Continuous "Connecting"...
DeepCore
Post by DeepCore »
Hello,
I started on FaH's second machine and has been hanging on "Connecting" status since installation. The first machine connected properly without any delay. Both machines connected to one local network. Is this the occupation of the FaH server ...?
Process Explorer shows no load on Client FaH or FaH Control. The resource monitor does not record any FaH traffic. And some time has passed since installation and firing the instance ...
On the first machine on which the FaH installation was carried out the same day, it downloads, processes and sends back the WU without any problem.
Regards
Sincerely
DeepCore
Re: Continuous "Connecting"...
By "Connecting" do you mean the client looking for an assignment of a WU? Or do you mean Web Control or FAHControl are continuously tryin to connect to show what the client is doing which is a different problem.
If this machine does not eventually download work, post the first 200 or so lines of your log file and we can take a look to see if there are ant problems with the configuration.
MobileGamesMotion
Hardware configuration: Windows 7, Intel i7-6600U CPU on a laptop
Post by MobileGamesMotion »
What CPU and GPU do you have? I know one of my PCs has been connecting for a while, but it was ARM so it didn't work.
#StayAtHome #AlertNotAnxious #FoldForCOVID :) :idea: :egeek:
Basic help stuff:viewtopic.php?f=61&t=26036 | Find Your Stats:https://stats.foldingathome.org/donors
https://folding.extremeoverclocking.com/
DeepCore
Post by DeepCore »
By "Connecting" I understand the situation as in this screenshot https://imgur.com/a/1oSUBaS.
I cannot access the log because FaHControl is not logging in.
Regards
Sincerely
DeepCore
DeepCore
Post by DeepCore »
MobileGamesMotion wrote:What CPU and GPU do you have? I know one of my PCs has been connecting for a while, but it was ARM so it didn't work.
Only the i3 M350 CPU counts on this machine.
Regards
Sincerely
DeepCore
MobileGamesMotion
go to viewtopic.php?p=261081&f=24#p261081 to get log. use method 3. If you have windows 10, scroll down on dat page
DeepCore
Post by DeepCore »
MobileGamesMotion wrote:go to viewtopic.php?p=261081&f=24#p261081 to get log. use method 3. If you have windows 10, scroll down on dat page
Thank you. I do.
Regards
Sincerely
DeepCore
DeepCore
Post by DeepCore »
*********************** Log Started 2020-03-29T18:32:48Z ***********************
18:32:48:************************* Folding@home Client *************************
18:32:48:      Website: https://foldingathome.org/
18:32:48:    Copyright: (c) 2009-2018 foldingathome.org
18:32:48:       Author: Joseph Coffland <joseph@cauldrondevelopment.com>
18:32:48:         Args: --open-web-control
18:32:48:       Config: <none>
18:32:48:******************************** Build ********************************
18:32:48:      Version: 7.5.1
18:32:48:         Date: May 11 2018
18:32:48:         Time: 13:06:32
18:32:48:   Repository: Git
18:32:48:     Revision: 4705bf53c635f88b8fe85af7675557e15d491ff0
18:32:48:       Branch: master
18:32:48:     Compiler: Visual C++ 2008
18:32:48:      Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
18:32:48:     Platform: win32 10
18:32:48:         Bits: 32
18:32:48:         Mode: Release
18:32:48:******************************* System ********************************
18:32:48:          CPU: Intel(R) Core(TM) i3 CPU M 350 @ 2.27GHz
18:32:48:       CPU ID: GenuineIntel Family 6 Model 37 Stepping 5
18:32:48:         CPUs: 4
18:32:48:       Memory: 7.86GiB
18:32:48:  Free Memory: 2.97GiB
18:32:48:      Threads: WINDOWS_THREADS
18:32:48:   OS Version: 6.1
18:32:48:  Has Battery: false
18:32:48:   On Battery: false
18:32:48:   UTC Offset: 2
18:32:48:          PID: 6692
18:32:48:          CWD: D:\FAHClient\Data
18:32:48:           OS: Windows 7 Ultimate
18:32:48:      OS Arch: AMD64
18:32:48:         GPUs: 1
18:32:48:        GPU 0: Bus:1 Slot:0 Func:0 AMD:4 Robson CE [Radeon HD 6300 Series]
18:32:48:         CUDA: Not detected: Failed to open dynamic library 'nvcuda.dll': Nie
18:32:48:               można odnaleźć określonego modułu.
18:32:48:
18:32:48:       OpenCL: Not detected: Win32: 0xc0000005: Exception access violation
18:32:48:Win32 Service: false
18:32:48:***********************************************************************
18:32:48:<config>
18:32:48:  <!-- Folding Slots -->
18:32:48:</config>
18:32:48:Trying to access database...
18:32:48:Successfully acquired database lock
18:32:48:Enabled folding slot 00: PAUSED cpu:2 (not configured)
The contents of earlier logs are identical.
Regards
Sincerely
DeepCore
Does the account you are running the client from have R/W access to CWD: D:\FAHClient\Data? That is not the default location so you may have some fixing up to do for the install this way to work. Without write access to this location the client can not write necessary files there and complete the installation enough for it to go active and be connected to.
There have been a number of posts and topics about this, look for ones about client being installed under wrong user and similar.
DeepCore
Post by DeepCore »
Joe_H wrote:Does the account you are running the client from have R/W access to CWD: D:\FAHClient\Data? That is not the default location so you may have some fixing up to do for the install this way to work. Without write access to this location the client can not write necessary files there and complete the installation enough for it to go active and be connected to.
Yes, this is not the default location for the Fah installation, but it did have full rights. I also installed FaH in the default location and the situation was similar. Before each subsequent installation, I thoroughly cleaned the remnants of the previous one in the system and in the registry. I have no idea what the reason is, and it annoys me terribly.
I will try to take it as soon as I find more free time than I currently have.
Regards
Sincerely
DeepCore
mandus
Post by mandus »
this approach solved my issue with stuck at connecting
viewtopic.php?f=106&t=33531
