Vega 64 - Nothing but errors
zombienerd
Post by zombienerd »
I pick up WU's from time to time, but every single one in the past 3 days since I have installed give me the same error every time it downloads one.
My curiosity mainly evolves from this line: 21:23:09:WU00:FS01:0x22:ERROR:exception: There is no registered Platform called "OpenCL"
Am I just getting bad work units, or is that error meaning I have something set up incorrectly?
This is the excerpt from the log:
21:23:07:WU00:FS01:Received Unit: id:00 state:DOWNLOAD error:NO_ERROR project:14533 run:0 clone:2424 gen:16 core:0x22 unit:0x0000001a80fccb025e72f2056a589492
21:23:07:WU00:FS01:Starting
21:23:07:WU00:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\ccr\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/Core_22.fah/FahCore_22.exe -dir 00 -suffix 01 -version 705 -lifeline 11784 -checkpoint 15 -gpu-vendor amd -opencl-device 0 -gpu 0
21:23:07:WU00:FS01:Started FahCore on PID 9928
21:23:07:WU00:FS01:Core PID:9060
21:23:07:WU00:FS01:FahCore 0x22 started
21:23:07:WU00:FS01:0x22:*********************** Log Started 2020-03-27T21:23:07Z ***********************
21:23:07:WU00:FS01:0x22:*************************** Core22 Folding@home Core ***************************
21:23:07:WU00:FS01:0x22:       Type: 0x22
21:23:07:WU00:FS01:0x22:       Core: Core22
21:23:07:WU00:FS01:0x22:    Website: https://foldingathome.org/
21:23:07:WU00:FS01:0x22:  Copyright: (c) 2009-2018 foldingathome.org
21:23:07:WU00:FS01:0x22:     Author: John Chodera <john.chodera@choderalab.org> and Rafal Wiewiora
21:23:07:WU00:FS01:0x22:             <rafal.wiewiora@choderalab.org>
21:23:07:WU00:FS01:0x22:       Args: -dir 00 -suffix 01 -version 705 -lifeline 9928 -checkpoint 15
21:23:07:WU00:FS01:0x22:             -gpu-vendor amd -opencl-device 0 -gpu 0
21:23:07:WU00:FS01:0x22:     Config: <none>
21:23:07:WU00:FS01:0x22:************************************ Build *************************************
21:23:07:WU00:FS01:0x22:    Version: 0.0.2
21:23:07:WU00:FS01:0x22:       Date: Dec 6 2019
21:23:07:WU00:FS01:0x22:       Time: 21:30:31
21:23:07:WU00:FS01:0x22: Repository: Git
21:23:07:WU00:FS01:0x22:   Revision: abeb39247cc72df5af0f63723edafadb23d5dfbe
21:23:07:WU00:FS01:0x22:     Branch: HEAD
21:23:07:WU00:FS01:0x22:   Compiler: Visual C++ 2008
21:23:07:WU00:FS01:0x22:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
21:23:07:WU00:FS01:0x22:   Platform: win32 10
21:23:07:WU00:FS01:0x22:       Bits: 64
21:23:07:WU00:FS01:0x22:       Mode: Release
21:23:07:WU00:FS01:0x22:************************************ System ************************************
21:23:07:WU00:FS01:0x22:        CPU: AMD Ryzen 5 3600 6-Core Processor
21:23:07:WU00:FS01:0x22:     CPU ID: AuthenticAMD Family 23 Model 113 Stepping 0
21:23:07:WU00:FS01:0x22:       CPUs: 12
21:23:07:WU00:FS01:0x22:     Memory: 31.93GiB
21:23:07:WU00:FS01:0x22:Free Memory: 26.32GiB
21:23:07:WU00:FS01:0x22:    Threads: WINDOWS_THREADS
21:23:07:WU00:FS01:0x22: OS Version: 6.2
21:23:07:WU00:FS01:0x22:Has Battery: false
21:23:07:WU00:FS01:0x22: On Battery: false
21:23:07:WU00:FS01:0x22: UTC Offset: -4
21:23:07:WU00:FS01:0x22:        PID: 9060
21:23:07:WU00:FS01:0x22:        CWD: C:\Users\ccr\AppData\Roaming\FAHClient\work
21:23:07:WU00:FS01:0x22:         OS: Windows 10 Home
21:23:07:WU00:FS01:0x22:    OS Arch: AMD64
21:23:07:WU00:FS01:0x22:********************************************************************************
21:23:07:WU00:FS01:0x22:Project: 14533 (Run 0, Clone 2424, Gen 16)
21:23:07:WU00:FS01:0x22:Unit: 0x0000001a80fccb025e72f2056a589492
21:23:07:WU00:FS01:0x22:Reading tar file core.xml
21:23:07:WU00:FS01:0x22:Reading tar file integrator.xml
21:23:07:WU00:FS01:0x22:Reading tar file state.xml
21:23:08:WU00:FS01:0x22:Reading tar file system.xml
21:23:09:WU00:FS01:0x22:Digital signatures verified
21:23:09:WU00:FS01:0x22:Folding@home GPU Core22 Folding@home Core
21:23:09:WU00:FS01:0x22:Version 0.0.2
21:23:09:WU00:FS01:0x22:Saving result file ..\logfile_01.txt
21:23:09:WU00:FS01:0x22:Saving result file science.log
21:23:09:WU00:FS01:0x22:Folding@home Core Shutdown: BAD_WORK_UNIT
21:23:09:WARNING:WU00:FS01:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
21:23:09:WU00:FS01:Sending unit results: id:00 state:SEND error:FAULTY project:14533 run:0 clone:2424 gen:16 core:0x22 unit:0x0000001a80fccb025e72f2056a589492
21:23:09:WU00:FS01:Uploading 7.00KiB to 128.252.203.2
Re: Vega 64 - Nothing but errors
Welcome to Folding@home!
I am guessing you are on some flavor of Windows. The first 200 lines of the log would have your configuration, so I was not making bad guesses. viewtopic.php?f=24&t=26036
The most likely scenario at this point is that your Drivers are not directly from AMD https://www.amd.com/en/support
Drivers from other sources (most often Microsoft) may lack the OpenCL support F@H needs to fold.
It is also possible you did not use the express installation and so have odd file permission issues, but that is beyond my skill level.
zombienerd
Update - Yes, it is on windows. I meant to add that to the original post, but couldn't edit it once I clicked post because it was awaiting moderation.
Anyway, I got it going. Indeed, my drivers were out of date by one version. Once updating my drivers and rebooting, it would throw BAD_WORK_UNIT every time it got a WU.
Removing the GPU slot, rebooting, re-adding the GPU slot, then rebooting again fixed it.
We can mark this one closed. Hopefully it will help someone else in the future.
And i thank you for the feed back! Sometimes, you never know if your guesses were at all right. In this case they weren't.
