gt635m 391.35 installed from nvidia
chrisdenhaag
Post by chrisdenhaag »
0:45:37:WU00:FS01:Received Unit: id:00 state:DOWNLOAD error:NO_ERROR project:11780 run:0 clone:5391 gen:14 core:0x22 unit:0x000000120d5a98395e758953a88ac3e5
20:45:37:WU00:FS01:Starting
20:45:37:WU00:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\Chris\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/Core_22.fah/FahCore_22.exe -dir 00 -suffix 01 -version 705 -lifeline 11940 -checkpoint 15 -gpu-vendor nvidia -opencl-platform 1 -opencl-device 0 -cuda-device 0 -gpu 0
20:45:37:WU00:FS01:Started FahCore on PID 12980
20:45:37:WU00:FS01:Core PID:13380
20:45:37:WU00:FS01:FahCore 0x22 started
20:45:39:WU00:FS01:0x22:*********************** Log Started 2020-03-27T20:45:38Z ***********************
20:45:39:WU00:FS01:0x22:*************************** Core22 Folding@home Core ***************************
20:45:39:WU00:FS01:0x22:       Type: 0x22
20:45:39:WU00:FS01:0x22:       Core: Core22
20:45:39:WU00:FS01:0x22:    Website: https://foldingathome.org/
20:45:39:WU00:FS01:0x22:  Copyright: (c) 2009-2018 foldingathome.org
20:45:39:WU00:FS01:0x22:     Author: John Chodera <john.chodera@choderalab.org> and Rafal Wiewiora
20:45:39:WU00:FS01:0x22:             <rafal.wiewiora@choderalab.org>
20:45:39:WU00:FS01:0x22:       Args: -dir 00 -suffix 01 -version 705 -lifeline 12980 -checkpoint 15
20:45:39:WU00:FS01:0x22:             -gpu-vendor nvidia -opencl-platform 1 -opencl-device 0 -cuda-device
20:45:39:WU00:FS01:0x22:             0 -gpu 0
20:45:39:WU00:FS01:0x22:     Config: <none>
20:45:39:WU00:FS01:0x22:************************************ Build *************************************
20:45:39:WU00:FS01:0x22:    Version: 0.0.2
20:45:39:WU00:FS01:0x22:       Date: Dec 6 2019
20:45:39:WU00:FS01:0x22:       Time: 21:30:31
20:45:39:WU00:FS01:0x22: Repository: Git
20:45:39:WU00:FS01:0x22:   Revision: abeb39247cc72df5af0f63723edafadb23d5dfbe
20:45:39:WU00:FS01:0x22:     Branch: HEAD
20:45:39:WU00:FS01:0x22:   Compiler: Visual C++ 2008
20:45:39:WU00:FS01:0x22:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
20:45:39:WU00:FS01:0x22:   Platform: win32 10
20:45:39:WU00:FS01:0x22:       Bits: 64
20:45:39:WU00:FS01:0x22:       Mode: Release
20:45:39:WU00:FS01:0x22:************************************ System ************************************
20:45:39:WU00:FS01:0x22:        CPU: Intel(R) Core(TM) i7-3630QM CPU @ 2.40GHz
20:45:39:WU00:FS01:0x22:     CPU ID: GenuineIntel Family 6 Model 58 Stepping 9
20:45:39:WU00:FS01:0x22:       CPUs: 8
20:45:39:WU00:FS01:0x22:     Memory: 7.88GiB
20:45:39:WU00:FS01:0x22:Free Memory: 2.97GiB
20:45:39:WU00:FS01:0x22:    Threads: WINDOWS_THREADS
20:45:39:WU00:FS01:0x22: OS Version: 6.2
20:45:39:WU00:FS01:0x22:Has Battery: true
20:45:39:WU00:FS01:0x22: On Battery: false
20:45:39:WU00:FS01:0x22: UTC Offset: 1
20:45:39:WU00:FS01:0x22:        PID: 13380
20:45:39:WU00:FS01:0x22:        CWD: C:\Users\Chris\AppData\Roaming\FAHClient\work
20:45:39:WU00:FS01:0x22:         OS: Windows 10 Home
20:45:39:WU00:FS01:0x22:    OS Arch: AMD64
20:45:39:WU00:FS01:0x22:********************************************************************************
20:45:39:WU00:FS01:0x22:Project: 11780 (Run 0, Clone 5391, Gen 14)
20:45:39:WU00:FS01:0x22:Unit: 0x000000120d5a98395e758953a88ac3e5
20:45:39:WU00:FS01:0x22:Reading tar file core.xml
20:45:39:WU00:FS01:0x22:Reading tar file integrator.xml
20:45:39:WU00:FS01:0x22:Reading tar file state.xml
20:45:39:WU00:FS01:0x22:Reading tar file system.xml
20:45:39:WU00:FS01:0x22:Digital signatures verified
20:45:39:WU00:FS01:0x22:Folding@home GPU Core22 Folding@home Core
20:45:39:WU00:FS01:0x22:Version 0.0.2
20:45:48:WU00:FS01:0x22:ERROR:exception: Error initializing context: clGetDeviceInfo (-5)
20:45:48:WU00:FS01:0x22:Saving result file ..\logfile_01.txt
20:45:48:WU00:FS01:0x22:Saving result file science.log
20:45:48:WU00:FS01:0x22:Folding@home Core Shutdown: BAD_WORK_UNIT
20:45:49:WARNING:WU00:FS01:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
20:45:49:WU00:FS01:Sending unit results: id:00 state:SEND error:FAULTY project:11780 run:0 clone:5391 gen:14 core:0x22 unit:0x000000120d5a98395e758953a88ac3e5
14:58:38:          GPU 0: Bus:1 Slot:0 Func:0 NVIDIA:2 GF108 [GeForce GT 635M]
14:58:38:  CUDA Device 0: Platform:0 Device:0 Bus:1 Slot:0 Compute:2.1 Driver:9.1
14:58:38:OpenCL Device 1: Platform:0 Device:1 Bus:NA Slot:NA Compute:1.2 Driver:10.18
14:58:38:OpenCL Device 2: Platform:1 Device:0 Bus:1 Slot:0 Compute:1.1 Driver:391.35
14:58:38:  Win32 Service: false
all slots set to -1 at the moment in config.
ERROR:exception: Error initializing context: clGetDeviceInfo (-5) is the same error I get from FAhBench when FAH is running, I get results from FAHBench when FAH is not running. I don't get results at other times.
I think I get results from FAHBanch when index is set to 1, but I am not sure.
Where am I going wrong?
jonault
Re: gt635m 391.35 installed from nvidia
Post by jonault »
According to TechPowerUp that GPU doesn't support OpenCL 1.2, so I don't think it's going to work. You can still do CPU folding.
chrisdenhaag
Yep, I was digging around in Caps Viewer and saw "OpenCL 1.1 CUDA" against version.
Problem solved.
chrisdenhaag
It appears it is WU dependent, I received and folded yesterday.
08:09:39:WU00:FS01:Requesting new work unit for slot 01: READY gpu:0:GF108 [GeForce GT 635M] from 140.163.4.231
08:09:39:WU00:FS01:Connecting to 140.163.4.231:8080
08:12:13:WU00:FS01:Downloading 13.15MiB
08:12:20:WU00:FS01:Download 17.11%
08:12:27:WU00:FS01:Download 22.34%
08:12:33:WU00:FS01:Download 76.05%
08:12:35:WU00:FS01:Download complete
08:12:35:WU00:FS01:Received Unit: id:00 state:DOWNLOAD error:NO_ERROR project:11752 run:0 clone:1160 gen:7 core:0x22 unit:0x0000001e8ca304e75e6a805f4389da90
08:12:35:WU00:FS01:Starting
08:12:35:WU00:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\Chris\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/Core_22.fah/FahCore_22.exe -dir 00 -suffix 01 -version 705 -lifeline 11940 -checkpoint 15 -gpu-vendor nvidia -opencl-platform 1 -opencl-device 0 -cuda-device 0 -gpu 0
08:12:35:WU00:FS01:Started FahCore on PID 15544
08:12:35:WU00:FS01:Core PID:10344
08:12:35:WU00:FS01:FahCore 0x22 started
08:12:36:WU00:FS01:0x22:*********************** Log Started 2020-03-29T08:12:35Z ***********************
08:12:36:WU00:FS01:0x22:*************************** Core22 Folding@home Core ***************************
08:12:36:WU00:FS01:0x22:       Type: 0x22
08:12:36:WU00:FS01:0x22:       Core: Core22
08:12:36:WU00:FS01:0x22:    Website: https://foldingathome.org/
08:12:36:WU00:FS01:0x22:  Copyright: (c) 2009-2018 foldingathome.org
08:12:36:WU00:FS01:0x22:     Author: John Chodera <john.chodera@choderalab.org> and Rafal Wiewiora
08:12:36:WU00:FS01:0x22:             <rafal.wiewiora@choderalab.org>
08:12:36:WU00:FS01:0x22:       Args: -dir 00 -suffix 01 -version 705 -lifeline 15544 -checkpoint 15
08:12:36:WU00:FS01:0x22:             -gpu-vendor nvidia -opencl-platform 1 -opencl-device 0 -cuda-device
08:12:36:WU00:FS01:0x22:             0 -gpu 0
08:12:36:WU00:FS01:0x22:     Config: <none>
08:12:36:WU00:FS01:0x22:************************************ Build *************************************
08:12:36:WU00:FS01:0x22:    Version: 0.0.2
08:12:36:WU00:FS01:0x22:       Date: Dec 6 2019
08:12:36:WU00:FS01:0x22:       Time: 21:30:31
08:12:36:WU00:FS01:0x22: Repository: Git
08:12:36:WU00:FS01:0x22:   Revision: abeb39247cc72df5af0f63723edafadb23d5dfbe
08:12:36:WU00:FS01:0x22:     Branch: HEAD
08:12:36:WU00:FS01:0x22:   Compiler: Visual C++ 2008
08:12:36:WU00:FS01:0x22:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
08:12:36:WU00:FS01:0x22:   Platform: win32 10
08:12:36:WU00:FS01:0x22:       Bits: 64
08:12:36:WU00:FS01:0x22:       Mode: Release
08:12:36:WU00:FS01:0x22:************************************ System ************************************
08:12:36:WU00:FS01:0x22:        CPU: Intel(R) Core(TM) i7-3630QM CPU @ 2.40GHz
08:12:36:WU00:FS01:0x22:     CPU ID: GenuineIntel Family 6 Model 58 Stepping 9
08:12:36:WU00:FS01:0x22:       CPUs: 8
08:12:36:WU00:FS01:0x22:     Memory: 7.88GiB
08:12:36:WU00:FS01:0x22:Free Memory: 2.22GiB
08:12:36:WU00:FS01:0x22:    Threads: WINDOWS_THREADS
08:12:36:WU00:FS01:0x22: OS Version: 6.2
08:12:36:WU00:FS01:0x22:Has Battery: true
08:12:36:WU00:FS01:0x22: On Battery: false
08:12:36:WU00:FS01:0x22: UTC Offset: 2
08:12:36:WU00:FS01:0x22:        PID: 10344
08:12:36:WU00:FS01:0x22:        CWD: C:\Users\Chris\AppData\Roaming\FAHClient\work
08:12:36:WU00:FS01:0x22:         OS: Windows 10 Home
08:12:36:WU00:FS01:0x22:    OS Arch: AMD64
08:12:36:WU00:FS01:0x22:********************************************************************************
08:12:36:WU00:FS01:0x22:Project: 11752 (Run 0, Clone 1160, Gen 7)
08:12:36:WU00:FS01:0x22:Unit: 0x0000001e8ca304e75e6a805f4389da90
08:12:36:WU00:FS01:0x22:Reading tar file core.xml
08:12:36:WU00:FS01:0x22:Reading tar file integrator.xml
08:12:36:WU00:FS01:0x22:Reading tar file state.xml
08:12:37:WU00:FS01:0x22:Reading tar file system.xml
08:12:38:WU00:FS01:0x22:Digital signatures verified
08:12:38:WU00:FS01:0x22:Folding@home GPU Core22 Folding@home Core
08:12:38:WU00:FS01:0x22:Version 0.0.2
08:13:08:WU00:FS01:0x22:Completed 0 out of 1000000 steps (0%)
08:13:08:WU00:FS01:0x22:Temperature control disabled. Requirements: single Nvidia GPU, tmax must be < 110 and twait >= 900
09:17:29:WU00:FS01:0x22:Completed 10000 out of 1000000 steps (1%)
10:23:19:WU00:FS01:0x22:Completed 20000 out of 1000000 steps (2%)
1 hour 4 minutes TPF...
This GPU has Double Precision (FP64) support, so it should work ... but it might be too slow to meet the deadlines.
Hmmm. So why does FAH's hardware detection say ...Slot:0 Compute:1.1...
If it supports hardware DP, shouldn't it say 1.2?
Well, I guess we were all wrong about this OpenCL 1.2 theory ... :
OpenCL 1.0 adds support for double precision floating-point as an optional extension. An application that wants to use double will need to include the #pragma OPENCL EXTENSION cl_khr_fp64 : enable directive before any double precision data type is declared in the kernel code.
From : https://www.khronos.org/registry/OpenCL ... _fp64.html
OpenCL 1.1 supports double precision floating-point as an optional extension. An application that wants to use double will need to include the #pragma OPENCL EXTENSION cl_khr_fp64 : enable directive before any double precision data type is declared in the kernel code.
cl_khr_fp64
Provided for backward compatibility if double floating-point precision is supported.
The 64-bit double scalar and corresponding vector types are optional types that are supported if CL_DEVICE_DOUBLE_FP_CONFIG in the table of allowed values for param_name for clGetDeviceInfo for a device is not zero.
So we have to stick to this guide line : G8x/G9x and GT2xx GPUs doesn't have hardware support of FP64, but starting with Fermi (GFxxx) GPUs, DP is supported.
mofalter
Post by mofalter »
I had the same issue with a GT520M and hit exactly the same effects.
First i had my old NVIDIA drivers installed, giving me these clDeviceID (-1) error, sometimes posted here in formu already.
This was solved by installing latest NVIDIA driver directly from NVIDIA (as laptop manufacturer won't updates it anymore)
Second then i run into your clGetDeviceInfo (-5) error. Looking around i came to the same folding bench mark and got the same trouble there.
This could be solved by following procedure.
Starting NVIDIA Control panel and going to "Change Screen settings with preview" (or something similar labeled in your system language).
(This starts a low performace anti aliasing rendering on NVIDIA GPU) -> i can see this in the NVIDIA optimus GPU-Activity program in my task bar.
-> Thus now NVIDIA card is always powered on (Optimus extension)
If i now run FaHbench it works in all settings (CPU, GPU single precision and GPU double precision) It gives me following results:
1.01 with CPU (on one core)
2.2 with GPU single precision (with 3 GPU cores used)
0.4 with GPU double precision (with 4 GPU cores used)
Anyway as soon as GPU is used heat siginificantly goes up, couldn't yet say what happend if f@h utilizes all avalibale Cores at the same time ... but it should give some additional calculation powers.
Usefull Links:
Nice help:
https://foldingforum.org/viewtopic.php?f=74&t=34233
Bench mark for F@H testing:
http://fahbench.github.io/
Important latest drivers:
https://www.nvidia.com
So now happy folding :)
