GPU with marked index greater than 10
liqid_mark
Post by liqid_mark »
I'm having issues with a server with more than 10 GPUs. I'm getting WUs but anything over an index value greater than 10 is being assigned to GPU 1.
22:15:29:WU11:FS11:Running FahCore: /usr/bin/FAHCoreWrapper /var/lib/fahclient/cores/cores.foldingathome.org/v7/lin/64bit/Core_22.fah/FahCore_22 -dir 11 -suffix 01 -version 705 -lifeline 4950 -checkpoint
15 -gpu-vendor nvidia -opencl-platform 0 -opencl-device 10 -cuda-device 10 -gpu 10
does this
| Processes:                                                       GPU Memory |
|  GPU       PID   Type   Process name                             Usage      |
|    1      9886      C   ...org/v7/lin/64bit/Core_22.fah/FahCore_22   323MiB |
Is there anything I can do to resolve this? This server has 20 Quadro RTX 8000s.
Re: GPU with marked index greater than 10
This is a known issue with the folding client, not sure if there is a way around using just the client software. There was another posting about this problem within the last 2-3 days if I recall correctly.
liqid_mark
Thank you Joe_H, sorry for having a duplicate post!
There's a reason we still call ourself FoldingAtHome. Our goal has alwasy been to make use of home computers to solve big problems ... and I think we're succeeding. Nobody has 10 GPUs in their home computer. I have no doubts that there are many supercomputers around with lots of GPUs running in parallel, but we're not equiped to handle them.
No problem, some items are hard to search on the forum because they occur so frequently like "GPU" and "10". If I or another moderator happen to find it, we can either merge your post with the topic, or post a link.
liqid_mark
Thanks for the reply bruce, I appreciate it. I'll try to setup another server in the datacenter for this and split the GPUs between them. Thank you!
_r2w_ben
Post by _r2w_ben »
Joe_H wrote:This is a known issue with the folding client, not sure if there is a way around using just the client software. There was another posting about this problem within the last 2-3 days if I recall correctly.
Here's the recent thread, which also has a link to the issue.
