Used to connect, now I see this in the logs
TheRealTomTom
Post by TheRealTomTom »
Is anyone able to offer advice? My client used to connect, but now it is not. Anything I can do?
08:18:07:44:127.0.0.1:New Web connection
08:18:11:ERROR:WU01:FS01:Exception: Failed to connect to 192.0.2.1:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
08:18:28:WU00:FS00:Connecting to 65.254.110.245:8080
08:18:29:WU01:FS01:Connecting to 65.254.110.245:8080
08:18:29:WARNING:WU00:FS00:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
08:18:29:WU00:FS00:Connecting to 18.218.241.186:80
08:18:29:WU01:FS01:Assigned to work server 192.0.2.1
08:18:29:WU01:FS01:Requesting new work unit for slot 01: READY gpu:0:Barts XT [Radeon HD 6800 Series] from 192.0.2.1
08:18:29:WU01:FS01:Connecting to 192.0.2.1:8080
08:18:29:WARNING:WU00:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
08:18:29:ERROR:WU00:FS00:Exception: Could not get an assignment
Re: Used to connect, now I see this in the logs
Your Radeon HD 6800 series GPU is no longer usable for GPU folding as it does not support Double Precision (FP64) calculations, the HD 6900 series do. The projects that were only using Single Precision finished up last year.
Your system can work on CPU folding, there are many projects coming out screening for possible drug candidates.
TheRealTomTom
Joe_H wrote:Your Radeon HD 6800 series GPU is no longer usable for GPU folding as it does not support Double Precision (FP64) calculations, the HD 6900 series do. The projects that were only using Single Precision finished up last year.
That is fine, but it's not even connecting for the CPU (or am I missing the point and there are no CPU things running at the mo)
Thanks
Post by Neil-B »
The issuing of WUs (both GPU and CPU) is under stress due to massive expansion of folding community ... the message for your CPU is nothing unusual at this point in time (see the many posts in this regard) ... the team are working to resolve this and issue WUs to everyone as quickly as they can but until things catch up there will be some periods of inactivity until a download occurs.
