Problems to connect to server ti get WU´s
Blankenfelder
Post by Blankenfelder »
Hey there,
unfortunatelly it seems that I am not able to get any WU´s.
Here is what the log says:
06:57:02:ERROR:Receive error: 10054: Eine vorhandene Verbindung wurde vom Remotehost geschlossen.
06:57:18:ERROR:Receive error: 10053: Eine bestehende Verbindung wurde softwaregesteuert
06:57:18:ERROR:durch den Hostcomputer abgebrochen.
06:57:34:ERROR:Receive error: 10053: Eine bestehende Verbindung wurde softwaregesteuert
06:57:34:ERROR:durch den Hostcomputer abgebrochen.
06:57:50:ERROR:Receive error: 10053: Eine bestehende Verbindung wurde softwaregesteuert
06:57:50:ERROR:durch den Hostcomputer abgebrochen.
06:58:06:ERROR:Receive error: 10053: Eine bestehende Verbindung wurde softwaregesteuert
06:58:06:ERROR:durch den Hostcomputer abgebrochen.
Maybe, there is a problem with my username "Blankenfelder"?
Would be nice to get Folding@home working ;)
Greetings from Germany
Blankenfelder
Re: Problems to connect to server ti get WU´s
The 10053 and 10054 messages are not related to getting a WU, and can be ignored. They come from Web Control or FAHViewer not closing a connection properly.
if you are getting message about being unable to connect to servers, or the connection closing with an unable to assign WU message, you may be running into this - viewtopic.php?f=24&t=33193
If you have concerns that your configuration might not be right, post the first 200 or so lines of your log that show the System information, and the folding configuration.
Blankenfelder
Hey Joe_H,
thank you. Simple as that, that´s it. ;)
Simple no WU´s to work at at the moment.
Sorry for inconveniance, Topic can be closed.
Greetings from Germany and stay healthy ;)
Blankenfelder
