser, how to disable?
Post by jonault »
Check the shortcut you use to start F@H, there's a command line argument that's causing it to start the Web Control. I don't remember what it is, but if you remove it the Web Control won't launch automatically anymore.
AFAIK, there isn't a similar option for the Advanced Control so no way to start that automatically instead.
ipkh
Post by ipkh »
Yes, open the advanced control and click configure. Under expert remove the web-control setting or set it to false.
massimo2
Post by massimo2 »
modifying the shortcut (by removing open-web-control) the browser do not open anymore on F&H startup
thanks a lot
massimo
