I'm a new member (part of the COVID-19 tidal wave, I suppose). My laptop is doing its little bit for the cause.
I am curious. I realize that not all work units will be COVID-19-related. Is it possible to map the work unit displayed in my web interface (e.g., "13840 (0, 3243, 19)" as my dashboard currently displays) to a human readable task? My perusal of the frequently asked questions didn't turn anything up.
Can I map work unit number to project/disease?
smontanaro
Re: Can I map work unit number to project/disease?
There is a list of active projects that you can look at. If you don't see the project you're looking for, you can do a search on this page, just enter the project number in the search field (in your example, that would be 13840).
smontanaro
Thanks. Exactly what I was looking for...
FYI, it's fair to say that right now, EVERYTHING that FAH is doing is COVAID related.
Many businesses are currently shut down but when this crisis is over, FAH will still be here and will go back to fighting cancer (etc.).
