GTX1060 Linux drv v430 Error compiling kernel BAD_WORK_UNIT
florinandrei
Ubuntu 16.04. Nvidia drivers version 430.64 installed from graphics-drivers/ppa
All I get is this:
00:32:09:WU00:FS01:0x22:Folding@home GPU Core22 Folding@home Core
00:32:09:WU00:FS01:0x22:Version 0.0.2
00:32:13:WU00:FS01:0x22:ERROR:exception: Error compiling kernel:
00:32:13:WU00:FS01:0x22:Saving result file ../logfile_01.txt
00:32:13:WU00:FS01:0x22:Saving result file science.log
00:32:13:WU00:FS01:0x22:Folding@home Core Shutdown: BAD_WORK_UNIT
00:32:14:WARNING:WU00:FS01:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
All I get is this:
Florin Andrei
http://florin.myip.org/
florinandrei
Re: GTX1060 driver 430.64 Error compiling kernel
Let me add the log:
*********************** Log Started 2020-03-27T00:48:56Z ***********************
00:48:56:************************* Folding@home Client *************************
00:48:56: Website: https://foldingathome.org/
00:48:56: Copyright: (c) 2009-2018 foldingathome.org
00:48:56: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
00:48:56: Args: --child --lifeline 9316 /etc/fahclient/config.xml --run-as
00:48:56: fahclient --pid-file=/var/run/fahclient.pid --daemon
00:48:56: Config: /etc/fahclient/config.xml
00:48:56:******************************** Build ********************************
00:48:56: Version: 7.5.1
00:48:56: Date: May 11 2018
00:48:56: Time: 19:59:04
00:48:56: Repository: Git
00:48:56: Revision: 4705bf53c635f88b8fe85af7675557e15d491ff0
00:48:56: Branch: master
00:48:56: Compiler: GNU 6.3.0 20170516
00:48:56: Options: -std=gnu++98 -O3 -funroll-loops
00:48:56: Platform: linux2 4.14.0-3-amd64
00:48:56: Bits: 64
00:48:56: Mode: Release
00:48:56:******************************* System ********************************
00:48:56: CPU: AMD FX(tm)-4300 Quad-Core Processor
00:48:56: CPU ID: AuthenticAMD Family 21 Model 2 Stepping 0
00:48:56: CPUs: 4
00:48:56: Memory: 15.65GiB
00:48:56: Free Memory: 11.92GiB
00:48:56: Threads: POSIX_THREADS
00:48:56: OS Version: 4.4
00:48:56: Has Battery: false
00:48:56: On Battery: false
00:48:56: UTC Offset: -7
00:48:56: PID: 9318
00:48:56: CWD: /var/lib/fahclient
00:48:56: OS: Linux 4.4.0-176-generic x86_64
00:48:56: OS Arch: AMD64
00:48:56: GPUs: 1
00:48:56: GPU 0: Bus:1 Slot:0 Func:0 NVIDIA:7 GP106 [GeForce GTX 1060 6GB] 4372
00:48:56: CUDA Device 0: Platform:0 Device:0 Bus:1 Slot:0 Compute:6.1 Driver:10.1
00:48:56:OpenCL Device 0: Platform:0 Device:0 Bus:1 Slot:0 Compute:1.2 Driver:430.64
00:48:56:***********************************************************************
00:48:56:<config>
00:48:56: <!-- Folding Slot Configuration -->
00:48:56: <smp v='false'/>
00:48:56:
00:48:56: <!-- User Information -->
00:48:56: <user v='florinandrei'/>
00:48:56:
00:48:56: <!-- Folding Slots -->
00:48:56: <slot id='1' type='GPU'/>
00:48:56:</config>
00:48:56:Switching to user fahclient
00:48:56:Trying to access database...
00:48:56:Successfully acquired database lock
00:48:56:Enabled folding slot 01: READY gpu:0:GP106 [GeForce GTX 1060 6GB] 4372
00:48:56:WU00:FS01:Connecting to 65.254.110.245:8080
Florin Andrei
Re: GTX1060 Linux drv v430 Error compiling kernel BAD_WORK_U
Did you also install the nvidia OpenCL support as well?
florinandrei
I think so.
BTW, this system used to mine cryptocurrency with ccminer on the GPU a while ago, but with older Nvidia drivers. All I did was - I removed all nvidia* packages, then reinstalled the latest (430) from the PPA:
https://launchpad.net/~graphics-drivers ... ubuntu/ppa
# clinfo
Number of platforms 1
Platform Name NVIDIA CUDA
Platform Vendor NVIDIA Corporation
Platform Version OpenCL 1.2 CUDA 10.1.120
Platform Profile FULL_PROFILE
Platform Extensions cl_khr_global_int32_base_atomics cl_khr_global_int32_extended_atomics cl_khr_local_int32_base_atomics cl_khr_local_int32_extended_atomics cl_khr_fp64 cl_khr_byte_addressable_store cl_khr_icd cl_khr_gl_sharing cl_nv_compiler_options cl_nv_device_attribute_query cl_nv_pragma_unroll cl_nv_copy_opts cl_nv_create_buffer
Platform Extensions function suffix NV
Number of devices 1
Device Name GeForce GTX 1060 6GB
Device Vendor NVIDIA Corporation
Device Vendor ID 0x10de
Device Version OpenCL 1.2 CUDA
Driver Version 430.64
Device OpenCL C Version OpenCL C 1.2
Device Type GPU
Device Profile FULL_PROFILE
Device Topology (NV) PCI-E, 01:00.0
Max compute units 10
Max clock frequency 1771MHz
Compute Capability (NV) 6.1
Device Partition (core)
Max number of sub-devices 1
Supported partition types None
Max work item dimensions 3
Max work item sizes 1024x1024x64
Max work group size 1024
=== CL_PROGRAM_BUILD_LOG ===
Preferred work group size multiple
Warp size (NV) 32
char 1 / 1
short 1 / 1
int 1 / 1
long 1 / 1
half 0 / 0 (n/a)
float 1 / 1
double 1 / 1 (cl_khr_fp64)
Half-precision Floating-point support (n/a)
Single-precision Floating-point support (core)
Denormals Yes
Infinity and NANs Yes
Round to nearest Yes
Round to zero Yes
Round to infinity Yes
IEEE754-2008 fused multiply-add Yes
Support is emulated in software No
Correctly-rounded divide and sqrt operations Yes
Double-precision Floating-point support (cl_khr_fp64)
Denormals Yes
Round to zero Yes
Correctly-rounded divide and sqrt operations No
Address bits 64, Little-Endian
Global memory size 6368198656 (5.931GiB)
Error Correction support No
Max memory allocation 1592049664 (1.483GiB)
Unified memory for Host and Device No
Integrated memory (NV) No
Minimum alignment for any data type 128 bytes
Alignment of base address 4096 bits (512 bytes)
Global Memory cache type Read/Write
Global Memory cache size 163840
Global Memory cache line 128 bytes
Image support Yes
Max number of samplers per kernel 32
Max size for 1D images from buffer 134217728 pixels
Max 1D or 2D image array size 2048 images
Max 2D image size 16384x32768 pixels
Max 3D image size 16384x16384x16384 pixels
Max number of read image args 256
Max number of write image args 16
Local memory type Local
Local memory size 49152 (48KiB)
Registers per block (NV) 65536
Max constant buffer size 65536 (64KiB)
Max number of constant args 9
Max size of kernel argument 4352 (4.25KiB)
Queue properties
Out-of-order execution Yes
Profiling Yes
Prefer user sync for interop No
Profiling timer resolution 1000ns
Execution capabilities
Run OpenCL kernels Yes
Run native kernels No
Kernel execution timeout (NV) Yes
Concurrent copy and kernel execution (NV) Yes
Number of async copy engines 2
printf() buffer size 1048576 (1024KiB)
Built-in kernels
Device Available Yes
Compiler Available Yes
Linker Available Yes
Device Extensions cl_khr_global_int32_base_atomics cl_khr_global_int32_extended_atomics cl_khr_local_int32_base_atomics cl_khr_local_int32_extended_atomics cl_khr_fp64 cl_khr_byte_addressable_store cl_khr_icd cl_khr_gl_sharing cl_nv_compiler_options cl_nv_device_attribute_query cl_nv_pragma_unroll cl_nv_copy_opts cl_nv_create_buffer
NULL platform behavior
clGetPlatformInfo(NULL, CL_PLATFORM_NAME, ...) NVIDIA CUDA
clGetDeviceIDs(NULL, CL_DEVICE_TYPE_ALL, ...) Success [NV]
clCreateContext(NULL, ...) [default] Success [NV]
clCreateContextFromType(NULL, CL_DEVICE_TYPE_CPU) No devices found in platform
clCreateContextFromType(NULL, CL_DEVICE_TYPE_GPU) No platform
clCreateContextFromType(NULL, CL_DEVICE_TYPE_ACCELERATOR) No devices found in platform
clCreateContextFromType(NULL, CL_DEVICE_TYPE_CUSTOM) No devices found in platform
clCreateContextFromType(NULL, CL_DEVICE_TYPE_ALL) No platform
ICD loader properties
ICD loader Name OpenCL ICD Loader
ICD loader Vendor OCL Icd free software
ICD loader Version 2.2.8
ICD loader Profile OpenCL 1.2
NOTE: your OpenCL library declares to support OpenCL 1.2,
but it seems to support up to OpenCL 2.1 too.
Florin Andrei
florinandrei
I just checked, ewbf-miner works just fine mining Zcash on this GPU with the 430 drivers. I see it in the output from nvidia-smi.
So the GPU-related stuff is not completely broken. At least the crypto apps still work (though at a financial loss).
$ nvidia-smi
Fri Mar 27 17:41:29 2020
| NVIDIA-SMI 430.64 Driver Version: 430.64 CUDA Version: 10.1 |
| GPU Name Persistence-M| Bus-Id Disp.A | Volatile Uncorr. ECC |
| Fan Temp Perf Pwr:Usage/Cap| Memory-Usage | GPU-Util Compute M. |
| 0 GeForce GTX 106... Off | 00000000:01:00.0 On | N/A |
| 49% 79C P2 116W / 120W | 615MiB / 6073MiB | 100% Default |
| Processes: GPU Memory |
| GPU PID Type Process name Usage |
| 0 1709 G /usr/lib/xorg/Xorg 32MiB |
| 0 11871 C ewbf-miner 571MiB |
Florin Andrei
Looks like the OpenCL support is there. It has been over a year since I set up my 16.04 system successfully, only thing else you might need is the OpenCL-dev package. But my notes are buried under a bunch of stuff at the moment, hopefully someone who has done this more recently can add to this topic and get you the rest of the way there.
florinandrei
I think I have it already:
# dpkg -l | grep nvidia
ii nvidia-430 430.64-0ubuntu0~gpu16.04.2 amd64 NVIDIA binary driver - version 430.64
ii nvidia-opencl-dev:amd64 7.5.18-0ubuntu1 amd64 NVIDIA OpenCL development files
ii nvidia-opencl-icd-430 430.64-0ubuntu0~gpu16.04.2 amd64 NVIDIA OpenCL ICD
ii nvidia-prime 0.8.2 amd64 Tools to enable NVIDIA's Prime
ii nvidia-settings 440.64.00-0ubuntu1 amd64 Tool for configuring the NVIDIA graphics driverFlorin Andrei
florinandrei
Current list of installed packages, still failing:
ii nvidia-cuda-dev 7.5.18-0ubuntu1 amd64 NVIDIA CUDA development files
ii nvidia-cuda-doc 7.5.18-0ubuntu1 all NVIDIA CUDA and OpenCL documentation
ii nvidia-cuda-gdb 7.5.18-0ubuntu1 amd64 NVIDIA CUDA Debugger (GDB)
ii nvidia-cuda-toolkit 7.5.18-0ubuntu1 amd64 NVIDIA CUDA development toolkit
ii nvidia-profiler 7.5.18-0ubuntu1 amd64 NVIDIA Profiler for CUDA and OpenCL
ii nvidia-visual-profiler 7.5.18-0ubuntu1 amd64 NVIDIA Visual Profiler for CUDA and OpenCL
Florin Andrei
florinandrei
Is there a way to increase the verbosity of the log? It fails to compile the kernel - okay, but how does it fail exactly? What is the error? That would help identify the cause of the error.
Florin Andrei
You can increase the FAHClient logging verbosity, but as I recall the error messages from the folding core may not show up there. The error report might be in the science.log, or other log associated with the processing in the work folder. Those might be too ephemeral in an error like this to capture. FAHClient collects and enters into its log many, but not all, messages connected to the folding cores processing a WU.
florinandrei
I've downgraded the drivers to 390.116 (apt-get install nvidia-390, with the PPA) and now the GPU core seems to be crunching WUs.
But, folks, this is not right. That's a very old driver. The current driver series is 44x. A lot of people will install the latest. A lot of Ubuntu users, like me, will follow the recommendation from the PPA, which is the 43x series - and FAH will fail.
Can we get the Linux GPU core to work with more recent drivers?
Thanks!
ii nvidia-390 390.116-0ubuntu1 amd64 NVIDIA binary driver - version 390.116
ii nvidia-opencl-icd-390 390.116-0ubuntu1 amd64 NVIDIA OpenCL ICD
21:56:38:WU00:FS01:0x22:Project: 11753 (Run 0, Clone 2636, Gen 10)
21:56:38:WU00:FS01:0x22:Unit: 0x000000119bf7a4d55e6d76c7d507bf1f
21:56:38:WU00:FS01:0x22:Reading tar file core.xml
21:56:38:WU00:FS01:0x22:Reading tar file integrator.xml
21:56:38:WU00:FS01:0x22:Reading tar file state.xml
21:56:39:WU00:FS01:0x22:Reading tar file system.xml
21:56:40:WU00:FS01:0x22:Digital signatures verified
21:56:40:WU00:FS01:0x22:Folding@home GPU Core22 Folding@home Core
21:56:40:WU00:FS01:0x22:Version 0.0.2
21:57:06:WU00:FS01:0x22:Completed 0 out of 1000000 steps (0%)
21:57:06:WU00:FS01:0x22:Temperature control disabled. Requirements: single Nvidia GPU, tmax must be < 110 and twait >= 900
21:59:49:WU00:FS01:0x22:Completed 10000 out of 1000000 steps (1%)
22:02:31:WU00:FS01:0x22:Completed 20000 out of 1000000 steps (2%)
Thanks!
Florin Andrei
kevinjos
- Hardware configuration: Igneous - iMac 4GHz 4-Core Intel i7
Valis - 2.2GHz 20-Core Intel Xeon Silver 4114 + 4x Titan V GPUs - Contact:
I am running FAH on Ubuntu 18.04 with Nvidia Driver Version: 440.64.00 + CUDA Version: 10.2.
Are you able to compile the Nvidia examples on your system with 430.xx installed? https://docs.nvidia.com/cuda/cuda-insta ... g-examples
I, too, have exactly this issue:
Xubuntu 19.10
GeForce GTX 1070 8GB
Nvidia Driver 440.64 (also tried 435, 430).
I have nvidia-opencl-dev, ocl-icd-opencl-dev, etc installed.
Machine info:
I am seeing the same error as others above:
Very occasionally, like once every 20 times, I'll see this:
The CPU was overclocked, but I completely put it back to standard and it made no difference. Still the same errors.
Any help greatly appreciated. I'd like this machine running long term as it's always on and usually not doing much at all. It's used for occasional FPGA builds.
Thanks!
Xubuntu 19.10
Machine info:
01:22:59:************************* Folding@home Client *************************
01:22:59: Website: https://foldingathome.org/
01:22:59: Copyright: (c) 2009-2018 foldingathome.org
01:22:59: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
01:22:59: Args: --child --lifeline 5517 /etc/fahclient/config.xml --run-as
01:22:59: fahclient --pid-file=/var/run/fahclient.pid --daemon
01:22:59: Config: /etc/fahclient/config.xml
01:22:59:******************************** Build ********************************
01:22:59: Version: 7.5.1
01:22:59: Date: May 11 2018
01:22:59: Time: 19:59:04
01:22:59: Repository: Git
01:22:59: Revision: 4705bf53c635f88b8fe85af7675557e15d491ff0
01:22:59: Branch: master
01:22:59: Compiler: GNU 6.3.0 20170516
01:22:59: Options: -std=gnu++98 -O3 -funroll-loops
01:22:59: Platform: linux2 4.14.0-3-amd64
01:22:59: Bits: 64
01:22:59: Mode: Release
01:22:59:******************************* System ********************************
01:22:59: CPU: AMD Ryzen 9 3900X 12-Core Processor
01:22:59: CPU ID: AuthenticAMD Family 23 Model 113 Stepping 0
01:22:59: CPUs: 24
01:22:59: Memory: 62.79GiB
01:22:59: Free Memory: 58.91GiB
01:22:59: Threads: POSIX_THREADS
01:22:59: OS Version: 5.3
01:22:59: Has Battery: false
01:22:59: On Battery: false
01:22:59: UTC Offset: 1
01:22:59: PID: 5519
01:22:59: CWD: /var/lib/fahclient
01:22:59: OS: Linux 5.3.0-42-generic x86_64
01:22:59: OS Arch: AMD64
01:22:59: GPUs: 1
01:22:59: GPU 0: Bus:9 Slot:0 Func:0 NVIDIA:7 GP104 [GeForce GTX 1070] 6463
01:22:59: CUDA Device 0: Platform:0 Device:0 Bus:9 Slot:0 Compute:6.1 Driver:10.2
01:22:59:OpenCL Device 0: Platform:0 Device:0 Bus:9 Slot:0 Compute:1.2 Driver:440.64
01:22:59:***********************************************************************
01:45:09:WU02:FS01:Connecting to 65.254.110.245:8080
01:45:09:WARNING:WU02:FS01:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
01:45:09:WU02:FS01:Connecting to 18.218.241.186:80
01:45:10:WU02:FS01:Assigned to work server 40.114.52.201
01:45:10:WU02:FS01:Requesting new work unit for slot 01: READY gpu:0:GP104 [GeForce GTX 1070] 6463 from 40.114.52.201
01:45:10:WU02:FS01:Connecting to 40.114.52.201:8080
01:45:33:WU02:FS01:Downloading 29.59MiB
01:45:39:WU02:FS01:Download 22.39%
01:45:45:WU02:FS01:Download 36.97%
01:45:51:WU02:FS01:Download 56.82%
01:45:57:WU02:FS01:Download 69.92%
01:46:03:WU02:FS01:Download 90.62%
01:46:05:WU02:FS01:Download complete
01:46:05:WU02:FS01:Received Unit: id:02 state:DOWNLOAD error:NO_ERROR project:11778 run:0 clone:30675 gen:6 core:0x22 unit:0x0000000b287234c95e792f710bd2efa9
01:46:05:WU02:FS01:Starting
01:46:05:WU02:FS01:Running FahCore: /usr/bin/FAHCoreWrapper /var/lib/fahclient/cores/cores.foldingathome.org/v7/lin/64bit/Core_22.fah/FahCore_22 -dir 02 -suffix 01 -version 705 -lifeline 5519 -checkpoint 15 -gpu-vendor nvidia -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu 0
01:46:05:WU02:FS01:Started FahCore on PID 8162
01:46:05:WU02:FS01:Core PID:8166
01:46:05:WU02:FS01:FahCore 0x22 started
01:46:05:WU02:FS01:0x22:*********************** Log Started 2020-03-31T01:46:05Z ***********************
01:46:05:WU02:FS01:0x22:*************************** Core22 Folding@home Core ***************************
01:46:05:WU02:FS01:0x22: Type: 0x22
01:46:05:WU02:FS01:0x22: Core: Core22
01:46:05:WU02:FS01:0x22: Website: https://foldingathome.org/
01:46:05:WU02:FS01:0x22: Copyright: (c) 2009-2018 foldingathome.org
01:46:05:WU02:FS01:0x22: Author: John Chodera <john.chodera@choderalab.org> and Rafal Wiewiora
01:46:05:WU02:FS01:0x22: <rafal.wiewiora@choderalab.org>
01:46:05:WU02:FS01:0x22: Args: -dir 02 -suffix 01 -version 705 -lifeline 8162 -checkpoint 15
01:46:05:WU02:FS01:0x22: -gpu-vendor nvidia -opencl-platform 0 -opencl-device 0 -cuda-device
01:46:05:WU02:FS01:0x22: 0 -gpu 0
01:46:05:WU02:FS01:0x22: Config: <none>
01:46:05:WU02:FS01:0x22:************************************ Build *************************************
01:46:05:WU02:FS01:0x22: Version: 0.0.2
01:46:05:WU02:FS01:0x22: Date: Dec 6 2019
01:46:05:WU02:FS01:0x22: Time: 21:20:17
01:46:05:WU02:FS01:0x22: Repository: Git
01:46:05:WU02:FS01:0x22: Revision: f87d92b58abdf7e6bf2e173cfbc4dc3e837c7042
01:46:05:WU02:FS01:0x22: Branch: core22
01:46:05:WU02:FS01:0x22: Compiler: GNU 4.8.2 20140120 (Red Hat 4.8.2-15)
01:46:05:WU02:FS01:0x22: Options: -std=gnu++98 -O3 -funroll-loops
01:46:05:WU02:FS01:0x22: Platform: linux2 4.9.87-linuxkit-aufs
01:46:05:WU02:FS01:0x22: Bits: 64
01:46:05:WU02:FS01:0x22: Mode: Release
01:46:05:WU02:FS01:0x22:************************************ System ************************************
01:46:05:WU02:FS01:0x22: CPU: AMD Ryzen 9 3900X 12-Core Processor
01:46:05:WU02:FS01:0x22: CPU ID: AuthenticAMD Family 23 Model 113 Stepping 0
01:46:05:WU02:FS01:0x22: CPUs: 24
01:46:05:WU02:FS01:0x22: Memory: 62.79GiB
01:46:05:WU02:FS01:0x22:Free Memory: 57.96GiB
01:46:05:WU02:FS01:0x22: Threads: POSIX_THREADS
01:46:05:WU02:FS01:0x22: OS Version: 5.3
01:46:05:WU02:FS01:0x22:Has Battery: false
01:46:05:WU02:FS01:0x22: On Battery: false
01:46:05:WU02:FS01:0x22: UTC Offset: 1
01:46:05:WU02:FS01:0x22: PID: 8166
01:46:05:WU02:FS01:0x22: CWD: /var/lib/fahclient/work
01:46:05:WU02:FS01:0x22: OS: Linux 5.3.0-42-generic x86_64
01:46:05:WU02:FS01:0x22: OS Arch: AMD64
01:46:05:WU02:FS01:0x22:********************************************************************************
01:46:05:WU02:FS01:0x22:Project: 11778 (Run 0, Clone 30675, Gen 6)
01:46:05:WU02:FS01:0x22:Unit: 0x0000000b287234c95e792f710bd2efa9
01:46:05:WU02:FS01:0x22:Reading tar file core.xml
01:46:05:WU02:FS01:0x22:Reading tar file integrator.xml
01:46:05:WU02:FS01:0x22:Reading tar file state.xml
01:46:05:WU02:FS01:0x22:Reading tar file system.xml
01:46:05:WU02:FS01:0x22:Digital signatures verified
01:46:05:WU02:FS01:0x22:Folding@home GPU Core22 Folding@home Core
01:46:05:WU02:FS01:0x22:Version 0.0.2
01:46:11:WU02:FS01:0x22:Completed 0 out of 2000000 steps (0%)
01:46:11:WU02:FS01:0x22:Temperature control disabled. Requirements: single Nvidia GPU, tmax must be < 110 and twait >= 900
01:46:15:WU02:FS01:0x22:ERROR:exception: clWaitForEvents
01:46:15:WU02:FS01:0x22:Saving result file ../logfile_01.txt
01:46:15:WU02:FS01:0x22:Saving result file checkpt.crc
01:46:15:WU02:FS01:0x22:Saving result file science.log
01:46:15:WU02:FS01:0x22:Folding@home Core Shutdown: BAD_WORK_UNIT
01:46:45:WARNING:WU02:FS01:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
01:46:45:WU02:FS01:Sending unit results: id:02 state:SEND error:FAULTY project:11778 run:0 clone:30675 gen:6 core:0x22 unit:0x0000000b287234c95e792f710bd2efa9
01:46:45:WU02:FS01:Uploading 9.00KiB to 40.114.52.201
01:48:59:WU02:FS01:Upload 100.00%
01:49:33:WU02:FS01:Upload complete
01:49:33:WU02:FS01:Server responded WORK_ACK (400)
01:49:33:WU02:FS01:Cleaning up
02:00:29:WU00:FS01:0x22:Unit: 0x0000002480fccb0a5e6ebfa00627303e
02:00:29:WU00:FS01:0x22:Reading tar file core.xml
02:00:29:WU00:FS01:0x22:Reading tar file integrator.xml
02:00:29:WU00:FS01:0x22:Reading tar file state.xml
02:00:29:WU00:FS01:0x22:Reading tar file system.xml
02:00:29:WU00:FS01:0x22:Digital signatures verified
02:00:29:WU00:FS01:0x22:Folding@home GPU Core22 Folding@home Core
02:00:29:WU00:FS01:0x22:Version 0.0.2
02:00:37:WU00:FS01:0x22:Completed 0 out of 1000000 steps (0%)
02:00:37:WU00:FS01:0x22:Temperature control disabled. Requirements: single Nvidia GPU, tmax must be < 110 and twait >= 900
02:00:58:WU00:FS01:0x22:Bad State detected... attempting to resume from last good checkpoint. Is your system overclocked?
02:00:58:WU00:FS01:0x22:Following exception occured: Particle coordinate is nan
02:01:16:WU00:FS01:0x22:Bad State detected... attempting to resume from last good checkpoint. Is your system overclocked?
02:01:16:WU00:FS01:0x22:Following exception occured: Particle coordinate is nan
Thanks!
As an update to my post yesterday, I can compile CUDA applications and they work.
bandwidthTest:
The same story with deviceQuery:
I hacked the matrix multiply example into an infinite loop and I can see the GPU utilisation hit 100% inside nvidia-settings, so I think everything is working.
Any suggestions would be greatly received. Thanks!
bandwidthTest:
george@ryzen:~/cuda-samples/Samples/bandwidthTest$ make
/usr/bin/nvcc -ccbin g++ -I../../Common -m64 -gencode arch=compute_30,code=sm_30 -gencode arch=compute_35,code=sm_35 -gencode arch=compute_37,code=sm_37 -gencode arch=compute_50,code=sm_50 -gencode arch=compute_52,code=sm_52 -gencode arch=compute_60,code=sm_60 -gencode arch=compute_61,code=sm_61 -gencode arch=compute_70,code=sm_70 -gencode arch=compute_75,code=sm_75 -gencode arch=compute_75,code=compute_75 -o bandwidthTest.o -c bandwidthTest.cu
/usr/bin/nvcc -ccbin g++ -m64 -gencode arch=compute_30,code=sm_30 -gencode arch=compute_35,code=sm_35 -gencode arch=compute_37,code=sm_37 -gencode arch=compute_50,code=sm_50 -gencode arch=compute_52,code=sm_52 -gencode arch=compute_60,code=sm_60 -gencode arch=compute_61,code=sm_61 -gencode arch=compute_70,code=sm_70 -gencode arch=compute_75,code=sm_75 -gencode arch=compute_75,code=compute_75 -o bandwidthTest bandwidthTest.o
mkdir -p ../../bin/x86_64/linux/release
cp bandwidthTest ../../bin/x86_64/linux/release
george@ryzen:~/cuda-samples/Samples/bandwidthTest$ ./bandwidthTest
[CUDA Bandwidth Test] - Starting...
Running on...
Device 0: GeForce GTX 1070
Quick Mode
Host to Device Bandwidth, 1 Device(s)
PINNED Memory Transfers
Transfer Size (Bytes) Bandwidth(GB/s)
32000000 13.1
Device to Host Bandwidth, 1 Device(s)
32000000 13.5
Device to Device Bandwidth, 1 Device(s)
32000000 196.1
Result = PASS
NOTE: The CUDA Samples are not meant for performance measurements. Results may vary when GPU Boost is enabled.
george@ryzen:~/cuda-samples/Samples/deviceQuery$ make
/usr/bin/nvcc -ccbin g++ -I../../Common -m64 -gencode arch=compute_30,code=sm_30 -gencode arch=compute_35,code=sm_35 -gencode arch=compute_37,code=sm_37 -gencode arch=compute_50,code=sm_50 -gencode arch=compute_52,code=sm_52 -gencode arch=compute_60,code=sm_60 -gencode arch=compute_61,code=sm_61 -gencode arch=compute_70,code=sm_70 -gencode arch=compute_75,code=sm_75 -gencode arch=compute_75,code=compute_75 -o deviceQuery.o -c deviceQuery.cpp
/usr/bin/nvcc -ccbin g++ -m64 -gencode arch=compute_30,code=sm_30 -gencode arch=compute_35,code=sm_35 -gencode arch=compute_37,code=sm_37 -gencode arch=compute_50,code=sm_50 -gencode arch=compute_52,code=sm_52 -gencode arch=compute_60,code=sm_60 -gencode arch=compute_61,code=sm_61 -gencode arch=compute_70,code=sm_70 -gencode arch=compute_75,code=sm_75 -gencode arch=compute_75,code=compute_75 -o deviceQuery deviceQuery.o
cp deviceQuery ../../bin/x86_64/linux/release
george@ryzen:~/cuda-samples/Samples/deviceQuery$ ./deviceQuery
./deviceQuery Starting...
CUDA Device Query (Runtime API) version (CUDART static linking)
Detected 1 CUDA Capable device(s)
Device 0: "GeForce GTX 1070"
CUDA Driver Version / Runtime Version 10.2 / 10.1
CUDA Capability Major/Minor version number: 6.1
Total amount of global memory: 8116 MBytes (8510701568 bytes)
(15) Multiprocessors, (128) CUDA Cores/MP: 1920 CUDA Cores
GPU Max Clock rate: 1835 MHz (1.84 GHz)
Memory Clock rate: 4004 Mhz
Memory Bus Width: 256-bit
L2 Cache Size: 2097152 bytes
Maximum Texture Dimension Size (x,y,z) 1D=(131072), 2D=(131072, 65536), 3D=(16384, 16384, 16384)
Maximum Layered 1D Texture Size, (num) layers 1D=(32768), 2048 layers
Maximum Layered 2D Texture Size, (num) layers 2D=(32768, 32768), 2048 layers
Total amount of constant memory: 65536 bytes
Total amount of shared memory per block: 49152 bytes
Total number of registers available per block: 65536
Warp size: 32
Maximum number of threads per multiprocessor: 2048
Maximum number of threads per block: 1024
Max dimension size of a thread block (x,y,z): (1024, 1024, 64)
Max dimension size of a grid size (x,y,z): (2147483647, 65535, 65535)
Maximum memory pitch: 2147483647 bytes
Texture alignment: 512 bytes
Concurrent copy and kernel execution: Yes with 2 copy engine(s)
Run time limit on kernels: Yes
Integrated GPU sharing Host Memory: No
Support host page-locked memory mapping: Yes
Alignment requirement for Surfaces: Yes
Device has ECC support: Disabled
Device supports Unified Addressing (UVA): Yes
Device supports Compute Preemption: Yes
Supports Cooperative Kernel Launch: Yes
Supports MultiDevice Co-op Kernel Launch: Yes
Device PCI Domain ID / Bus ID / location ID: 0 / 9 / 0
Compute Mode:
< Default (multiple host threads can use ::cudaSetDevice() with device simultaneously) >
deviceQuery, CUDA Driver = CUDART, CUDA Driver Version = 10.2, CUDA Runtime Version = 10.1, NumDevs = 1
Result = PASS
I can't think of anything wrong about your configuration. Everything in the long file seems to backup that your card is detected properly and that cuda and opencl is detected.
My only thing thought is that maybe an update to the kernel might be needed as I personally run Xubuntuu 18.04 with a newer kernel.
