GPU unsupported but work sometimes
formol
Post by formol »
Hello,
I'm a news donors since a week.
I have a GTX 2070, but it's say " GPU: 1 unsupporter : 0X0000:0X0000". But sometimes, it's works !
My CPU and my GPU can't work in the same time in this soft ? Cause sometimes, i don't use my computed and i can offer everyy my ressources.
And, sometimes, nothing works, no CPU, no GPU.
Someones can explain me basicly how to fix it please ?
Thanks, and good luck to everyone from France :)
Re: GPU unsupported but work sometimes
Post by Neil-B »
You will need to give a little more information if anyone is to be able to assist - probably best starting by posting your FAH log:
Sorry I stuffed up link above - so for the re record viewtopic.php?f=61&t=15446
ajm
Post by ajm »
As for the unsupported message, as Neil-B said, more information is needed. If it is an RTX 2070 (I don't think a GTX 2070 does exist?), it should work.
Now, as a general rule, even if your hardware is compatible, disponible and in good shape, it can happen that F@H can't use it, momentarily. Most of the time it is because the servers are overloaded and don't have any appropriate job for your hardware when your client requires it. In that case, the client will ask again automatically after a while.
formol
Post by formol »
Sorry, you're right, i forgot to post my log.
Here, my log since this morning :
*********************** Log Started 2020-03-27T08:46:16Z ***********************
08:46:16:************************* Folding@home Client *************************
08:46:16:        Website: https://foldingathome.org/
08:46:16:      Copyright: (c) 2009-2018 foldingathome.org
08:46:16:         Author: Joseph Coffland <joseph@cauldrondevelopment.com>
08:46:16:           Args:
08:46:16:         Config: C:\Users\alexi\AppData\Roaming\FAHClient\config.xml
08:46:16:******************************** Build ********************************
08:46:16:        Version: 7.5.1
08:46:16:           Date: May 11 2018
08:46:16:           Time: 13:06:32
08:46:16:     Repository: Git
08:46:16:       Revision: 4705bf53c635f88b8fe85af7675557e15d491ff0
08:46:16:         Branch: master
08:46:16:       Compiler: Visual C++ 2008
08:46:16:        Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
08:46:16:       Platform: win32 10
08:46:16:           Bits: 32
08:46:16:           Mode: Release
08:46:16:******************************* System ********************************
08:46:16:            CPU: AMD Ryzen 5 2600X Six-Core Processor
08:46:16:         CPU ID: AuthenticAMD Family 23 Model 8 Stepping 2
08:46:16:           CPUs: 12
08:46:16:         Memory: 15.95GiB
08:46:16:    Free Memory: 11.16GiB
08:46:16:        Threads: WINDOWS_THREADS
08:46:16:     OS Version: 6.2
08:46:16:    Has Battery: false
08:46:16:     On Battery: false
08:46:16:     UTC Offset: 1
08:46:16:            PID: 24040
08:46:16:            CWD: C:\Users\alexi\AppData\Roaming\FAHClient
08:46:16:             OS: Windows 10 Home
08:46:16:        OS Arch: AMD64
08:46:16:           GPUs: 1
08:46:16:          GPU 0: Bus:28 Slot:0 Func:0 NVIDIA:7 TU106 [GeForce RTX 2070] M 6497
08:46:16:  CUDA Device 0: Platform:0 Device:0 Bus:28 Slot:0 Compute:7.5 Driver:10.2
08:46:16:OpenCL Device 0: Platform:0 Device:0 Bus:28 Slot:0 Compute:1.2 Driver:442.59
08:46:16:  Win32 Service: false
08:46:16:***********************************************************************
08:46:16:<config>
08:46:16:  <!-- Network -->
08:46:16:  <proxy v=':8080'/>
08:46:16:
08:46:16:  <!-- Slot Control -->
08:46:16:  <power v='full'/>
08:46:16:
08:46:16:  <!-- User Information -->
08:46:16:  <user v='formol'/>
08:46:16:
08:46:16:  <!-- Folding Slots -->
08:46:16:  <slot id='0' type='CPU'/>
08:46:16:  <slot id='1' type='GPU'>
08:46:16:    <cuda-index v='1'/>
08:46:16:    <gpu-index v='1'/>
08:46:16:    <opencl-index v='1'/>
08:46:16:  </slot>
08:46:16:</config>
08:46:16:Trying to access database...
08:46:16:Successfully acquired database lock
08:46:16:Enabled folding slot 00: READY cpu:11
08:46:16:ERROR:Exception: GPU 1 not found
08:46:16:ERROR:No compute devices matched GPU #1 UNSUPPORTED: 0x0000:0x0000.  You may need to update your graphics drivers.
08:46:17:WU00:FS00:Connecting to 65.254.110.245:8080
08:46:17:WU01:FS01:Connecting to 65.254.110.245:8080
08:46:18:WARNING:WU01:FS01:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
08:46:18:WU01:FS01:Connecting to 18.218.241.186:80
08:46:18:WARNING:WU00:FS00:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
08:46:18:WU00:FS00:Connecting to 18.218.241.186:80
08:46:18:WARNING:WU01:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
08:46:18:ERROR:WU01:FS01:Exception: Could not get an assignment
08:46:18:WARNING:WU00:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
08:46:18:ERROR:WU00:FS00:Exception: Could not get an assignment
08:46:18:WU01:FS01:Connecting to 65.254.110.245:8080
08:46:18:WU00:FS00:Connecting to 65.254.110.245:8080
08:46:19:WARNING:WU01:FS01:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
08:46:19:WU01:FS01:Connecting to 18.218.241.186:80
08:46:19:WARNING:WU00:FS00:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
08:46:19:WU00:FS00:Connecting to 18.218.241.186:80
08:46:19:WARNING:WU01:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
08:46:19:ERROR:WU01:FS01:Exception: Could not get an assignment
08:46:19:WARNING:WU00:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
08:46:19:ERROR:WU00:FS00:Exception: Could not get an assignment
08:47:19:WU00:FS00:Connecting to 65.254.110.245:8080
08:47:19:WU01:FS01:Connecting to 65.254.110.245:8080
08:47:19:WARNING:WU00:FS00:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
08:47:19:WU00:FS00:Connecting to 18.218.241.186:80
08:47:19:WARNING:WU01:FS01:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
08:47:19:WU01:FS01:Connecting to 18.218.241.186:80
08:47:19:WARNING:WU00:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
08:47:19:ERROR:WU00:FS00:Exception: Could not get an assignment
08:47:19:WU01:FS01:Assigned to work server 40.114.52.201
08:47:19:WU01:FS01:Requesting new work unit for slot 01: READY gpu:1:UNSUPPORTED: 0x0000:0x0000 from 40.114.52.201
08:47:19:WU01:FS01:Connecting to 40.114.52.201:8080
08:47:59:ERROR:WU01:FS01:Exception: 10002: Received short response, expected 512 bytes, got 0
08:48:56:WU00:FS00:Connecting to 65.254.110.245:8080
08:48:56:WARNING:WU00:FS00:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
08:48:56:WU00:FS00:Connecting to 18.218.241.186:80
08:48:56:WU01:FS01:Connecting to 65.254.110.245:8080
08:48:56:WARNING:WU00:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
08:48:56:ERROR:WU00:FS00:Exception: Could not get an assignment
08:48:56:WARNING:WU01:FS01:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
08:48:56:WU01:FS01:Connecting to 18.218.241.186:80
08:48:57:WARNING:WU01:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
08:48:57:ERROR:WU01:FS01:Exception: Could not get an assignment
08:51:33:WU00:FS00:Connecting to 65.254.110.245:8080
08:51:33:WARNING:WU00:FS00:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
08:51:33:WU00:FS00:Connecting to 18.218.241.186:80
08:51:33:WU01:FS01:Connecting to 65.254.110.245:8080
08:51:33:WU00:FS00:Assigned to work server 155.247.166.219
08:51:33:WU00:FS00:Requesting new work unit for slot 00: READY cpu:11 from 155.247.166.219
08:51:33:WU00:FS00:Connecting to 155.247.166.219:8080
08:51:33:WU01:FS01:Assigned to work server 155.247.166.219
08:51:33:WU01:FS01:Requesting new work unit for slot 01: READY gpu:1:UNSUPPORTED: 0x0000:0x0000 from 155.247.166.219
08:51:33:WU01:FS01:Connecting to 155.247.166.219:8080
08:51:34:ERROR:WU00:FS00:Exception: Server did not assign work unit
08:51:34:ERROR:WU01:FS01:Exception: Server did not assign work unit
08:55:47:WU00:FS00:Connecting to 65.254.110.245:8080
08:55:47:WU00:FS00:Assigned to work server 40.114.52.201
08:55:47:WU00:FS00:Requesting new work unit for slot 00: READY cpu:11 from 40.114.52.201
08:55:47:WU00:FS00:Connecting to 40.114.52.201:8080
08:55:47:WU01:FS01:Connecting to 65.254.110.245:8080
08:55:48:WARNING:WU01:FS01:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
08:55:48:WU01:FS01:Connecting to 18.218.241.186:80
08:55:48:WARNING:WU01:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
08:55:48:ERROR:WU01:FS01:Exception: Could not get an assignment
08:56:36:WU00:FS00:Downloading 1.23MiB
08:56:36:WU00:FS00:Download complete
08:56:36:WU00:FS00:Received Unit: id:00 state:DOWNLOAD error:NO_ERROR project:14572 run:0 clone:3551 gen:2 core:0xa7 unit:0x00000003287234c95e7b87828c369a00
08:56:36:WU00:FS00:Starting
08:56:36:WARNING:WU00:FS00:AS lowered CPUs from 11 to 9
08:56:36:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\alexi\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/avx/Core_a7.fah/FahCore_a7.exe -dir 00 -suffix 01 -version 705 -lifeline 24040 -checkpoint 15 -np 9
08:56:36:WU00:FS00:Started FahCore on PID 23596
08:56:36:WU00:FS00:Core PID:24852
08:56:36:WU00:FS00:FahCore 0xa7 started
08:56:37:WU00:FS00:0xa7:*********************** Log Started 2020-03-27T08:56:36Z ***********************
08:56:37:WU00:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
08:56:37:WU00:FS00:0xa7:       Type: 0xa7
08:56:37:WU00:FS00:0xa7:       Core: Gromacs
08:56:37:WU00:FS00:0xa7:       Args: -dir 00 -suffix 01 -version 705 -lifeline 23596 -checkpoint 15 -np
08:56:37:WU00:FS00:0xa7:             9
08:56:37:WU00:FS00:0xa7:************************************ CBang *************************************
08:56:37:WU00:FS00:0xa7:       Date: Oct 26 2019
08:56:37:WU00:FS00:0xa7:       Time: 01:38:25
08:56:37:WU00:FS00:0xa7:   Revision: c46a1a011a24143739ac7218c5a435f66777f62f
08:56:37:WU00:FS00:0xa7:     Branch: master
08:56:37:WU00:FS00:0xa7:   Compiler: Visual C++ 2008
08:56:37:WU00:FS00:0xa7:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
08:56:37:WU00:FS00:0xa7:   Platform: win32 10
08:56:37:WU00:FS00:0xa7:       Bits: 64
08:56:37:WU00:FS00:0xa7:       Mode: Release
08:56:37:WU00:FS00:0xa7:************************************ System ************************************
08:56:37:WU00:FS00:0xa7:        CPU: AMD Ryzen 5 2600X Six-Core Processor
08:56:37:WU00:FS00:0xa7:     CPU ID: AuthenticAMD Family 23 Model 8 Stepping 2
08:56:37:WU00:FS00:0xa7:       CPUs: 12
08:56:37:WU00:FS00:0xa7:     Memory: 15.95GiB
08:56:37:WU00:FS00:0xa7:Free Memory: 9.05GiB
08:56:37:WU00:FS00:0xa7:    Threads: WINDOWS_THREADS
08:56:37:WU00:FS00:0xa7: OS Version: 6.2
08:56:37:WU00:FS00:0xa7:Has Battery: false
08:56:37:WU00:FS00:0xa7: On Battery: false
08:56:37:WU00:FS00:0xa7: UTC Offset: 1
08:56:37:WU00:FS00:0xa7:        PID: 24852
08:56:37:WU00:FS00:0xa7:        CWD: C:\Users\alexi\AppData\Roaming\FAHClient\work
08:56:37:WU00:FS00:0xa7:******************************** Build - libFAH ********************************
08:56:37:WU00:FS00:0xa7:    Version: 0.0.18
08:56:37:WU00:FS00:0xa7:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
08:56:37:WU00:FS00:0xa7:  Copyright: 2019 foldingathome.org
08:56:37:WU00:FS00:0xa7:   Homepage: https://foldingathome.org/
08:56:37:WU00:FS00:0xa7:       Time: 01:52:30
08:56:37:WU00:FS00:0xa7:   Revision: c1e3513b1bc0c16013668f2173ee969e5995b38e
08:56:37:WU00:FS00:0xa7:************************************ Build *************************************
08:56:37:WU00:FS00:0xa7:       SIMD: avx_256
08:56:37:WU00:FS00:0xa7:********************************************************************************
08:56:37:WU00:FS00:0xa7:Project: 14572 (Run 0, Clone 3551, Gen 2)
08:56:37:WU00:FS00:0xa7:Unit: 0x00000003287234c95e7b87828c369a00
08:56:37:WU00:FS00:0xa7:Reading tar file core.xml
08:56:37:WU00:FS00:0xa7:Reading tar file frame2.tpr
08:56:37:WU00:FS00:0xa7:Digital signatures verified
08:56:37:WU00:FS00:0xa7:Calling: mdrun -s frame2.tpr -o frame2.trr -x frame2.xtc -cpt 15 -nt 9
08:56:37:WU00:FS00:0xa7:Steps: first=1000000 total=500000
08:56:37:WU00:FS00:0xa7:Completed 1 out of 500000 steps (0%)
08:57:34:WU00:FS00:0xa7:Completed 5000 out of 500000 steps (1%)
08:58:33:WU00:FS00:0xa7:Completed 10000 out of 500000 steps (2%)
08:59:31:WU00:FS00:0xa7:Completed 15000 out of 500000 steps (3%)
09:00:29:WU00:FS00:0xa7:Completed 20000 out of 500000 steps (4%)
09:01:27:WU00:FS00:0xa7:Completed 25000 out of 500000 steps (5%)
09:02:26:WU00:FS00:0xa7:Completed 30000 out of 500000 steps (6%)
09:02:39:WU01:FS01:Connecting to 65.254.110.245:8080
09:02:39:WARNING:WU01:FS01:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
09:02:39:WU01:FS01:Connecting to 18.218.241.186:80
09:02:39:WARNING:WU01:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
09:02:39:ERROR:WU01:FS01:Exception: Could not get an assignment
09:03:24:WU00:FS00:0xa7:Completed 35000 out of 500000 steps (7%)
09:04:22:WU00:FS00:0xa7:Completed 40000 out of 500000 steps (8%)
09:05:20:WU00:FS00:0xa7:Completed 45000 out of 500000 steps (9%)
09:06:20:WU00:FS00:0xa7:Completed 50000 out of 500000 steps (10%)
09:07:20:WU00:FS00:0xa7:Completed 55000 out of 500000 steps (11%)
09:08:18:WU00:FS00:0xa7:Completed 60000 out of 500000 steps (12%)
09:09:18:WU00:FS00:0xa7:Completed 65000 out of 500000 steps (13%)
09:10:17:WU00:FS00:0xa7:Completed 70000 out of 500000 steps (14%)
09:11:17:WU00:FS00:0xa7:Completed 75000 out of 500000 steps (15%)
09:12:16:WU00:FS00:0xa7:Completed 80000 out of 500000 steps (16%)
09:13:15:WU00:FS00:0xa7:Completed 85000 out of 500000 steps (17%)
09:13:44:WU01:FS01:Connecting to 65.254.110.245:8080
09:13:45:WARNING:WU01:FS01:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
09:13:45:WU01:FS01:Connecting to 18.218.241.186:80
09:13:45:WARNING:WU01:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
09:13:45:ERROR:WU01:FS01:Exception: Could not get an assignment
09:14:12:WU00:FS00:0xa7:Completed 90000 out of 500000 steps (18%)
09:15:10:WU00:FS00:0xa7:Completed 95000 out of 500000 steps (19%)
09:16:11:WU00:FS00:0xa7:Completed 100000 out of 500000 steps (20%)
09:17:14:WU00:FS00:0xa7:Completed 105000 out of 500000 steps (21%)
09:18:17:WU00:FS00:0xa7:Completed 110000 out of 500000 steps (22%)
09:19:17:WU00:FS00:0xa7:Completed 115000 out of 500000 steps (23%)
09:20:15:WU00:FS00:0xa7:Completed 120000 out of 500000 steps (24%)
09:21:15:WU00:FS00:0xa7:Completed 125000 out of 500000 steps (25%)
09:22:13:WU00:FS00:0xa7:Completed 130000 out of 500000 steps (26%)
09:23:12:WU00:FS00:0xa7:Completed 135000 out of 500000 steps (27%)
09:24:10:WU00:FS00:0xa7:Completed 140000 out of 500000 steps (28%)
09:25:08:WU00:FS00:0xa7:Completed 145000 out of 500000 steps (29%)
09:26:06:WU00:FS00:0xa7:Completed 150000 out of 500000 steps (30%)
09:27:05:WU00:FS00:0xa7:Completed 155000 out of 500000 steps (31%)
09:28:05:WU00:FS00:0xa7:Completed 160000 out of 500000 steps (32%)
09:29:03:WU00:FS00:0xa7:Completed 165000 out of 500000 steps (33%)
09:30:02:WU00:FS00:0xa7:Completed 170000 out of 500000 steps (34%)
09:31:02:WU00:FS00:0xa7:Completed 175000 out of 500000 steps (35%)
09:31:41:WU01:FS01:Connecting to 65.254.110.245:8080
09:31:41:WARNING:WU01:FS01:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
09:31:42:WU01:FS01:Connecting to 18.218.241.186:80
09:31:42:WARNING:WU01:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
09:31:42:ERROR:WU01:FS01:Exception: Could not get an assignment
09:32:01:WU00:FS00:0xa7:Completed 180000 out of 500000 steps (36%)
09:33:00:WU00:FS00:0xa7:Completed 185000 out of 500000 steps (37%)
09:33:59:WU00:FS00:0xa7:Completed 190000 out of 500000 steps (38%)
09:34:57:WU00:FS00:0xa7:Completed 195000 out of 500000 steps (39%)
09:35:57:WU00:FS00:0xa7:Completed 200000 out of 500000 steps (40%)
09:36:55:WU00:FS00:0xa7:Completed 205000 out of 500000 steps (41%)
09:37:55:WU00:FS00:0xa7:Completed 210000 out of 500000 steps (42%)
09:38:53:WU00:FS00:0xa7:Completed 215000 out of 500000 steps (43%)
09:39:52:WU00:FS00:0xa7:Completed 220000 out of 500000 steps (44%)
09:40:53:WU00:FS00:0xa7:Completed 225000 out of 500000 steps (45%)
09:41:53:WU00:FS00:0xa7:Completed 230000 out of 500000 steps (46%)
09:42:52:WU00:FS00:0xa7:Completed 235000 out of 500000 steps (47%)
09:43:52:WU00:FS00:0xa7:Completed 240000 out of 500000 steps (48%)
09:44:00:50:127.0.0.1:New Web connection
09:44:57:WU00:FS00:0xa7:Completed 245000 out of 500000 steps (49%)
09:45:55:WU00:FS00:0xa7:Completed 250000 out of 500000 steps (50%)
09:46:53:WU00:FS00:0xa7:Completed 255000 out of 500000 steps (51%)
09:47:51:WU00:FS00:0xa7:Completed 260000 out of 500000 steps (52%)
09:48:49:WU00:FS00:0xa7:Completed 265000 out of 500000 steps (53%)
09:49:49:WU00:FS00:0xa7:Completed 270000 out of 500000 steps (54%)
09:50:49:WU00:FS00:0xa7:Completed 275000 out of 500000 steps (55%)
09:51:48:WU00:FS00:0xa7:Completed 280000 out of 500000 steps (56%)
09:52:48:WU00:FS00:0xa7:Completed 285000 out of 500000 steps (57%)
09:53:48:WU00:FS00:0xa7:Completed 290000 out of 500000 steps (58%)
09:54:48:WU00:FS00:0xa7:Completed 295000 out of 500000 steps (59%)
09:55:48:WU00:FS00:0xa7:Completed 300000 out of 500000 steps (60%)
09:56:47:WU00:FS00:0xa7:Completed 305000 out of 500000 steps (61%)
09:57:46:WU00:FS00:0xa7:Completed 310000 out of 500000 steps (62%)
09:58:45:WU00:FS00:0xa7:Completed 315000 out of 500000 steps (63%)
09:59:44:WU00:FS00:0xa7:Completed 320000 out of 500000 steps (64%)
10:00:42:WU00:FS00:0xa7:Completed 325000 out of 500000 steps (65%)
10:00:43:WU01:FS01:Connecting to 65.254.110.245:8080
10:00:44:WARNING:WU01:FS01:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
10:00:44:WU01:FS01:Connecting to 18.218.241.186:80
10:00:44:WARNING:WU01:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
10:00:44:ERROR:WU01:FS01:Exception: Could not get an assignment
10:01:40:WU00:FS00:0xa7:Completed 330000 out of 500000 steps (66%)
10:02:38:WU00:FS00:0xa7:Completed 335000 out of 500000 steps (67%)
10:03:37:WU00:FS00:0xa7:Completed 340000 out of 500000 steps (68%)
10:04:37:WU00:FS00:0xa7:Completed 345000 out of 500000 steps (69%)
10:05:38:WU00:FS00:0xa7:Completed 350000 out of 500000 steps (70%)
10:06:40:WU00:FS00:0xa7:Completed 355000 out of 500000 steps (71%)
10:07:41:WU00:FS00:0xa7:Completed 360000 out of 500000 steps (72%)
10:08:44:WU00:FS00:0xa7:Completed 365000 out of 500000 steps (73%)
10:09:42:WU00:FS00:0xa7:Completed 370000 out of 500000 steps (74%)
10:10:41:WU00:FS00:0xa7:Completed 375000 out of 500000 steps (75%)
10:11:40:WU00:FS00:0xa7:Completed 380000 out of 500000 steps (76%)
10:12:38:WU00:FS00:0xa7:Completed 385000 out of 500000 steps (77%)
10:13:39:WU00:FS00:0xa7:Completed 390000 out of 500000 steps (78%)
10:14:43:WU00:FS00:0xa7:Completed 395000 out of 500000 steps (79%)
10:15:45:WU00:FS00:0xa7:Completed 400000 out of 500000 steps (80%)
10:16:48:WU00:FS00:0xa7:Completed 405000 out of 500000 steps (81%)
10:17:50:WU00:FS00:0xa7:Completed 410000 out of 500000 steps (82%)
10:18:50:WU00:FS00:0xa7:Completed 415000 out of 500000 steps (83%)
10:19:49:WU00:FS00:0xa7:Completed 420000 out of 500000 steps (84%)
10:20:50:WU00:FS00:0xa7:Completed 425000 out of 500000 steps (85%)
10:21:48:WU00:FS00:0xa7:Completed 430000 out of 500000 steps (86%)
10:22:46:WU00:FS00:0xa7:Completed 435000 out of 500000 steps (87%)
10:23:45:WU00:FS00:0xa7:Completed 440000 out of 500000 steps (88%)
10:24:44:WU00:FS00:0xa7:Completed 445000 out of 500000 steps (89%)
10:25:47:WU00:FS00:0xa7:Completed 450000 out of 500000 steps (90%)
10:26:45:WU00:FS00:0xa7:Completed 455000 out of 500000 steps (91%)
10:27:44:WU00:FS00:0xa7:Completed 460000 out of 500000 steps (92%)
10:28:45:WU00:FS00:0xa7:Completed 465000 out of 500000 steps (93%)
10:29:49:WU00:FS00:0xa7:Completed 470000 out of 500000 steps (94%)
10:30:48:WU00:FS00:0xa7:Completed 475000 out of 500000 steps (95%)
10:31:47:WU00:FS00:0xa7:Completed 480000 out of 500000 steps (96%)
10:32:47:WU00:FS00:0xa7:Completed 485000 out of 500000 steps (97%)
10:33:46:WU00:FS00:0xa7:Completed 490000 out of 500000 steps (98%)
10:34:51:WU00:FS00:0xa7:Completed 495000 out of 500000 steps (99%)
10:34:52:WU02:FS00:Connecting to 65.254.110.245:8080
10:34:52:WARNING:WU02:FS00:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
10:34:52:WU02:FS00:Connecting to 18.218.241.186:80
10:34:53:WARNING:WU02:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
10:34:53:ERROR:WU02:FS00:Exception: Could not get an assignment
10:34:53:WU02:FS00:Connecting to 65.254.110.245:8080
10:34:53:WARNING:WU02:FS00:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
10:34:53:WU02:FS00:Connecting to 18.218.241.186:80
10:34:54:WARNING:WU02:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
10:34:54:ERROR:WU02:FS00:Exception: Could not get an assignment
10:35:53:WU02:FS00:Connecting to 65.254.110.245:8080
10:35:53:WARNING:WU02:FS00:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
10:35:53:WU02:FS00:Connecting to 18.218.241.186:80
10:35:54:WARNING:WU02:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
10:35:54:ERROR:WU02:FS00:Exception: Could not get an assignment
10:35:55:WU00:FS00:0xa7:Completed 500000 out of 500000 steps (100%)
10:35:55:WU00:FS00:0xa7:Saving result file ..\logfile_01.txt
10:35:55:WU00:FS00:0xa7:Saving result file frame2.trr
10:35:55:WU00:FS00:0xa7:Saving result file frame2.xtc
10:35:55:WU00:FS00:0xa7:Saving result file md.log
10:35:55:WU00:FS00:0xa7:Saving result file science.log
10:35:55:WU00:FS00:0xa7:Folding@home Core Shutdown: FINISHED_UNIT
10:35:56:WU00:FS00:FahCore returned: FINISHED_UNIT (100 = 0x64)
10:35:56:WU00:FS00:Sending unit results: id:00 state:SEND error:NO_ERROR project:14572 run:0 clone:3551 gen:2 core:0xa7 unit:0x00000003287234c95e7b87828c369a00
10:35:56:WU00:FS00:Uploading 1.41MiB to 40.114.52.201
10:35:56:WU00:FS00:Connecting to 40.114.52.201:8080
10:36:17:WARNING:WU00:FS00:WorkServer connection failed on port 8080 trying 80
10:36:17:WU00:FS00:Connecting to 40.114.52.201:80
10:36:18:WU00:FS00:Upload 4.44%
10:36:50:WARNING:WU00:FS00:Exception: Failed to send results to work server: 10002: Received short response, expected 512 bytes, got 0
10:36:50:WU00:FS00:Trying to send results to collection server
10:36:50:WU00:FS00:Uploading 1.41MiB to 155.247.164.214
10:36:50:WU00:FS00:Connecting to 155.247.164.214:8080
10:36:52:WU00:FS00:Upload complete
10:36:52:WU00:FS00:Server responded WORK_ACK (400)
10:36:52:WU00:FS00:Final credit estimate, 420.00 points
10:36:52:WU00:FS00:Cleaning up
10:37:30:WU02:FS00:Connecting to 65.254.110.245:8080
10:37:30:WARNING:WU02:FS00:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
10:37:30:WU02:FS00:Connecting to 18.218.241.186:80
10:37:31:WARNING:WU02:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
10:37:31:ERROR:WU02:FS00:Exception: Could not get an assignment
10:40:07:WU02:FS00:Connecting to 65.254.110.245:8080
10:40:07:WARNING:WU02:FS00:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
10:40:07:WU02:FS00:Connecting to 18.218.241.186:80
10:40:08:WARNING:WU02:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
10:40:08:ERROR:WU02:FS00:Exception: Could not get an assignment
10:44:22:WU02:FS00:Connecting to 65.254.110.245:8080
10:44:22:WARNING:WU02:FS00:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
10:44:22:WU02:FS00:Connecting to 18.218.241.186:80
10:44:22:WARNING:WU02:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
10:44:22:ERROR:WU02:FS00:Exception: Could not get an assignment
10:47:42:WU01:FS01:Connecting to 65.254.110.245:8080
10:47:42:WARNING:WU01:FS01:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
10:47:42:WU01:FS01:Connecting to 18.218.241.186:80
10:47:43:WARNING:WU01:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
10:47:43:ERROR:WU01:FS01:Exception: Could not get an assignment
10:51:13:WU02:FS00:Connecting to 65.254.110.245:8080
10:51:13:WARNING:WU02:FS00:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
10:51:13:WU02:FS00:Connecting to 18.218.241.186:80
10:51:14:WARNING:WU02:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
10:51:14:ERROR:WU02:FS00:Exception: Could not get an assignment
ajm
Post by ajm »
It looks like you should update the driver for the 2070: https://www.nvidia.fr/Download/index.aspx?lang=fr
The message "Failed to get assignment from (...) No WUs available for this configuration (...) Could not get an assignment" generally (almost always right now) means that the servers don't have any WU for your configuration. You just need a bit of patience.
formol
Post by formol »
I just instal the new graphic pilote from "geforce experience", is it the same thing ?
Because it's "unsupported " again :( but sometimes it's work.
Post by Neil-B »
Long shot - have you rebooted your machine since updating the drivers? … I was thinking the F@H Client might not spot the drive change until this is done? … BUT this is a wild guess on my part - Someone with more knowledgemay be able to advise better … If you reboot probably best to set any current WU to "Finish" and wait for this to happen so as not to have any issues with checkpointing.
ajm
Post by ajm »
There are known issues after a driver update. Haven't encountered that myself, but it can happen that the GPU index gets messed up. I just had to add a GPU in my PC and I was recommended to uninstall F@H before that and reinstall it afterwards. I can confirm that that indeed works. But you might find a better shortcut in the section of the forum on the NVidia drivers: viewforum.php?f=80
And there's a thread about a very similar problem with the same card: viewtopic.php?f=61&t=33062
formol
Post by formol »
yeap, i reboot it, but now, i can't connecting xD
Thanks AJM, il will be search if is not too difficult for me :)
ajm
Post by ajm »
You're welcome!
If you uninstall and reinstall F@H, it is a good idea to copy the file config.xml (%AppData%\FAHClient) somewhere before uninstalling. You have there everything handy to reconfigure your account just the way it was, with username, team #, passkey, and some special codes you might have added in the expert section.
jonault
Post by jonault »
It looks to me like the GPU slot is misconfigured. According to this you've got one GPU, GPU 0:
08:46:16: GPUs: 1
but your GPU slot appears to be looking for GPU 1 which apparently doesn't exist:
08:46:16: </slot>
which would explain this error:
I'd suggest deleting your GPU slot & creating a new one. Or you can do as ajm suggests & reinstall.
formol
Post by formol »
I reinstall and it's look works !! Thanks guys :)
