Please add AMD Ryzen 5 2400G with Radeon Vega Graphics
ManuelOsdoba
Post by ManuelOsdoba »
Hi,
Could you add the Integrated VEGA graphics in Ryzen 2400G?
38:00.0 VGA compatible controller [0300]: Advanced Micro Devices, Inc. [AMD/ATI] Raven Ridge [Radeon Vega Series / Radeon Vega Mobile Series] [1002:15dd] (rev c6) (prog-if 00 [VGA controller])
        Subsystem: Advanced Micro Devices, Inc. [AMD/ATI] Raven Ridge [Radeon Vega Series / Radeon Vega Mobile Series] [1002:15dd]
        Control: I/O+ Mem+ BusMaster+ SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR- FastB2B- DisINTx+
        Status: Cap+ 66MHz- UDF- FastB2B- ParErr- DEVSEL=fast >TAbort+ <TAbort- <MAbort- >SERR- <PERR- INTx-
        Latency: 0, Cache Line Size: 64 bytes
        Interrupt: pin A routed to IRQ 73
        Region 0: Memory at e0000000 (64-bit, prefetchable) [size=256M]
        Region 2: Memory at f0000000 (64-bit, prefetchable) [size=2M]
        Region 4: I/O ports at e000 [size=256]
        Region 5: Memory at fe500000 (32-bit, non-prefetchable) [size=512K]
        Expansion ROM at 000c0000 [virtual] [disabled] [size=128K]
        Capabilities: <access denied>
        Kernel driver in use: amdgpu
        Kernel modules: amdgpu
05:47:36:WU00:FS00:0xa7:Folding@home Core Shutdown: INTERRUPTED
05:47:36:WU00:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
05:47:37:WU00:FS00:Starting
05:47:37:WARNING:WU00:FS00:Changed SMP threads from 7 to 8 this can cause some work units to fail
05:47:37:WARNING:WU00:FS00:AS lowered CPUs from 8 to 7
05:47:37:WU00:FS00:Running FahCore: /opt/fah/FAHCoreWrapper /opt/fah/cores/cores.foldingathome.org/v7/lin/64bit/avx/Core_a7.fah/FahCore_a7 -dir 00 -suffix 01 -version 705 -lifeline 102680 -checkpoint 15 -np 7
05:47:37:WU00:FS00:Started FahCore on PID 104450
05:47:37:WU00:FS00:Core PID:104454
05:47:37:WU00:FS00:FahCore 0xa7 started
05:47:37:WU00:FS00:0xa7:*********************** Log Started 2020-03-29T05:47:37Z ***********************
05:47:37:WU00:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
05:47:37:WU00:FS00:0xa7:       Type: 0xa7
05:47:37:WU00:FS00:0xa7:       Core: Gromacs
05:47:37:WU00:FS00:0xa7:       Args: -dir 00 -suffix 01 -version 705 -lifeline 104450 -checkpoint 15 -np
05:47:37:WU00:FS00:0xa7:             7
05:47:37:WU00:FS00:0xa7:************************************ CBang *************************************
05:47:37:WU00:FS00:0xa7:       Date: Nov 5 2019
05:47:37:WU00:FS00:0xa7:       Time: 06:06:57
05:47:37:WU00:FS00:0xa7:   Revision: 46c96f1aa8419571d83f3e63f9c99a0d602f6da9
05:47:37:WU00:FS00:0xa7:     Branch: master
05:47:37:WU00:FS00:0xa7:   Compiler: GNU 8.3.0
05:47:37:WU00:FS00:0xa7:    Options: -std=c++11 -O3 -funroll-loops -fno-pie -fPIC
05:47:37:WU00:FS00:0xa7:   Platform: linux2 4.19.0-5-amd64
05:47:37:WU00:FS00:0xa7:       Bits: 64
05:47:37:WU00:FS00:0xa7:       Mode: Release
05:47:37:WU00:FS00:0xa7:************************************ System ************************************
05:47:37:WU00:FS00:0xa7:        CPU: AMD Ryzen 5 2400G with Radeon Vega Graphics
05:47:37:WU00:FS00:0xa7:     CPU ID: AuthenticAMD Family 23 Model 17 Stepping 0
05:47:37:WU00:FS00:0xa7:       CPUs: 8
05:47:37:WU00:FS00:0xa7:     Memory: 61.83GiB
05:47:37:WU00:FS00:0xa7:Free Memory: 42.79GiB
05:47:37:WU00:FS00:0xa7:    Threads: POSIX_THREADS
05:47:37:WU00:FS00:0xa7: OS Version: 5.5
05:47:37:WU00:FS00:0xa7:Has Battery: false
05:47:37:WU00:FS00:0xa7: On Battery: false
05:47:37:WU00:FS00:0xa7: UTC Offset: 2
05:47:37:WU00:FS00:0xa7:        PID: 104454
05:47:37:WU00:FS00:0xa7:        CWD: /opt/fah/work
05:47:37:WU00:FS00:0xa7:******************************** Build - libFAH ********************************
05:47:37:WU00:FS00:0xa7:    Version: 0.0.18
05:47:37:WU00:FS00:0xa7:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
05:47:37:WU00:FS00:0xa7:  Copyright: 2019 foldingathome.org
05:47:37:WU00:FS00:0xa7:   Homepage: https://foldingathome.org/
05:47:37:WU00:FS00:0xa7:       Time: 06:13:26
05:47:37:WU00:FS00:0xa7:   Revision: 490c9aa2957b725af319379424d5c5cb36efb656
05:47:37:WU00:FS00:0xa7:************************************ Build *************************************
05:47:37:WU00:FS00:0xa7:       SIMD: avx_256
05:47:37:WU00:FS00:0xa7:********************************************************************************
05:47:37:WU00:FS00:0xa7:Project: 14308 (Run 9, Clone 155, Gen 49)
05:47:37:WU00:FS00:0xa7:Unit: 0x000000399bf7a4d55e66c2cba957f750
05:47:37:WU00:FS00:0xa7:Digital signatures verified
05:47:37:WU00:FS00:0xa7:Reducing thread count from 7 to 6 to avoid domain decomposition by a prime number > 3
05:47:37:WU00:FS00:0xa7:Calling: mdrun -s frame49.tpr -o frame49.trr -cpi state.cpt -cpt 15 -nt 6
05:47:37:WU00:FS00:0xa7:Steps: first=24500000 total=500000
05:47:38:WU00:FS00:0xa7:Completed 21212 out of 500000 steps (4%)
05:49:29:WU00:FS00:0xa7:Completed 25000 out of 500000 steps (5%)
05:51:59:WU00:FS00:0xa7:Completed 30000 out of 500000 steps (6%)
05:54:25:WU00:FS00:0xa7:Completed 35000 out of 500000 steps (7%)
05:56:55:WU00:FS00:0xa7:Completed 40000 out of 500000 steps (8%)
05:59:23:WU00:FS00:0xa7:Completed 45000 out of 500000 steps (9%)
06:01:54:WU00:FS00:0xa7:Completed 50000 out of 500000 steps (10%)
06:04:23:WU00:FS00:0xa7:Completed 55000 out of 500000 steps (11%)
06:06:49:WU00:FS00:0xa7:Completed 60000 out of 500000 steps (12%)
processor	: 7
vendor_id	: AuthenticAMD
cpu family	: 23
model		: 17
model name	: AMD Ryzen 5 2400G with Radeon Vega Graphics
stepping	: 0
microcode	: 0x810100b
cpu MHz		: 3692.844
cache size	: 512 KB
physical id	: 0
siblings	: 8
core id		: 3
cpu cores	: 4
apicid		: 7
initial apicid	: 7
fpu		: yes
fpu_exception	: yes
cpuid level	: 13
wp		: yes
flags		: fpu vme de pse tsc msr pae mce cx8 apic sep mtrr pge mca cmov pat pse36 clflush mmx fxsr sse sse2 ht syscall nx mmxext fxsr_opt pdpe1gb rdtscp lm constant_tsc rep_good nopl nonstop_tsc cpuid extd_apicid aperfmperf pni pclmulqdq monitor ssse3 fma cx16 sse4_1 sse4_2 movbe popcnt aes xsave avx f16c rdrand lahf_lm cmp_legacy svm extapic cr8_legacy abm sse4a misalignsse 3dnowprefetch osvw skinit wdt tce topoext perfctr_core perfctr_nb bpext perfctr_llc mwaitx cpb hw_pstate sme ssbd sev ibpb vmmcall fsgsbase bmi1 avx2 smep bmi2 rdseed adx smap clflushopt sha_ni xsaveopt xsavec xgetbv1 xsaves clzero irperf xsaveerptr arat npt lbrv svm_lock nrip_save tsc_scale vmcb_clean flushbyasid decodeassists pausefilter pfthreshold avic v_vmsave_vmload vgif overflow_recov succor smca
bugs		: sysret_ss_attrs null_seg spectre_v1 spectre_v2 spec_store_bypass
bogomips	: 7189.68
TLB size	: 2560 4K pages
clflush size	: 64
cache_alignment	: 64
address sizes	: 43 bits physical, 48 bits virtual
power management: ts ttp tm hwpstate eff_freq_ro [13] [14]
Kind regards,
Manuel
Re: Please add AMD Ryzen 5 2400G with Radeon Vega Graphics
Already present in the GPUs.txt file, this shares the same device ID, 1002:15dd, as the Vega 8 Mobile and should be configurable.
ManuelOsdoba
Hi, for completeness, the clinfo from Razen 5 2400g:
[ossy@engineering ~]$ clinfo
  Platform Name                                   AMD Accelerated Parallel Processing
  Platform Vendor                                 Advanced Micro Devices, Inc.
  Platform Version                                OpenCL 2.1 AMD-APP (3004.6)
  Platform Extensions                             cl_khr_icd cl_amd_event_callback cl_amd_offline_devices
  Platform Host timer resolution                  1ns
  Platform Extensions function suffix             AMD
  Device Name                                     gfx902
  Device Vendor                                   Advanced Micro Devices, Inc.
  Device Version                                  OpenCL 2.0 AMD-APP (3004.6)
  Driver Version                                  3004.6 (PAL,HSAIL)
  Device OpenCL C Version                         OpenCL C 2.0
  Device Board Name (AMD)                         Unknown AMD GPU
  Device Topology (AMD)                           PCI-E, 38:00.0
  Max compute units                               11
  SIMD per compute unit (AMD)                     4
  SIMD width (AMD)                                16
  SIMD instruction width (AMD)                    1
  Max clock frequency                             1250MHz
  Graphics IP (AMD)                               9.2
    Max number of sub-devices                     11
    Supported affinity domains                    (n/a)
  Max work item sizes                             1024x1024x1024
  Preferred work group size (AMD)                 256
  Max work group size (AMD)                       1024
  Preferred work group size multiple              64
  Wavefront width (AMD)                           64
    char                                                 4 / 4
    short                                                2 / 2
    half                                                 1 / 1        (cl_khr_fp16)
  Half-precision Floating-point support           (cl_khr_fp16)
    Denormals                                     No
    Infinity and NANs                             No
    Round to nearest                              No
    Round to zero                                 No
    Round to infinity                             No
    IEEE754-2008 fused multiply-add               No
    Denormals                                     No
  Global memory size                              2684354560 (2.5GiB)
  Global free memory (AMD)                        2551712 (2.434GiB)
  Global memory channels (AMD)                    4
  Global memory banks per channel (AMD)           4
  Global memory bank width (AMD)                  256 bytes
  Max memory allocation                           912680550 (870.4MiB)
  Unified memory for Host and Device              Yes
  Shared Virtual Memory (SVM) capabilities        (core)
    Coarse-grained buffer sharing                 Yes
    Fine-grained buffer sharing                   Yes
    Fine-grained system sharing                   No
    Atomics                                       No
  Alignment of base address                       2048 bits (256 bytes)
  Preferred alignment for atomics
    SVM                                           0 bytes
    Global                                        0 bytes
    Local                                         0 bytes
  Max size for global variable                    821412352 (783.4MiB)
  Preferred total size of global vars             2684354560 (2.5GiB)
  Global Memory cache size                        16384 (16KiB)
  Global Memory cache line size                   64 bytes
    Max number of samplers per kernel             16
    Max size for 1D images from buffer            134217728 pixels
    Max 1D or 2D image array size                 2048 images
    Base address alignment for 2D image buffers   256 bytes
    Pitch alignment for 2D image buffers          256 pixels
    Max 2D image size                             16384x16384 pixels
    Max 3D image size                             2048x2048x2048 pixels
    Max number of read image args                 128
    Max number of write image args                64
    Max number of read/write image args           64
  Max number of pipe args                         16
  Max active pipe reservations                    16
  Max pipe packet size                            912680550 (870.4MiB)
  Local memory size                               65536 (64KiB)
  Local memory syze per CU (AMD)                  65536 (64KiB)
  Local memory banks (AMD)                        32
  Max constant buffer size                        912680550 (870.4MiB)
  Preferred constant buffer size (AMD)            16384 (16KiB)
  Queue properties (on host)
  Queue properties (on device)
    Out-of-order execution                        Yes
    Preferred size                                262144 (256KiB)
    Max size                                      8388608 (8MiB)
  Max queues on device                            1
  Max events on device                            1024
  Number of P2P devices (AMD)                     0
  P2P devices (AMD)                               <printDeviceInfo:147: get number of CL_DEVICE_P2P_DEVICES_AMD : error -30>
  Profiling timer offset since Epoch (AMD)        1585390551571452631ns (Sat Mar 28 11:15:51 2020)
  Execution capabilities
    Thread trace supported (AMD)                  Yes
    Number of async queues (AMD)                  4
    Max real-time compute queues (AMD)            0
    Max real-time compute units (AMD)             0
  printf() buffer size                            4194304 (4MiB)
  Built-in kernels                                (n/a)
  Device Extensions                               cl_khr_fp64 cl_amd_fp64 cl_khr_global_int32_base_atomics cl_khr_global_int32_extended_atomics cl_khr_local_int32_base_atomics cl_khr_local_int32_extended_atomics cl_khr_int64_base_atomics cl_khr_int64_extended_atomics cl_khr_3d_image_writes cl_khr_byte_addressable_store cl_khr_fp16 cl_khr_gl_sharing cl_khr_gl_depth_images cl_amd_device_attribute_query cl_amd_vec3 cl_amd_printf cl_amd_media_ops cl_amd_media_ops2 cl_amd_popcnt cl_khr_image2d_from_buffer cl_khr_subgroups cl_khr_gl_event cl_khr_depth_images cl_khr_mipmap_image cl_khr_mipmap_image_writes cl_amd_copy_buffer_p2p
NULL platform behavior
  clGetPlatformInfo(NULL, CL_PLATFORM_NAME, ...)  AMD Accelerated Parallel Processing
  clGetDeviceIDs(NULL, CL_DEVICE_TYPE_ALL, ...)   Success [AMD]
  clCreateContext(NULL, ...) [default]            Success [AMD]
  clCreateContextFromType(NULL, CL_DEVICE_TYPE_DEFAULT)  Success (1)
    Device Name                                   gfx902
  clCreateContextFromType(NULL, CL_DEVICE_TYPE_GPU)  Success (1)
    Device Name                                   gfx902
  clCreateContextFromType(NULL, CL_DEVICE_TYPE_CUSTOM)  No devices found in platform
  clCreateContextFromType(NULL, CL_DEVICE_TYPE_ALL)  Success (1)
    Device Name                                   gfx902
ICD loader properties
  ICD loader Name                                 OpenCL ICD Loader
  ICD loader Vendor                               OCL Icd free software
  ICD loader Version                              2.2.12
  ICD loader Profile                              OpenCL 2.2
BobWilliams757
Ryzen 2400G APU
32 GB DDR4-3200
MSI GTX 1660 Super Gaming X
Post by BobWilliams757 »
Joe_H wrote:Already present in the GPUs.txt file, this shares the same device ID, 1002:15dd, as the Vega 8 Mobile and should be configurable.
My 2400G detected as the Vega 8 Mobile and has been folding just fine. Well, slow obviously, but better than nothing!
Fold them if you get them!
iceman1992
Post by iceman1992 »
Out of curiosity, what kind of PPD do you get from that?
Someone else reported about 16,000 PPD - YMMV
iceman1992
Oh, not bad actually for integrated graphics
BobWilliams757
Ryzen 2400G APU
32 GB DDR4-3200
Mine varies from high 16s to low 17s with the GPU only.
It's not much, but it's something.
