11762 might be incomplete due to automatic driver update
I forgot to turn off nvidia driver auto updates and i was folding 11762, I immediately turned driver updates of afterwards, but it already updated the gpu driver. Then when i started the folding@home client after the driver update, it was sending the "results" of 11762 and started working on the next one right away, but i think it didnt finish 11762 before the update happened.
davidcoton
Re: 11762 might be incomplete due to automatic driver update
Don't panic, the system will sort it out. Nothing worse that some lost credit for you and a re-issued WU for the project.
Most long-term folders have done that or worse at some point.
