Client doesn't start work
Tockra
Post by Tockra »
Hi Guys,
I have a RTX 2080 in my computer and would to like to help this month.
The current problem is that the software doesn't run properly.
Here the log:
15:07:48:WARNING:WU01:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
15:07:48:ERROR:WU01:FS01:Exception: Could not get an assignment
15:07:48:WU01:FS01:Connecting to 65.254.110.245:8080
15:07:51:WU00:FS00:Assigned to work server 155.247.166.219
15:07:51:WU00:FS00:Requesting new work unit for slot 00: READY cpu:7 from 155.247.166.219
15:07:51:WU00:FS00:Connecting to 155.247.166.219:8080
15:07:52:WARNING:WU01:FS01:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
15:07:52:WU01:FS01:Connecting to 18.218.241.186:80
15:07:56:ERROR:WU00:FS00:Exception: Server did not assign work unit
15:07:57:WARNING:WU01:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
15:07:57:ERROR:WU01:FS01:Exception: Could not get an assignment
15:07:57:WU00:FS00:Connecting to 65.254.110.245:8080
15:08:01:WARNING:WU00:FS00:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
15:08:01:WU00:FS00:Connecting to 18.218.241.186:80
15:08:05:WU00:FS00:Assigned to work server 40.114.52.201
15:08:05:WU00:FS00:Requesting new work unit for slot 00: READY cpu:7 from 40.114.52.201
15:08:05:WU00:FS00:Connecting to 40.114.52.201:8080
I already used google and just found solutions for linux or bad discribed solutions.
I'm using windows 10.
T
Frogging101
Re: Client doesn't start work
Post by Frogging101 »
These messages indicate that your client is contacting the Folding@Home servers, but is not being assigned any work units.
This is due to the increased server load and work unit shortage. It is being worked on. Nothing in your log indicates a problem with your client. Just leave your client running and it will eventually receive a work unit.
Tockra
Post by Tockra »
I had this problem for days. Not just a short time.
SparkiTom
Hardware configuration: Intel i9 10900X | ASUS nvidia 2080 Ti 11GB | ASUS X299-E Gaming 2 mobo | 32GB DDR4 3200Mhz | M.2 SSD's
Post by SparkiTom »
Click on the pause tab wait 2-3 seconds then unpause (fold), it resets the server auto request timer to less than 90 seconds or so. I've noticed if you don't do that at least every so often then that timer can go on for over an hour before it requests for a new WU download.
I'm a proper noob at this by the way, so feel free to kick my ass if necessary anyone.
Tockra
Post by Tockra »
I already tried to hit the pause button. I already try to reinstall the program...
The software seems not to be very stable.
When I need to run my computer for one hour, to help another hour, then it isn't a good solution.
Frogging101
I see a potential problem here, actually.
Your CPU slot is set to 7 threads. Not all projects support odd numbers of threads. Some do, but with the current work unit shortage, we want to maximize your chances.
Set your threads to an even number. Subtract one thread for each GPU, but round down to the nearest even number after that.
Edit: Actually, I'm not sure the problem is odd numbers, it's "large prime" numbers and multiples of such numbers, with large being 7 or more. This has been talked about on the forum before, but unfortunately it's not prominently mentioned in the program help or support documentation. It'd be nice if the team could make an official statement that explains the thread number issue in exhaustive detail.
