FahCore returned: FAILED_2 (1 = 0x1)
ptfah
Post by ptfah »
Hello, I'm new to FAH and having some trouble getting it to run on CentOS 6. I am getting the error: FahCore returned: FAILED_2 (1 = 0x1)
See log entry below:
*********************** Log Started 2020-03-30T03:09:16Z ***********************
03:09:16:************************* Folding@home Client *************************
03:09:16:    Website: https://foldingathome.org/
03:09:16:  Copyright: (c) 2009-2018 foldingathome.org
03:09:16:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
03:09:16:       Args: --child --lifeline 8325 /etc/fahclient/config.xml --run-as
03:09:16:             fahclient --pid-file=/var/run/fahclient.pid --daemon
03:09:16:     Config: /etc/fahclient/config.xml
03:09:16:******************************** Build ********************************
03:09:16:    Version: 7.5.1
03:09:16:       Date: May 12 2018
03:09:16:       Time: 22:51:07
03:09:16: Repository: Git
03:09:16:   Revision: 4705bf53c635f88b8fe85af7675557e15d491ff0
03:09:16:     Branch: master
03:09:16:   Compiler: GNU 4.4.7 20120313 (Red Hat 4.4.7-18)
03:09:16:    Options: -std=gnu++98 -O3 -funroll-loops
03:09:16:   Platform: linux2 4.14.0-3-amd64
03:09:16:       Bits: 64
03:09:16:       Mode: Release
03:09:16:******************************* System ********************************
03:09:16:        CPU: Intel(R) Xeon(TM) CPU 3.00GHz
03:09:16:     CPU ID: GenuineIntel Family 15 Model 4 Stepping 1
03:09:16:       CPUs: 4
03:09:16:     Memory: 3.74GiB
03:09:16:Free Memory: 739.01MiB
03:09:16:    Threads: POSIX_THREADS
03:09:16: OS Version: 2.6
03:09:16:Has Battery: false
03:09:16: On Battery: false
03:09:16: UTC Offset: -4
03:09:16:        PID: 8327
03:09:16:        CWD: /var/lib/fahclient
03:09:16:         OS: Linux 2.6.32-642.11.1.el6.x86_64 x86_64
03:09:16:    OS Arch: AMD64
03:09:16:       GPUs: 0
03:09:16:       CUDA: Not detected: Failed to open dynamic library 'libcuda.so':
03:09:16:             libcuda.so: cannot open shared object file: No such file or
03:09:16:             directory
03:09:16:     OpenCL: Not detected: Failed to open dynamic library 'libOpenCL.so':
03:09:16:             libOpenCL.so: cannot open shared object file: No such file or
03:09:16:             directory
03:09:16:***********************************************************************
03:09:16:<config>
03:09:16:  <!-- Client Control -->
03:09:16:  <fold-anon v='true'/>
03:09:16:
03:09:16:  <!-- Folding Slot Configuration -->
03:09:16:  <gpu v='false'/>
03:09:16:
03:09:16:  <!-- Network -->
03:09:16:  <proxy v=':8080'/>
03:09:16:
03:09:16:  <!-- Remote Command Server -->
03:09:16:  <password v='*****************'/>
03:09:16:
03:09:16:  <!-- User Information -->
03:09:16:  <passkey v='********************************'/>
03:09:16:  <team v='******'/>
03:09:16:  <user v='******'/>
03:09:16:
03:09:16:  <!-- Folding Slots -->
03:09:16:  <slot id='0' type='CPU'/>
03:09:16:</config>
03:09:16:Switching to user fahclient
03:09:16:Trying to access database...
03:09:16:Successfully acquired database lock
03:09:16:Enabled folding slot 00: READY cpu:3
03:09:16:WU00:FS00:Connecting to 65.254.110.245:8080
03:09:17:WARNING:WU00:FS00:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
03:09:17:WU00:FS00:Connecting to 18.218.241.186:80
03:09:17:WARNING:WU00:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
03:09:17:ERROR:WU00:FS00:Exception: Could not get an assignment
03:09:17:WU00:FS00:Connecting to 65.254.110.245:8080
03:09:18:WU00:FS00:Assigned to work server 128.252.203.9
03:09:18:WU00:FS00:Requesting new work unit for slot 00: READY cpu:3 from 128.252.203.9
03:09:18:WU00:FS00:Connecting to 128.252.203.9:8080
03:10:21:WARNING:WU00:FS00:WorkServer connection failed on port 8080 trying 80
03:10:21:WU00:FS00:Connecting to 128.252.203.9:80
03:12:30:ERROR:WU00:FS00:Exception: 10002: Received short response, expected 512 bytes, got 0
03:12:30:WU00:FS00:Connecting to 65.254.110.245:8080
03:12:30:WARNING:WU00:FS00:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
03:12:30:WU00:FS00:Connecting to 18.218.241.186:80
03:12:30:WARNING:WU00:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
03:12:30:ERROR:WU00:FS00:Exception: Could not get an assignment
03:14:07:WU00:FS00:Connecting to 65.254.110.245:8080
03:14:07:WARNING:WU00:FS00:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
03:14:07:WU00:FS00:Connecting to 18.218.241.186:80
03:14:07:WARNING:WU00:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
03:14:07:ERROR:WU00:FS00:Exception: Could not get an assignment
03:16:44:WU00:FS00:Connecting to 65.254.110.245:8080
03:16:44:WARNING:WU00:FS00:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
03:16:44:WU00:FS00:Connecting to 18.218.241.186:80
03:16:45:WARNING:WU00:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
03:16:45:ERROR:WU00:FS00:Exception: Could not get an assignment
03:20:59:WU00:FS00:Connecting to 65.254.110.245:8080
03:20:59:WU00:FS00:Assigned to work server 13.90.152.57
03:20:59:WU00:FS00:Requesting new work unit for slot 00: READY cpu:3 from 13.90.152.57
03:20:59:WU00:FS00:Connecting to 13.90.152.57:8080
03:21:17:WU00:FS00:Downloading 4.93MiB
03:21:18:WU00:FS00:Download complete
03:21:18:WU00:FS00:Received Unit: id:00 state:DOWNLOAD error:NO_ERROR project:14335 run:0 clone:284 gen:14 core:0xa7 unit:0x000000130d5a98395e75253ca65328d2
03:21:18:WU00:FS00:Downloading core from http://cores.foldingathome.org/v7/lin/64bit/Core_a7.fah
03:21:18:WU00:FS00:Connecting to cores.foldingathome.org:80
03:21:18:WU00:FS00:FahCore a7: Downloading 7.85MiB
03:21:20:WU00:FS00:FahCore a7: Download complete
03:21:20:WU00:FS00:Valid core signature
03:21:21:WU00:FS00:Unpacked 18.96MiB to cores/cores.foldingathome.org/v7/lin/64bit/Core_a7.fah/FahCore_a7
03:21:21:WU00:FS00:Starting
03:21:21:WU00:FS00:Running FahCore: /usr/bin/FAHCoreWrapper /var/lib/fahclient/cores/cores.foldingathome.org/v7/lin/64bit/Core_a7.fah/FahCore_a7 -dir 00 -suffix 01 -version 705 -lifeline 8327 -checkpoint 15 -np 3
03:21:21:WU00:FS00:Started FahCore on PID 9090
03:21:21:WU00:FS00:Core PID:9094
03:21:21:WU00:FS00:FahCore 0xa7 started
03:21:21:WARNING:WU00:FS00:FahCore returned: FAILED_2 (1 = 0x1)
03:21:21:WU00:FS00:Started FahCore on PID 9095
03:21:21:WU00:FS00:Core PID:9099
03:21:22:WARNING:WU00:FS00:FahCore returned: FAILED_2 (1 = 0x1)
03:22:22:WU00:FS00:Starting
03:22:22:WU00:FS00:Running FahCore: /usr/bin/FAHCoreWrapper /var/lib/fahclient/cores/cores.foldingathome.org/v7/lin/64bit/Core_a7.fah/FahCore_a7 -dir 00 -suffix 01 -version 705 -lifeline 8327 -checkpoint 15 -np 3
03:22:22:WU00:FS00:Started FahCore on PID 9163
03:22:22:WU00:FS00:Core PID:9167
03:22:22:WU00:FS00:FahCore 0xa7 started
03:22:22:WARNING:WU00:FS00:FahCore returned: FAILED_2 (1 = 0x1)
03:23:22:WU00:FS00:Starting
03:23:22:WU00:FS00:Running FahCore: /usr/bin/FAHCoreWrapper /var/lib/fahclient/cores/cores.foldingathome.org/v7/lin/64bit/Core_a7.fah/FahCore_a7 -dir 00 -suffix 01 -version 705 -lifeline 8327 -checkpoint 15 -np 3
03:23:22:WU00:FS00:Started FahCore on PID 9230
03:23:22:WU00:FS00:Core PID:9234
03:23:22:WU00:FS00:FahCore 0xa7 started
03:23:22:WARNING:WU00:FS00:FahCore returned: FAILED_2 (1 = 0x1)
03:24:22:WU00:FS00:Starting
03:24:22:WU00:FS00:Running FahCore: /usr/bin/FAHCoreWrapper /var/lib/fahclient/cores/cores.foldingathome.org/v7/lin/64bit/Core_a7.fah/FahCore_a7 -dir 00 -suffix 01 -version 705 -lifeline 8327 -checkpoint 15 -np 3
03:24:22:WU00:FS00:Started FahCore on PID 9297
03:24:22:WU00:FS00:Core PID:9301
03:24:22:WU00:FS00:FahCore 0xa7 started
03:24:22:WARNING:WU00:FS00:FahCore returned: FAILED_2 (1 = 0x1)
03:24:22:WARNING:WU00:FS00:Too many errors, failing
03:24:22:WU00:FS00:Sending unit results: id:00 state:SEND error:FAILED project:14335 run:0 clone:284 gen:14 core:0xa7 unit:0x000000130d5a98395e75253ca65328d2
03:24:22:WU00:FS00:Connecting to 13.90.152.57:8080
03:24:23:WU01:FS00:Connecting to 65.254.110.245:8080
03:24:23:WARNING:WU01:FS00:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
03:24:23:WU01:FS00:Connecting to 18.218.241.186:80
03:24:23:WARNING:WU01:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
03:24:23:ERROR:WU01:FS00:Exception: Could not get an assignment
03:24:24:WARNING:WU01:FS00:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
03:24:24:WU01:FS00:Connecting to 18.218.241.186:80
03:24:24:WARNING:WU01:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
03:24:24:ERROR:WU01:FS00:Exception: Could not get an assignment
03:24:52:WU00:FS00:Server responded WORK_ACK (400)
03:24:52:WU00:FS00:Cleaning up
03:25:23:WU01:FS00:Connecting to 65.254.110.245:8080
03:25:24:WU01:FS00:Assigned to work server 128.252.203.9
03:25:24:WU01:FS00:Requesting new work unit for slot 00: READY cpu:3 from 128.252.203.9
03:25:24:WU01:FS00:Connecting to 128.252.203.9:8080
03:25:50:WU01:FS00:Downloading 2.16MiB
03:25:51:WU01:FS00:Download complete
03:25:51:WU01:FS00:Received Unit: id:01 state:DOWNLOAD error:NO_ERROR project:13833 run:0 clone:1559 gen:23 core:0xa7 unit:0x0000002180fccb095e6e5655bfbab1d7
03:25:51:WU01:FS00:Starting
03:25:51:WU01:FS00:Running FahCore: /usr/bin/FAHCoreWrapper /var/lib/fahclient/cores/cores.foldingathome.org/v7/lin/64bit/Core_a7.fah/FahCore_a7 -dir 01 -suffix 01 -version 705 -lifeline 8327 -checkpoint 15 -np 3
03:25:51:WU01:FS00:Started FahCore on PID 9395
03:25:51:WU01:FS00:Core PID:9399
03:25:51:WU01:FS00:FahCore 0xa7 started
03:25:52:WARNING:WU01:FS00:FahCore returned: FAILED_2 (1 = 0x1)
03:25:52:WU01:FS00:Starting
03:25:52:WU01:FS00:Running FahCore: /usr/bin/FAHCoreWrapper /var/lib/fahclient/cores/cores.foldingathome.org/v7/lin/64bit/Core_a7.fah/FahCore_a7 -dir 01 -suffix 01 -version 705 -lifeline 8327 -checkpoint 15 -np 3
03:25:52:WU01:FS00:Started FahCore on PID 9401
03:25:52:WU01:FS00:Core PID:9405
03:25:52:WU01:FS00:FahCore 0xa7 started
03:25:53:WARNING:WU01:FS00:FahCore returned: FAILED_2 (1 = 0x1)
03:26:52:WU01:FS00:Starting
03:26:52:WU01:FS00:Running FahCore: /usr/bin/FAHCoreWrapper /var/lib/fahclient/cores/cores.foldingathome.org/v7/lin/64bit/Core_a7.fah/FahCore_a7 -dir 01 -suffix 01 -version 705 -lifeline 8327 -checkpoint 15 -np 3
03:26:52:WU01:FS00:Started FahCore on PID 9468
03:26:52:WU01:FS00:Core PID:9472
03:26:52:WU01:FS00:FahCore 0xa7 started
03:26:53:WARNING:WU01:FS00:FahCore returned: FAILED_2 (1 = 0x1)
03:27:52:WU01:FS00:Starting
03:27:52:WU01:FS00:Running FahCore: /usr/bin/FAHCoreWrapper /var/lib/fahclient/cores/cores.foldingathome.org/v7/lin/64bit/Core_a7.fah/FahCore_a7 -dir 01 -suffix 01 -version 705 -lifeline 8327 -checkpoint 15 -np 3
03:27:52:WU01:FS00:Started FahCore on PID 9535
03:27:52:WU01:FS00:Core PID:9539
03:27:52:WU01:FS00:FahCore 0xa7 started
03:27:53:WARNING:WU01:FS00:FahCore returned: FAILED_2 (1 = 0x1)
03:28:52:WU01:FS00:Starting
03:28:52:WU01:FS00:Running FahCore: /usr/bin/FAHCoreWrapper /var/lib/fahclient/cores/cores.foldingathome.org/v7/lin/64bit/Core_a7.fah/FahCore_a7 -dir 01 -suffix 01 -version 705 -lifeline 8327 -checkpoint 15 -np 3
03:28:52:WU01:FS00:Started FahCore on PID 9601
03:28:52:WU01:FS00:Core PID:9605
03:28:52:WU01:FS00:FahCore 0xa7 started
03:28:53:WARNING:WU01:FS00:FahCore returned: FAILED_2 (1 = 0x1)
03:28:53:WARNING:WU01:FS00:Too many errors, failing
03:28:53:WU01:FS00:Sending unit results: id:01 state:SEND error:FAILED project:13833 run:0 clone:1559 gen:23 core:0xa7 unit:0x0000002180fccb095e6e5655bfbab1d7
03:28:53:WU01:FS00:Connecting to 128.252.203.9:8080
03:28:53:WU00:FS00:Connecting to 65.254.110.245:8080
03:28:53:WARNING:WU00:FS00:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
03:28:53:WU00:FS00:Connecting to 18.218.241.186:80
03:28:54:WARNING:WU00:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
03:28:54:ERROR:WU00:FS00:Exception: Could not get an assignment
03:28:54:WU00:FS00:Connecting to 65.254.110.245:8080
03:28:54:WARNING:WU00:FS00:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
03:28:54:WU00:FS00:Connecting to 18.218.241.186:80
03:28:54:WU00:FS00:Assigned to work server 155.247.164.214
03:28:54:WU00:FS00:Requesting new work unit for slot 00: READY cpu:3 from 155.247.164.214
03:28:54:WU00:FS00:Connecting to 155.247.164.214:8080
03:28:55:ERROR:WU00:FS00:Exception: Server did not assign work unit
03:29:54:WU00:FS00:Connecting to 65.254.110.245:8080
03:29:54:WARNING:WU00:FS00:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
03:29:54:WU00:FS00:Connecting to 18.218.241.186:80
03:29:54:WARNING:WU00:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
03:29:54:ERROR:WU00:FS00:Exception: Could not get an assignment
03:29:55:WU01:FS00:Server responded WORK_ACK (400)
03:29:55:WU01:FS00:Cleaning up
03:31:31:WU00:FS00:Connecting to 65.254.110.245:8080
03:31:31:WU00:FS00:Assigned to work server 168.245.198.125
03:31:31:WU00:FS00:Requesting new work unit for slot 00: READY cpu:3 from 168.245.198.125
03:31:31:WU00:FS00:Connecting to 168.245.198.125:8080
03:31:32:ERROR:WU00:FS00:Exception: Server did not assign work unit
03:34:09:WU00:FS00:Connecting to 65.254.110.245:8080
03:34:09:WARNING:WU00:FS00:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
03:34:09:WU00:FS00:Connecting to 18.218.241.186:80
03:34:09:WARNING:WU00:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
03:34:09:ERROR:WU00:FS00:Exception: Could not get an assignment
03:38:23:WU00:FS00:Connecting to 65.254.110.245:8080
03:38:23:WARNING:WU00:FS00:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
03:38:23:WU00:FS00:Connecting to 18.218.241.186:80
03:38:23:WARNING:WU00:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
03:38:23:ERROR:WU00:FS00:Exception: Could not get an assignment
03:45:14:WU00:FS00:Connecting to 65.254.110.245:8080
03:45:15:WARNING:WU00:FS00:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
03:45:15:WU00:FS00:Connecting to 18.218.241.186:80
03:45:15:WU00:FS00:Assigned to work server 128.252.203.10
03:45:15:WU00:FS00:Requesting new work unit for slot 00: READY cpu:3 from 128.252.203.10
03:45:15:WU00:FS00:Connecting to 128.252.203.10:8080
03:46:07:WU00:FS00:Downloading 2.73MiB
03:46:08:WU00:FS00:Download complete
03:46:08:WU00:FS00:Received Unit: id:00 state:DOWNLOAD error:NO_ERROR project:14244 run:0 clone:6 gen:362 core:0xa7 unit:0x000001a380fccb0a5d6ee30ea96e40f4
03:46:08:WU00:FS00:Starting
03:46:08:WU00:FS00:Running FahCore: /usr/bin/FAHCoreWrapper /var/lib/fahclient/cores/cores.foldingathome.org/v7/lin/64bit/Core_a7.fah/FahCore_a7 -dir 00 -suffix 01 -version 705 -lifeline 8327 -checkpoint 15 -np 3
03:46:08:WU00:FS00:Started FahCore on PID 10687
03:46:08:WU00:FS00:Core PID:10691
03:46:08:WU00:FS00:FahCore 0xa7 started
03:46:08:WARNING:WU00:FS00:FahCore returned: FAILED_2 (1 = 0x1)
03:46:08:WU00:FS00:Started FahCore on PID 10693
03:46:08:WU00:FS00:Core PID:10697
03:46:09:WARNING:WU00:FS00:FahCore returned: FAILED_2 (1 = 0x1)
03:47:09:WU00:FS00:Starting
03:47:09:WU00:FS00:Running FahCore: /usr/bin/FAHCoreWrapper /var/lib/fahclient/cores/cores.foldingathome.org/v7/lin/64bit/Core_a7.fah/FahCore_a7 -dir 00 -suffix 01 -version 705 -lifeline 8327 -checkpoint 15 -np 3
03:47:09:WU00:FS00:Started FahCore on PID 10760
03:47:09:WU00:FS00:Core PID:10764
03:47:09:WU00:FS00:FahCore 0xa7 started
03:47:09:WARNING:WU00:FS00:FahCore returned: FAILED_2 (1 = 0x1)
Re: FahCore returned: FAILED_2 (1 = 0x1)
I did some searching, the error FAILED_2 (1 = 0x1) points towards Centos 6 having a glibc library that is older than required for the A7 folding core. A newer version of Centos would have the needed library.
ptfah
Post by ptfah »
Thanks! I'll check version of glibc. Do you know what the currently required minimum version is?
If you try to run /var/lib/fahclient/cores/cores.foldingathome.org/v7/lin/64bit/Core_a7.fah/FahCore_a7 in a terminal, the error message will print the required version ...
