140.163.4.241 Down?
geokilla
Hardware configuration: Intel Core i5-10600KF @ 4.9Ghz @ 1.25V
MSI Z490 Gaming Edge Wi-Fi BIOS v17
XPG D50 32GB DDR4-3200 16-19-9-36 2T (Samsung M-Die)
XPG S11 Pro 1TB and Western Digital WD140EDFZ 14TB
EVGA RTX 3060 XC
Corsair RM650x
Phantek P360A with Noctua Exhaust Fans
140.163.4.241 Down?
Post by geokilla »
I completed a WU overnight and more than 12 hours later, the WU still cannot be sent. Lost over 400k PPD on this.... Trying to send project 11744 (0, 5618, 10).
ASUS TUF RTX 3070 OC
Corsair RM650x
jonault
Re: 140.163.4.241 Down?
Post by jonault »
The server stats page says that server has been up all day. What's your log file showing when it tries to upload?
geokilla
EVGA RTX 3060 XC
Corsair RM650x
Post by geokilla »
Looks normal to me? Upload didn't get to 100% for some reason.
00:07:35:WU00:FS01:0x22:*********************** Log Started 2020-03-26T00:07:35Z ***********************
00:07:35:WU00:FS01:0x22:*************************** Core22 Folding@home Core ***************************
00:07:35:WU00:FS01:0x22:       Type: 0x22
00:07:35:WU00:FS01:0x22:       Core: Core22
00:07:35:WU00:FS01:0x22:    Website: https://foldingathome.org/
00:07:35:WU00:FS01:0x22:  Copyright: (c) 2009-2018 foldingathome.org
00:07:35:WU00:FS01:0x22:     Author: John Chodera <john.chodera@choderalab.org> and Rafal Wiewiora
00:07:35:WU00:FS01:0x22:             <rafal.wiewiora@choderalab.org>
00:07:35:WU00:FS01:0x22:       Args: -dir 00 -suffix 01 -version 705 -lifeline 7760 -checkpoint 15
00:07:35:WU00:FS01:0x22:             -gpu-vendor amd -opencl-platform 0 -opencl-device 0 -gpu 0
00:07:35:WU00:FS01:0x22:     Config: <none>
00:07:35:WU00:FS01:0x22:************************************ Build *************************************
00:07:35:WU00:FS01:0x22:    Version: 0.0.2
00:07:35:WU00:FS01:0x22:       Date: Dec 6 2019
00:07:35:WU00:FS01:0x22:       Time: 21:30:31
00:07:35:WU00:FS01:0x22: Repository: Git
00:07:35:WU00:FS01:0x22:   Revision: abeb39247cc72df5af0f63723edafadb23d5dfbe
00:07:35:WU00:FS01:0x22:     Branch: HEAD
00:07:35:WU00:FS01:0x22:   Compiler: Visual C++ 2008
00:07:35:WU00:FS01:0x22:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
00:07:35:WU00:FS01:0x22:   Platform: win32 10
00:07:35:WU00:FS01:0x22:       Bits: 64
00:07:35:WU00:FS01:0x22:       Mode: Release
00:07:35:WU00:FS01:0x22:************************************ System ************************************
00:07:35:WU00:FS01:0x22:        CPU: Intel(R) Core(TM) i5-3570K CPU @ 3.40GHz
00:07:35:WU00:FS01:0x22:     CPU ID: GenuineIntel Family 6 Model 58 Stepping 9
00:07:35:WU00:FS01:0x22:       CPUs: 4
00:07:35:WU00:FS01:0x22:     Memory: 15.96GiB
00:07:35:WU00:FS01:0x22:Free Memory: 11.58GiB
00:07:35:WU00:FS01:0x22:    Threads: WINDOWS_THREADS
00:07:35:WU00:FS01:0x22: OS Version: 6.2
00:07:35:WU00:FS01:0x22:Has Battery: false
00:07:35:WU00:FS01:0x22: On Battery: false
00:07:35:WU00:FS01:0x22: UTC Offset: -4
00:07:35:WU00:FS01:0x22:        PID: 7096
00:07:35:WU00:FS01:0x22:        CWD: C:\Users\Vernon\AppData\Roaming\FAHClient\work
00:07:35:WU00:FS01:0x22:         OS: Windows 10 Home
00:07:35:WU00:FS01:0x22:    OS Arch: AMD64
00:07:35:WU00:FS01:0x22:********************************************************************************
00:07:35:WU00:FS01:0x22:Project: 11744 (Run 0, Clone 5618, Gen 10)
00:07:35:WU00:FS01:0x22:Unit: 0x000000158ca304f15e6bc444c3bf0ca4
00:07:35:WU00:FS01:0x22:Reading tar file core.xml
00:07:35:WU00:FS01:0x22:Reading tar file integrator.xml
00:07:35:WU00:FS01:0x22:Reading tar file state.xml
00:07:36:WU00:FS01:0x22:Reading tar file system.xml
00:07:37:WU00:FS01:0x22:Digital signatures verified
00:07:37:WU00:FS01:0x22:Folding@home GPU Core22 Folding@home Core
00:07:37:WU00:FS01:0x22:Version 0.0.2
00:07:52:WU00:FS01:0x22:Completed 0 out of 1000000 steps (0%)
00:07:52:WU00:FS01:0x22:Temperature control disabled. Requirements: single Nvidia GPU, tmax must be < 110 and twait >= 900
00:09:52:WU00:FS01:0x22:Completed 10000 out of 1000000 steps (1%)
00:11:52:WU00:FS01:0x22:Completed 20000 out of 1000000 steps (2%)
00:13:50:WU00:FS01:0x22:Completed 30000 out of 1000000 steps (3%)
*snip*
02:42:40:WU00:FS01:0x22:Completed 850000 out of 1000000 steps (85%)
02:44:44:WU00:FS01:0x22:WARNING:Console control signal 1 on PID 7096
02:44:44:WU00:FS01:0x22:Exiting, please wait. . .
02:44:44:WU00:FS01:0x22:Folding@home Core Shutdown: INTERRUPTED
02:44:45:WU00:FS01:FahCore returned: INTERRUPTED (102 = 0x66)
03:14:03:WU00:FS01:Starting
03:14:03:WU00:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\Vernon\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/Core_22.fah/FahCore_22.exe -dir 00 -suffix 01 -version 705 -lifeline 7684 -checkpoint 15 -gpu-vendor amd -opencl-platform 0 -opencl-device 0 -gpu 0
03:14:03:WU00:FS01:Started FahCore on PID 1972
03:14:03:WU00:FS01:Core PID:6400
03:14:03:WU00:FS01:FahCore 0x22 started
03:14:04:WU00:FS01:0x22:*********************** Log Started 2020-03-26T03:14:03Z ***********************
03:14:04:WU00:FS01:0x22:*************************** Core22 Folding@home Core ***************************
03:14:04:WU00:FS01:0x22:       Type: 0x22
03:14:04:WU00:FS01:0x22:       Core: Core22
03:14:04:WU00:FS01:0x22:    Website: https://foldingathome.org/
03:14:04:WU00:FS01:0x22:  Copyright: (c) 2009-2018 foldingathome.org
03:14:04:WU00:FS01:0x22:     Author: John Chodera <john.chodera@choderalab.org> and Rafal Wiewiora
03:14:04:WU00:FS01:0x22:             <rafal.wiewiora@choderalab.org>
03:14:04:WU00:FS01:0x22:       Args: -dir 00 -suffix 01 -version 705 -lifeline 1972 -checkpoint 15
03:14:04:WU00:FS01:0x22:             -gpu-vendor amd -opencl-platform 0 -opencl-device 0 -gpu 0
03:14:04:WU00:FS01:0x22:     Config: <none>
03:14:04:WU00:FS01:0x22:************************************ Build *************************************
03:14:04:WU00:FS01:0x22:    Version: 0.0.2
03:14:04:WU00:FS01:0x22:       Date: Dec 6 2019
03:14:04:WU00:FS01:0x22:       Time: 21:30:31
03:14:04:WU00:FS01:0x22: Repository: Git
03:14:04:WU00:FS01:0x22:   Revision: abeb39247cc72df5af0f63723edafadb23d5dfbe
03:14:04:WU00:FS01:0x22:     Branch: HEAD
03:14:04:WU00:FS01:0x22:   Compiler: Visual C++ 2008
03:14:04:WU00:FS01:0x22:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
03:14:04:WU00:FS01:0x22:   Platform: win32 10
03:14:04:WU00:FS01:0x22:       Bits: 64
03:14:04:WU00:FS01:0x22:       Mode: Release
03:14:04:WU00:FS01:0x22:************************************ System ************************************
03:14:04:WU00:FS01:0x22:        CPU: Intel(R) Core(TM) i5-3570K CPU @ 3.40GHz
03:14:04:WU00:FS01:0x22:     CPU ID: GenuineIntel Family 6 Model 58 Stepping 9
03:14:04:WU00:FS01:0x22:       CPUs: 4
03:14:04:WU00:FS01:0x22:     Memory: 15.96GiB
03:14:04:WU00:FS01:0x22:Free Memory: 12.52GiB
03:14:04:WU00:FS01:0x22:    Threads: WINDOWS_THREADS
03:14:04:WU00:FS01:0x22: OS Version: 6.2
03:14:04:WU00:FS01:0x22:Has Battery: false
03:14:04:WU00:FS01:0x22: On Battery: false
03:14:04:WU00:FS01:0x22: UTC Offset: -4
03:14:04:WU00:FS01:0x22:        PID: 6400
03:14:04:WU00:FS01:0x22:        CWD: C:\Users\Vernon\AppData\Roaming\FAHClient\work
03:14:04:WU00:FS01:0x22:         OS: Windows 10 Home
03:14:04:WU00:FS01:0x22:    OS Arch: AMD64
03:14:04:WU00:FS01:0x22:********************************************************************************
03:14:04:WU00:FS01:0x22:Project: 11744 (Run 0, Clone 5618, Gen 10)
03:14:04:WU00:FS01:0x22:Unit: 0x000000158ca304f15e6bc444c3bf0ca4
03:14:04:WU00:FS01:0x22:Digital signatures verified
03:14:04:WU00:FS01:0x22:Folding@home GPU Core22 Folding@home Core
03:14:04:WU00:FS01:0x22:Version 0.0.2
03:14:04:WU00:FS01:0x22:  Found a checkpoint file
03:14:21:WU00:FS01:0x22:Completed 850000 out of 1000000 steps (85%)
03:14:21:WU00:FS01:0x22:Temperature control disabled. Requirements: single Nvidia GPU, tmax must be < 110 and twait >= 900
03:16:15:WU00:FS01:0x22:Completed 860000 out of 1000000 steps (86%)
*snip*
03:45:29:WU00:FS01:0x22:Completed 1000000 out of 1000000 steps (100%)
03:45:34:WU00:FS01:0x22:Saving result file ..\logfile_01.txt
03:45:34:WU00:FS01:0x22:Saving result file checkpointState.xml
03:45:36:WU00:FS01:0x22:Saving result file checkpt.crc
03:45:36:WU00:FS01:0x22:Saving result file positions.xtc
03:45:38:WU00:FS01:0x22:Saving result file science.log
03:45:38:WU00:FS01:0x22:Folding@home Core Shutdown: FINISHED_UNIT
03:45:38:WU00:FS01:FahCore returned: FINISHED_UNIT (100 = 0x64)
03:45:38:WU00:FS01:Sending unit results: id:00 state:SEND error:NO_ERROR project:11744 run:0 clone:5618 gen:10 core:0x22 unit:0x000000158ca304f15e6bc444c3bf0ca4
03:45:38:WU00:FS01:Uploading 14.51MiB to 140.163.4.241
03:45:38:WU00:FS01:Connecting to 140.163.4.241:8080
03:47:16:WU00:FS01:Upload 0.86%
03:47:22:WU00:FS01:Upload 23.26%
03:47:28:WU00:FS01:Upload 87.00%
******************************* Date: 2020-03-26 *******************************
Edit: Restarting the computer did the trick... Weird.
Corsair RM650x
According to your log, you've been hit by the stuck download (or upload) bug where nothing moves, but the client never detects a timeout ... Restarting the client or the computer was the only fix for this.
