How to view logs on windows 10
Kebast
Post by Kebast »
I'm having an issue with windows 10 client where I have to quit the folding client before the log writes to the logs directory. Normally I'd just look on the logs tab in the app, but parts scroll off during the day so I can't see everything.
Is there a better way to view the full log file without having to stop the client?
Ryzen 5900x 12T - RTX 4070 TI
jonault
Re: How to view logs on windows 10
Post by jonault »
You can find the current log file in /Users/<user name>/AppData/FAHClient/log.txt. Previous log files can be found in the logs directory in that same folder.
I don't know of a way to get the Advanced Control to show the full log file.
Kebast
Post by Kebast »
Hah, thanks. No idea how I missed that. Probably just saw the logs directory and didn't look past that.
If you click on the Refresh button next to the log window in FAHControl, that reloads the current log from the beginning. You can then scroll all the way up, turning off "Follow" helps.
geokilla
Hardware configuration: Intel Core i5-10600KF @ 4.9Ghz @ 1.25V
MSI Z490 Gaming Edge Wi-Fi BIOS v17
XPG D50 32GB DDR4-3200 16-19-9-36 2T (Samsung M-Die)
XPG S11 Pro 1TB and Western Digital WD140EDFZ 14TB
EVGA RTX 3060 XC
Corsair RM650x
Phantek P360A with Noctua Exhaust Fans
Post by geokilla »
Did the location get moved? I can't find the logs. Pressing refresh doesn't bring up older logs either. I think I lost my CPU WUs by turning off the computer each night.
ASUS TUF RTX 3070 OC
Corsair RM650x
geokilla wrote: Thu Jun 09, 2022 5:21 pm Did the location get moved? I can't find the logs. Pressing refresh doesn't bring up older logs either. I think I lost my CPU WUs by turning off the computer each night.
The current version of the client stores work files and the log files in a different location to make it possible for the client to be installed and used by more than one user on a Windows PC. Go to this topic - viewtopic.php?p=327412#p327412, and follow Method 2 on locating and posting logs. It includes how to get to both locations for the older client versions and the current one.
