[rejected] Quadro FX 1700
squeegily
Hardware configuration: Xeon E5410 [Fedora 31]
i5-3230M + Radeon HD 7570M [Windows 10.0.18363]
Post by squeegily »
0x8086:0x4003:0:0:0:Intel Corporation:
0x8086:0x4021:0:1:0:Intel Corporation:
0x8086:0x4025:0:5:0:Intel Corporation:
0x8086:0x4029:0:9:0:Intel Corporation:
0x8086:0x4030:0:16:0:Intel Corporation:
0x8086:0x4030:0:16:1:Intel Corporation:
0x8086:0x4030:0:16:2:Intel Corporation:
0x8086:0x4030:0:16:3:Intel Corporation:
0x8086:0x4030:0:16:4:Intel Corporation:
0x8086:0x4031:0:17:0:Intel Corporation:
0x8086:0x4035:0:21:0:Intel Corporation:
0x8086:0x4035:0:21:1:Intel Corporation:
0x8086:0x4036:0:22:0:Intel Corporation:
0x8086:0x4036:0:22:1:Intel Corporation:
0x8086:0x269a:0:27:0:Intel Corporation:
0x8086:0x2690:0:28:0:Intel Corporation:
0x8086:0x2688:0:29:0:Intel Corporation:
0x8086:0x2689:0:29:1:Intel Corporation:
0x8086:0x268a:0:29:2:Intel Corporation:
0x8086:0x268b:0:29:3:Intel Corporation:
0x8086:0x268c:0:29:7:Intel Corporation:
0x8086:0x244e:0:30:0:Intel Corporation:
0x8086:0x2670:0:31:0:Intel Corporation:
0x8086:0x269e:0:31:1:Intel Corporation:
0x8086:0x2681:0:31:2:Intel Corporation:
0x8086:0x269b:0:31:3:Intel Corporation:
0x10de:0x040f:2:0:0:NVIDIA Corporation:
0x8086:0x3500:3:0:0:Intel Corporation:
0x8086:0x350c:3:0:3:Intel Corporation:
0x8086:0x3510:4:0:0:Intel Corporation:
0x8086:0x3514:4:1:0:Intel Corporation:
0x1000:0x0058:5:0:0:LSI Logic / Symbios Logic:
0x14e4:0x167a:8:0:0:Broadcom Corporation:
0x104c:0x8023:9:10:0:Texas Instruments:
*********************** Log Started 2020-03-27T02:38:30Z ***********************
02:38:30:************************* Folding@home Client *************************
02:38:30:        Website: https://foldingathome.org/
02:38:30:      Copyright: (c) 2009-2018 foldingathome.org
02:38:30:         Author: Joseph Coffland <joseph@cauldrondevelopment.com>
02:38:30:           Args: --child --lifeline 1094 /etc/fahclient/config.xml --run-as
02:38:30:                 fahclient --pid-file=/var/run/fahclient.pid --daemon
02:38:30:         Config: /etc/fahclient/config.xml
02:38:30:******************************** Build ********************************
02:38:30:        Version: 7.5.1
02:38:30:           Date: May 12 2018
02:38:30:           Time: 22:51:07
02:38:30:     Repository: Git
02:38:30:       Revision: 4705bf53c635f88b8fe85af7675557e15d491ff0
02:38:30:         Branch: master
02:38:30:       Compiler: GNU 4.4.7 20120313 (Red Hat 4.4.7-18)
02:38:30:        Options: -std=gnu++98 -O3 -funroll-loops
02:38:30:       Platform: linux2 4.14.0-3-amd64
02:38:30:           Bits: 64
02:38:30:           Mode: Release
02:38:30:******************************* System ********************************
02:38:30:            CPU: Intel(R) Xeon(R) CPU E5410 @ 2.33GHz
02:38:30:         CPU ID: GenuineIntel Family 6 Model 23 Stepping 6
02:38:30:           CPUs: 8
02:38:30:         Memory: 31.36GiB
02:38:30:    Free Memory: 30.67GiB
02:38:30:        Threads: POSIX_THREADS
02:38:30:     OS Version: 5.5
02:38:30:    Has Battery: false
02:38:30:     On Battery: false
02:38:30:     UTC Offset: -5
02:38:30:            PID: 1096
02:38:30:            CWD: /var/lib/fahclient
02:38:30:             OS: Linux 5.5.10-200.fc31.x86_64 x86_64
02:38:30:        OS Arch: AMD64
02:38:30:           GPUs: 1
02:38:30:          GPU 0: Bus:2 Slot:0 Func:0 NVIDIA:0 G84 [Quadro FX 1700]
02:38:30:  CUDA Device 0: Platform:0 Device:0 Bus:2 Slot:0 Compute:1.1 Driver:6.5
02:38:30:OpenCL Device 0: Platform:0 Device:0 Bus:2 Slot:0 Compute:1.0 Driver:340.108
02:38:30:***********************************************************************
02:38:30:<config>
02:38:30:  <!-- User Information -->
02:38:30:  <passkey v='********************************'/>
02:38:30:  <team v='31885'/>
02:38:30:  <user v='James.Edington@█████'/>
02:38:30:
02:38:30:  <!-- Folding Slots -->
02:38:30:  <slot id='0' type='CPU'/>
02:38:30:  <slot id='1' type='GPU'/>
02:38:30:</config>
02:38:30:Switching to user fahclient
02:38:30:Trying to access database...
02:38:31:Successfully acquired database lock
02:38:31:Enabled folding slot 00: READY cpu:6
02:38:31:Enabled folding slot 01: READY gpu:0:G84 [Quadro FX 1700]
02:38:31:WU01:FS00:Starting
02:38:31:WU01:FS00:Running FahCore: /usr/bin/FAHCoreWrapper /var/lib/fahclient/cores/cores.foldingathome.org/v7/lin/64bit/Core_a7.fah/FahCore_a7 -dir 01 -suffix 01 -version 705 -lifeline 1096 -checkpoint 15 -np 6
02:38:31:WU01:FS00:Started FahCore on PID 1113
02:38:31:WU01:FS00:Core PID:1117
02:38:31:WU01:FS00:FahCore 0xa7 started
02:38:31:WU01:FS00:0xa7:*********************** Log Started 2020-03-27T02:38:31Z ***********************
02:38:31:WU01:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
02:38:31:WU01:FS00:0xa7:       Type: 0xa7
02:38:31:WU01:FS00:0xa7:       Core: Gromacs
02:38:31:WU01:FS00:0xa7:       Args: -dir 01 -suffix 01 -version 705 -lifeline 1113 -checkpoint 15 -np 6
02:38:31:WU01:FS00:0xa7:************************************ CBang *************************************
02:38:31:WU01:FS00:0xa7:       Date: Nov 5 2019
02:38:31:WU01:FS00:0xa7:       Time: 05:57:01
02:38:31:WU01:FS00:0xa7:   Revision: 46c96f1aa8419571d83f3e63f9c99a0d602f6da9
02:38:31:WU01:FS00:0xa7:     Branch: master
02:38:31:WU01:FS00:0xa7:   Compiler: GNU 8.3.0
02:38:31:WU01:FS00:0xa7:    Options: -std=c++11 -O3 -funroll-loops -fno-pie -fPIC
02:38:31:WU01:FS00:0xa7:   Platform: linux2 4.19.0-5-amd64
02:38:31:WU01:FS00:0xa7:       Bits: 64
02:38:31:WU01:FS00:0xa7:       Mode: Release
02:38:31:WU01:FS00:0xa7:************************************ System ************************************
02:38:31:WU01:FS00:0xa7:        CPU: Intel(R) Xeon(R) CPU E5410 @ 2.33GHz
02:38:31:WU01:FS00:0xa7:     CPU ID: GenuineIntel Family 6 Model 23 Stepping 6
02:38:31:WU01:FS00:0xa7:       CPUs: 8
02:38:31:WU01:FS00:0xa7:     Memory: 31.36GiB
02:38:31:WU01:FS00:0xa7:Free Memory: 30.63GiB
02:38:31:WU01:FS00:0xa7:    Threads: POSIX_THREADS
02:38:31:WU01:FS00:0xa7: OS Version: 5.5
02:38:31:WU01:FS00:0xa7:Has Battery: false
02:38:31:WU01:FS00:0xa7: On Battery: false
02:38:31:WU01:FS00:0xa7: UTC Offset: -5
02:38:31:WU01:FS00:0xa7:        PID: 1117
02:38:31:WU01:FS00:0xa7:        CWD: /var/lib/fahclient/work
02:38:31:WU01:FS00:0xa7:******************************** Build - libFAH ********************************
02:38:31:WU01:FS00:0xa7:    Version: 0.0.18
02:38:31:WU01:FS00:0xa7:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
02:38:31:WU01:FS00:0xa7:  Copyright: 2019 foldingathome.org
02:38:31:WU01:FS00:0xa7:   Homepage: https://foldingathome.org/
02:38:31:WU01:FS00:0xa7:       Time: 06:13:26
02:38:31:WU01:FS00:0xa7:   Revision: 490c9aa2957b725af319379424d5c5cb36efb656
02:38:31:WU01:FS00:0xa7:************************************ Build *************************************
02:38:31:WU01:FS00:0xa7:       SIMD: sse2
02:38:31:WU01:FS00:0xa7:********************************************************************************
02:38:31:WU01:FS00:0xa7:Project: 13850 (Run 0, Clone 37467, Gen 2)
02:38:31:WU01:FS00:0xa7:Unit: 0x00000004287234c95e788a97a6c3879a
02:38:31:WU01:FS00:0xa7:Digital signatures verified
02:38:31:WU01:FS00:0xa7:Calling: mdrun -s frame2.tpr -o frame2.trr -x frame2.xtc -e frame2.edr -cpi state.cpt -cpt 15 -nt 6
02:38:32:WU01:FS00:0xa7:Steps: first=1000000 total=500000
02:38:33:WU00:FS01:Connecting to 65.254.110.245:8080
02:38:34:WU00:FS01:Assigned to work server 192.0.2.1
02:38:34:WU00:FS01:Requesting new work unit for slot 01: READY gpu:0:G84 [Quadro FX 1700] from 192.0.2.1
02:38:34:WU00:FS01:Connecting to 192.0.2.1:8080
02:38:35:WU01:FS00:0xa7:Completed 379042 out of 500000 steps (75%)
02:39:35:WU01:FS00:0xa7:Completed 380000 out of 500000 steps (76%)
02:40:44:WARNING:WU00:FS01:WorkServer connection failed on port 8080 trying 80
02:40:44:WU00:FS01:Connecting to 192.0.2.1:80
02:40:51:ERROR:WU00:FS01:Exception: Failed to connect to 192.0.2.1:80: Connection refused
02:40:52:WU00:FS01:Connecting to 65.254.110.245:8080
02:40:52:WU00:FS01:Assigned to work server 192.0.2.1
02:40:52:WU00:FS01:Requesting new work unit for slot 01: READY gpu:0:G84 [Quadro FX 1700] from 192.0.2.1
02:40:52:WU00:FS01:Connecting to 192.0.2.1:8080
02:40:52:WARNING:WU00:FS01:WorkServer connection failed on port 8080 trying 80
02:40:52:ERROR:WU00:FS01:Exception: Failed to connect to 192.0.2.1:80: Connection refused
02:41:52:WU00:FS01:Connecting to 65.254.110.245:8080
02:41:52:WU00:FS01:Assigned to work server 192.0.2.1
02:41:52:WU00:FS01:Requesting new work unit for slot 01: READY gpu:0:G84 [Quadro FX 1700] from 192.0.2.1
02:41:52:WU00:FS01:Connecting to 192.0.2.1:8080
02:42:20:ERROR:WU00:FS01:Exception: Server did not assign work unit
02:43:05:WU01:FS00:0xa7:Completed 385000 out of 500000 steps (77%)
02:43:29:WU00:FS01:Connecting to 65.254.110.245:8080
02:43:29:WU00:FS01:Assigned to work server 192.0.2.1
02:43:29:WU00:FS01:Requesting new work unit for slot 01: READY gpu:0:G84 [Quadro FX 1700] from 192.0.2.1
02:43:29:WU00:FS01:Connecting to 192.0.2.1:8080
02:43:45:ERROR:WU00:FS01:Exception: 10002: Received short response, expected 512 bytes, got 0
02:46:06:WU00:FS01:Connecting to 65.254.110.245:8080
02:46:07:WU00:FS01:Assigned to work server 192.0.2.1
02:46:07:WU00:FS01:Requesting new work unit for slot 01: READY gpu:0:G84 [Quadro FX 1700] from 192.0.2.1
02:46:07:WU00:FS01:Connecting to 192.0.2.1:8080
02:46:36:WU01:FS00:0xa7:Completed 390000 out of 500000 steps (78%)
02:50:06:WU01:FS00:0xa7:Completed 395000 out of 500000 steps (79%)
02:53:36:WU01:FS00:0xa7:Completed 400000 out of 500000 steps (80%)
02:57:04:WU01:FS00:0xa7:Completed 405000 out of 500000 steps (81%)
03:00:30:WU01:FS00:0xa7:Completed 410000 out of 500000 steps (82%)
03:03:59:WU01:FS00:0xa7:Completed 415000 out of 500000 steps (83%)
03:07:28:WU01:FS00:0xa7:Completed 420000 out of 500000 steps (84%)
Xe E5410 (1x)
i5-3230M (1x)
Ra HD 7570M (1x)
Re: Quadro FX 1700 [0x10de:0x040f:2:0:G84]
The Quadro FX 1700 is too old to be used for folding, it is based on Tesla. Its G84 GPU chip is basically the same as used on the GeForce 8600 GT. The card is marked as unsupported in the GPUs.txt file. If you modified the entry to get the card to configure in the client, that is not enough.
squeegily
Post by squeegily »
Joe_H wrote:The Quadro FX 1700 is too old to be used for folding
alas.
It seemed to support a reasonable featureset / “Device Extensions” below; does it just have too low a clockspeed for the turnaround? :(
02:00.0 VGA compatible controller [0300]: NVIDIA Corporation G84GL [Quadro FX 1700] [10de:040f] (rev a1) (prog-if 00 [VGA controller])
	Subsystem: NVIDIA Corporation Device [10de:049a]
	Flags: bus master, fast devsel, latency 0, IRQ 35
	Memory at fa000000 (32-bit, non-prefetchable) [size=16M]
	Memory at c0000000 (64-bit, prefetchable) [size=512M]
	Memory at f8000000 (64-bit, non-prefetchable) [size=32M]
	I/O ports at dc80 [size=128]
	Expansion ROM at 000c0000 [virtual] [disabled] [size=128K]
	Capabilities: [60] Power Management version 2
	Capabilities: [68] MSI: Enable+ Count=1/1 Maskable- 64bit+
	Capabilities: [78] Express Endpoint, MSI 00
	Capabilities: [100] Virtual Channel
	Capabilities: [128] Power Budgeting <?>
	Capabilities: [600] Vendor Specific Information: ID=0001 Rev=1 Len=024 <?>
	Kernel driver in use: nvidia
	Kernel modules: nouveau, nvidia
Number of platforms                               2
  Platform Name                                   NVIDIA CUDA
  Platform Vendor                                 NVIDIA Corporation
  Platform Version                                OpenCL 1.1 CUDA 6.5.51
  Platform Extensions                             cl_khr_byte_addressable_store cl_khr_icd cl_khr_gl_sharing cl_nv_compiler_options cl_nv_device_attribute_query cl_nv_pragma_unroll cl_nv_copy_opts
  Platform Extensions function suffix             NV
  Platform Name                                   Portable Computing Language
  Platform Vendor                                 The pocl project
  Platform Version                                OpenCL 1.2 pocl 1.5-pre, RelWithDebInfo, LLVM 9.0.0, RELOC, SLEEF, DISTRO, POCL_DEBUG
  Platform Extensions                             cl_khr_icd
  Platform Extensions function suffix             POCL
  Device Name                                     Quadro FX 1700
  Device Vendor                                   NVIDIA Corporation
  Device Vendor ID                                0x10de
  Device Version                                  OpenCL 1.0 CUDA
  Driver Version                                  340.108
  Device OpenCL C Version                         OpenCL C 1.0
  Device Topology (NV)                            PCI-E, 02:00.0
  Max compute units                               4
  Max clock frequency                             920MHz
  Compute Capability (NV)                         1.1
  Max work item sizes                             512x512x64
  Max work group size                             512
  Preferred work group size multiple              32
  Warp size (NV)                                  32
    char                                                 1 / 1
    short                                                1 / 1
    half                                                 0 / 0        (n/a)
    double                                               0 / 0        (n/a)
  Half-precision Floating-point support           (n/a)
    Denormals                                     No
    Correctly-rounded divide and sqrt operations  No
  Double-precision Floating-point support         (n/a)
  Address bits                                    32, Little-Endian
  Global memory size                              536150016 (511.3MiB)
  Max memory allocation                           134217728 (128MiB)
  Integrated memory (NV)                          No
  Alignment of base address                       2048 bits (256 bytes)
  Global Memory cache type                        None
    Max number of samplers per kernel             16
    Max 2D image size                             4096x16383 pixels
    Max 3D image size                             2048x2048x2048 pixels
    Max number of read image args                 128
    Max number of write image args                8
  Local memory size                               16384 (16KiB)
  Registers per block (NV)                        8192
  Max number of constant args                     9
  Max constant buffer size                        65536 (64KiB)
  Max size of kernel argument                     4352 (4.25KiB)
  Queue properties
    Out-of-order execution                        Yes
  Profiling timer resolution                      1000ns
  Execution capabilities
    Kernel execution timeout (NV)                 No
  Concurrent copy and kernel execution (NV)       Yes
    Number of async copy engines                  1
  Device Extensions                               cl_khr_byte_addressable_store cl_khr_icd cl_khr_gl_sharing cl_nv_compiler_options cl_nv_device_attribute_query cl_nv_pragma_unroll cl_nv_copy_opts  cl_khr_global_int32_base_atomics cl_khr_global_int32_extended_atomics
  Device Name                                     pthread-Intel(R) Xeon(R) CPU           E5410  @ 2.33GHz
  Device Vendor                                   GenuineIntel
  Device Vendor ID                                0x6c636f70
  Device Version                                  OpenCL 1.2 pocl HSTR: pthread-x86_64-unknown-linux-gnu-penryn
  Driver Version                                  1.5-pre
  Device OpenCL C Version                         OpenCL C 1.2 pocl
  Device Type                                     CPU
  Max compute units                               8
  Max clock frequency                             2333MHz
    Max number of sub-devices                     8
    Supported partition types                     equally, by counts
    Supported affinity domains                    (n/a)
  Max work item sizes                             4096x4096x4096
  Max work group size                             4096
  Preferred work group size multiple              8
    char                                                16 / 16
    short                                                8 / 8
    int                                                  4 / 4
    long                                                 2 / 2
    half                                                 0 / 0        (n/a)
    float                                                4 / 4
    double                                               2 / 2        (cl_khr_fp64)
    IEEE754-2008 fused multiply-add               No
  Global memory size                              31520968704 (29.36GiB)
  Max memory allocation                           8589934592 (8GiB)
  Unified memory for Host and Device              Yes
  Alignment of base address                       1024 bits (128 bytes)
  Global Memory cache size                        6291456 (6MiB)
  Global Memory cache line size                   64 bytes
    Max size for 1D images from buffer            536870912 pixels
    Max 1D or 2D image array size                 2048 images
    Max 2D image size                             16384x16384 pixels
    Max number of write image args                128
  Local memory type                               Global
  Local memory size                               4194304 (4MiB)
  Max constant buffer size                        4194304 (4MiB)
  Queue properties
    Run native kernels                            Yes
  printf() buffer size                            16777216 (16MiB)
  Built-in kernels                                (n/a)
  Device Extensions                               cl_khr_byte_addressable_store cl_khr_global_int32_base_atomics cl_khr_global_int32_extended_atomics cl_khr_local_int32_base_atomics cl_khr_local_int32_extended_atomics cl_khr_3d_image_writes cl_khr_fp64 cl_khr_int64_base_atomics cl_khr_int64_extended_atomics cl_khr_fp64
NULL platform behavior
  clGetPlatformInfo(NULL, CL_PLATFORM_NAME, ...)  NVIDIA CUDA
  clGetDeviceIDs(NULL, CL_DEVICE_TYPE_ALL, ...)   Success [NV]
  clCreateContext(NULL, ...) [default]            Success [NV]
  clCreateContext(NULL, ...) [other]              Success [POCL]
  clCreateContextFromType(NULL, CL_DEVICE_TYPE_DEFAULT)  No platform
  clCreateContextFromType(NULL, CL_DEVICE_TYPE_GPU)  No platform
  clCreateContextFromType(NULL, CL_DEVICE_TYPE_CUSTOM)  Invalid device type for platform
  clCreateContextFromType(NULL, CL_DEVICE_TYPE_ALL)  No platform
ICD loader properties
  ICD loader Name                                 OpenCL ICD Loader
  ICD loader Vendor                               OCL Icd free software
  ICD loader Version                              2.2.12
  ICD loader Profile                              OpenCL 2.2
Xe E5410 (1x)
i5-3230M (1x)
Ra HD 7570M (1x)
When a GPU supports only OpenCL 1.1, it generally indicates that it is unable to run code that contains DoublePrecision Floating Point calculations. With OpenCL 1.2 support, you'd be able to do the calculations needed by FAH.
The card does not support OpenCL 1.2 or greater, and it does not support Double Precision arithmetic. Those are the current minimum for GPU folding, and even when DP was not required it could not be used. The minimum GPU architecture from nVidia is Fermi based, Kepler or later is preferable.
https://www.techpowerup.com/gpu-specs/q ... 1700.c1345
Yep, no OpenCL 1.2, no Double Precision floating point math, and about 10 times too slow too meet deadlines if it did meet the requirements.
SlodkiOtus
Re: [rejected] Quadro FX 1700
Post by SlodkiOtus »
So Quadro FX3700 the same? :e(
SlodkiOtus wrote:So Quadro FX3700 the same? :e(
Yes, the same holds as that is an old Tesla based GPU. Tesla has not been supported for years, it last could be used with Core_15 which last was used for projects at least 5 years ago.
