Missing points after work unit completion
I did a work unit yesterday (Project: 13850 (Run 0, Clone 6218, Gen 3)) and the server responded with WORK_ACK (400). However, the points from the work unit have not been registered yet. I've also completed two other work units and both have had their score added to my total.
Re: Missing points after work unit completion
There are a few reported problems with results not getting from some servers to the stats database, they are currently looking into this. The F@h team does have a policy of tracking down all points and getting them awarded, it just may take a bit of time and they will be retroactively given.
It's unfortunate that there is a (variable) delay in getting the points credited. https://apps.foldingathome.org/credit-log
note that SOMETHING is interrupting the crediting process and causing dips but the processing generaly makes up for it with a big peak later. This doesn't tell us what happened to the (relatively few???) credit records that did go somewhere else and debugging those cases is a manual process as well as (re-) adding them.
bamapolitics
Yea seeing all of my recent WU uploads not showing as credited. Was getting worried.
Comparing my logs to the stats page I seem to be missing a little over 500,000 credits. It's been over a week, any ideas when the catch-up or correction will happen?
I'm getting my numbers by running the command
grep "Final credit" logs/log*.txt log.txt | cut -d " " -f 4 | numsum
