Just downloaded and getting two errors.
Dannigan
Post by Dannigan »
Hello,
Error #1 The first error involves the Web Control. It worked at first, and then I clicked on the page when it went opaque (it gave a message; I cannot recall what it was). Now, the web page just continually reloads once every second or so. Attempting to interact with the page doesn't work (a help screen will come up if I'm fast enough to click it, but then the page reloads).
Error #2. On the Advanced Control Log tab, I continue to get error messages (see below toward the end of this page). I have uninstalled and reinstalled and this does not solve the problem. The pasted text is below these symbols in this text * * *.
I have read through your FAQS. I am the owner of this computer (although, for years, I can't convince it that I'm the administrator. I don't know what to do about that, but does that prevent me from running folding@home on my computer? I want to help, but my computer operating skills are limited. What do you recommend, please?
-Dannigan
P.S.Your software has asked me to put the information inside of "code" using brackets. I will do so now.
*********************** Log Started 2020-03-28T04:58:17Z ***********************
04:58:17:************************* Folding@home Client *************************
04:58:17:        Website: https://foldingathome.org/
04:58:17:      Copyright: (c) 2009-2018 foldingathome.org
04:58:17:         Author: Joseph Coffland <joseph@cauldrondevelopment.com>
04:58:17:           Args: --open-web-control
04:58:17:         Config: C:\Users\PantherPurr\AppData\Roaming\FAHClient\config.xml
04:58:17:******************************** Build ********************************
04:58:17:        Version: 7.5.1
04:58:17:           Date: May 11 2018
04:58:17:           Time: 13:06:32
04:58:17:     Repository: Git
04:58:17:       Revision: 4705bf53c635f88b8fe85af7675557e15d491ff0
04:58:17:         Branch: master
04:58:17:       Compiler: Visual C++ 2008
04:58:17:        Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
04:58:17:       Platform: win32 10
04:58:17:           Bits: 32
04:58:17:           Mode: Release
04:58:17:******************************* System ********************************
04:58:17:            CPU: Intel(R) Core(TM) i7-2600K CPU @ 3.40GHz
04:58:17:         CPU ID: GenuineIntel Family 6 Model 42 Stepping 7
04:58:17:           CPUs: 8
04:58:17:         Memory: 15.98GiB
04:58:17:    Free Memory: 10.06GiB
04:58:17:        Threads: WINDOWS_THREADS
04:58:17:     OS Version: 6.2
04:58:17:    Has Battery: false
04:58:17:     On Battery: false
04:58:17:     UTC Offset: -4
04:58:17:            PID: 8492
04:58:17:            CWD: C:\Users\PantherPurr\AppData\Roaming\FAHClient
04:58:17:             OS: Windows 10 Home
04:58:17:        OS Arch: AMD64
04:58:17:           GPUs: 1
04:58:17:          GPU 0: Bus:2 Slot:0 Func:0 NVIDIA:7 GP107 [GeForce GTX 1050 Ti] 2138
04:58:17:  CUDA Device 0: Platform:0 Device:0 Bus:2 Slot:0 Compute:6.1 Driver:10.1
04:58:17:OpenCL Device 0: Platform:0 Device:0 Bus:2 Slot:0 Compute:1.2 Driver:432.0
04:58:17:  Win32 Service: false
04:58:17:***********************************************************************
04:58:17:<config>
04:58:17:  <!-- Slot Control -->
04:58:17:  <power v='FULL'/>
04:58:17:
04:58:17:  <!-- User Information -->
04:58:17:  <passkey v='********************************'/>
04:58:17:  <user v='Dannigan'/>
04:58:17:
04:58:17:  <!-- Folding Slots -->
04:58:17:  <slot id='0' type='CPU'/>
04:58:17:  <slot id='1' type='GPU'/>
04:58:17:</config>
04:58:17:Trying to access database...
04:58:17:Successfully acquired database lock
04:58:17:Enabled folding slot 00: READY cpu:7
04:58:17:Enabled folding slot 01: READY gpu:0:GP107 [GeForce GTX 1050 Ti]  2138
04:58:17:WU02:FS01:Starting
04:58:17:WU02:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\PantherPurr\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/Core_22.fah/FahCore_22.exe -dir 02 -suffix 01 -version 705 -lifeline 8492 -checkpoint 15 -gpu-vendor nvidia -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu 0
04:58:18:WU02:FS01:Started FahCore on PID 2116
04:58:18:WU02:FS01:Core PID:15128
04:58:18:WU02:FS01:FahCore 0x22 started
04:58:18:WU02:FS01:0x22:*********************** Log Started 2020-03-28T04:58:18Z ***********************
04:58:18:WU02:FS01:0x22:*************************** Core22 Folding@home Core ***************************
04:58:18:WU02:FS01:0x22:       Type: 0x22
04:58:18:WU02:FS01:0x22:       Core: Core22
04:58:18:WU02:FS01:0x22:    Website: https://foldingathome.org/
04:58:18:WU02:FS01:0x22:  Copyright: (c) 2009-2018 foldingathome.org
04:58:18:WU02:FS01:0x22:     Author: John Chodera <john.chodera@choderalab.org> and Rafal Wiewiora
04:58:18:WU02:FS01:0x22:             <rafal.wiewiora@choderalab.org>
04:58:18:WU02:FS01:0x22:       Args: -dir 02 -suffix 01 -version 705 -lifeline 2116 -checkpoint 15
04:58:18:WU02:FS01:0x22:             -gpu-vendor nvidia -opencl-platform 0 -opencl-device 0 -cuda-device
04:58:18:WU02:FS01:0x22:             0 -gpu 0
04:58:18:WU02:FS01:0x22:     Config: <none>
04:58:18:WU02:FS01:0x22:************************************ Build *************************************
04:58:18:WU02:FS01:0x22:    Version: 0.0.2
04:58:18:WU02:FS01:0x22:       Date: Dec 6 2019
04:58:18:WU02:FS01:0x22:       Time: 21:30:31
04:58:18:WU02:FS01:0x22: Repository: Git
04:58:18:WU02:FS01:0x22:   Revision: abeb39247cc72df5af0f63723edafadb23d5dfbe
04:58:18:WU02:FS01:0x22:     Branch: HEAD
04:58:18:WU02:FS01:0x22:   Compiler: Visual C++ 2008
04:58:18:WU02:FS01:0x22:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
04:58:18:WU02:FS01:0x22:   Platform: win32 10
04:58:18:WU02:FS01:0x22:       Bits: 64
04:58:18:WU02:FS01:0x22:       Mode: Release
04:58:18:WU02:FS01:0x22:************************************ System ************************************
04:58:18:WU02:FS01:0x22:        CPU: Intel(R) Core(TM) i7-2600K CPU @ 3.40GHz
04:58:18:WU02:FS01:0x22:     CPU ID: GenuineIntel Family 6 Model 42 Stepping 7
04:58:18:WU02:FS01:0x22:       CPUs: 8
04:58:18:WU02:FS01:0x22:     Memory: 15.98GiB
04:58:18:WU02:FS01:0x22:Free Memory: 10.04GiB
04:58:18:WU02:FS01:0x22:    Threads: WINDOWS_THREADS
04:58:19:WU02:FS01:0x22: OS Version: 6.2
04:58:19:WU02:FS01:0x22:Has Battery: false
04:58:19:WU02:FS01:0x22: On Battery: false
04:58:19:WU02:FS01:0x22: UTC Offset: -4
04:58:19:WU02:FS01:0x22:        PID: 15128
04:58:19:WU02:FS01:0x22:        CWD: C:\Users\PantherPurr\AppData\Roaming\FAHClient\work
04:58:19:WU02:FS01:0x22:         OS: Windows 10 Home
04:58:19:WU02:FS01:0x22:    OS Arch: AMD64
04:58:19:WU02:FS01:0x22:********************************************************************************
04:58:19:WU02:FS01:0x22:Project: 11746 (Run 0, Clone 1932, Gen 11)
04:58:19:WU02:FS01:0x22:Unit: 0x000000188ca304f15e67fc22bcda70cd
04:58:19:WU02:FS01:0x22:Digital signatures verified
04:58:19:WU02:FS01:0x22:Folding@home GPU Core22 Folding@home Core
04:58:19:WU02:FS01:0x22:Version 0.0.2
04:58:19:WU02:FS01:0x22:  Found a checkpoint file
04:58:35:WU00:FS00:Connecting to 65.254.110.245:8080
04:58:36:WU00:FS00:Assigned to work server 13.82.98.119
04:58:36:WU00:FS00:Requesting new work unit for slot 00: READY cpu:7 from 13.82.98.119
04:58:36:WU00:FS00:Connecting to 13.82.98.119:8080
04:58:36:WU00:FS00:Downloading 1.23MiB
04:58:37:WU00:FS00:Download complete
04:58:37:WU00:FS00:Received Unit: id:00 state:DOWNLOAD error:NO_ERROR project:14590 run:1675 clone:2 gen:12 core:0xa7 unit:0x0000000c0d5262775e7a990ec2c38e35
04:58:37:WU00:FS00:Starting
04:58:37:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\PantherPurr\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/avx/Core_a7.fah/FahCore_a7.exe -dir 00 -suffix 01 -version 705 -lifeline 8492 -checkpoint 15 -np 7
04:58:37:WU00:FS00:Started FahCore on PID 8012
04:58:37:WU00:FS00:Core PID:4040
04:58:37:WU00:FS00:FahCore 0xa7 started
04:58:37:WU00:FS00:0xa7:*********************** Log Started 2020-03-28T04:58:37Z ***********************
04:58:37:WU00:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
04:58:37:WU00:FS00:0xa7:       Type: 0xa7
04:58:37:WU00:FS00:0xa7:       Core: Gromacs
04:58:37:WU00:FS00:0xa7:       Args: -dir 00 -suffix 01 -version 705 -lifeline 8012 -checkpoint 15 -np 7
04:58:37:WU00:FS00:0xa7:************************************ CBang *************************************
04:58:37:WU00:FS00:0xa7:       Date: Oct 26 2019
04:58:37:WU00:FS00:0xa7:       Time: 01:38:25
04:58:37:WU00:FS00:0xa7:   Revision: c46a1a011a24143739ac7218c5a435f66777f62f
04:58:37:WU00:FS00:0xa7:     Branch: master
04:58:37:WU00:FS00:0xa7:   Compiler: Visual C++ 2008
04:58:37:WU00:FS00:0xa7:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
04:58:37:WU00:FS00:0xa7:   Platform: win32 10
04:58:37:WU00:FS00:0xa7:       Bits: 64
04:58:37:WU00:FS00:0xa7:       Mode: Release
04:58:37:WU00:FS00:0xa7:************************************ System ************************************
04:58:37:WU00:FS00:0xa7:        CPU: Intel(R) Core(TM) i7-2600K CPU @ 3.40GHz
04:58:37:WU00:FS00:0xa7:     CPU ID: GenuineIntel Family 6 Model 42 Stepping 7
04:58:37:WU00:FS00:0xa7:       CPUs: 8
04:58:37:WU00:FS00:0xa7:     Memory: 15.98GiB
04:58:37:WU00:FS00:0xa7:Free Memory: 9.27GiB
04:58:37:WU00:FS00:0xa7:    Threads: WINDOWS_THREADS
04:58:37:WU00:FS00:0xa7: OS Version: 6.2
04:58:37:WU00:FS00:0xa7:Has Battery: false
04:58:37:WU00:FS00:0xa7: On Battery: false
04:58:37:WU00:FS00:0xa7: UTC Offset: -4
04:58:37:WU00:FS00:0xa7:        PID: 4040
04:58:37:WU00:FS00:0xa7:        CWD: C:\Users\PantherPurr\AppData\Roaming\FAHClient\work
04:58:37:WU00:FS00:0xa7:******************************** Build - libFAH ********************************
04:58:38:WU00:FS00:0xa7:    Version: 0.0.18
04:58:38:WU00:FS00:0xa7:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
04:58:38:WU00:FS00:0xa7:  Copyright: 2019 foldingathome.org
04:58:38:WU00:FS00:0xa7:   Homepage: https://foldingathome.org/
04:58:38:WU00:FS00:0xa7:       Date: Oct 26 2019
04:58:38:WU00:FS00:0xa7:       Time: 01:52:30
04:58:38:WU00:FS00:0xa7:   Revision: c1e3513b1bc0c16013668f2173ee969e5995b38e
04:58:38:WU00:FS00:0xa7:     Branch: master
04:58:38:WU00:FS00:0xa7:   Compiler: Visual C++ 2008
04:58:38:WU00:FS00:0xa7:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
04:58:38:WU00:FS00:0xa7:   Platform: win32 10
04:58:38:WU00:FS00:0xa7:       Bits: 64
04:58:38:WU00:FS00:0xa7:       Mode: Release
04:58:38:WU00:FS00:0xa7:************************************ Build *************************************
04:58:38:WU00:FS00:0xa7:       SIMD: avx_256
04:58:38:WU00:FS00:0xa7:********************************************************************************
04:58:38:WU00:FS00:0xa7:Project: 14590 (Run 1675, Clone 2, Gen 12)
04:58:38:WU00:FS00:0xa7:Unit: 0x0000000c0d5262775e7a990ec2c38e35
04:58:38:WU00:FS00:0xa7:Reading tar file core.xml
04:58:38:WU00:FS00:0xa7:Reading tar file frame12.tpr
04:58:38:WU00:FS00:0xa7:Digital signatures verified
04:58:38:WU00:FS00:0xa7:Reducing thread count from 7 to 6 to avoid domain decomposition by a prime number > 3
04:58:38:WU00:FS00:0xa7:Calling: mdrun -s frame12.tpr -o frame12.trr -x frame12.xtc -cpt 15 -nt 6
04:58:38:WU00:FS00:0xa7:Steps: first=6000000 total=500000
04:58:38:WU02:FS01:0x22:Completed 650000 out of 1000000 steps (65%)
04:58:38:WU00:FS00:0xa7:Completed 1 out of 500000 steps (0%)
04:58:38:WU02:FS01:0x22:Temperature control disabled. Requirements: single Nvidia GPU, tmax must be < 110 and twait >= 900
04:59:10:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
04:59:26:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
04:59:42:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
04:59:58:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
05:00:14:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
05:00:30:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
05:00:46:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
05:00:50:WU00:FS00:0xa7:Completed 5000 out of 500000 steps (1%)
05:01:02:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
05:01:18:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
05:01:34:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
05:01:50:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
05:02:06:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
05:02:22:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
05:02:38:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
05:02:52:WU00:FS00:0xa7:Completed 10000 out of 500000 steps (2%)
05:02:54:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
05:03:10:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
05:03:26:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
05:03:42:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
05:03:50:WU02:FS01:0x22:Completed 660000 out of 1000000 steps (66%)
05:03:58:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
05:04:14:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
05:04:30:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
05:04:46:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
05:04:58:WU00:FS00:0xa7:Completed 15000 out of 500000 steps (3%)
05:05:02:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
05:05:18:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
05:05:34:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
05:05:50:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
05:06:06:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
05:06:22:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
05:06:38:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
05:06:54:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
05:07:05:WU00:FS00:0xa7:Completed 20000 out of 500000 steps (4%)
05:07:10:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
05:07:26:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
05:07:42:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
05:07:58:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
05:08:14:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
05:08:30:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
05:08:46:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
05:09:02:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
05:09:03:WU02:FS01:0x22:Completed 670000 out of 1000000 steps (67%)
05:09:05:WU00:FS00:0xa7:Completed 25000 out of 500000 steps (5%)
05:09:18:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
05:09:34:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
05:09:50:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
05:10:06:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
05:10:22:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
05:10:38:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
05:10:54:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
05:10:55:WU00:FS00:0xa7:Completed 30000 out of 500000 steps (6%)
05:11:10:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
05:11:26:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
05:11:42:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
05:11:58:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
05:12:14:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
05:12:30:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
05:12:45:WU00:FS00:0xa7:Completed 35000 out of 500000 steps (7%)
05:12:46:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
05:13:02:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
05:13:18:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
05:13:34:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
05:13:50:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
05:14:06:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
05:14:14:WU02:FS01:0x22:Completed 680000 out of 1000000 steps (68%)
05:14:22:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
05:14:35:WU00:FS00:0xa7:Completed 40000 out of 500000 steps (8%)
05:14:38:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
05:14:54:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
05:15:10:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
05:15:26:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
05:15:42:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
05:15:58:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
05:16:14:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
05:16:26:WU00:FS00:0xa7:Completed 45000 out of 500000 steps (9%)
05:16:30:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
05:16:46:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
05:17:02:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
05:17:18:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
05:17:34:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
05:17:50:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
05:18:06:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
05:18:19:WU00:FS00:0xa7:Completed 50000 out of 500000 steps (10%)
05:18:22:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
05:18:38:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
05:18:54:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
05:19:10:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
05:19:25:WU02:FS01:0x22:Completed 690000 out of 1000000 steps (69%)
05:19:26:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
05:19:42:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
05:19:58:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
05:20:09:WU00:FS00:0xa7:Completed 55000 out of 500000 steps (11%)
05:20:14:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
05:20:30:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
05:20:46:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
05:21:02:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
05:21:18:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
05:21:34:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
05:21:50:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
05:22:00:WU00:FS00:0xa7:Completed 60000 out of 500000 steps (12%)
05:22:06:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
05:22:22:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
05:22:38:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
05:22:54:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
05:23:10:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
05:23:26:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
05:23:42:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
05:23:53:WU00:FS00:0xa7:Completed 65000 out of 500000 steps (13%)
05:23:58:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
05:24:14:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
05:24:30:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
05:24:41:WU02:FS01:0x22:Completed 700000 out of 1000000 steps (70%)
05:24:46:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
05:25:02:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
Re: Just downloaded and getting two errors.
For #1 see the 7th section of this FAQ - viewtopic.php?f=19&t=32463 - about issues with Chrome and some workarounds.
For #2 You can ignore those 10053 error messages. They come from the Web Control not properly closing its connection.
Dannigan
Post by Dannigan »
Joe_H,
Clearing my cache corrected the issue and I'll ignore those errors! Thanks a bunch for taking the time to explain. What I have doesn't have a cure, but I do love helping folding@home find cures for those who do.
-Happy Dannigan =)
