My computer keeps overheating whenever F@H runs.
Is there an option to limit CPU usage by the program? (64bit Win7 Home.)
Limit CPU usage?
Re: Limit CPU usage?
You can see this to limit CPU and GPU usage https://github.com/FoldingAtHome/fah-issues/issues/1324Mugsy_in_Houston wrote:My computer keeps overheating whenever F@H runs.
Consulta como ver TV y leer noticias desde tu movil en una sola app con FeedTV.
Apoya la investigación desde esta imagen
Welcome to Folding@Home!
In the Advanced Control you can set the number of threads F@H is allowed to use. I do not know how many threads you have but if you do, you can make adjustments.
You can enter any number from 1 to the number of threads you CPU supports.
If you have GPUs, F@H reserves one CPU per GPU to feed it data across the PCIE bus.
F@H has difficulty with large primes and their multiples number of CPUs.
7 is always large, 5 is sometimes large, and 3 is never large. Try to choose a number that is a multiple of 2 and/or 3.
2, 3, 4, 6, 8, 9, 12, 16, 18, 24, 27, etc. are good numbers of CPUs to choose.
5. 10. 15, 20 etc may work most of the time. Other numbers will bite you.
Having said that, the new 7.51 client tries to automatically shift down to a safe number.
Enter the number you choose and click save.
Perfect. Just what I needed. Thx.
