Recent dowload to Mac, 'Could not get an assignment'
lovegrovec
Post by lovegrovec »
Hi all,
I downloaded Folding@home yesterday to my iMac (mid-2010, 3.6GHz Intel i5). The client seems unable to connect and download WUs. I am using the default settings. The log reads:
*********************** Log Started 2020-03-29T08:54:59Z ***********************
08:54:59:************************* Folding@home Client *************************
08:54:59:    Website: https://foldingathome.org/
08:54:59:  Copyright: (c) 2009-2018 foldingathome.org
08:54:59:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
08:54:59:       Args:
08:54:59:     Config: /Library/Application Support/FAHClient/config.xml
08:54:59:******************************** Build ********************************
08:54:59:    Version: 7.5.1
08:54:59:       Date: May 11 2018
08:54:59:       Time: 12:57:01
08:54:59: Repository: Git
08:54:59:   Revision: 4705bf53c635f88b8fe85af7675557e15d491ff0
08:54:59:     Branch: master
08:54:59:   Compiler: GNU 4.2.1 Compatible Apple LLVM 7.3.0 (clang-703.0.31)
08:54:59:    Options: -std=gnu++98 -O3 -funroll-loops -mmacosx-version-min=10.6
08:54:59:             -Wno-unused-local-typedefs
08:54:59:   Platform: darwin 15.6.0
08:54:59:       Bits: 64
08:54:59:       Mode: Release
08:54:59:******************************* System ********************************
08:54:59:        CPU: Intel(R) Core(TM) i5 CPU 680 @ 3.60GHz
08:54:59:     CPU ID: GenuineIntel Family 6 Model 37 Stepping 5
08:54:59:       CPUs: 4
08:54:59:     Memory: 16.00GiB
08:54:59:Free Memory: 13.35GiB
08:54:59:    Threads: POSIX_THREADS
08:54:59: OS Version: 10.13
08:54:59:Has Battery: false
08:54:59: On Battery: false
08:54:59: UTC Offset: 1
08:54:59:        PID: 79
08:54:59:        CWD: /Library/Application Support/FAHClient
08:54:59:         OS: Darwin 17.7.0 x86_64
08:54:59:    OS Arch: AMD64
08:54:59:       GPUs: 1
08:54:59:      GPU 0: Bus:1 Slot:0 Func:0 AMD:4 Madison [Mobility Radeon HD 5000 Series]
08:54:59:       CUDA: Not detected: Failed to open dynamic library 'libcuda.dylib':
08:54:59:             dlopen(libcuda.dylib, 1): image not found
08:54:59:     OpenCL: Not detected: Failed to open dynamic library 'libOpenCL.dylib':
08:54:59:             dlopen(libOpenCL.dylib, 1): image not found
08:54:59:***********************************************************************
08:54:59:<config>
08:54:59:  <!-- Network -->
08:54:59:  <proxy v=':8080'/>
08:54:59:
08:54:59:  <!-- User Information -->
08:54:59:  <passkey v='********************************'/>
08:54:59:  <team v='234020'/>
08:54:59:  <user v='Chris.Lovegrove'/>
08:54:59:
08:54:59:  <!-- Folding Slots -->
08:54:59:  <slot id='0' type='CPU'/>
08:54:59:</config>
08:54:59:Trying to access database...
08:55:19:Successfully acquired database lock
08:55:19:Enabled folding slot 00: READY cpu:3
08:55:20:WU00:FS00:Connecting to 65.254.110.245:8080
08:55:23:WARNING:WU00:FS00:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
08:55:23:WU00:FS00:Connecting to 18.218.241.186:80
08:55:23:WARNING:WU00:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
08:55:23:ERROR:WU00:FS00:Exception: Could not get an assignment
08:55:24:WU00:FS00:Connecting to 65.254.110.245:8080
08:55:24:WARNING:WU00:FS00:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
08:55:24:WU00:FS00:Connecting to 18.218.241.186:80
08:55:25:WARNING:WU00:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
08:55:25:ERROR:WU00:FS00:Exception: Could not get an assignment
08:56:24:WU00:FS00:Connecting to 65.254.110.245:8080
08:56:24:WARNING:WU00:FS00:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
08:56:24:WU00:FS00:Connecting to 18.218.241.186:80
08:56:25:WARNING:WU00:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
08:56:25:ERROR:WU00:FS00:Exception: Could not get an assignment
08:58:01:WU00:FS00:Connecting to 65.254.110.245:8080
08:58:01:WARNING:WU00:FS00:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
08:58:01:WU00:FS00:Connecting to 18.218.241.186:80
08:58:03:WARNING:WU00:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
08:58:03:ERROR:WU00:FS00:Exception: Could not get an assignment
09:00:38:WU00:FS00:Connecting to 65.254.110.245:8080
09:00:39:WU00:FS00:Assigned to work server 13.82.98.119
09:00:39:WU00:FS00:Requesting new work unit for slot 00: READY cpu:3 from 13.82.98.119
09:00:39:WU00:FS00:Connecting to 13.82.98.119:8080
09:00:43:ERROR:WU00:FS00:Exception: Server did not assign work unit
09:04:53:WU00:FS00:Connecting to 65.254.110.245:8080
09:04:53:WARNING:WU00:FS00:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
09:04:53:WU00:FS00:Connecting to 18.218.241.186:80
09:04:54:WARNING:WU00:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
09:04:54:ERROR:WU00:FS00:Exception: Could not get an assignment
Is there a setting I need to adjust to get this to connect?
Also, is there a way to set a preference for WUs for specific conditions?
Re: Recent dowload to Mac, 'Could not get an assignment'
Your setup looks okay from what I see there, you may just be running into problems getting a WU due to the heavy server load as described here - viewtopic.php?f=24&t=33193. You may just need to wait a bit. I do know that more CPU is being added and moving out of beta testing, see announcements here - viewforum.php?f=24.
lovegrovec wrote:Also, is there a way to set a preference for WUs for specific conditions?
The client has a setting for some diseases, and Any. Currently all COVID-19 are going out under Any, with a higher priority set on the server side. Adding a specific option for it would take updating the software, an effort that would take quite a while to do and test before releasing. They are using the developer resources available to add more servers and keep things going instead.
