F@H seems to be enable to connect to the system
Extract of the log file :
07:30:09:WARNING:WU00:FS00:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
07:30:09:WARNING:WU00:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
07:30:09:ERROR:WU00:FS00:Exception: Could not get an assignment
07:30:10:WARNING:WU00:FS00:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
07:30:10:WARNING:WU00:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
07:30:10:ERROR:WU00:FS00:Exception: Could not get an assignment
07:30:30:WARNING:WU01:FS01:WorkServer connection failed on port 8080 trying 80
07:30:52:ERROR:WU01:FS01:Exception: Failed to connect to 192.0.2.1:80: Une tentative de connexion a échoué car le parti connecté n’a pas répondu convenablement au-delà d’une certaine durée ou une connexion établie a échoué car l’hôte de connexion n’a pas répondu.
System Windows 10 at home
Identity AlainB-FR-73 ant team number = 242593 (my identity does not appear in the list
Thanks for your help
Connexion errors
Re: Connexion errors
These warnings and errors are not alarming: they just indicate that the servers are momentarily overloaded (a very common occurrence right now) and that you have to be patient. It will start eventually.
I am running into a similar situation. I understand that the connection errors themselves aren't alarming, and just need to be sorted out on the server end, but as far as I can tell, I'm not sure I've ever connected to the server. When I go to check my stats, it says that none are available. Is this also a side effect of the aforementioned server issue, or do I need to do something specifically? I made sure that the port was open in my firewall.
Yes it is, there's an explanation here: viewtopic.php?f=18&t=33072&start=15#p319257
Points are currently credited late because the collection servers, where data is parked until it can be processed by the work unit servers, currently don't credit points directly. You'll get them eventually, there's just a (currently significant) delay.
