MSI Afterburner Graph
GPU-Z Info
Driver Version: 26.20.15019.19000 (Adrenalin 20.2.2) DCH /Win10 64
Clinfo
https://pastebin.com/6T6hKUPyCode: Select all
*********************** Log Started 2020-03-25T10:04:15Z ***********************
10:04:15:************************* Folding@home Client *************************
10:04:15: Website: https://foldingathome.org/
10:04:15: Copyright: (c) 2009-2018 foldingathome.org
10:04:15: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
10:04:15: Args:
10:04:15: Config: D:\Users\Public\Documents\FAHClient\config.xml
10:04:15:******************************** Build ********************************
10:04:15: Version: 7.5.1
10:04:15: Date: May 11 2018
10:04:15: Time: 13:06:32
10:04:15: Repository: Git
10:04:15: Revision: 4705bf53c635f88b8fe85af7675557e15d491ff0
10:04:15: Branch: master
10:04:15: Compiler: Visual C++ 2008
10:04:15: Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
10:04:15: Platform: win32 10
10:04:15: Bits: 32
10:04:15: Mode: Release
10:04:15:******************************* System ********************************
10:04:15: CPU: Intel(R) Core(TM) i5-6402P CPU @ 2.80GHz
10:04:15: CPU ID: GenuineIntel Family 6 Model 94 Stepping 3
10:04:15: CPUs: 4
10:04:15: Memory: 15.87GiB
10:04:15: Free Memory: 9.72GiB
10:04:15: Threads: WINDOWS_THREADS
10:04:15: OS Version: 6.2
10:04:15: Has Battery: false
10:04:15: On Battery: false
10:04:15: UTC Offset: 2
10:04:15: PID: 15920
10:04:15: CWD: D:\Users\Public\Documents\FAHClient
10:04:15: OS: Windows 10 Enterprise
10:04:15: OS Arch: AMD64
10:04:15: GPUs: 1
10:04:15: GPU 0: Bus:1 Slot:0 Func:0 AMD:5 Ellesmere XT [Radeon RX
10:04:15: 470/480/570/580]
10:04:15: CUDA: Not detected: Failed to open dynamic library 'nvcuda.dll': The
10:04:15: specified module could not be found.
10:04:15:
10:04:15:OpenCL Device 0: Platform:0 Device:0 Bus:NA Slot:NA Compute:2.1 Driver:26.20
10:04:15:OpenCL Device 2: Platform:1 Device:0 Bus:1 Slot:0 Compute:1.2 Driver:3004.8
10:04:15: Win32 Service: false
10:04:15:***********************************************************************
10:04:16:<config>
10:04:16: <!-- Folding Core -->
10:04:16: <checkpoint v='3'/>
10:04:16:
10:04:16: <!-- Network -->
10:04:16: <proxy v=':8080'/>
10:04:16:
10:04:16: <!-- Slot Control -->
10:04:16: <power v='full'/>
10:04:16:
10:04:16: <!-- User Information -->
10:04:16: <passkey v='********************************'/>
10:04:16: <team v='224497'/>
10:04:16: <user v='e3ccf0cda2_ALL_13Vy3LVepXngBqNP5YNnj1WX5rBqgvqHdt'/>
10:04:16:
10:04:16: <!-- Folding Slots -->
10:04:16: <slot id='0' type='CPU'/>
10:04:16: <slot id='1' type='GPU'>
10:04:16: <max-packet-size v='big'/>
10:04:16: <next-unit-percentage v='95'/>
10:04:16: </slot>
10:04:16:</config>
10:04:16:Trying to access database...
10:04:16:Successfully acquired database lock
10:04:16:Enabled folding slot 00: READY cpu:3
10:04:16:Enabled folding slot 01: READY gpu:0:Ellesmere XT [Radeon RX 470/480/570/580]
10:04:16:ERROR:Exception: Failed to register systray icon: Unspecified error
10:04:16:WU01:FS00:Starting
10:04:16:WU01:FS00:Running FahCore: "D:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" D:\Users\Public\Documents\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/avx/Core_a7.fah/FahCore_a7.exe -dir 01 -suffix 01 -version 705 -lifeline 15920 -checkpoint 3 -np 3
10:04:16:WU01:FS00:Started FahCore on PID 14392
10:04:16:WU01:FS00:Core PID:272
10:04:16:WU01:FS00:FahCore 0xa7 started
10:04:16:WU00:FS01:Connecting to 65.254.110.245:8080
10:04:16:WU01:FS00:0xa7:*********************** Log Started 2020-03-25T10:04:16Z ***********************
10:04:16:WU01:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
10:04:16:WU01:FS00:0xa7: Type: 0xa7
10:04:16:WU01:FS00:0xa7: Core: Gromacs
10:04:16:WU01:FS00:0xa7: Args: -dir 01 -suffix 01 -version 705 -lifeline 14392 -checkpoint 3 -np 3
10:04:16:WU01:FS00:0xa7:************************************ CBang *************************************
10:04:16:WU01:FS00:0xa7: Date: Oct 26 2019
10:04:16:WU01:FS00:0xa7: Time: 01:38:25
10:04:16:WU01:FS00:0xa7: Revision: c46a1a011a24143739ac7218c5a435f66777f62f
10:04:16:WU01:FS00:0xa7: Branch: master
10:04:16:WU01:FS00:0xa7: Compiler: Visual C++ 2008
10:04:16:WU01:FS00:0xa7: Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
10:04:16:WU01:FS00:0xa7: Platform: win32 10
10:04:16:WU01:FS00:0xa7: Bits: 64
10:04:16:WU01:FS00:0xa7: Mode: Release
10:04:16:WU01:FS00:0xa7:************************************ System ************************************
10:04:16:WU01:FS00:0xa7: CPU: Intel(R) Core(TM) i5-6402P CPU @ 2.80GHz
10:04:16:WU01:FS00:0xa7: CPU ID: GenuineIntel Family 6 Model 94 Stepping 3
10:04:16:WU01:FS00:0xa7: CPUs: 4
10:04:16:WU01:FS00:0xa7: Memory: 15.87GiB
10:04:16:WU01:FS00:0xa7:Free Memory: 9.67GiB
10:04:16:WU01:FS00:0xa7: Threads: WINDOWS_THREADS
10:04:16:WU01:FS00:0xa7: OS Version: 6.2
10:04:16:WU01:FS00:0xa7:Has Battery: false
10:04:16:WU01:FS00:0xa7: On Battery: false
10:04:16:WU01:FS00:0xa7: UTC Offset: 2
10:04:16:WU01:FS00:0xa7: PID: 272
10:04:16:WU01:FS00:0xa7: CWD: D:\Users\Public\Documents\FAHClient\work
10:04:16:WU01:FS00:0xa7:******************************** Build - libFAH ********************************
10:04:16:WU01:FS00:0xa7: Version: 0.0.18
10:04:16:WU01:FS00:0xa7: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
10:04:16:WU01:FS00:0xa7: Copyright: 2019 foldingathome.org
10:04:16:WU01:FS00:0xa7: Homepage: https://foldingathome.org/
10:04:16:WU01:FS00:0xa7: Time: 01:52:30
10:04:16:WU01:FS00:0xa7: Revision: c1e3513b1bc0c16013668f2173ee969e5995b38e
10:04:16:WU01:FS00:0xa7:************************************ Build *************************************
10:04:16:WU01:FS00:0xa7: SIMD: avx_256
10:04:16:WU01:FS00:0xa7:********************************************************************************
10:04:16:WU01:FS00:0xa7:Project: 14304 (Run 0, Clone 61, Gen 37)
10:04:16:WU01:FS00:0xa7:Unit: 0x0000002a9bf7a4d55e655f7a8a2627e3
10:04:16:WU01:FS00:0xa7:Digital signatures verified
10:04:16:WU01:FS00:0xa7:Calling: mdrun -s frame37.tpr -o frame37.trr -cpi state.cpt -cpt 3 -nt 3
10:04:16:WU01:FS00:0xa7:Steps: first=18500000 total=500000
10:04:17:WU01:FS00:0xa7:Completed 14572 out of 500000 steps (2%)
10:04:17:WARNING:WU00:FS01:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
10:04:17:WU00:FS01:Connecting to 18.218.241.186:80
10:04:18:WARNING:WU00:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
10:04:18:ERROR:WU00:FS01:Exception: Could not get an assignment
10:04:18:WU00:FS01:Connecting to 65.254.110.245:8080
10:04:19:WARNING:WU00:FS01:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
10:04:19:WU00:FS01:Connecting to 18.218.241.186:80
10:04:20:WARNING:WU00:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
10:04:20:ERROR:WU00:FS01:Exception: Could not get an assignment
10:04:24:WU01:FS00:0xa7:Completed 15000 out of 500000 steps (3%)
10:05:18:WU00:FS01:Connecting to 65.254.110.245:8080
10:05:19:WARNING:WU00:FS01:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
10:05:19:WU00:FS01:Connecting to 18.218.241.186:80
10:05:19:WARNING:WU00:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
10:05:19:ERROR:WU00:FS01:Exception: Could not get an assignment
10:05:30:WU01:FS00:0xa7:Completed 20000 out of 500000 steps (4%)
10:06:46:WU01:FS00:0xa7:Completed 25000 out of 500000 steps (5%)
10:06:55:WU00:FS01:Connecting to 65.254.110.245:8080
10:06:56:WU00:FS01:Assigned to work server 128.252.203.10
10:06:56:WU00:FS01:Requesting new work unit for slot 01: READY gpu:0:Ellesmere XT [Radeon RX 470/480/570/580] from 128.252.203.10
10:06:56:WU00:FS01:Connecting to 128.252.203.10:8080
10:07:17:WARNING:WU00:FS01:WorkServer connection failed on port 8080 trying 80
10:07:17:WU00:FS01:Connecting to 128.252.203.10:80
10:07:39:ERROR:WU00:FS01:Exception: Failed to connect to 128.252.203.10:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
10:08:08:WU01:FS00:0xa7:Completed 30000 out of 500000 steps (6%)
10:09:28:WU01:FS00:0xa7:Completed 35000 out of 500000 steps (7%)
10:09:33:WU00:FS01:Connecting to 65.254.110.245:8080
10:09:33:WU00:FS01:Assigned to work server 40.114.52.201
10:09:33:WU00:FS01:Requesting new work unit for slot 01: READY gpu:0:Ellesmere XT [Radeon RX 470/480/570/580] from 40.114.52.201
10:09:33:WU00:FS01:Connecting to 40.114.52.201:8080
10:09:54:WARNING:WU00:FS01:WorkServer connection failed on port 8080 trying 80
10:09:54:WU00:FS01:Connecting to 40.114.52.201:80
10:10:16:ERROR:WU00:FS01:Exception: Failed to connect to 40.114.52.201:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
10:10:49:WU01:FS00:0xa7:Completed 40000 out of 500000 steps (8%)
10:12:09:WU01:FS00:0xa7:Completed 45000 out of 500000 steps (9%)
10:13:30:WU01:FS00:0xa7:Completed 50000 out of 500000 steps (10%)
10:13:47:WU00:FS01:Connecting to 65.254.110.245:8080
10:13:47:WARNING:WU00:FS01:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
10:13:47:WU00:FS01:Connecting to 18.218.241.186:80
10:13:48:WARNING:WU00:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
10:13:48:ERROR:WU00:FS01:Exception: Could not get an assignment
10:14:49:WU01:FS00:0xa7:Completed 55000 out of 500000 steps (11%)
10:16:09:WU01:FS00:0xa7:Completed 60000 out of 500000 steps (12%)
10:17:30:WU01:FS00:0xa7:Completed 65000 out of 500000 steps (13%)
10:18:52:WU01:FS00:0xa7:Completed 70000 out of 500000 steps (14%)
10:20:12:WU01:FS00:0xa7:Completed 75000 out of 500000 steps (15%)
10:20:38:WU00:FS01:Connecting to 65.254.110.245:8080
10:20:39:WARNING:WU00:FS01:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
10:20:39:WU00:FS01:Connecting to 18.218.241.186:80
10:20:39:WARNING:WU00:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
10:20:39:ERROR:WU00:FS01:Exception: Could not get an assignment
10:21:33:WU01:FS00:0xa7:Completed 80000 out of 500000 steps (16%)
10:22:53:WU01:FS00:0xa7:Completed 85000 out of 500000 steps (17%)
10:24:13:WU01:FS00:0xa7:Completed 90000 out of 500000 steps (18%)
10:25:34:WU01:FS00:0xa7:Completed 95000 out of 500000 steps (19%)
10:26:55:WU01:FS00:0xa7:Completed 100000 out of 500000 steps (20%)
10:28:28:WU01:FS00:0xa7:Completed 105000 out of 500000 steps (21%)
10:30:39:WU01:FS00:0xa7:Completed 110000 out of 500000 steps (22%)
10:31:44:WU00:FS01:Connecting to 65.254.110.245:8080
10:31:44:WARNING:WU00:FS01:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
10:31:44:WU00:FS01:Connecting to 18.218.241.186:80
10:31:45:WARNING:WU00:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
10:31:45:ERROR:WU00:FS01:Exception: Could not get an assignment
10:32:25:FS01:Paused
10:32:37:FS01:Unpaused
10:32:44:WU00:FS01:Connecting to 65.254.110.245:8080
10:32:44:WARNING:WU00:FS01:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
10:32:44:WU00:FS01:Connecting to 18.218.241.186:80
10:32:45:WARNING:WU00:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
10:32:45:ERROR:WU00:FS01:Exception: Could not get an assignment
10:33:16:WU01:FS00:0xa7:Completed 115000 out of 500000 steps (23%)
10:34:21:WU00:FS01:Connecting to 65.254.110.245:8080
10:34:21:WARNING:WU00:FS01:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
10:34:21:WU00:FS01:Connecting to 18.218.241.186:80
10:34:22:WARNING:WU00:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
10:34:22:ERROR:WU00:FS01:Exception: Could not get an assignment
10:35:38:WU01:FS00:0xa7:Completed 120000 out of 500000 steps (24%)
10:36:44:WU01:FS00:0xa7:Completed 125000 out of 500000 steps (25%)
10:36:58:WU00:FS01:Connecting to 65.254.110.245:8080
10:36:59:WARNING:WU00:FS01:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
10:36:59:WU00:FS01:Connecting to 18.218.241.186:80
10:36:59:WARNING:WU00:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
10:36:59:ERROR:WU00:FS01:Exception: Could not get an assignment
10:37:49:WU01:FS00:0xa7:Completed 130000 out of 500000 steps (26%)
10:38:54:WU01:FS00:0xa7:Completed 135000 out of 500000 steps (27%)
10:39:58:WU01:FS00:0xa7:Completed 140000 out of 500000 steps (28%)
10:41:03:WU01:FS00:0xa7:Completed 145000 out of 500000 steps (29%)
10:41:13:WU00:FS01:Connecting to 65.254.110.245:8080
10:41:13:WARNING:WU00:FS01:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
10:41:13:WU00:FS01:Connecting to 18.218.241.186:80
10:41:14:WARNING:WU00:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
10:41:14:ERROR:WU00:FS01:Exception: Could not get an assignment
10:42:08:WU01:FS00:0xa7:Completed 150000 out of 500000 steps (30%)
10:43:15:WU01:FS00:0xa7:Completed 155000 out of 500000 steps (31%)
10:44:19:WU01:FS00:0xa7:Completed 160000 out of 500000 steps (32%)
10:45:22:WU01:FS00:0xa7:Completed 165000 out of 500000 steps (33%)
10:46:27:WU01:FS00:0xa7:Completed 170000 out of 500000 steps (34%)
10:47:30:WU01:FS00:0xa7:Completed 175000 out of 500000 steps (35%)
10:48:04:WU00:FS01:Connecting to 65.254.110.245:8080
10:48:04:WARNING:WU00:FS01:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
10:48:04:WU00:FS01:Connecting to 18.218.241.186:80
10:48:05:WARNING:WU00:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
10:48:05:ERROR:WU00:FS01:Exception: Could not get an assignment
10:48:34:WU01:FS00:0xa7:Completed 180000 out of 500000 steps (36%)
10:49:38:WU01:FS00:0xa7:Completed 185000 out of 500000 steps (37%)
10:50:42:WU01:FS00:0xa7:Completed 190000 out of 500000 steps (38%)
10:51:45:WU01:FS00:0xa7:Completed 195000 out of 500000 steps (39%)
10:52:49:WU01:FS00:0xa7:Completed 200000 out of 500000 steps (40%)
10:53:52:WU01:FS00:0xa7:Completed 205000 out of 500000 steps (41%)
10:54:56:WU01:FS00:0xa7:Completed 210000 out of 500000 steps (42%)
10:56:00:WU01:FS00:0xa7:Completed 215000 out of 500000 steps (43%)
10:57:03:WU01:FS00:0xa7:Completed 220000 out of 500000 steps (44%)
10:58:06:WU01:FS00:0xa7:Completed 225000 out of 500000 steps (45%)
10:59:10:WU00:FS01:Connecting to 65.254.110.245:8080
10:59:10:WU00:FS01:Assigned to work server 40.114.52.201
10:59:10:WU00:FS01:Requesting new work unit for slot 01: READY gpu:0:Ellesmere XT [Radeon RX 470/480/570/580] from 40.114.52.201
10:59:10:WU00:FS01:Connecting to 40.114.52.201:8080
10:59:11:WU01:FS00:0xa7:Completed 230000 out of 500000 steps (46%)
10:59:31:WARNING:WU00:FS01:WorkServer connection failed on port 8080 trying 80
10:59:31:WU00:FS01:Connecting to 40.114.52.201:80
10:59:48:ERROR:WU00:FS01:Exception: Failed to connect to 40.114.52.201:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
11:00:14:WU01:FS00:0xa7:Completed 235000 out of 500000 steps (47%)
11:01:18:WU01:FS00:0xa7:Completed 240000 out of 500000 steps (48%)
11:02:22:WU01:FS00:0xa7:Completed 245000 out of 500000 steps (49%)
11:03:25:WU01:FS00:0xa7:Completed 250000 out of 500000 steps (50%)
11:04:29:WU01:FS00:0xa7:Completed 255000 out of 500000 steps (51%)
11:05:33:WU01:FS00:0xa7:Completed 260000 out of 500000 steps (52%)
11:06:36:WU01:FS00:0xa7:Completed 265000 out of 500000 steps (53%)
11:07:40:WU01:FS00:0xa7:Completed 270000 out of 500000 steps (54%)
11:08:44:WU01:FS00:0xa7:Completed 275000 out of 500000 steps (55%)
11:09:47:WU01:FS00:0xa7:Completed 280000 out of 500000 steps (56%)
11:10:52:WU01:FS00:0xa7:Completed 285000 out of 500000 steps (57%)
11:11:55:WU01:FS00:0xa7:Completed 290000 out of 500000 steps (58%)
11:12:59:WU01:FS00:0xa7:Completed 295000 out of 500000 steps (59%)
11:14:03:WU01:FS00:0xa7:Completed 300000 out of 500000 steps (60%)
11:15:06:WU01:FS00:0xa7:Completed 305000 out of 500000 steps (61%)
11:16:10:WU01:FS00:0xa7:Completed 310000 out of 500000 steps (62%)
11:17:06:WU00:FS01:Connecting to 65.254.110.245:8080
11:17:07:WARNING:WU00:FS01:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
11:17:07:WU00:FS01:Connecting to 18.218.241.186:80
11:17:07:WARNING:WU00:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
11:17:07:ERROR:WU00:FS01:Exception: Could not get an assignment
11:17:14:WU01:FS00:0xa7:Completed 315000 out of 500000 steps (63%)
11:18:18:WU01:FS00:0xa7:Completed 320000 out of 500000 steps (64%)
11:19:22:WU01:FS00:0xa7:Completed 325000 out of 500000 steps (65%)
11:20:26:WU01:FS00:0xa7:Completed 330000 out of 500000 steps (66%)
11:21:30:WU01:FS00:0xa7:Completed 335000 out of 500000 steps (67%)
11:22:35:WU01:FS00:0xa7:Completed 340000 out of 500000 steps (68%)
11:23:39:WU01:FS00:0xa7:Completed 345000 out of 500000 steps (69%)
11:24:43:WU01:FS00:0xa7:Completed 350000 out of 500000 steps (70%)
11:25:48:WU01:FS00:0xa7:Completed 355000 out of 500000 steps (71%)
11:26:52:WU01:FS00:0xa7:Completed 360000 out of 500000 steps (72%)
11:27:56:WU01:FS00:0xa7:Completed 365000 out of 500000 steps (73%)
11:29:00:WU01:FS00:0xa7:Completed 370000 out of 500000 steps (74%)
11:30:04:WU01:FS00:0xa7:Completed 375000 out of 500000 steps (75%)
11:31:08:WU01:FS00:0xa7:Completed 380000 out of 500000 steps (76%)
11:32:13:WU01:FS00:0xa7:Completed 385000 out of 500000 steps (77%)
11:33:18:WU01:FS00:0xa7:Completed 390000 out of 500000 steps (78%)
11:34:22:WU01:FS00:0xa7:Completed 395000 out of 500000 steps (79%)
11:35:26:WU01:FS00:0xa7:Completed 400000 out of 500000 steps (80%)
11:36:31:WU01:FS00:0xa7:Completed 405000 out of 500000 steps (81%)
11:37:35:WU01:FS00:0xa7:Completed 410000 out of 500000 steps (82%)
11:38:39:WU01:FS00:0xa7:Completed 415000 out of 500000 steps (83%)
11:39:44:WU01:FS00:0xa7:Completed 420000 out of 500000 steps (84%)
11:40:48:WU01:FS00:0xa7:Completed 425000 out of 500000 steps (85%)
11:41:53:WU01:FS00:0xa7:Completed 430000 out of 500000 steps (86%)
11:42:57:WU01:FS00:0xa7:Completed 435000 out of 500000 steps (87%)
11:44:01:WU01:FS00:0xa7:Completed 440000 out of 500000 steps (88%)
11:45:06:WU01:FS00:0xa7:Completed 445000 out of 500000 steps (89%)
11:46:09:WU00:FS01:Connecting to 65.254.110.245:8080
11:46:09:WARNING:WU00:FS01:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
11:46:09:WU00:FS01:Connecting to 18.218.241.186:80
11:46:09:WU01:FS00:0xa7:Completed 450000 out of 500000 steps (90%)
11:46:09:WU00:FS01:Assigned to work server 40.114.52.201
11:46:09:WU00:FS01:Requesting new work unit for slot 01: READY gpu:0:Ellesmere XT [Radeon RX 470/480/570/580] from 40.114.52.201
11:46:09:WU00:FS01:Connecting to 40.114.52.201:8080
11:46:41:ERROR:WU00:FS01:Exception: 10002: Received short response, expected 512 bytes, got 0
11:47:14:WU01:FS00:0xa7:Completed 455000 out of 500000 steps (91%)
11:48:18:WU01:FS00:0xa7:Completed 460000 out of 500000 steps (92%)
11:49:22:WU01:FS00:0xa7:Completed 465000 out of 500000 steps (93%)
11:50:28:WU01:FS00:0xa7:Completed 470000 out of 500000 steps (94%)
11:51:32:WU01:FS00:0xa7:Completed 475000 out of 500000 steps (95%)
11:52:37:WU01:FS00:0xa7:Completed 480000 out of 500000 steps (96%)
11:53:40:WU01:FS00:0xa7:Completed 485000 out of 500000 steps (97%)
11:54:44:WU01:FS00:0xa7:Completed 490000 out of 500000 steps (98%)
11:55:49:WU01:FS00:0xa7:Completed 495000 out of 500000 steps (99%)
11:55:50:WU02:FS00:Connecting to 65.254.110.245:8080
11:55:50:WU02:FS00:Assigned to work server 13.90.152.57
11:55:50:WU02:FS00:Requesting new work unit for slot 00: RUNNING cpu:3 from 13.90.152.57
11:55:50:WU02:FS00:Connecting to 13.90.152.57:8080
11:55:52:WU02:FS00:Downloading 4.50MiB
11:55:58:WU02:FS00:Download 77.86%
11:55:59:WU02:FS00:Download complete
11:55:59:WU02:FS00:Received Unit: id:02 state:DOWNLOAD error:NO_ERROR project:13860 run:0 clone:2750 gen:8 core:0xa7 unit:0x0000000a0d5a98395e72df1477b5001a
11:56:52:WU01:FS00:0xa7:Completed 500000 out of 500000 steps (100%)
11:56:53:WU01:FS00:0xa7:Saving result file ..\logfile_01.txt
11:56:53:WU01:FS00:0xa7:Saving result file frame37.trr
11:56:53:WU01:FS00:0xa7:Saving result file md.log
11:56:53:WU01:FS00:0xa7:Saving result file pullf.xvg
11:56:53:WU01:FS00:0xa7:Saving result file pullx.xvg
11:56:53:WU01:FS00:0xa7:Saving result file science.log
11:56:53:WU01:FS00:0xa7:Saving result file traj_comp.xtc
11:56:53:WU01:FS00:0xa7:Folding@home Core Shutdown: FINISHED_UNIT
11:56:54:WU01:FS00:FahCore returned: FINISHED_UNIT (100 = 0x64)
11:56:54:WU01:FS00:Sending unit results: id:01 state:SEND error:NO_ERROR project:14304 run:0 clone:61 gen:37 core:0xa7 unit:0x0000002a9bf7a4d55e655f7a8a2627e3
11:56:54:WU01:FS00:Uploading 2.65MiB to 155.247.164.213
11:56:54:WU02:FS00:Starting
11:56:54:WU01:FS00:Connecting to 155.247.164.213:8080
11:56:54:WU02:FS00:Running FahCore: "D:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" D:\Users\Public\Documents\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/avx/Core_a7.fah/FahCore_a7.exe -dir 02 -suffix 01 -version 705 -lifeline 15920 -checkpoint 3 -np 3
11:56:54:WU02:FS00:Started FahCore on PID 26540
11:56:54:WU02:FS00:Core PID:14228
11:56:54:WU02:FS00:FahCore 0xa7 started
11:56:55:WU02:FS00:0xa7:*********************** Log Started 2020-03-25T11:56:54Z ***********************
11:56:55:WU02:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
11:56:55:WU02:FS00:0xa7: Type: 0xa7
11:56:55:WU02:FS00:0xa7: Core: Gromacs
11:56:55:WU02:FS00:0xa7: Args: -dir 02 -suffix 01 -version 705 -lifeline 26540 -checkpoint 3 -np 3
11:56:55:WU02:FS00:0xa7:************************************ CBang *************************************
11:56:55:WU02:FS00:0xa7: Date: Oct 26 2019
11:56:55:WU02:FS00:0xa7: Time: 01:38:25
11:56:55:WU02:FS00:0xa7: Revision: c46a1a011a24143739ac7218c5a435f66777f62f
11:56:55:WU02:FS00:0xa7: Branch: master
11:56:55:WU02:FS00:0xa7: Compiler: Visual C++ 2008
11:56:55:WU02:FS00:0xa7: Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
11:56:55:WU02:FS00:0xa7: Platform: win32 10
11:56:55:WU02:FS00:0xa7: Bits: 64
11:56:55:WU02:FS00:0xa7: Mode: Release
11:56:55:WU02:FS00:0xa7:************************************ System ************************************
11:56:55:WU02:FS00:0xa7: CPU: Intel(R) Core(TM) i5-6402P CPU @ 2.80GHz
11:56:55:WU02:FS00:0xa7: CPU ID: GenuineIntel Family 6 Model 94 Stepping 3
11:56:55:WU02:FS00:0xa7: CPUs: 4
11:56:55:WU02:FS00:0xa7: Memory: 15.87GiB
11:56:55:WU02:FS00:0xa7:Free Memory: 10.30GiB
11:56:55:WU02:FS00:0xa7: Threads: WINDOWS_THREADS
11:56:55:WU02:FS00:0xa7: OS Version: 6.2
11:56:55:WU02:FS00:0xa7:Has Battery: false
11:56:55:WU02:FS00:0xa7: On Battery: false
11:56:55:WU02:FS00:0xa7: UTC Offset: 2
11:56:55:WU02:FS00:0xa7: PID: 14228
11:56:55:WU02:FS00:0xa7: CWD: D:\Users\Public\Documents\FAHClient\work
11:56:55:WU02:FS00:0xa7:******************************** Build - libFAH ********************************
11:56:55:WU02:FS00:0xa7: Version: 0.0.18
11:56:55:WU02:FS00:0xa7: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
11:56:55:WU02:FS00:0xa7: Copyright: 2019 foldingathome.org
11:56:55:WU02:FS00:0xa7: Homepage: https://foldingathome.org/
11:56:55:WU02:FS00:0xa7: Time: 01:52:30
11:56:55:WU02:FS00:0xa7: Revision: c1e3513b1bc0c16013668f2173ee969e5995b38e
11:56:55:WU02:FS00:0xa7:************************************ Build *************************************
11:56:55:WU02:FS00:0xa7: SIMD: avx_256
11:56:55:WU02:FS00:0xa7:********************************************************************************
11:56:55:WU02:FS00:0xa7:Project: 13860 (Run 0, Clone 2750, Gen 8)
11:56:55:WU02:FS00:0xa7:Unit: 0x0000000a0d5a98395e72df1477b5001a
11:56:55:WU02:FS00:0xa7:Reading tar file core.xml
11:56:55:WU02:FS00:0xa7:Reading tar file frame8.tpr
11:56:55:WU02:FS00:0xa7:Digital signatures verified
11:56:55:WU02:FS00:0xa7:Calling: mdrun -s frame8.tpr -o frame8.trr -x frame8.xtc -e frame8.edr -cpt 3 -nt 3
11:56:55:WU02:FS00:0xa7:Steps: first=1000000 total=125000
11:56:55:WARNING:WU01:FS00:Exception: Failed to send results to work server: Transfer failed
11:56:55:WU01:FS00:Trying to send results to collection server
11:56:55:WU01:FS00:Uploading 2.65MiB to 155.247.164.214
11:56:55:WU01:FS00:Connecting to 155.247.164.214:8080
11:56:56:WU01:FS00:Upload complete
11:56:56:WU02:FS00:0xa7:Completed 1 out of 125000 steps (0%)
11:56:57:WU01:FS00:Server responded WORK_ACK (400)
11:56:57:WU01:FS00:Final credit estimate, 220.00 points
11:56:57:WU01:FS00:Cleaning up
11:58:17:WU02:FS00:0xa7:Completed 1250 out of 125000 steps (1%)
11:59:36:WU02:FS00:0xa7:Completed 2500 out of 125000 steps (2%)
12:00:58:WU02:FS00:0xa7:Completed 3750 out of 125000 steps (3%)
12:02:18:WU02:FS00:0xa7:Completed 5000 out of 125000 steps (4%)
12:03:40:WU02:FS00:0xa7:Completed 6250 out of 125000 steps (5%)
12:04:59:WU02:FS00:0xa7:Completed 7500 out of 125000 steps (6%)
12:06:21:WU02:FS00:0xa7:Completed 8750 out of 125000 steps (7%)
12:07:42:WU02:FS00:0xa7:Completed 10000 out of 125000 steps (8%)
12:09:04:WU02:FS00:0xa7:Completed 11250 out of 125000 steps (9%)
12:10:24:WU02:FS00:0xa7:Completed 12500 out of 125000 steps (10%)
12:11:45:WU02:FS00:0xa7:Completed 13750 out of 125000 steps (11%)
12:13:07:WU02:FS00:0xa7:Completed 15000 out of 125000 steps (12%)
12:14:27:WU02:FS00:0xa7:Completed 16250 out of 125000 steps (13%)
12:15:48:WU02:FS00:0xa7:Completed 17500 out of 125000 steps (14%)
12:17:08:WU02:FS00:0xa7:Completed 18750 out of 125000 steps (15%)
12:18:30:WU02:FS00:0xa7:Completed 20000 out of 125000 steps (16%)
12:19:50:WU02:FS00:0xa7:Completed 21250 out of 125000 steps (17%)
12:21:12:WU02:FS00:0xa7:Completed 22500 out of 125000 steps (18%)
12:22:33:WU02:FS00:0xa7:Completed 23750 out of 125000 steps (19%)
12:23:53:WU02:FS00:0xa7:Completed 25000 out of 125000 steps (20%)
12:25:15:WU02:FS00:0xa7:Completed 26250 out of 125000 steps (21%)
12:26:35:WU02:FS00:0xa7:Completed 27500 out of 125000 steps (22%)
12:27:56:WU02:FS00:0xa7:Completed 28750 out of 125000 steps (23%)
12:29:17:WU02:FS00:0xa7:Completed 30000 out of 125000 steps (24%)
12:30:38:WU02:FS00:0xa7:Completed 31250 out of 125000 steps (25%)
12:31:58:WU02:FS00:0xa7:Completed 32500 out of 125000 steps (26%)
12:33:07:WU00:FS01:Connecting to 65.254.110.245:8080
12:33:08:WARNING:WU00:FS01:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
12:33:08:WU00:FS01:Connecting to 18.218.241.186:80
12:33:08:WU00:FS01:Assigned to work server 128.252.203.10
12:33:08:WU00:FS01:Requesting new work unit for slot 01: READY gpu:0:Ellesmere XT [Radeon RX 470/480/570/580] from 128.252.203.10
12:33:08:WU00:FS01:Connecting to 128.252.203.10:8080
12:33:20:WU02:FS00:0xa7:Completed 33750 out of 125000 steps (27%)
12:33:29:WARNING:WU00:FS01:WorkServer connection failed on port 8080 trying 80
12:33:29:WU00:FS01:Connecting to 128.252.203.10:80
12:34:24:WU00:FS01:Downloading 51.20MiB
12:34:30:WU00:FS01:Download 4.64%
12:34:36:WU00:FS01:Download 8.67%
12:34:41:WU02:FS00:0xa7:Completed 35000 out of 125000 steps (28%)
12:34:42:WU00:FS01:Download 13.43%
12:34:48:WU00:FS01:Download 19.17%
12:34:54:WU00:FS01:Download 24.17%
12:35:00:WU00:FS01:Download 30.27%
12:35:06:WU00:FS01:Download 35.16%
12:35:12:WU00:FS01:Download 40.90%
12:35:18:WU00:FS01:Download 45.90%
12:35:24:WU00:FS01:Download 51.15%
12:35:30:WU00:FS01:Download 56.15%
12:35:36:WU00:FS01:Download 61.89%
12:35:42:WU00:FS01:Download 66.41%
12:35:48:WU00:FS01:Download 71.90%
12:35:54:WU00:FS01:Download 77.15%
12:36:00:WU00:FS01:Download 81.42%
12:36:03:WU02:FS00:0xa7:Completed 36250 out of 125000 steps (29%)
12:36:06:WU00:FS01:Download 86.80%
12:36:12:WU00:FS01:Download 91.92%
12:36:18:WU00:FS01:Download 97.78%
12:36:20:WU00:FS01:Download complete
12:36:20:WU00:FS01:Received Unit: id:00 state:DOWNLOAD error:NO_ERROR project:11763 run:0 clone:3834 gen:15 core:0x22 unit:0x0000001780fccb0a5e6d8165585b7e7c
12:36:20:WU00:FS01:Starting
12:36:20:WU00:FS01:Running FahCore: "D:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" D:\Users\Public\Documents\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/Core_22.fah/FahCore_22.exe -dir 00 -suffix 01 -version 705 -lifeline 15920 -checkpoint 3 -gpu-vendor amd -opencl-platform 1 -opencl-device 0 -gpu 0
12:36:20:WU00:FS01:Started FahCore on PID 5380
12:36:20:WU00:FS01:Core PID:20880
12:36:20:WU00:FS01:FahCore 0x22 started
12:36:21:WU00:FS01:0x22:*********************** Log Started 2020-03-25T12:36:20Z ***********************
12:36:21:WU00:FS01:0x22:*************************** Core22 Folding@home Core ***************************
12:36:21:WU00:FS01:0x22: Type: 0x22
12:36:21:WU00:FS01:0x22: Core: Core22
12:36:21:WU00:FS01:0x22: Website: https://foldingathome.org/
12:36:21:WU00:FS01:0x22: Copyright: (c) 2009-2018 foldingathome.org
12:36:21:WU00:FS01:0x22: Author: John Chodera <john.chodera@choderalab.org> and Rafal Wiewiora
12:36:21:WU00:FS01:0x22: <rafal.wiewiora@choderalab.org>
12:36:21:WU00:FS01:0x22: Args: -dir 00 -suffix 01 -version 705 -lifeline 5380 -checkpoint 3
12:36:21:WU00:FS01:0x22: -gpu-vendor amd -opencl-platform 1 -opencl-device 0 -gpu 0
12:36:21:WU00:FS01:0x22: Config: <none>
12:36:21:WU00:FS01:0x22:************************************ Build *************************************
12:36:21:WU00:FS01:0x22: Version: 0.0.2
12:36:21:WU00:FS01:0x22: Date: Dec 6 2019
12:36:21:WU00:FS01:0x22: Time: 21:30:31
12:36:21:WU00:FS01:0x22: Repository: Git
12:36:21:WU00:FS01:0x22: Revision: abeb39247cc72df5af0f63723edafadb23d5dfbe
12:36:21:WU00:FS01:0x22: Branch: HEAD
12:36:21:WU00:FS01:0x22: Compiler: Visual C++ 2008
12:36:21:WU00:FS01:0x22: Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
12:36:21:WU00:FS01:0x22: Platform: win32 10
12:36:21:WU00:FS01:0x22: Bits: 64
12:36:21:WU00:FS01:0x22: Mode: Release
12:36:21:WU00:FS01:0x22:************************************ System ************************************
12:36:21:WU00:FS01:0x22: CPU: Intel(R) Core(TM) i5-6402P CPU @ 2.80GHz
12:36:21:WU00:FS01:0x22: CPU ID: GenuineIntel Family 6 Model 94 Stepping 3
12:36:21:WU00:FS01:0x22: CPUs: 4
12:36:21:WU00:FS01:0x22: Memory: 15.87GiB
12:36:21:WU00:FS01:0x22:Free Memory: 10.16GiB
12:36:21:WU00:FS01:0x22: Threads: WINDOWS_THREADS
12:36:21:WU00:FS01:0x22: OS Version: 6.2
12:36:21:WU00:FS01:0x22:Has Battery: false
12:36:21:WU00:FS01:0x22: On Battery: false
12:36:21:WU00:FS01:0x22: UTC Offset: 2
12:36:21:WU00:FS01:0x22: PID: 20880
12:36:21:WU00:FS01:0x22: CWD: D:\Users\Public\Documents\FAHClient\work
12:36:21:WU00:FS01:0x22: OS: Windows 10 Pro
12:36:21:WU00:FS01:0x22: OS Arch: AMD64
12:36:21:WU00:FS01:0x22:********************************************************************************
12:36:21:WU00:FS01:0x22:Project: 11763 (Run 0, Clone 3834, Gen 15)
12:36:21:WU00:FS01:0x22:Unit: 0x0000001780fccb0a5e6d8165585b7e7c
12:36:21:WU00:FS01:0x22:Reading tar file core.xml
12:36:21:WU00:FS01:0x22:Reading tar file integrator.xml
12:36:21:WU00:FS01:0x22:Reading tar file state.xml
12:36:21:WU00:FS01:0x22:Reading tar file system.xml
12:36:22:WU00:FS01:0x22:Digital signatures verified
12:36:22:WU00:FS01:0x22:Folding@home GPU Core22 Folding@home Core
12:36:22:WU00:FS01:0x22:Version 0.0.2
12:36:56:WU00:FS01:0x22:Completed 0 out of 1000000 steps (0%)
12:36:56:WU00:FS01:0x22:Temperature control disabled. Requirements: single Nvidia GPU, tmax must be < 110 and twait >= 900
12:37:51:WU02:FS00:0xa7:Completed 37500 out of 125000 steps (30%)
12:39:16:WU02:FS00:0xa7:Completed 38750 out of 125000 steps (31%)
12:40:40:WU02:FS00:0xa7:Completed 40000 out of 125000 steps (32%)
12:40:49:WU00:FS01:0x22:Completed 10000 out of 1000000 steps (1%)
12:42:05:WU02:FS00:0xa7:Completed 41250 out of 125000 steps (33%)
12:43:28:WU02:FS00:0xa7:Completed 42500 out of 125000 steps (34%)
12:44:41:WU00:FS01:0x22:Completed 20000 out of 1000000 steps (2%)
12:44:51:WU02:FS00:0xa7:Completed 43750 out of 125000 steps (35%)
12:46:16:WU02:FS00:0xa7:Completed 45000 out of 125000 steps (36%)
12:47:40:WU02:FS00:0xa7:Completed 46250 out of 125000 steps (37%)
12:48:31:WU00:FS01:0x22:Completed 30000 out of 1000000 steps (3%)
12:49:04:WU02:FS00:0xa7:Completed 47500 out of 125000 steps (38%)
12:50:28:WU02:FS00:0xa7:Completed 48750 out of 125000 steps (39%)
12:51:53:WU02:FS00:0xa7:Completed 50000 out of 125000 steps (40%)
12:52:23:WU00:FS01:0x22:Completed 40000 out of 1000000 steps (4%)
12:53:16:WU02:FS00:0xa7:Completed 51250 out of 125000 steps (41%)
12:54:41:WU02:FS00:0xa7:Completed 52500 out of 125000 steps (42%)
12:56:04:WU02:FS00:0xa7:Completed 53750 out of 125000 steps (43%)
12:56:15:WU00:FS01:0x22:Completed 50000 out of 1000000 steps (5%)
12:57:41:WU02:FS00:0xa7:Completed 55000 out of 125000 steps (44%)
12:59:04:WU02:FS00:0xa7:Completed 56250 out of 125000 steps (45%)
13:00:11:WU00:FS01:0x22:Completed 60000 out of 1000000 steps (6%)
13:00:30:WU02:FS00:0xa7:Completed 57500 out of 125000 steps (46%)
13:01:53:WU02:FS00:0xa7:Completed 58750 out of 125000 steps (47%)
13:03:18:WU02:FS00:0xa7:Completed 60000 out of 125000 steps (48%)
13:04:03:WU00:FS01:0x22:Completed 70000 out of 1000000 steps (7%)
13:04:41:WU02:FS00:0xa7:Completed 61250 out of 125000 steps (49%)
13:06:07:WU02:FS00:0xa7:Completed 62500 out of 125000 steps (50%)
13:07:30:WU02:FS00:0xa7:Completed 63750 out of 125000 steps (51%)
13:07:55:WU00:FS01:0x22:Completed 80000 out of 1000000 steps (8%)
13:08:54:WU02:FS00:0xa7:Completed 65000 out of 125000 steps (52%)
13:10:19:WU02:FS00:0xa7:Completed 66250 out of 125000 steps (53%)
13:11:43:WU02:FS00:0xa7:Completed 67500 out of 125000 steps (54%)
13:11:47:WU00:FS01:0x22:Completed 90000 out of 1000000 steps (9%)
13:13:08:WU02:FS00:0xa7:Completed 68750 out of 125000 steps (55%)
13:14:31:WU02:FS00:0xa7:Completed 70000 out of 125000 steps (56%)
13:15:38:WU00:FS01:0x22:Completed 100000 out of 1000000 steps (10%)
13:16:08:WU02:FS00:0xa7:Completed 71250 out of 125000 steps (57%)
13:17:31:WU02:FS00:0xa7:Completed 72500 out of 125000 steps (58%)
13:18:56:WU02:FS00:0xa7:Completed 73750 out of 125000 steps (59%)
13:19:38:WU00:FS01:0x22:Completed 110000 out of 1000000 steps (11%)
13:20:19:WU02:FS00:0xa7:Completed 75000 out of 125000 steps (60%)
13:21:44:WU02:FS00:0xa7:Completed 76250 out of 125000 steps (61%)
13:23:07:WU02:FS00:0xa7:Completed 77500 out of 125000 steps (62%)
13:23:32:WU00:FS01:0x22:Completed 120000 out of 1000000 steps (12%)
13:24:32:WU02:FS00:0xa7:Completed 78750 out of 125000 steps (63%)
13:25:55:WU02:FS00:0xa7:Completed 80000 out of 125000 steps (64%)
13:27:20:WU02:FS00:0xa7:Completed 81250 out of 125000 steps (65%)
13:27:21:WU00:FS01:0x22:Completed 130000 out of 1000000 steps (13%)
13:28:43:WU02:FS00:0xa7:Completed 82500 out of 125000 steps (66%)
13:30:08:WU02:FS00:0xa7:Completed 83750 out of 125000 steps (67%)
13:31:14:WU00:FS01:0x22:Completed 140000 out of 1000000 steps (14%)
13:31:32:WU02:FS00:0xa7:Completed 85000 out of 125000 steps (68%)
13:32:55:WU02:FS00:0xa7:Completed 86250 out of 125000 steps (69%)
13:34:20:WU02:FS00:0xa7:Completed 87500 out of 125000 steps (70%)
13:35:05:WU00:FS01:0x22:Completed 150000 out of 1000000 steps (15%)
13:35:55:WU02:FS00:0xa7:Completed 88750 out of 125000 steps (71%)
13:37:21:WU02:FS00:0xa7:Completed 90000 out of 125000 steps (72%)
13:38:44:WU02:FS00:0xa7:Completed 91250 out of 125000 steps (73%)
13:39:01:WU00:FS01:0x22:Completed 160000 out of 1000000 steps (16%)
13:40:09:WU02:FS00:0xa7:Completed 92500 out of 125000 steps (74%)
13:41:33:WU02:FS00:0xa7:Completed 93750 out of 125000 steps (75%)
13:42:55:WU00:FS01:0x22:Completed 170000 out of 1000000 steps (17%)
13:42:58:WU02:FS00:0xa7:Completed 95000 out of 125000 steps (76%)
13:44:21:WU02:FS00:0xa7:Completed 96250 out of 125000 steps (77%)
13:45:45:WU02:FS00:0xa7:Completed 97500 out of 125000 steps (78%)
13:46:49:WU00:FS01:0x22:Completed 180000 out of 1000000 steps (18%)
13:47:08:WU02:FS00:0xa7:Completed 98750 out of 125000 steps (79%)
13:48:33:WU02:FS00:0xa7:Completed 100000 out of 125000 steps (80%)
13:49:56:WU02:FS00:0xa7:Completed 101250 out of 125000 steps (81%)
13:50:41:WU00:FS01:0x22:Completed 190000 out of 1000000 steps (19%)
13:51:21:WU02:FS00:0xa7:Completed 102500 out of 125000 steps (82%)
13:52:45:WU02:FS00:0xa7:Completed 103750 out of 125000 steps (83%)
13:54:10:WU02:FS00:0xa7:Completed 105000 out of 125000 steps (84%)
13:54:31:WU00:FS01:0x22:Completed 200000 out of 1000000 steps (20%)
13:55:44:WU02:FS00:0xa7:Completed 106250 out of 125000 steps (85%)
13:57:09:WU02:FS00:0xa7:Completed 107500 out of 125000 steps (86%)
13:58:28:WU00:FS01:0x22:Completed 210000 out of 1000000 steps (21%)
13:58:33:WU02:FS00:0xa7:Completed 108750 out of 125000 steps (87%)
13:59:56:WU02:FS00:0xa7:Completed 110000 out of 125000 steps (88%)
14:01:21:WU02:FS00:0xa7:Completed 111250 out of 125000 steps (89%)
14:02:20:WU00:FS01:0x22:Completed 220000 out of 1000000 steps (22%)
14:02:44:WU02:FS00:0xa7:Completed 112500 out of 125000 steps (90%)
14:04:09:WU02:FS00:0xa7:Completed 113750 out of 125000 steps (91%)
14:05:32:WU02:FS00:0xa7:Completed 115000 out of 125000 steps (92%)
14:06:11:WU00:FS01:0x22:Completed 230000 out of 1000000 steps (23%)
14:06:58:WU02:FS00:0xa7:Completed 116250 out of 125000 steps (93%)
14:08:22:WU02:FS00:0xa7:Completed 117500 out of 125000 steps (94%)
14:09:46:WU02:FS00:0xa7:Completed 118750 out of 125000 steps (95%)
14:10:03:WU00:FS01:0x22:Completed 240000 out of 1000000 steps (24%)
14:11:10:WU02:FS00:0xa7:Completed 120000 out of 125000 steps (96%)
14:12:35:WU02:FS00:0xa7:Completed 121250 out of 125000 steps (97%)
14:13:58:WU02:FS00:0xa7:Completed 122500 out of 125000 steps (98%)
14:13:58:WU00:FS01:0x22:Completed 250000 out of 1000000 steps (25%)
14:15:42:WU02:FS00:0xa7:Completed 123750 out of 125000 steps (99%)
14:15:43:WU01:FS00:Connecting to 65.254.110.245:8080
14:15:44:WARNING:WU01:FS00:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
14:15:44:WU01:FS00:Connecting to 18.218.241.186:80
14:15:44:WARNING:WU01:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
14:15:44:ERROR:WU01:FS00:Exception: Could not get an assignment
14:15:44:WU01:FS00:Connecting to 65.254.110.245:8080
14:15:45:WARNING:WU01:FS00:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
14:15:45:WU01:FS00:Connecting to 18.218.241.186:80
14:15:45:WARNING:WU01:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
14:15:45:ERROR:WU01:FS00:Exception: Could not get an assignment
14:16:45:WU01:FS00:Connecting to 65.254.110.245:8080
14:16:45:WARNING:WU01:FS00:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
14:16:45:WU01:FS00:Connecting to 18.218.241.186:80
14:16:45:WARNING:WU01:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
14:16:45:ERROR:WU01:FS00:Exception: Could not get an assignment
14:17:05:WU02:FS00:0xa7:Completed 125000 out of 125000 steps (100%)
14:17:10:WU02:FS00:0xa7:Saving result file ..\logfile_01.txt
14:17:10:WU02:FS00:0xa7:Saving result file frame8.edr
14:17:10:WU02:FS00:0xa7:Saving result file frame8.trr
14:17:10:WU02:FS00:0xa7:Saving result file frame8.xtc
14:17:10:WU02:FS00:0xa7:Saving result file md.log
14:17:10:WU02:FS00:0xa7:Saving result file science.log
14:17:10:WU02:FS00:0xa7:Folding@home Core Shutdown: FINISHED_UNIT
14:17:10:WU02:FS00:FahCore returned: FINISHED_UNIT (100 = 0x64)
14:17:10:WU02:FS00:Sending unit results: id:02 state:SEND error:NO_ERROR project:13860 run:0 clone:2750 gen:8 core:0xa7 unit:0x0000000a0d5a98395e72df1477b5001a
14:17:10:WU02:FS00:Uploading 5.49MiB to 13.90.152.57
14:17:10:WU02:FS00:Connecting to 13.90.152.57:8080
14:17:16:WU02:FS00:Upload 35.29%
14:17:22:WU02:FS00:Upload 59.20%
14:17:27:WU00:FS01:0x22:Completed 260000 out of 1000000 steps (26%)
14:17:28:WU02:FS00:Upload 100.00%
14:17:28:WU02:FS00:Upload complete
14:17:28:WU02:FS00:Server responded WORK_ACK (400)
14:17:28:WU02:FS00:Final credit estimate, 2089.00 points
14:17:28:WU02:FS00:Cleaning up
14:18:22:WU01:FS00:Connecting to 65.254.110.245:8080
14:18:22:WARNING:WU01:FS00:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
14:18:22:WU01:FS00:Connecting to 18.218.241.186:80
14:18:23:WARNING:WU01:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
14:18:23:ERROR:WU01:FS00:Exception: Could not get an assignment
14:19:10:WU00:FS01:0x22:Completed 270000 out of 1000000 steps (27%)
14:20:53:WU00:FS01:0x22:Completed 280000 out of 1000000 steps (28%)
14:20:59:WU01:FS00:Connecting to 65.254.110.245:8080
14:20:59:WARNING:WU01:FS00:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
14:20:59:WU01:FS00:Connecting to 18.218.241.186:80
14:21:00:WARNING:WU01:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
14:21:00:ERROR:WU01:FS00:Exception: Could not get an assignment
14:22:35:WU00:FS01:0x22:Completed 290000 out of 1000000 steps (29%)
14:24:18:WU00:FS01:0x22:Completed 300000 out of 1000000 steps (30%)
14:25:13:WU01:FS00:Connecting to 65.254.110.245:8080
14:25:13:WARNING:WU01:FS00:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
14:25:13:WU01:FS00:Connecting to 18.218.241.186:80
14:25:14:WARNING:WU01:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
14:25:14:ERROR:WU01:FS00:Exception: Could not get an assignment
14:26:24:WU00:FS01:0x22:Completed 310000 out of 1000000 steps (31%)
14:28:08:WU00:FS01:0x22:Completed 320000 out of 1000000 steps (32%)
14:29:52:WU00:FS01:0x22:Completed 330000 out of 1000000 steps (33%)
14:31:36:WU00:FS01:0x22:Completed 340000 out of 1000000 steps (34%)
14:32:04:WU01:FS00:Connecting to 65.254.110.245:8080
14:32:05:WARNING:WU01:FS00:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
14:32:05:WU01:FS00:Connecting to 18.218.241.186:80
14:32:05:WARNING:WU01:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
14:32:05:ERROR:WU01:FS00:Exception: Could not get an assignment
14:33:20:WU00:FS01:0x22:Completed 350000 out of 1000000 steps (35%)
14:35:18:WU00:FS01:0x22:Completed 360000 out of 1000000 steps (36%)
14:37:02:WU00:FS01:0x22:Completed 370000 out of 1000000 steps (37%)
14:38:46:WU00:FS01:0x22:Completed 380000 out of 1000000 steps (38%)
14:40:31:WU00:FS01:0x22:Completed 390000 out of 1000000 steps (39%)
14:42:15:WU00:FS01:0x22:Completed 400000 out of 1000000 steps (40%)
14:43:10:WU01:FS00:Connecting to 65.254.110.245:8080
14:43:10:WARNING:WU01:FS00:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
14:43:10:WU01:FS00:Connecting to 18.218.241.186:80
14:43:11:WARNING:WU01:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
14:43:11:ERROR:WU01:FS00:Exception: Could not get an assignment
14:44:12:WU00:FS01:0x22:Completed 410000 out of 1000000 steps (41%)
14:45:56:WU00:FS01:0x22:Completed 420000 out of 1000000 steps (42%)
14:47:40:WU00:FS01:0x22:Completed 430000 out of 1000000 steps (43%)
14:49:24:WU00:FS01:0x22:Completed 440000 out of 1000000 steps (44%)
14:51:08:WU00:FS01:0x22:Completed 450000 out of 1000000 steps (45%)
14:52:56:WU00:FS01:0x22:Completed 460000 out of 1000000 steps (46%)
14:54:39:WU00:FS01:0x22:Completed 470000 out of 1000000 steps (47%)
14:56:23:WU00:FS01:0x22:Completed 480000 out of 1000000 steps (48%)
14:58:07:WU00:FS01:0x22:Completed 490000 out of 1000000 steps (49%)
14:59:50:WU00:FS01:0x22:Completed 500000 out of 1000000 steps (50%)
15:01:07:WU01:FS00:Connecting to 65.254.110.245:8080
15:01:07:WARNING:WU01:FS00:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
15:01:07:WU01:FS00:Connecting to 18.218.241.186:80
15:01:07:WARNING:WU01:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
15:01:07:ERROR:WU01:FS00:Exception: Could not get an assignment
15:01:37:WU00:FS01:0x22:Completed 510000 out of 1000000 steps (51%)
15:03:21:WU00:FS01:0x22:Completed 520000 out of 1000000 steps (52%)
15:05:04:WU00:FS01:0x22:Completed 530000 out of 1000000 steps (53%)
15:06:47:WU00:FS01:0x22:Completed 540000 out of 1000000 steps (54%)
15:08:30:WU00:FS01:0x22:Completed 550000 out of 1000000 steps (55%)
15:10:17:WU00:FS01:0x22:Completed 560000 out of 1000000 steps (56%)
15:12:01:WU00:FS01:0x22:Completed 570000 out of 1000000 steps (57%)
15:13:44:WU00:FS01:0x22:Completed 580000 out of 1000000 steps (58%)
15:15:28:WU00:FS01:0x22:Completed 590000 out of 1000000 steps (59%)
15:17:11:WU00:FS01:0x22:Completed 600000 out of 1000000 steps (60%)
15:18:59:WU00:FS01:0x22:Completed 610000 out of 1000000 steps (61%)
15:20:41:WU00:FS01:0x22:Completed 620000 out of 1000000 steps (62%)
15:22:24:WU00:FS01:0x22:Completed 630000 out of 1000000 steps (63%)
15:24:06:WU00:FS01:0x22:Completed 640000 out of 1000000 steps (64%)
15:25:50:WU00:FS01:0x22:Completed 650000 out of 1000000 steps (65%)
15:27:37:WU00:FS01:0x22:Completed 660000 out of 1000000 steps (66%)
15:29:21:WU00:FS01:0x22:Completed 670000 out of 1000000 steps (67%)
15:30:09:WU01:FS00:Connecting to 65.254.110.245:8080
15:30:09:WARNING:WU01:FS00:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
15:30:09:WU01:FS00:Connecting to 18.218.241.186:80
15:30:10:WARNING:WU01:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
15:30:10:ERROR:WU01:FS00:Exception: Could not get an assignment
15:31:04:WU00:FS01:0x22:Completed 680000 out of 1000000 steps (68%)
15:32:48:WU00:FS01:0x22:Completed 690000 out of 1000000 steps (69%)
15:34:32:WU00:FS01:0x22:Completed 700000 out of 1000000 steps (70%)
15:36:20:WU00:FS01:0x22:Completed 710000 out of 1000000 steps (71%)
15:38:03:WU00:FS01:0x22:Completed 720000 out of 1000000 steps (72%)
15:39:47:WU00:FS01:0x22:Completed 730000 out of 1000000 steps (73%)
15:41:31:WU00:FS01:0x22:Completed 740000 out of 1000000 steps (74%)
15:43:14:WU00:FS01:0x22:Completed 750000 out of 1000000 steps (75%)
15:45:01:WU00:FS01:0x22:Completed 760000 out of 1000000 steps (76%)
15:46:45:WU00:FS01:0x22:Completed 770000 out of 1000000 steps (77%)
15:48:28:WU00:FS01:0x22:Completed 780000 out of 1000000 steps (78%)
15:50:12:WU00:FS01:0x22:Completed 790000 out of 1000000 steps (79%)
15:51:55:WU00:FS01:0x22:Completed 800000 out of 1000000 steps (80%)
15:53:44:WU00:FS01:0x22:Completed 810000 out of 1000000 steps (81%)
15:55:27:WU00:FS01:0x22:Completed 820000 out of 1000000 steps (82%)
15:57:10:WU00:FS01:0x22:Completed 830000 out of 1000000 steps (83%)
15:58:52:WU00:FS01:0x22:Completed 840000 out of 1000000 steps (84%)
16:00:35:WU00:FS01:0x22:Completed 850000 out of 1000000 steps (85%)
16:02:23:WU00:FS01:0x22:Completed 860000 out of 1000000 steps (86%)
16:04:07:WU00:FS01:0x22:Completed 870000 out of 1000000 steps (87%)
******************************* Date: 2020-03-25 *******************************
16:05:50:WU00:FS01:0x22:Completed 880000 out of 1000000 steps (88%)
16:07:35:WU00:FS01:0x22:Completed 890000 out of 1000000 steps (89%)
16:09:19:WU00:FS01:0x22:Completed 900000 out of 1000000 steps (90%)
16:11:07:WU00:FS01:0x22:Completed 910000 out of 1000000 steps (91%)
16:12:49:WU00:FS01:0x22:Completed 920000 out of 1000000 steps (92%)
16:14:32:WU00:FS01:0x22:Completed 930000 out of 1000000 steps (93%)
16:16:14:WU00:FS01:0x22:Completed 940000 out of 1000000 steps (94%)
16:17:07:WU01:FS00:Connecting to 65.254.110.245:8080
16:17:08:WARNING:WU01:FS00:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
16:17:08:WU01:FS00:Connecting to 18.218.241.186:80
16:17:08:WARNING:WU01:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
16:17:08:ERROR:WU01:FS00:Exception: Could not get an assignment
16:17:58:WU00:FS01:0x22:Completed 950000 out of 1000000 steps (95%)
16:17:59:WU02:FS01:Connecting to 65.254.110.245:8080
16:18:00:WARNING:WU02:FS01:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
16:18:00:WU02:FS01:Connecting to 18.218.241.186:80
16:18:00:WARNING:WU02:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
16:18:00:ERROR:WU02:FS01:Exception: Could not get an assignment
16:18:01:WU02:FS01:Connecting to 65.254.110.245:8080
16:18:01:WARNING:WU02:FS01:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
16:18:01:WU02:FS01:Connecting to 18.218.241.186:80
16:18:02:WARNING:WU02:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
16:18:02:ERROR:WU02:FS01:Exception: Could not get an assignment
16:19:01:WU02:FS01:Connecting to 65.254.110.245:8080
16:19:01:WU02:FS01:Assigned to work server 40.114.52.201
16:19:01:WU02:FS01:Requesting new work unit for slot 01: RUNNING gpu:0:Ellesmere XT [Radeon RX 470/480/570/580] from 40.114.52.201
16:19:01:WU02:FS01:Connecting to 40.114.52.201:8080
16:19:22:WARNING:WU02:FS01:WorkServer connection failed on port 8080 trying 80
16:19:22:WU02:FS01:Connecting to 40.114.52.201:80
16:19:43:ERROR:WU02:FS01:Exception: Failed to connect to 40.114.52.201:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
16:19:46:WU00:FS01:0x22:Completed 960000 out of 1000000 steps (96%)
16:20:38:WU02:FS01:Connecting to 65.254.110.245:8080
16:20:38:WARNING:WU02:FS01:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
16:20:38:WU02:FS01:Connecting to 18.218.241.186:80
16:20:39:WARNING:WU02:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
16:20:39:ERROR:WU02:FS01:Exception: Could not get an assignment
16:21:30:WU00:FS01:0x22:Completed 970000 out of 1000000 steps (97%)
16:23:12:WU00:FS01:0x22:Completed 980000 out of 1000000 steps (98%)
16:23:15:WU02:FS01:Connecting to 65.254.110.245:8080
16:23:16:WARNING:WU02:FS01:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
16:23:16:WU02:FS01:Connecting to 18.218.241.186:80
16:23:16:WARNING:WU02:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
16:23:16:ERROR:WU02:FS01:Exception: Could not get an assignment
16:24:55:WU00:FS01:0x22:Completed 990000 out of 1000000 steps (99%)
16:26:38:WU00:FS01:0x22:Completed 1000000 out of 1000000 steps (100%)
16:26:42:WU00:FS01:0x22:Saving result file ..\logfile_01.txt
16:26:42:WU00:FS01:0x22:Saving result file checkpointState.xml
16:26:42:WU00:FS01:0x22:Saving result file checkpt.crc
16:26:42:WU00:FS01:0x22:Saving result file positions.xtc
16:26:43:WU00:FS01:0x22:Saving result file science.log
16:26:49:WU00:FS01:0x22:Folding@home Core Shutdown: FINISHED_UNIT
16:26:50:WU00:FS01:FahCore returned: FINISHED_UNIT (100 = 0x64)
16:26:50:WU00:FS01:Sending unit results: id:00 state:SEND error:NO_ERROR project:11763 run:0 clone:3834 gen:15 core:0x22 unit:0x0000001780fccb0a5e6d8165585b7e7c
16:26:50:WU00:FS01:Uploading 33.37MiB to 128.252.203.10
16:26:50:WU00:FS01:Connecting to 128.252.203.10:8080
16:27:11:WARNING:WU00:FS01:WorkServer connection failed on port 8080 trying 80
16:27:11:WU00:FS01:Connecting to 128.252.203.10:80
16:27:29:WU02:FS01:Connecting to 65.254.110.245:8080
16:27:30:WARNING:WU02:FS01:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
16:27:30:WU02:FS01:Connecting to 18.218.241.186:80
16:27:30:WARNING:WU02:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
16:27:30:ERROR:WU02:FS01:Exception: Could not get an assignment
16:27:32:WARNING:WU00:FS01:Exception: Failed to send results to work server: Failed to connect to 128.252.203.10:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
16:27:32:WU00:FS01:Trying to send results to collection server
16:27:33:WU00:FS01:Uploading 33.37MiB to 155.247.166.219
16:27:33:WU00:FS01:Connecting to 155.247.166.219:8080
16:27:33:ERROR:WU00:FS01:Exception: Transfer failed
16:27:33:WU00:FS01:Sending unit results: id:00 state:SEND error:NO_ERROR project:11763 run:0 clone:3834 gen:15 core:0x22 unit:0x0000001780fccb0a5e6d8165585b7e7c
16:27:33:WU00:FS01:Uploading 33.37MiB to 128.252.203.10
16:27:33:WU00:FS01:Connecting to 128.252.203.10:8080
16:27:54:WARNING:WU00:FS01:WorkServer connection failed on port 8080 trying 80
16:27:54:WU00:FS01:Connecting to 128.252.203.10:80
16:28:16:WARNING:WU00:FS01:Exception: Failed to send results to work server: Failed to connect to 128.252.203.10:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
16:28:16:WU00:FS01:Trying to send results to collection server
16:28:16:WU00:FS01:Uploading 33.37MiB to 155.247.166.219
16:28:16:WU00:FS01:Connecting to 155.247.166.219:8080
16:28:27:WU00:FS01:Upload 1.12%
16:28:36:WU00:FS01:Upload 1.87%
16:28:45:WU00:FS01:Upload 2.43%
16:28:52:WU00:FS01:Upload 2.81%
16:28:59:WU00:FS01:Upload 3.18%
16:29:08:WU00:FS01:Upload 3.93%
16:30:10:WU00:FS01:Upload 4.12%
16:30:10:ERROR:WU00:FS01:Exception: Transfer failed
16:30:10:WU00:FS01:Sending unit results: id:00 state:SEND error:NO_ERROR project:11763 run:0 clone:3834 gen:15 core:0x22 unit:0x0000001780fccb0a5e6d8165585b7e7c
16:30:10:WU00:FS01:Uploading 33.37MiB to 128.252.203.10
16:30:10:WU00:FS01:Connecting to 128.252.203.10:8080
16:30:25:WU00:FS01:Upload 0.37%
16:31:02:WU00:FS01:Upload 0.94%
16:31:08:WU00:FS01:Upload 86.16%
16:31:13:WU00:FS01:Upload complete
16:31:13:WU00:FS01:Server responded WORK_ACK (400)
16:31:13:WU00:FS01:Final credit estimate, 46871.00 points
16:31:13:WU00:FS01:Cleaning up
16:34:21:WU02:FS01:Connecting to 65.254.110.245:8080
16:34:21:WU02:FS01:Assigned to work server 40.114.52.201
16:34:21:WU02:FS01:Requesting new work unit for slot 01: READY gpu:0:Ellesmere XT [Radeon RX 470/480/570/580] from 40.114.52.201
16:34:21:WU02:FS01:Connecting to 40.114.52.201:8080
16:34:49:ERROR:WU02:FS01:Exception: 10002: Received short response, expected 512 bytes, got 0
16:41:32:FS00:Paused
16:41:32:FS01:Paused
16:41:47:Removing old file 'configs/config-20200323-163724.xml'
16:41:47:Saving configuration to config.xml
16:41:47:<config>
16:41:47: <!-- Folding Core -->
16:41:47: <checkpoint v='3'/>
16:41:47:
16:41:47: <!-- Network -->
16:41:47: <proxy v=':8080'/>
16:41:47:
16:41:47: <!-- Slot Control -->
16:41:47: <power v='full'/>
16:41:47:
16:41:47: <!-- User Information -->
16:41:47: <passkey v='********************************'/>
16:41:47: <team v='224497'/>
16:41:47: <user v='e3ccf0cda2_ALL_13Vy3LVepXngBqNP5YNnj1WX5rBqgvqHdt'/>
16:41:47:
16:41:47: <!-- Folding Slots -->
16:41:47: <slot id='0' type='CPU'>
16:41:47: <paused v='true'/>
16:41:47: </slot>
16:41:47: <slot id='1' type='GPU'>
16:41:47: <max-packet-size v='big'/>
16:41:47: <next-unit-percentage v='95'/>
16:41:47: </slot>
16:41:47:</config>
https://drive.google.com/file/d/1vBQlMBoVEfKLZNxdPcTh95sxKk38zL31/view?usp=sharing
