Windows task manager reports that FAH is running with 80% CPU, but the right-side progress bar remains at zero. Am I wasting my resources?
The web interface shows Running "All systems go", a Green dot is on the left, but a yellow dot is on the right. The time to completion is dropping.
PC is running hard and showing no progress on Right side
davidcoton
Re: PC is running hard and showing no progress on Right side
Can you post the log from Advanced Control? (Refresh, then Copy and paste here between Code tags.)
The Web Control will show two or more "tabs" if you have both a CPU and one or more GPUs set up to fold. That is what you description is sounding like, the CPU tab is active and the GPU may be waiting on an assignment.
So at the point you are describing, yes you are contributing.
