So i noticed that my WUs on https://folding.extremeoverclocking.com ... &u=1013265 are more than the
display number than on https://stats.foldingathome.org/donor/J ... s_creek_MO
But if you click on the Display Number on stats.foldingathome.org its some times lager than both of them.
Is this just my web Browser
WUs number out of sync
Re: WUs number out of sync
Yes, at folding.extremeoverclocking.com, the stats are updated more frequently than on stats.foldingathome.org/donor (because the servers and the developers are overloaded right now).
As you can see, the stats at stats.foldingathome.org/donor were last updated the 2020-03-27 15:12:19, two days back...
Not sure what you mean with "click on the Display Number", but you can indeed have a even more current (and thus possibly higher) number in the Web Control, for example.
When you click on the number it generates a image
Ah yes, indeed. I guess this system gives you the current number, as it is a one-shot operation that only has to collect the number of WUs.
