Target Machine Actively Refused 40.114.52.201:80
LuroLucario
Post by LuroLucario »
*********************** Log Started 2020-03-29T07:51:40Z ***********************
07:51:40:************************* Folding@home Client *************************
07:51:40:        Website: https://foldingathome.org/
07:51:40:      Copyright: (c) 2009-2018 foldingathome.org
07:51:40:         Author: Joseph Coffland <joseph@cauldrondevelopment.com>
07:51:40:           Args: --open-web-control
07:51:40:         Config: C:\Users\Steven\AppData\Roaming\FAHClient\config.xml
07:51:40:******************************** Build ********************************
07:51:40:        Version: 7.5.1
07:51:40:           Date: May 11 2018
07:51:40:           Time: 13:06:32
07:51:40:     Repository: Git
07:51:40:       Revision: 4705bf53c635f88b8fe85af7675557e15d491ff0
07:51:40:         Branch: master
07:51:40:       Compiler: Visual C++ 2008
07:51:40:        Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
07:51:40:       Platform: win32 10
07:51:40:           Bits: 32
07:51:40:           Mode: Release
07:51:40:******************************* System ********************************
07:51:40:            CPU: AMD Ryzen 7 3700X 8-Core Processor
07:51:40:         CPU ID: AuthenticAMD Family 23 Model 113 Stepping 0
07:51:40:           CPUs: 16
07:51:40:         Memory: 15.93GiB
07:51:40:    Free Memory: 12.45GiB
07:51:40:        Threads: WINDOWS_THREADS
07:51:40:     OS Version: 6.2
07:51:40:    Has Battery: false
07:51:40:     On Battery: false
07:51:40:     UTC Offset: -7
07:51:40:            PID: 18992
07:51:40:            CWD: C:\Users\Steven\AppData\Roaming\FAHClient
07:51:40:             OS: Windows 10 Enterprise
07:51:40:        OS Arch: AMD64
07:51:40:           GPUs: 1
07:51:40:          GPU 0: Bus:7 Slot:0 Func:0 NVIDIA:8 TU102 [GeForce RTX 2080 Ti Rev. A]
07:51:40:                 M 13448
07:51:40:  CUDA Device 0: Platform:0 Device:0 Bus:7 Slot:0 Compute:7.5 Driver:11.0
07:51:40:OpenCL Device 0: Platform:0 Device:0 Bus:7 Slot:0 Compute:1.2 Driver:445.75
07:51:40:  Win32 Service: false
07:51:40:***********************************************************************
07:51:40:<config>
07:51:40:  <!-- Folding Core -->
07:51:40:  <checkpoint v='30'/>
07:51:40:
07:51:40:  <!-- Network -->
07:51:40:  <proxy v=':8080'/>
07:51:40:
07:51:40:  <!-- Slot Control -->
07:51:40:  <power v='full'/>
07:51:40:
07:51:40:  <!-- User Information -->
07:51:40:  <passkey v='********************************'/>
07:51:40:  <team v='142249'/>
07:51:40:  <user v='FOR_THE_BOY'/>
07:51:40:
07:51:40:  <!-- Folding Slots -->
07:51:40:  <slot id='0' type='CPU'/>
07:51:40:  <slot id='1' type='GPU'/>
07:51:40:</config>
07:51:40:Trying to access database...
07:51:40:Successfully acquired database lock
07:51:40:Enabled folding slot 00: READY cpu:15
07:51:40:Enabled folding slot 01: READY gpu:0:TU102 [GeForce RTX 2080 Ti Rev. A] M 13448
07:51:41:WU00:FS00:Connecting to 65.254.110.245:8080
07:51:41:WU01:FS01:Connecting to 65.254.110.245:8080
07:51:41:WU01:FS01:Assigned to work server 40.114.52.201
07:51:41:WU01:FS01:Requesting new work unit for slot 01: READY gpu:0:TU102 [GeForce RTX 2080 Ti Rev. A] M 13448 from 40.114.52.201
07:51:41:WU01:FS01:Connecting to 40.114.52.201:8080
07:51:42:WARNING:WU00:FS00:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
07:51:42:WU00:FS00:Connecting to 18.218.241.186:80
07:51:42:WARNING:WU00:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
07:51:42:ERROR:WU00:FS00:Exception: Could not get an assignment
07:51:42:WU00:FS00:Connecting to 65.254.110.245:8080
07:51:43:WARNING:WU00:FS00:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
07:51:43:WU00:FS00:Connecting to 18.218.241.186:80
07:51:43:WARNING:WU00:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
07:51:43:ERROR:WU00:FS00:Exception: Could not get an assignment
07:51:44:WARNING:WU01:FS01:WorkServer connection failed on port 8080 trying 80
07:51:44:WU01:FS01:Connecting to 40.114.52.201:80
07:51:46:ERROR:WU01:FS01:Exception: Failed to connect to 40.114.52.201:80: No connection could be made because the target machine actively refused it.
07:51:47:WU01:FS01:Connecting to 65.254.110.245:8080
07:51:47:WARNING:WU01:FS01:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
07:51:47:WU01:FS01:Connecting to 18.218.241.186:80
07:51:47:WU01:FS01:Assigned to work server 40.114.52.201
07:51:47:WU01:FS01:Requesting new work unit for slot 01: READY gpu:0:TU102 [GeForce RTX 2080 Ti Rev. A] M 13448 from 40.114.52.201
07:51:47:WU01:FS01:Connecting to 40.114.52.201:8080
07:51:50:WARNING:WU01:FS01:WorkServer connection failed on port 8080 trying 80
07:51:50:WU01:FS01:Connecting to 40.114.52.201:80
07:51:52:ERROR:WU01:FS01:Exception: Failed to connect to 40.114.52.201:80: No connection could be made because the target machine actively refused it.
I'm only posting this here because of the 40.114.52.201:80 message. I expected the No WUs available message, but added them in in case of relevance. Is there any way to fix the 40.xx message? Successfully running a CPU unit, but no GPU units for a while now. Probably doesn't help I start late at night since I game and occasionally stream to hours like now, 1a PST.
Re: Target Machine Actively Refused 40.114.52.201:80
Has this cleared up for you? I see from checking the Server Status page that an update to its software was applied recently, The AS could have assigned your system to 40.114.52.201 in the gap between it being taken offline for the update and getting the status update that the server was unavailable.
LuroLucario
Joe_H wrote:Has this cleared up for you? I see from checking the Server Status page that an update to its software was applied recently, The AS could have assigned your system to 40.114.52.201 in the gap between it being taken offline for the update and getting the status update that the server was unavailable.
Can confirm I've gotten some units for both CPU and GPU, though for the GPU I had upload problems as well between 128.252.203.4 and 140.163.4.231 (though that WU did eventually get uploaded after around 10 minutes of effort to 140.163.4.231). Next GPU WU should be finishing up within 15 mins -- will update if there are any upload issues.
