Client local, online, inactive
AnonymusPlatypus
Post by AnonymusPlatypus »
Hello everyone!
I'm absoultely new here and English isn't my native language, so please bear with me... ^^'
I just loaded the FAH client today and tried to make it work while I'm doing some things afk, but it seems stuck in this local/online/inactive state. When I click in the work queue section I can see a countdown for a download saying "Next attempt", but as soon as it's down to zero it starts counting again instead of starting the download.
Computer Specs: Intel Core i9-99000KF @ 3.60 GHz, 16GB RAM, nVidia GeForce RTX 2080Ti
Network Connection: Cable internet through powerline adapter, Windows Firewall and Bitdefender AV Free (added an exception for both client folder and website)
Operating System: Windows 10 Pro
Overclocked?: no
Stable?: yes
Software: FAHClient v7.5.1
WU details: none so far
Here's my log:
*********************** Log Started 2020-03-26T15:25:36Z ***********************
15:25:36:************************* Folding@home Client *************************
15:25:36:        Website: https://foldingathome.org/
15:25:36:      Copyright: (c) 2009-2018 foldingathome.org
15:25:36:         Author: Joseph Coffland <joseph@cauldrondevelopment.com>
15:25:36:           Args:
15:25:36:         Config: <none>
15:25:36:******************************** Build ********************************
15:25:36:        Version: 7.5.1
15:25:36:           Date: May 11 2018
15:25:36:           Time: 13:06:32
15:25:36:     Repository: Git
15:25:36:       Revision: 4705bf53c635f88b8fe85af7675557e15d491ff0
15:25:36:         Branch: master
15:25:36:       Compiler: Visual C++ 2008
15:25:36:        Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
15:25:36:       Platform: win32 10
15:25:36:           Bits: 32
15:25:36:           Mode: Release
15:25:36:******************************* System ********************************
15:25:36:            CPU: Intel(R) Core(TM) i9-9900KF CPU @ 3.60GHz
15:25:36:         CPU ID: GenuineIntel Family 6 Model 158 Stepping 12
15:25:36:           CPUs: 16
15:25:36:         Memory: 15.92GiB
15:25:36:    Free Memory: 10.37GiB
15:25:36:        Threads: WINDOWS_THREADS
15:25:36:     OS Version: 6.2
15:25:36:    Has Battery: false
15:25:36:     On Battery: false
15:25:36:     UTC Offset: 1
15:25:36:            PID: 4784
15:25:36:            CWD: D:\Programme (x86)\FAHClient
15:25:36:             OS: Windows 10 Enterprise
15:25:36:        OS Arch: AMD64
15:25:36:           GPUs: 0
15:25:36:  CUDA Device 0: Platform:0 Device:0 Bus:1 Slot:0 Compute:7.5 Driver:10.2
15:25:36:OpenCL Device 0: Platform:0 Device:0 Bus:1 Slot:0 Compute:1.2 Driver:441.87
15:25:36:  Win32 Service: false
15:25:36:***********************************************************************
15:25:36:<config>
15:25:36:  <!-- Folding Slots -->
15:25:36:</config>
15:25:36:Connecting to assign1.foldingathome.org:8080
15:25:37:Updated GPUs.txt
15:25:37:Read GPUs.txt
15:25:37:Trying to access database...
15:25:37:Successfully acquired database lock
15:25:37:Enabled folding slot 00: PAUSED cpu:14 (not configured)
15:25:37:Enabled folding slot 01: PAUSED gpu:0:TU102 [GeForce RTX 2080 Ti Rev. A] M 13448 (not configured)
15:25:47:Set client configured
15:25:48:WU00:FS00:Connecting to 65.254.110.245:8080
15:25:48:WU01:FS01:Connecting to 65.254.110.245:8080
15:25:49:WU01:FS01:Connecting to 65.254.110.245:8080
15:25:49:WARNING:WU00:FS00:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
15:25:49:WU00:FS00:Connecting to 18.218.241.186:80
15:25:49:WARNING:WU01:FS01:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
15:25:49:WU01:FS01:Connecting to 18.218.241.186:80
15:25:49:WARNING:WU00:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
15:25:49:ERROR:WU00:FS00:Exception: Could not get an assignment
15:25:49:WU00:FS00:Connecting to 65.254.110.245:8080
15:25:50:WARNING:WU01:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
15:25:50:ERROR:WU01:FS01:Exception: Could not get an assignment
15:25:50:WU01:FS01:Connecting to 65.254.110.245:8080
15:25:50:WARNING:WU00:FS00:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
15:25:50:WU00:FS00:Connecting to 18.218.241.186:80
15:25:50:WARNING:WU01:FS01:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
15:25:50:WU01:FS01:Connecting to 18.218.241.186:80
15:25:50:WARNING:WU00:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
15:25:50:ERROR:WU00:FS00:Exception: Could not get an assignment
15:25:51:WARNING:WU01:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
15:25:51:ERROR:WU01:FS01:Exception: Could not get an assignment
Re: Client local, online, inactive
It's a question of Supply and Demand. Please be patient.
The FAH servers are overwhelmed with Donors trying to help. Nothing appears to be wrong on your end except maybe your drivers. Did you install the drivers from NVidia or are you using the ones supplied with your OS?
Post by Neil-B »
The Assignment Servers and Work Servers have been pretty overloaded last few weeks (you will see many similar threads/topics to yours in this forum) … Your log looks to be ok just the assignment server is busy … Be patient - I would expect you to get WUs before long … The countdown will get longer each attempt so as to not overload the severs with requests - if it gets too long (say over an hour) then pause the client for say a minute then restart folding and the countdown timer with reset.
jonault
Post by jonault »
The servers are very busy because of the large number of new users coming in the last couple of weeks. The "Could not get an assignment" message just means that you're having trouble getting through to the servers. Let the software keep trying and it should eventually get through.
AnonymusPlatypus
Wow, three replies within a couple minutes, you guys are fast :D thanks for that, I guess I'll just wait, then.
bruce wrote:Did you install the drivers from NVidia or are you using the ones supplied with your OS?
I use GeForce Experience to make sure the graphic drivers are up to date, so it should be those from nVidia.
