Link for project in advanced control does nothing
HesletQuillan
Post by HesletQuillan »
Here's an extremely minor gripe.
In Advanced Control (7.5.1 Windows), the current project is shown as a link, but clicking it does nothing. If I right click and select Copy URL, nothing gets copied. The links for Name and Team work.
kostuek
Re: Link for project in advanced control does nothing
Post by kostuek »
Indeed. It worked in 7.4.4, but now it doesn't want to.
Frogging101
Post by Frogging101 »
As a workaround, you can use the following URL (replace XXXXX with the project number):
https://apps.foldingathome.org/project.py?p=XXXXX
What's weird is that I could swear this used to work for me recently, and I don't recall making any significant changes to my installation since then. I had to get that URL from somewhere, after all.
HesletQuillan
Thanks. Curiously, https://stats.foldingathome.org/project , which is the Statistics > Project Statistics link from the main web site, displays Donor Statistics instead. I recall the other day I managed to stumble across a page on the F@H site that listed all the projects with, supposedly, links to descriptions, but several of the links I clicked on displayed "no such project" or similar.
Frogging101
HesletQuillan wrote:Thanks. Curiously, https://stats.foldingathome.org/project , which is the Statistics > Project Statistics link from the main web site, displays Donor Statistics instead. I recall the other day I managed to stumble across a page on the F@H site that listed all the projects with, supposedly, links to descriptions, but several of the links I clicked on displayed "no such project" or similar.
You are probably thinking of this: https://apps.foldingathome.org/psummary
HesletQuillan
That's the one.
Some of the new projects are missing the descriptions, or there is an error in how they were entered that needs to be fixed before it will display. That will get you a "Project unspecified" page. We have requests in to the person managing a number of projects, to get these descriptions in place. as soon as they can find some time to do so.
They are also having some issues with the editor, so for the moment can not make changes to existing descriptions to fix up typos or add to an existing one that is just minimal in what it says.
