*********************** Log Started 2020-03-28T04:00:45Z ***********************
04:00:45:************************* Folding@home Client *************************
04:00:45: Website: https://foldingathome.org/
04:00:45: Copyright: (c) 2009-2018 foldingathome.org
04:00:45: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
04:00:45: Args:
04:00:45: Config: C:\Users\C\AppData\Roaming\FAHClient\config.xml
04:00:45:******************************** Build ********************************
04:00:45: Version: 7.5.1
04:00:45: Date: May 11 2018
04:00:45: Time: 13:06:32
04:00:45: Repository: Git
04:00:45: Revision: 4705bf53c635f88b8fe85af7675557e15d491ff0
04:00:45: Branch: master
04:00:45: Compiler: Visual C++ 2008
04:00:45: Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
04:00:45: Platform: win32 10
04:00:45: Bits: 32
04:00:45: Mode: Release
04:00:45:******************************* System ********************************
04:00:45: CPU: Intel(R) Core(TM)2 Duo CPU E7500 @ 2.93GHz
04:00:45: CPU ID: GenuineIntel Family 6 Model 23 Stepping 10
04:00:45: CPUs: 2
04:00:45: Memory: 1.99GiB
04:00:45: Free Memory: 1.47GiB
04:00:45: Threads: WINDOWS_THREADS
04:00:45: OS Version: 6.1
04:00:45: Has Battery: false
04:00:45: On Battery: false
04:00:45: UTC Offset: 7
04:00:45: PID: 1604
04:00:45: CWD: C:\Users\C\AppData\Roaming\FAHClient
04:00:45: OS: Windows 7 Ultimate Service Pack 1
04:00:45: OS Arch: X86
04:00:45: GPUs: 0
04:00:45: CUDA: Not detected: Failed to open dynamic library 'nvcuda.dll': The
04:00:45: specified module could not be found.
04:00:45:
04:00:45: OpenCL: Not detected: Failed to open dynamic library 'OpenCL.dll': The
04:00:45:
04:00:45:Win32 Service: false
04:00:45:***********************************************************************
04:00:45:<config>
04:00:45: <!-- Folding Core -->
04:00:45: <core-priority v='low'/>
04:00:45:
04:00:45: <!-- Network -->
04:00:45: <proxy v=':8080'/>
04:00:45:
04:00:45: <!-- Slot Control -->
04:00:45: <power v='full'/>
04:00:45:
04:00:45: <!-- User Information -->
04:00:45: <team v='38156'/>
04:00:45: <user v='LetterL76'/>
04:00:45:
04:00:45: <!-- Folding Slots -->
04:00:45: <slot id='1' type='CPU'/>
04:00:45:</config>
04:00:45:Trying to access database...
04:00:45:Successfully acquired database lock
04:00:45:Enabled folding slot 01: READY cpu:2
04:00:45:WU01:FS01:Starting
04:00:45:WU01:FS01:Running FahCore: "C:\Program Files\FAHClient/FAHCoreWrapper.exe" C:\Users\C\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/32bit/Core_a7.fah/FahCore_a7.exe -dir 01 -suffix 01 -version 705 -lifeline 1604 -checkpoint 15 -np 2
04:00:45:WU01:FS01:Started FahCore on PID 1496
04:00:46:WU01:FS01:Core PID:1220
04:00:46:WU01:FS01:FahCore 0xa7 started
04:00:47:WU01:FS01:0xa7:*********************** Log Started 2020-03-28T04:00:46Z ***********************
04:00:47:WU01:FS01:0xa7:************************** Gromacs Folding@home Core ***************************
04:00:47:WU01:FS01:0xa7: Type: 0xa7
04:00:47:WU01:FS01:0xa7: Core: Gromacs
04:00:47:WU01:FS01:0xa7: Args: -dir 01 -suffix 01 -version 705 -lifeline 1496 -checkpoint 15 -np 2
04:00:47:WU01:FS01:0xa7:************************************ CBang *************************************
04:00:47:WU01:FS01:0xa7: Date: Oct 26 2019
04:00:47:WU01:FS01:0xa7: Time: 01:27:58
04:00:47:WU01:FS01:0xa7: Revision: c46a1a011a24143739ac7218c5a435f66777f62f
04:00:47:WU01:FS01:0xa7: Branch: master
04:00:47:WU01:FS01:0xa7: Compiler: Visual C++ 2008
04:00:47:WU01:FS01:0xa7: Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
04:00:47:WU01:FS01:0xa7: Platform: win32 10
04:00:47:WU01:FS01:0xa7: Bits: 32
04:00:47:WU01:FS01:0xa7: Mode: Release
04:00:47:WU01:FS01:0xa7:************************************ System ************************************
04:00:47:WU01:FS01:0xa7: CPU: Intel(R) Core(TM)2 Duo CPU E7500 @ 2.93GHz
04:00:47:WU01:FS01:0xa7: CPU ID: GenuineIntel Family 6 Model 23 Stepping 10
04:00:47:WU01:FS01:0xa7: CPUs: 2
04:00:47:WU01:FS01:0xa7: Memory: 1.99GiB
04:00:47:WU01:FS01:0xa7:Free Memory: 1.44GiB
04:00:47:WU01:FS01:0xa7: Threads: WINDOWS_THREADS
04:00:47:WU01:FS01:0xa7: OS Version: 6.1
04:00:47:WU01:FS01:0xa7:Has Battery: false
04:00:47:WU01:FS01:0xa7: On Battery: false
04:00:47:WU01:FS01:0xa7: UTC Offset: 7
04:00:47:WU01:FS01:0xa7: PID: 1220
04:00:47:WU01:FS01:0xa7: CWD: C:\Users\C\AppData\Roaming\FAHClient\work
04:00:47:WU01:FS01:0xa7:******************************** Build - libFAH ********************************
04:00:47:WU01:FS01:0xa7: Version: 0.0.18
04:00:47:WU01:FS01:0xa7: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
04:00:47:WU01:FS01:0xa7: Copyright: 2019 foldingathome.org
04:00:47:WU01:FS01:0xa7: Homepage: https://foldingathome.org/
04:00:47:WU01:FS01:0xa7: Time: 01:34:37
04:00:47:WU01:FS01:0xa7: Revision: c1e3513b1bc0c16013668f2173ee969e5995b38e
04:00:47:WU01:FS01:0xa7:************************************ Build *************************************
04:00:47:WU01:FS01:0xa7: SIMD: sse2
04:00:47:WU01:FS01:0xa7:********************************************************************************
04:00:47:WU01:FS01:0xa7:Project: 13850 (Run 0, Clone 1826, Gen 7)
04:00:47:WU01:FS01:0xa7:Unit: 0x0000000b287234c95e725942dd79fa6c
04:00:47:WU01:FS01:0xa7:Digital signatures verified
04:00:47:WU01:FS01:0xa7:Calling: mdrun -s frame7.tpr -o frame7.trr -x frame7.xtc -e frame7.edr -cpi state.cpt -cpt 15 -nt 2
04:00:47:WU01:FS01:0xa7:Steps: first=3500000 total=500000
04:00:50:WU01:FS01:0xa7:Completed 461101 out of 500000 steps (92%)
04:19:28:WU01:FS01:0xa7:Completed 465000 out of 500000 steps (93%)
04:29:21:WU01:FS01:0xa7:Completed 470000 out of 500000 steps (94%)
04:39:15:WU01:FS01:0xa7:Completed 475000 out of 500000 steps (95%)
04:49:04:WU01:FS01:0xa7:Completed 480000 out of 500000 steps (96%)
04:58:54:WU01:FS01:0xa7:Completed 485000 out of 500000 steps (97%)
05:08:43:WU01:FS01:0xa7:Completed 490000 out of 500000 steps (98%)
05:18:33:WU01:FS01:0xa7:Completed 495000 out of 500000 steps (99%)
05:18:34:WU00:FS01:Connecting to 65.254.110.245:8080
05:18:35:WARNING:WU00:FS01:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
05:18:35:WU00:FS01:Connecting to 18.218.241.186:80
05:18:35:WU00:FS01:Assigned to work server 40.114.52.201
05:18:35:WU00:FS01:Requesting new work unit for slot 01: RUNNING cpu:2 from 40.114.52.201
05:18:35:WU00:FS01:Connecting to 40.114.52.201:8080
05:18:57:WARNING:WU00:FS01:WorkServer connection failed on port 8080 trying 80
05:18:57:WU00:FS01:Connecting to 40.114.52.201:80
05:19:18:ERROR:WU00:FS01:Exception: Failed to connect to 40.114.52.201:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
05:19:18:WU00:FS01:Connecting to 65.254.110.245:8080
05:19:19:WARNING:WU00:FS01:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
05:19:19:WU00:FS01:Connecting to 18.218.241.186:80
05:19:20:WARNING:WU00:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
05:19:20:ERROR:WU00:FS01:Exception: Could not get an assignment
05:20:18:WU00:FS01:Connecting to 65.254.110.245:8080
05:20:19:WARNING:WU00:FS01:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
05:20:19:WU00:FS01:Connecting to 18.218.241.186:80
05:20:19:WARNING:WU00:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
05:20:19:ERROR:WU00:FS01:Exception: Could not get an assignment
05:21:55:WU00:FS01:Connecting to 65.254.110.245:8080
05:21:56:WARNING:WU00:FS01:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
05:21:56:WU00:FS01:Connecting to 18.218.241.186:80
05:21:57:WARNING:WU00:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
05:21:57:ERROR:WU00:FS01:Exception: Could not get an assignment
05:24:32:WU00:FS01:Connecting to 65.254.110.245:8080
05:24:33:WARNING:WU00:FS01:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
05:24:33:WU00:FS01:Connecting to 18.218.241.186:80
05:24:34:WARNING:WU00:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
05:24:34:ERROR:WU00:FS01:Exception: Could not get an assignment
05:28:47:WU00:FS01:Connecting to 65.254.110.245:8080
05:28:47:WARNING:WU00:FS01:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
05:28:47:WU00:FS01:Connecting to 18.218.241.186:80
05:28:48:WARNING:WU00:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
05:28:48:ERROR:WU00:FS01:Exception: Could not get an assignment
05:29:30:WU01:FS01:0xa7:Completed 500000 out of 500000 steps (100%)
05:29:32:WU01:FS01:0xa7:Saving result file ..\logfile_01.txt
05:29:32:WU01:FS01:0xa7:Saving result file frame7.edr
05:29:32:WU01:FS01:0xa7:Saving result file frame7.trr
05:29:32:WU01:FS01:0xa7:Saving result file frame7.xtc
05:29:33:WU01:FS01:0xa7:Saving result file md.log
05:29:33:WU01:FS01:0xa7:Saving result file science.log
05:29:33:WU01:FS01:0xa7:Folding@home Core Shutdown: FINISHED_UNIT
05:29:33:WU01:FS01:FahCore returned: FINISHED_UNIT (100 = 0x64)
05:29:33:WU01:FS01:Sending unit results: id:01 state:SEND error:NO_ERROR project:13850 run:0 clone:1826 gen:7 core:0xa7 unit:0x0000000b287234c95e725942dd79fa6c
05:29:33:WU01:FS01:Uploading 2.53MiB to 40.114.52.201
05:29:33:WU01:FS01:Connecting to 40.114.52.201:8080
05:29:54:WARNING:WU01:FS01:WorkServer connection failed on port 8080 trying 80
05:29:54:WU01:FS01:Connecting to 40.114.52.201:80
05:30:16:WARNING:WU01:FS01:Exception: Failed to send results to work server: Failed to connect to 40.114.52.201:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
05:30:16:WU01:FS01:Trying to send results to collection server
05:30:16:WU01:FS01:Uploading 2.53MiB to 155.247.164.214
05:30:16:WU01:FS01:Connecting to 155.247.164.214:8080
05:30:23:WU01:FS01:Upload 12.36%
05:30:29:WU01:FS01:Upload 22.26%
05:30:35:WU01:FS01:Upload 32.15%
05:30:41:WU01:FS01:Upload 42.04%
05:30:47:WU01:FS01:Upload 51.93%
05:30:53:WU01:FS01:Upload 61.82%
05:30:59:WU01:FS01:Upload 71.72%
05:31:05:WU01:FS01:Upload 79.13%
05:31:11:WU01:FS01:Upload 89.03%
05:31:17:WU01:FS01:Upload 98.92%
05:31:18:WU01:FS01:Upload complete
05:31:18:WU01:FS01:Server responded WORK_ACK (400)
05:31:18:WU01:FS01:Final credit estimate, 1000.00 points
