i9 macbook pro 2019 16 inch - how many threads
vegancookies
Post by vegancookies »
Macs aren't the best at staying cool, to try and stop the CPU getting too hot how many threads should I set it to.
On my windows i77700K I was getting nearly 90 degrees (it's water cooled as well...) but since setting thread level to 4 it's just below 80 (which is much more reasonable).
Thanks for any and all help!
kiore
Re: i9 macbook pro 2019 16 inch - how many threads
Post by kiore »
Laptops are problematic for cooling, you can do 2 things: move the slider left to decrease priority, or use the advanced function to reduce cores manually perhaps choosing just 4 to see how that goes.
TomJohnson
Hardware configuration: F@H Info – V8.4.9 – 12 Machines – 123 CPUs - 1,000K+ PPD; 1/5/2025
Mac Pro 14,8, 24 CPUs, 256K PPD;
Mac Pro 5,1, 24 CPUs, 496K PPD;
Mac Studio 13,1, 10 CPUs, 146K PPD;
iMac Pro 1,1, 15 CPUs, 267K PPD;
iMac 18,2, 4 CPUs, 29K PPD;
iMac 14,1, 4 CPUs, 40K PPD;
Mac Book Pro 17,1, 8 CPUs, 166K PPD;
Mac Book Pro 13,3, 8 CPUs, 57K PPD;
Mac Book Air 5,2, 4 CPUs, 23K PPD;
Mac Mini 7,1, 4 CPUs, 9K PPD;
HP Pavilion, 12 CPUs, 105K PPD;
SONY VAIO, 8 CPUs, 44K PPD.
Post by TomJohnson »
i have two MBPs folding 24/7 at the Full setting - one a 8,3 from 2011 and a 13,3 from 2016. I use Macs Fan Control to change fan RPM to keep CPU temp around 150 degrees F. Max temp for laptop is 212 then computer will turn itself off. I also have laptops on a raised cookie cooling rack since the bottom acts as a heat sink. https://folding.extremeoverclocking.com ... s=&u=33541
Mac Pro 14,8, 24 CPUs, 226K PPD;
iMac Pro 1,1. 15 CPUs, 267K PPD;
iMac 18,2, 4 CPUs, 29K PPD; + 7 more CPUs
I have had a 2012 model 13" MBP folding or nearly 4.5 years. I keep it raised so air can circulate under it and aid in cooling, and I use 2 of the 4 CPU threads to fold on.
