Project: 11780 (Run 0, Clone 3622, Gen 20)
Jertzuu
Hardware configuration: Ryzen 5 2600 @ 4,1GHz
G.Skill Trident Z RGB 3200mHz CL14 32Gb
Asus Prime X470-PRO
Zotac AMP! Extreme 1080 Ti
Samsung Evo 970 250Gb NVMe M.2
Samsung Evo 860 500Gb SSD
WD Black 1Tb 7200RPM HDD
Post by Jertzuu »
Just got this
16:01:36:WU01:FS01:Received Unit: id:01 state:DOWNLOAD error:NO_ERROR project:11780 run:0 clone:3622 gen:20 core:0x22 unit:0x0000001e0d5a98395e73c55831ce8988
16:01:36:WU01:FS01:Starting
16:01:36:WU01:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\jeret\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/Core_22.fah/FahCore_22.exe -dir 01 -suffix 01 -version 705 -lifeline 16640 -checkpoint 10 -gpu-vendor nvidia -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu 0
16:01:36:WU01:FS01:Started FahCore on PID 384
16:01:36:WU01:FS01:Core PID:12276
16:01:36:WU01:FS01:FahCore 0x22 started
16:01:36:WU01:FS01:0x22:*********************** Log Started 2020-03-27T16:01:36Z ***********************
16:01:36:WU01:FS01:0x22:*************************** Core22 Folding@home Core ***************************
16:01:36:WU01:FS01:0x22:       Type: 0x22
16:01:36:WU01:FS01:0x22:       Core: Core22
16:01:36:WU01:FS01:0x22:    Website: https://foldingathome.org/
16:01:36:WU01:FS01:0x22:  Copyright: (c) 2009-2018 foldingathome.org
16:01:36:WU01:FS01:0x22:     Author: John Chodera <john.chodera@choderalab.org> and Rafal Wiewiora
16:01:36:WU01:FS01:0x22:             <rafal.wiewiora@choderalab.org>
16:01:36:WU01:FS01:0x22:       Args: -dir 01 -suffix 01 -version 705 -lifeline 384 -checkpoint 10
16:01:36:WU01:FS01:0x22:             -gpu-vendor nvidia -opencl-platform 0 -opencl-device 0 -cuda-device
16:01:36:WU01:FS01:0x22:             0 -gpu 0
16:01:36:WU01:FS01:0x22:     Config: <none>
16:01:36:WU01:FS01:0x22:************************************ Build *************************************
16:01:36:WU01:FS01:0x22:    Version: 0.0.2
16:01:36:WU01:FS01:0x22:       Date: Dec 6 2019
16:01:36:WU01:FS01:0x22:       Time: 21:30:31
16:01:36:WU01:FS01:0x22: Repository: Git
16:01:36:WU01:FS01:0x22:   Revision: abeb39247cc72df5af0f63723edafadb23d5dfbe
16:01:36:WU01:FS01:0x22:     Branch: HEAD
16:01:36:WU01:FS01:0x22:   Compiler: Visual C++ 2008
16:01:36:WU01:FS01:0x22:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
16:01:36:WU01:FS01:0x22:   Platform: win32 10
16:01:36:WU01:FS01:0x22:       Bits: 64
16:01:36:WU01:FS01:0x22:       Mode: Release
16:01:36:WU01:FS01:0x22:************************************ System ************************************
16:01:36:WU01:FS01:0x22:        CPU: AMD Ryzen 5 2600 Six-Core Processor
16:01:36:WU01:FS01:0x22:     CPU ID: AuthenticAMD Family 23 Model 8 Stepping 2
16:01:36:WU01:FS01:0x22:       CPUs: 12
16:01:36:WU01:FS01:0x22:     Memory: 31.92GiB
16:01:36:WU01:FS01:0x22:Free Memory: 28.09GiB
16:01:36:WU01:FS01:0x22:    Threads: WINDOWS_THREADS
16:01:36:WU01:FS01:0x22: OS Version: 6.2
16:01:36:WU01:FS01:0x22:Has Battery: false
16:01:36:WU01:FS01:0x22: On Battery: false
16:01:36:WU01:FS01:0x22: UTC Offset: 2
16:01:36:WU01:FS01:0x22:        PID: 12276
16:01:36:WU01:FS01:0x22:        CWD: C:\Users\jeret\AppData\Roaming\FAHClient\work
16:01:36:WU01:FS01:0x22:         OS: Windows 10 Pro
16:01:36:WU01:FS01:0x22:    OS Arch: AMD64
16:01:36:WU01:FS01:0x22:********************************************************************************
16:01:36:WU01:FS01:0x22:Project: 11780 (Run 0, Clone 3622, Gen 20)
16:01:36:WU01:FS01:0x22:Unit: 0x0000001e0d5a98395e73c55831ce8988
16:01:36:WU01:FS01:0x22:Reading tar file core.xml
16:01:36:WU01:FS01:0x22:Reading tar file integrator.xml
16:01:36:WU01:FS01:0x22:Reading tar file state.xml
16:01:37:WU01:FS01:0x22:Reading tar file system.xml
16:01:37:WU01:FS01:0x22:Digital signatures verified
16:01:37:WU01:FS01:0x22:Folding@home GPU Core22 Folding@home Core
16:01:37:WU01:FS01:0x22:Version 0.0.2
16:01:50:WU01:FS01:0x22:Completed 0 out of 1000000 steps (0%)
16:01:50:WU01:FS01:0x22:Temperature control disabled. Requirements: single Nvidia GPU, tmax must be < 110 and twait >= 900
16:01:59:WU01:FS01:0x22:ERROR:exception: clWaitForEvents
16:01:59:WU01:FS01:0x22:Saving result file ..\logfile_01.txt
16:01:59:WU01:FS01:0x22:Saving result file checkpt.crc
16:01:59:WU01:FS01:0x22:Saving result file science.log
16:01:59:WU01:FS01:0x22:Folding@home Core Shutdown: BAD_WORK_UNIT
16:02:00:WARNING:WU01:FS01:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
16:02:00:WU01:FS01:Sending unit results: id:01 state:SEND error:FAULTY project:11780 run:0 clone:3622 gen:20 core:0x22 unit:0x0000001e0d5a98395e73c55831ce8988
16:02:00:WU01:FS01:Uploading 10.00KiB to 13.90.152.57
Re: Project: 11780 (Run 0, Clone 3622, Gen 20)
Wow, this one failed 5 times ! I guess we have a bad WU here ...
edit : the WS is set to terminate a trajectory after 5 failures, this WU won't be send again.
